[SCM] PostGIS branch master updated. 3.7.0beta1-75-gd3bda3e955
git at osgeo.org
git at osgeo.org
Mon Jul 27 11:14:50 PDT 2026
the project "PostGIS".
via d3bda3e955fd941fae9b043c67ca311e4240b938 (commit)
via 6ad0228c83de35418fcafebe64cddb0f9b33adcf (commit)
via 23734f7524bff1b25851c5f1a6e87a922007fa8e (commit)
via 892cc936a9e0254cd4ea70a502f161279bdc3071 (commit)
from e1f090fe8a9c2ced44f22ca298668f255083f42b (commit)
revisions in full, below.
commit d3bda3e955fd941fae9b043c67ca311e4240b938
Merge: e1f090fe8a 6ad0228c83
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 11:14:48 2026 -0700
Merge pull request 'ci: add Woodpecker CodeQL analysis' (!554) from Komzpa/postgis:ci/woodpecker-codeql-20260727 into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/554
commit 6ad0228c83de35418fcafebe64cddb0f9b33adcf
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 27 11:16:17 2026 +0400
Fix CodeQL loader buffer findings
diff --git a/loader/shp2pgsql-core.c b/loader/shp2pgsql-core.c
index a62e8113b0..9ebfa8fb4f 100644
--- a/loader/shp2pgsql-core.c
+++ b/loader/shp2pgsql-core.c
@@ -1322,9 +1322,12 @@ ShpLoaderOpenShape(SHPLOADERSTATE *state)
state->widths = malloc(state->num_fields * sizeof(int));
state->precisions = malloc(state->num_fields * sizeof(int));
state->pgfieldtypes = malloc(state->num_fields * sizeof(char *));
- state->col_names = malloc((state->num_fields + 2) * sizeof(char) * MAXFIELDNAMELEN);
+ state->col_names = calloc(
+ (size_t)state->num_fields * (MAXFIELDNAMELEN + 2) +
+ (state->config->readshape ? strlen(state->geo_col) : 0) + 1,
+ sizeof(char)
- strcpy(state->col_names, "" );
/* Generate a string of comma separated column names of the form "col1, col2 ... colN" for the SQL
insertion string */
diff --git a/raster/loader/raster2pgsql.c b/raster/loader/raster2pgsql.c
index 5551c2f5ba..c093a412ee 100644
--- a/raster/loader/raster2pgsql.c
+++ b/raster/loader/raster2pgsql.c
@@ -30,6 +30,7 @@
#include "gdal_vrt.h"
#include "ogr_srs_api.h"
#include <assert.h>
+#include <stdarg.h>
#define xstr(s) str(s)
#define str(s) #s
@@ -85,6 +86,37 @@ rt_init_allocators(void) {
+static char *
+rtloader_alloc_sprintf(const char *fmt, ...) __attribute__ ((format (printf, 1, 2)));
+static char *
+ int len;
+ char *result;
+ va_list ap;
+ va_list ap2;
+ va_start(ap, fmt);
+ va_copy(ap2, ap);
+ len = vsnprintf(NULL, 0, fmt, ap);
+ va_end(ap);
+ if (len < 0) {
+ va_end(ap2);
+ return NULL;
+ result = rtalloc((size_t)len + 1);
+ if (result == NULL) {
+ va_end(ap2);
+ return NULL;
+ vsnprintf(result, (size_t)len + 1, fmt, ap2);
+ va_end(ap2);
+ return result;
static void
raster_destroy(rt_raster raster) {
uint16_t i;
@@ -906,31 +938,21 @@ copy_from(const char *schema, const char *table, const char *column,
STRINGBUFFER *buffer)
char *sql = NULL;
- uint32_t len = 0;
assert(table != NULL);
assert(column != NULL);
- len = strlen("COPY () FROM stdin;") + 1;
- if (schema != NULL)
- len += strlen(schema);
- len += strlen(table);
- len += strlen(column);
- if (filename != NULL)
- len += strlen(",") + strlen(file_column_name);
- sql = rtalloc(sizeof(char) * len);
- if (sql == NULL) {
- rterror(_("copy_from: Could not allocate memory for COPY statement"));
