[SCM] PostGIS branch master updated. 3.7.0beta1-77-g023ac85a98
Mon Jul 27 11:15:41 PDT 2026
the project "PostGIS".
       via  023ac85a987b77c2045c165c7ff539d94ba067ff (commit)
       via  de37c70c27d72cbb8e88b82bcfd42f4b42fe9c8f (commit)
      from  d3bda3e955fd941fae9b043c67ca311e4240b938 (commit)
revisions in full, below.
commit 023ac85a987b77c2045c165c7ff539d94ba067ff
Merge: d3bda3e955 de37c70c27
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 11:15:40 2026 -0700
    Merge pull request 'ci: show actionable dashboard failure reasons' (!557) from Komzpa/postgis:ci/dashboard-failure-reasons-20260727 into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/557
commit de37c70c27d72cbb8e88b82bcfd42f4b42fe9c8f
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Jul 27 14:20:06 2026 +0400
diff --git a/utils/ci-status.py b/utils/ci-status.py
index 7d8f3f3cd2..866a00a3d4 100755
--- a/utils/ci-status.py
+++ b/utils/ci-status.py
@@ -31,6 +31,7 @@ STALE_PASSED = "stale-passed"
 STALE_FAILED = "stale-fail"
 DISABLED = "disabled"
 NOT_APPLICABLE = "not_applicable"
+JENKINS_STALE_QUEUE_HOURS = 4
 SYMBOLS = {
     SUCCESS: ("✅", "OK"),
@@ -465,6 +466,57 @@ def woodpecker_workflow_details(pipeline, web_url):
     return details
+def woodpecker_error_details(pipeline):
+    errors = [
+        error.get("message")
+        for error in pipeline.get("errors") or []
+        if isinstance(error, dict) and error.get("message") and not error.get("is_warning")
+    if not errors:
+        return None
+    return {
+        "message": "; ".join(errors),
+        "status_label": "Config error",
+def woodpecker_leaf_steps(workflow):
+    children = workflow.get("children") or []
+    if children:
+        return children
+    return [workflow]
+def woodpecker_killed_details(pipeline):
+    workflows = pipeline.get("workflows") or []
+    if not workflows:
+        return None
+    non_success = []
+    killed_zero = []
+    for workflow in workflows:
+        for step in woodpecker_leaf_steps(workflow):
+            status = normalize_woodpecker_status(step.get("state") or step.get("status"))
+            if status == SUCCESS:
+                continue
+            non_success.append(step)
+            if str(step.get("state") or step.get("status")).lower() == "killed" and step.get("exit_code") == 0:
+                killed_zero.append(step)
+    if not non_success or len(non_success) != len(killed_zero):
+        return None
+    labels = [
+        str(step.get("name") or f"step {step.get('pid') or step.get('id')}")
+        for step in killed_zero[:3]
+    suffix = f" ({', '.join(labels)}" + (", ..." if len(killed_zero) > len(labels) else "") + ")"
+    return {
+        "message": f"agent lost: {plural(len(killed_zero), 'step')} killed at exit 0{suffix}",
+        "status_label": "Agent lost",
 def woodpecker_check(check, branch, timeout):
     query = urllib.parse.urlencode({
         "branch": branch["name"],
@@ -490,17 +542,32 @@ def woodpecker_check(check, branch, timeout):
     web_url = check.get("web_url")
     run_url = woodpecker_pipeline_url(web_url, current)
     detail_url = woodpecker_pipeline_detail_url(api_url, current)
-    if detail_url and "workflows" not in current:
+    needs_detail = "workflows" not in current
+    if (
+        normalize_woodpecker_status(current.get("status")) == FAILURE
+        and str(current.get("status")).lower() == "error"
+        and current.get("errors")
+        needs_detail = False
+    if detail_url and needs_detail:
         try:
             current = {**current, **http_json(detail_url, timeout=timeout)}
         except RECOVERABLE_PROVIDER_ERRORS:
             pass
     message = current.get("message")
+    extra = {}
     if normalize_woodpecker_status(current.get("status")) != SUCCESS:
-        details = woodpecker_workflow_details(current, web_url)
+        details = None
+        if str(current.get("status")).lower() == "error" and not (current.get("workflows") or []):
+            details = woodpecker_error_details(current)
+        if not details and str(current.get("status")).lower() == "failure":
+            details = woodpecker_killed_details(current)
+        if not details:
+            details = woodpecker_workflow_details(current, web_url)
         if details:
             message = details["message"]
             run_url = details.get("url") or run_url
+            extra.update({key: details[key] for key in ("status_label",) if key in details})
     result = make_result(
         check,
         branch,
@@ -510,6 +577,7 @@ def woodpecker_check(check, branch, timeout):
         revision=current.get("commit"),
         completed_at=current.get("finished") or current.get("updated") or current.get("created"),
         message=message,
+        **extra,