- return 0;
- sprintf(sql, "COPY %s%s (%s%s%s) FROM stdin;",
+ sql = rtloader_alloc_sprintf("COPY %s%s (%s%s%s) FROM stdin;",
(schema != NULL ? schema : ""),
table,
column,
(filename != NULL ? "," : ""),
(filename != NULL ? file_column_name : "")
+ if (sql == NULL) {
+ rterror(_("copy_from: Could not allocate memory for COPY statement"));
+ return 0;
append_sql_to_buffer(buffer, sql);
sql = NULL;
@@ -955,7 +977,6 @@ insert_records(
STRINGBUFFER *tileset, STRINGBUFFER *buffer
char *fn = NULL;
- uint32_t len = 0;
char *sql = NULL;
uint32_t x = 0;
@@ -981,21 +1002,15 @@ insert_records(
/* rows */
for (x = 0; x < tileset->length; x++) {
- len = strlen(tileset->line[x]) + 1;
- len += strlen(fn) + 1;
- rterror(_("insert_records: Could not allocate memory for COPY statement"));
- return 0;
- sprintf(sql, "%s%s%s",
+ sql = rtloader_alloc_sprintf("%s%s%s",
tileset->line[x],
(filename != NULL ? "\t" : ""),
(filename != NULL ? fn : "")
+ rterror(_("insert_records: Could not allocate memory for COPY statement"));
+ return 0;
sql = NULL;
@@ -1009,52 +1024,39 @@ insert_records(
/* INSERT statements */
else {
- len = strlen("INSERT INTO () VALUES (ST_Transform(''::raster,xxxxxxxxx));") + 1;
/* escape single-quotes in filename */
fn = strreplace(filename, "'", "''", NULL);
- char *ptr;
- int sqllen = len;
- sqllen += strlen(tileset->line[x]);
- sqllen += strlen(",''") + strlen(fn);
- sql = rtalloc(sizeof(char) * sqllen);
+ if (out_srid != SRID_UNKNOWN && filename != NULL) {
+ "INSERT INTO %s%s (%s,%s) VALUES (ST_Transform('%s'::raster, %d),'%s');",
+ (schema != NULL ? schema : ""), table, column,
+ file_column_name, tileset->line[x], out_srid, fn);
+ else if (out_srid != SRID_UNKNOWN) {
+ "INSERT INTO %s%s (%s) VALUES (ST_Transform('%s'::raster, %d));",
+ tileset->line[x], out_srid);
+ else if (filename != NULL) {
+ "INSERT INTO %s%s (%s,%s) VALUES ('%s'::raster,'%s');",
+ file_column_name, tileset->line[x], fn);
+ else {
+ "INSERT INTO %s%s (%s) VALUES ('%s'::raster);",
+ tileset->line[x]);
if (sql == NULL) {
rterror(_("insert_records: Could not allocate memory for INSERT statement"));
return 0;
- ptr = sql;
- ptr += sprintf(sql, "INSERT INTO %s%s (%s%s%s) VALUES (",
- (schema != NULL ? schema : ""),
- table,
- column,
- (filename != NULL ? "," : ""),
- (filename != NULL ? file_column_name : "")
- if (out_srid != SRID_UNKNOWN) {
- ptr += sprintf(ptr, "ST_Transform(");
- ptr += sprintf(ptr, "'%s'::raster",
- tileset->line[x]
- ptr += sprintf(ptr, ", %d)", out_srid);
- if (filename != NULL) {
- ptr += sprintf(ptr, ",'%s'", fn);
- ptr += sprintf(ptr, ");");
sql = NULL;
@@ -1068,22 +1070,15 @@ insert_records(
static int
drop_table(const char *schema, const char *table, STRINGBUFFER *buffer) {
char *sql = NULL;
- uint32_t len = 0;
- len = strlen("DROP TABLE IF EXISTS ;") + 1;
+ sql = rtloader_alloc_sprintf("DROP TABLE IF EXISTS %s%s;",
+ table
if (sql == NULL) {
rterror(_("drop_table: Could not allocate memory for DROP TABLE statement"));
return 0;
- sprintf(sql, "DROP TABLE IF EXISTS %s%s;",
- table
@@ -1102,29 +1097,11 @@ create_table(const char *schema,
char *sql = NULL;
- uint32_t len = 0;