     if previous:
         previous_url = woodpecker_pipeline_url(web_url, previous)
@@ -795,6 +863,18 @@ def queued_jenkins_revision(item):
     return None
+def jenkins_queued_status_label(item):
+    queued_at = parse_time(item.get("inQueueSince"))
+    if not queued_at:
+        return "Queued"
+    age = utc_now() - queued_at
+    if age.total_seconds() > JENKINS_STALE_QUEUE_HOURS * 3600:
+        return "Queued stale"
+    if item.get("stuck"):
+        return "Queued stuck"
+    return "Queued"
 def jenkins_queue_item_rank(item, branch):
     revision = queued_jenkins_revision(item)
     is_current = False
@@ -837,6 +917,7 @@ def jenkins_queued_check(check, branch, job_url, timeout):
         revision=params.get("after") or params.get("BRANCH"),
         completed_at=item.get("inQueueSince"),
         message=message,
+        status_label=jenkins_queued_status_label(item),
diff --git a/utils/test_ci_status.py b/utils/test_ci_status.py
index c22a04fa7c..9ba6674795 100644
--- a/utils/test_ci_status.py
+++ b/utils/test_ci_status.py
@@ -536,6 +536,16 @@ class RequiredFailureHtmlTest(unittest.TestCase):
         self.assertEqual(current_revision, result["revision"])
         self.assertEqual("queued item 108746: Build #8,030 is already in progress", result["message"])
+    def test_jenkins_old_queue_item_is_labeled_stale(self):
+        queued = {
+            "id": 108746,
+            "inQueueSince": 1784821000000,
+        now = CI_STATUS.dt.datetime.fromtimestamp(1784840000, CI_STATUS.dt.timezone.utc)
+        with mock.patch.object(CI_STATUS, "utc_now", return_value=now):
+            self.assertEqual("Queued stale", CI_STATUS.jenkins_queued_status_label(queued))
     def test_woodpecker_failure_names_single_failed_workflow(self):
         check_config = {
             "name": "Woodpecker",
@@ -575,6 +585,79 @@ class RequiredFailureHtmlTest(unittest.TestCase):
             http_json.call_args_list[1].args[0],
+    def test_woodpecker_error_without_workflows_shows_error_message(self):
+        check_config = {
+            "name": "Woodpecker",
+            "provider": "woodpecker",
+            "required": True,
+            "api_url": "https://woodie.example.test/api/repos/30/pipelines",
+            "web_url": "https://woodie.example.test/repos/30",
+        branch = {"name": "master", "label": "master"}
+        pipeline = {
+            "number": 5733,
+            "event": "push",
+            "branch": "master",
+            "ref": "refs/heads/master",
+            "status": "error",
+            "commit": "c" * 40,
+            "message": "opaque commit message",
+            "errors": [{"message": "step 'html-ja' depends on unknown step 'html-de'"}],
+        with mock.patch.object(CI_STATUS, "http_json", return_value=[pipeline]) as http_json:
+            result = CI_STATUS.woodpecker_check(check_config, branch, timeout=5)
+        self.assertEqual(CI_STATUS.FAILURE, result["status"])
+        self.assertEqual("Config error", result["status_label"])
+        self.assertEqual("step 'html-ja' depends on unknown step 'html-de'", result["message"])
+        http_json.assert_called_once()
+    def test_woodpecker_killed_zero_exit_steps_are_agent_loss(self):
+        check_config = {
+            "required": True,
+        branch = {"name": "stable-3.6", "label": "3.6"}
+        pipeline = {
+            "number": 5696,
+            "event": "pull_request",
+            "branch": "stable-3.6",
+            "ref": "refs/heads/stable-3.6",
+            "status": "failure",
+            "commit": "d" * 40,
+        pipeline_detail = {
+            **pipeline,
+            "workflows": [
+                    "pid": 1,
+                    "name": "docs",
+                    "state": "failure",
+                    "children": [
+                        {"pid": 4, "name": "clone", "state": "killed", "exit_code": 0},
+                        {"pid": 5, "name": "prepare", "state": "killed", "exit_code": 0},
+                        {"pid": 6, "name": "check-xml", "state": "killed", "exit_code": 0},
+        with mock.patch.object(CI_STATUS, "http_json", side_effect=([pipeline], pipeline_detail)):
+                {**check_config, "event": "pull_request"},
+                branch,
+                timeout=5,
+        self.assertEqual("Agent lost", result["status_label"])
+        self.assertEqual("agent lost: 3 steps killed at exit 0 (clone, prepare, check-xml)", result["message"])
     def test_woodpecker_running_workflows_are_summarized(self):
         check_config = {
Summary of changes:
 utils/ci-status.py      | 85 +++++++++++++++++++++++++++++++++++++++++++++++--
 utils/test_ci_status.py | 83 +++++++++++++++++++++++++++++++++++++++++++++++
 2 files changed, 166 insertions(+), 2 deletions(-)
hooks/post-receive