- len = strlen("CREATE TABLE IF NOT EXISTS (\"rid\" serial PRIMARY KEY, raster);") + 1;
- if (file_column)
- len += strlen(", text") + strlen(file_column_name);
- if (tablespace != NULL)
- len += strlen(" TABLESPACE ") + strlen(tablespace);
- if (idx_tablespace != NULL)
- len += strlen(" USING INDEX TABLESPACE ") + strlen(idx_tablespace);
- rterror(_("create_table: Could not allocate memory for CREATE TABLE statement"));
- return 0;
- sprintf(sql,
"CREATE TABLE %s%s%s (\"rid\" serial PRIMARY KEY%s%s,%s raster%s%s%s)%s%s;",
(if_not_exists ? "IF NOT EXISTS " : ""),
@@ -1137,6 +1114,10 @@ create_table(const char *schema,
(file_column ? " text" : ""),
(tablespace != NULL ? " TABLESPACE " : ""),
(tablespace != NULL ? tablespace : ""));
+ rterror(_("create_table: Could not allocate memory for CREATE TABLE statement"));
+ return 0;
@@ -1218,24 +1199,17 @@ analyze_table(
char *sql = NULL;
- uint32_t len = 0;
- len = strlen("ANALYZE ;") + 1;
+ sql = rtloader_alloc_sprintf("ANALYZE %s%s;",
+ table
if (sql == NULL) {
rterror(_("analyze_table: Could not allocate memory for ANALYZE TABLE statement"));
return 0;
- sprintf(sql, "ANALYZE %s%s;",
- table
@@ -1246,21 +1220,18 @@ static int
vacuum_table(const char *schema, const char *table, int analyze, STRINGBUFFER *buffer)
char *sql = NULL;
- uint32_t len = 0;
- len = strlen("VACUUM ANALYZE ;") + 1;
+ sql = rtloader_alloc_sprintf("VACUUM%s %s%s;",
+ (analyze ? " ANALYZE" : ""),
+ table
if (sql == NULL) {
rterror(_("vacuum_table: Could not allocate memory for VACUUM statement"));
return 0;
- sprintf(sql, "VACUUM%s %s%s;", (analyze ? " ANALYZE" : ""), (schema != NULL ? schema : ""), table);
@@ -1274,7 +1245,6 @@ add_raster_constraints(
char *sql = NULL;
- uint32_t len = 0;
char *_tmp = NULL;
char *_schema = NULL;
@@ -1304,24 +1274,22 @@ add_raster_constraints(
_column = strreplace(_tmp, "'", "''", NULL);
rtdealloc(_tmp);
- len = strlen("SELECT AddRasterConstraints('','','',TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,FALSE,TRUE,TRUE,TRUE,TRUE,FALSE);") + 1;
- if (_schema != NULL)
- len += strlen(_schema);
- len += strlen(_table);
- len += strlen(_column);
- rterror(_("add_raster_constraints: Could not allocate memory for AddRasterConstraints statement"));
- return 0;
- sprintf(sql, "SELECT AddRasterConstraints('%s','%s','%s',TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,%s,TRUE,TRUE,TRUE,TRUE,%s);",
+ "SELECT AddRasterConstraints('%s','%s','%s',TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,%s,TRUE,TRUE,TRUE,TRUE,%s);",
(_schema != NULL ? _schema : ""),
_table,
_column,
(regular_blocking ? "TRUE" : "FALSE"),
(max_extent ? "TRUE" : "FALSE")
+ rterror(_("add_raster_constraints: Could not allocate memory for AddRasterConstraints statement"));
+ if (_schema != NULL)
+ rtdealloc(_schema);
+ rtdealloc(_table);
+ rtdealloc(_column);
+ return 0;
rtdealloc(_schema);
@@ -1341,7 +1309,6 @@ add_overview_constraints(
char *sql = NULL;
- uint32_t len = 0;
char *_tmp = NULL;
@@ -1399,22 +1366,8 @@ add_overview_constraints(
rtdealloc(_tmp);
- len = strlen("SELECT AddOverviewConstraints('','','','','','',);") + 5;
- if (_ovschema != NULL)
- len += strlen(_ovschema);
- len += strlen(_ovtable);
- len += strlen(_ovcolumn);
- rterror(_("add_overview_constraints: Could not allocate memory for AddOverviewConstraints statement"));
- return 0;
- sprintf(sql, "SELECT AddOverviewConstraints('%s','%s','%s','%s','%s','%s',%d);",
+ "SELECT AddOverviewConstraints('%s','%s','%s','%s','%s','%s',%d);",
(_ovschema != NULL ? _ovschema : ""),
_ovtable,
_ovcolumn,
@@ -1423,6 +1376,18 @@ add_overview_constraints(
_column,
factor
+ rterror(_("add_overview_constraints: Could not allocate memory for AddOverviewConstraints statement"));
+ if (_ovschema != NULL)
+ rtdealloc(_ovschema);
+ rtdealloc(_ovtable);
+ rtdealloc(_ovcolumn);
+ return 0;
@@ -3202,7 +3167,6 @@ main(int argc, char **argv) {
if (config->overview_count) {
- char factor[4];
config->overview_table = rtalloc(sizeof(char *) * config->overview_count);
if (config->overview_table == NULL) {
rterror(_("Could not allocate memory for overview table names"));
@@ -3211,15 +3175,15 @@ main(int argc, char **argv) {
for (i = 0; i < config->overview_count; i++) {
- sprintf(factor, "%d", config->overview[i]);
- config->overview_table[i] = rtalloc(sizeof(char) * (strlen("o__") + strlen(factor) + strlen(config->table) + 1));
+ config->overview_table[i] = rtloader_alloc_sprintf("o_%d_%s",
+ config->overview[i],
+ config->table
if (config->overview_table[i] == NULL) {
rterror(_("Could not allocate memory for overview table name"));
rtdealloc_config(config);
exit(1);
- sprintf(config->overview_table[i], "o_%d_%s", config->overview[i], config->table);
@@ -3279,87 +3243,80 @@ main(int argc, char **argv) {
if (config->schema != NULL) {
- tmp = rtalloc(sizeof(char) * (strlen(config->schema) + 4));
+ tmp = rtloader_alloc_sprintf("\"%s\".", config->schema);
if (tmp == NULL) {
rterror(_("Could not allocate memory for quoting schema name"));
exit(1);
- sprintf(tmp, "\"%s\".", config->schema);
rtdealloc(config->schema);
config->schema = tmp;
if (config->table != NULL) {
- tmp = rtalloc(sizeof(char) * (strlen(config->table) + 3));
+ tmp = rtloader_alloc_sprintf("\"%s\"", config->table);
if (tmp == NULL) {
rterror(_("Could not allocate memory for quoting table name"));
exit(1);
- sprintf(tmp, "\"%s\"", config->table);
rtdealloc(config->table);
config->table = tmp;
if (config->raster_column != NULL) {
- tmp = rtalloc(sizeof(char) * (strlen(config->raster_column) + 3));
+ tmp = rtloader_alloc_sprintf("\"%s\"", config->raster_column);
if (tmp == NULL) {
rterror(_("Could not allocate memory for quoting raster column name"));
exit(1);
- sprintf(tmp, "\"%s\"", config->raster_column);
rtdealloc(config->raster_column);
config->raster_column = tmp;
if (config->file_column_name != NULL) {
- tmp = rtalloc(sizeof(char) * (strlen(config->file_column_name) + 3));
+ tmp = rtloader_alloc_sprintf("\"%s\"", config->file_column_name);
if (tmp == NULL) {
exit(1);
- sprintf(tmp, "\"%s\"", config->file_column_name);
rtdealloc(config->file_column_name);
config->file_column_name = tmp;
if (config->tablespace != NULL) {
- tmp = rtalloc(sizeof(char) * (strlen(config->tablespace) + 3));
+ tmp = rtloader_alloc_sprintf("\"%s\"", config->tablespace);
if (tmp == NULL) {
rterror(_("Could not allocate memory for quoting tablespace name"));
exit(1);
- sprintf(tmp, "\"%s\"", config->tablespace);
rtdealloc(config->tablespace);
config->tablespace = tmp;
if (config->idx_tablespace != NULL) {
- tmp = rtalloc(sizeof(char) * (strlen(config->idx_tablespace) + 3));
+ tmp = rtloader_alloc_sprintf("\"%s\"", config->idx_tablespace);
if (tmp == NULL) {
rterror(_("Could not allocate memory for quoting index tablespace name"));
exit(1);
- sprintf(tmp, "\"%s\"", config->idx_tablespace);
rtdealloc(config->idx_tablespace);
config->idx_tablespace = tmp;
- tmp = rtalloc(sizeof(char) * (strlen(config->overview_table[i]) + 3));
+ tmp = rtloader_alloc_sprintf("\"%s\"", config->overview_table[i]);
if (tmp == NULL) {
rterror(_("Could not allocate memory for quoting overview table name"));
exit(1);
- sprintf(tmp, "\"%s\"", config->overview_table[i]);
rtdealloc(config->overview_table[i]);
config->overview_table[i] = tmp;
commit 23734f7524bff1b25851c5f1a6e87a922007fa8e
Date: Mon Jul 27 11:00:21 2026 +0400
ci: gate Woodpecker CodeQL on pull requests
diff --git a/.woodpecker/codeql.yml b/.woodpecker/codeql.yml
index 6edb73941b..7c5a225fe3 100644
--- a/.woodpecker/codeql.yml
+++ b/.woodpecker/codeql.yml
@@ -15,6 +15,7 @@ steps:
image: repo.osgeo.org/postgis/build-test:debian13
pull: true
commands:
+ - python3 ci/dronie/codeql_should_run.py; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
- export CODEQL_TMP="$${CI_WORKSPACE}/.tmp/codeql"
- export CODEQL_HOME="$${CODEQL_TMP}/codeql"
- export CODEQL_DB="$${CODEQL_TMP}/db"
diff --git a/ci/dronie/codeql_should_run.py b/ci/dronie/codeql_should_run.py
new file mode 100755
index 0000000000..109d145fb1
--- /dev/null
+++ b/ci/dronie/codeql_should_run.py
@@ -0,0 +1,111 @@
+#!/usr/bin/env python3
+"""Gate expensive Woodpecker CodeQL analysis by changed surface.
+Exit status 0 means run CodeQL. Exit status 78 means skip the expensive body
+successfully. Ambiguous changed-path discovery fails open and runs CodeQL.
+from __future__ import annotations
+import fnmatch
+import os
+import subprocess
+import sys
+CODEQL_GLOBS = (
+ ".woodpecker/codeql.yml",
+ ".github/workflows/codeql.yml",
+ "ci/dronie/codeql_build.sh",
+ "ci/dronie/codeql_should_run.py",
+ "configure.ac",
+ "configure.in",
+ "autogen.sh",
+ "GNUmakefile.in",
+ "Makefile.in",
+ "*/Makefile.in",
+ "macros/**",
+ "build-aux/**",
+ "liblwgeom/**",
+ "libpgcommon/**",
+ "postgis/**",
+ "deps/**",
+ "loader/**",
+ "raster/**",
+ "sfcgal/**",
+ "topology/**",
+ "extensions/**",
+def run_git(args: list[str], check: bool = True) -> subprocess.CompletedProcess[str]:
+ return subprocess.run(
+ ["git", *args],
+ check=check,
+ text=True,
+ stdout=subprocess.PIPE,
+ stderr=subprocess.PIPE,
+def resolve_base() -> str:
+ for name in (
+ "CI_COMMIT_TARGET_BRANCH",
+ "WOODPECKER_PULL_REQUEST_TARGET",
+ "CI_COMMIT_TARGET",
+ target = os.environ.get(name)
+ if not target:
+ continue
+ ref = f"refs/ci-target/{target}"
+ fetched = run_git(
+ ["fetch", "--no-tags", "origin", f"+refs/heads/{target}:{ref}"],
+ check=False,
+ if fetched.returncode == 0:
+ return ref
+ raise RuntimeError(f"{name}={target} is set, but fetching it failed")
+ for candidate in ("origin/master", "master"):
+ if run_git(["rev-parse", "--verify", candidate], check=False).returncode == 0:
+ return candidate
+ raise RuntimeError("no pull-request target branch or local master ref found")
+def changed_paths(base: str) -> list[str]:
+ merge_base = run_git(["merge-base", base, "HEAD"]).stdout.strip()
+ if not merge_base:
+ raise RuntimeError(f"no merge base between {base} and HEAD")
+ diff = run_git(["diff", "--name-only", f"{merge_base}...HEAD"]).stdout
+ return [line for line in diff.splitlines() if line]
+def main() -> int:
+ event = os.environ.get("CI_PIPELINE_EVENT")
+ if event not in (None, "", "pull_request"):
+ print(f"RUN: {event} event runs full CodeQL")
+ return 0
+ try:
+ paths = changed_paths(resolve_base())
+ except Exception as exc:
+ print(f"RUN: changed-path discovery failed open: {exc}")
+ return 0
+ if not paths:
+ print("RUN: changed-path list is empty; failing open")
+ return 0
+ for path in paths:
+ for pattern in CODEQL_GLOBS:
+ if fnmatch.fnmatch(path, pattern):
+ print(f"RUN: {path} matches CodeQL-relevant pattern {pattern}")
+ return 0
+ print("SKIP: no CodeQL-relevant path changed")
+ return 78
+if __name__ == "__main__":
+ sys.exit(main())
commit 892cc936a9e0254cd4ea70a502f161279bdc3071
Date: Mon Jul 27 03:31:30 2026 +0300
new file mode 100644
index 0000000000..6edb73941b
--- /dev/null
@@ -0,0 +1,40 @@
+labels:
+ platform: linux/amd64
+when:
+ event: [push, pull_request, tag]
+clone:
+ git:
+ image: woodpeckerci/plugin-git
+ settings:
+ depth: 0
+ partial: false
+steps:
+ analyze:
+ image: repo.osgeo.org/postgis/build-test:debian13
+ pull: true
+ commands:
+ - export CODEQL_TMP="$${CI_WORKSPACE}/.tmp/codeql"
+ - export CODEQL_HOME="$${CODEQL_TMP}/codeql"
+ - export CODEQL_DB="$${CODEQL_TMP}/db"
+ - export CODEQL_SARIF="$${CODEQL_TMP}/postgis-codeql.sarif"
+ - mkdir -p "$${CODEQL_TMP}"
+ curl -fsSL https://github.com/github/codeql-action/releases/latest/download/codeql-bundle-linux64.tar.gz
+ | tar -xz -C "$${CODEQL_TMP}"
+ "$${CODEQL_HOME}/codeql" version
+ - ./autogen.sh
+ "$${CODEQL_HOME}/codeql" database create "$${CODEQL_DB}"
+ --language=cpp
+ --source-root="$${CI_WORKSPACE}"
+ --command=ci/dronie/codeql_build.sh
+ "$${CODEQL_HOME}/codeql" database analyze "$${CODEQL_DB}"
+ cpp-security-and-quality.qls
+ --format=sarif-latest
+ --output="$${CODEQL_SARIF}"
+ python3 -c 'import json, os; p=os.environ["CODEQL_SARIF"]; d=json.load(open(p)); rs=sum(len(r.get("results", [])) for r in d.get("runs", [])); print(f"CodeQL SARIF: {p} ({rs} results)")'
diff --git a/ci/dronie/codeql_build.sh b/ci/dronie/codeql_build.sh
index 0000000000..7e74b29c14
--- /dev/null
+++ b/ci/dronie/codeql_build.sh
@@ -0,0 +1,9 @@
+#!/bin/sh
+set -e
+mkdir -p build/codeql
+cd build/codeql
+../../configure --without-interrupt-tests
+make -j1
Summary of changes:
.woodpecker/codeql.yml | 41 ++++++
ci/dronie/codeql_build.sh | 9 ++
ci/dronie/codeql_should_run.py | 111 ++++++++++++++++
loader/shp2pgsql-core.c | 7 +-
raster/loader/raster2pgsql.c | 281 +++++++++++++++++------------------------
5 files changed, 285 insertions(+), 164 deletions(-)
create mode 100644 .woodpecker/codeql.yml
create mode 100755 ci/dronie/codeql_build.sh
create mode 100755 ci/dronie/codeql_should_run.py
hooks/post-receive
