[SCM] PostGIS branch master updated. 3.7.0beta1-81-gbbf0087251
git at osgeo.org
git at osgeo.org
Mon Jul 27 11:56:44 PDT 2026
the project "PostGIS".
via bbf00872510c92d78b1bdaae297652378b353f95 (commit)
via 597138b97f8a666c56f7f9d284fe6e4a89bd504d (commit)
via 772215b879f89485af9ffe11c9386435324f2508 (commit)
via 42b0d845a7c00848d501fdeacf3633e41fe68eb1 (commit)
from 023ac85a987b77c2045c165c7ff539d94ba067ff (commit)
revisions in full, below.
commit bbf00872510c92d78b1bdaae297652378b353f95
Merge: 023ac85a98 597138b97f
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 11:56:42 2026 -0700
Merge pull request 'ci: gate expensive pull-request workflows by changed surface' (!529) from Komzpa/postgis:ci/proportional-path-filters-20260726 into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/529
commit 597138b97f8a666c56f7f9d284fe6e4a89bd504d
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Mon Jul 27 22:23:46 2026 +0400
ci: move gating helpers under ci
diff --git a/.github/workflows/ci-freebsd.yml b/.github/workflows/ci-freebsd.yml
index e8ae945aa7..ea88bbcbc3 100644
--- a/.github/workflows/ci-freebsd.yml
+++ b/.github/workflows/ci-freebsd.yml
@@ -30,7 +30,7 @@ jobs:
run: |
set +e
- python3 utils/ci_need_suite.py github-ci
+ python3 ci/ci_need_suite.py github-ci
gate_status=$?
set -e
if test "${gate_status}" = 78; then
diff --git a/.github/workflows/ci-macos.yml b/.github/workflows/ci-macos.yml
index e1d67b5b89..2241c337c2 100644
--- a/.github/workflows/ci-macos.yml
+++ b/.github/workflows/ci-macos.yml
@@ -27,7 +27,7 @@ jobs:
run: |
set +e
gate_status=$?
set -e
diff --git a/.github/workflows/ci.yml b/.github/workflows/ci.yml
index fae239715b..20d7f9c50e 100644
--- a/.github/workflows/ci.yml
+++ b/.github/workflows/ci.yml
@@ -54,7 +54,7 @@ jobs:
run: |
set +e
gate_status=$?
set -e
diff --git a/.github/workflows/codeql.yml b/.github/workflows/codeql.yml
index 6909620cb1..d87640e061 100644
--- a/.github/workflows/codeql.yml
+++ b/.github/workflows/codeql.yml
@@ -45,7 +45,7 @@ jobs:
run: |
set +e
gate_status=$?
set -e
diff --git a/.github/workflows/msys.yml b/.github/workflows/msys.yml
index 2026c0edb8..34c3dbc46e 100644
--- a/.github/workflows/msys.yml
+++ b/.github/workflows/msys.yml
@@ -28,7 +28,7 @@ jobs:
shell: bash
run: |
set +e
gate_status=$?
set -e
diff --git a/.woodpecker/qa.yml b/.woodpecker/qa.yml
index f647055826..6ba78f226d 100644
--- a/.woodpecker/qa.yml
+++ b/.woodpecker/qa.yml
@@ -41,7 +41,7 @@ steps:
QA_MODE: usan_clang
commands:
- <<: *steps-env
- - python3 $${SRCDIR}/utils/ci_need_suite.py qa; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
+ - python3 $${SRCDIR}/ci/ci_need_suite.py qa; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
- <<: *steps-start-postgresql
- mkdir -p "$${BUILDDIR}"
- cd "$${BUILDDIR}"
@@ -61,7 +61,7 @@ steps:
QA_MODE: standard_conforming_strings_off
commands:
- <<: *steps-env
- cd "$${BUILDDIR}"
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index 155a4713bb..f88575c4ff 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -18,7 +18,7 @@ variables:
- . ci/start-postgresql.sh
- psql -c 'select version()' template1
steps-pg-build: &steps-pg-build
- - python3 $${SRCDIR}/utils/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}" --upgrade-surface; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
+ - python3 $${SRCDIR}/ci/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}" --upgrade-surface; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
- cd "$${BUILDDIR}"
- $${SRCDIR}/configure
@@ -31,7 +31,7 @@ variables:
# make graph can otherwise race generation of files such as postgis.control.
- make -j1
steps-pg-test-all-upgrades: &steps-pg-test-all-upgrades
- cd "$${BUILDDIR}"
- export CHECK_FIFO=check-$${UPGRADE_EXTENSION}.fifo
- export CHECK_LOG=check-$${UPGRADE_EXTENSION}.log
@@ -86,7 +86,7 @@ steps:
REGRESS_SUITE: preinstall
commands:
- <<: *steps-env
- - python3 $${SRCDIR}/utils/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}"; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
+ - python3 $${SRCDIR}/ci/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}"; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
- make -C "$${BUILDDIR}" $${REGRESS_TARGET}
@@ -98,7 +98,7 @@ steps:
REGRESS_SUITE: install
commands:
- <<: *steps-env
- make -C "$${BUILDDIR}" install
@@ -111,7 +111,7 @@ steps:
REGRESS_SUITE: extension-upgrade
commands:
- export SRCDIR=$${CI_WORKSPACE}
- <<: *steps-env
- make -C "$${BUILDDIR}" staged-install
@@ -126,7 +126,7 @@ steps:
REGRESS_SUITE: cluster-upgrade
commands:
- make -C build/pg$${PGVER} install
- make -C build/pg$${SECOND_PGVER} install
- export PGPORT=$$((20000 + ($${CI_PIPELINE_NUMBER:-0} % 1000) * 32 + ($${CI_WORKFLOW_NUMBER:-30} % 32)))
diff --git a/utils/ci_changed_paths.py b/ci/ci_changed_paths.py
similarity index 100%
rename from utils/ci_changed_paths.py
rename to ci/ci_changed_paths.py
diff --git a/utils/ci_need_suite.py b/ci/ci_need_suite.py
similarity index 98%
rename from utils/ci_need_suite.py
rename to ci/ci_need_suite.py
index 57a8569cec..e05f8429e3 100755
--- a/utils/ci_need_suite.py
+++ b/ci/ci_need_suite.py
@@ -89,7 +89,7 @@ def match_any(path: str, globs: tuple[str, ...]) -> str | None:
def changed_paths(base: str | None, head: str) -> tuple[list[str], str]:
- cmd = ["python3", "utils/ci_changed_paths.py", "--head", head]
+ cmd = ["python3", "ci/ci_changed_paths.py", "--head", head]
if base:
cmd.extend(["--base", base])
result = subprocess.run(
diff --git a/doc/development/testing/ci-gating.md b/doc/development/testing/ci-gating.md
index 8f7814219e..95157fdaa5 100644
--- a/doc/development/testing/ci-gating.md
+++ b/doc/development/testing/ci-gating.md
@@ -26,7 +26,7 @@ The gated pull-request bodies are:
| GitHub Actions mirror workflows | Linux Docker, FreeBSD, macOS, MSYS2, and CodeQL build or analysis bodies |
The status context still appears. A skipped body exits successfully after
-printing a `SKIP:` reason from `utils/ci_need_suite.py`.
+printing a `SKIP:` reason from `ci/ci_need_suite.py`.
Documentation checks owned by `.woodpecker/docs.yml` are not reduced by this
gate. Cheap setup steps that exist only to keep workflow structure intact may
@@ -80,7 +80,7 @@ pull-request events. Once a change lands, push CI runs the full set.
## How To Tell Whether A Pull Request Was Gated
Open the CI job log for a skipped or unexpectedly short context and look for
-the `utils/ci_need_suite.py` verdict near the start of the job body.
+the `ci/ci_need_suite.py` verdict near the start of the job body.
`RUN:` means the expensive body was kept. The line includes the file or rule
that required the suite, or says that discovery failed open.
@@ -97,8 +97,8 @@ To reproduce a decision locally, fetch the pull-request base and run the same
helper against the branch:
```sh
-python3 utils/ci_need_suite.py install --target check --extension none --base upstream/master
-python3 utils/ci_need_suite.py extension-upgrade --target check --extension postgis --upgrade-surface --base upstream/master
+python3 ci/ci_need_suite.py install --target check --extension none --base upstream/master
+python3 ci/ci_need_suite.py extension-upgrade --target check --extension postgis --upgrade-surface --base upstream/master
Status `0` means run. Status `78` means skip.
@@ -117,6 +117,6 @@ force the expensive pull-request bodies. Remove the temporary forcing change
before merge if it is not part of the intended patch.
If a forced run exposes that the gate skipped a suite it should have run, fix
-the glob or ABI rule in `utils/ci_need_suite.py` or
+the glob or ABI rule in `ci/ci_need_suite.py` or
`utils/check_upgrade_surface.py` instead of relying on the temporary forcing
change.
diff --git a/utils/check_upgrade_surface.py b/utils/check_upgrade_surface.py
index 7ee61548bb..a6d88074f4 100755
--- a/utils/check_upgrade_surface.py
+++ b/utils/check_upgrade_surface.py
@@ -75,7 +75,7 @@ def match_any(path: str, globs: tuple[str, ...]) -> str | None:
def resolve_base(base: str | None, head: str) -> tuple[str, list[str]]:
if base:
result = run(cmd, check=False)
commit 772215b879f89485af9ffe11c9386435324f2508
Date: Mon Jul 27 20:19:05 2026 +0400
docs: explain pull-request CI gating
diff --git a/doc/development/testing/_index.md b/doc/development/testing/_index.md
index c03319aee7..47c9a8becf 100644
--- a/doc/development/testing/_index.md
+++ b/doc/development/testing/_index.md
@@ -135,6 +135,9 @@ Other useful targets:
* [CI inventory standards](ci.md) describe how to keep build-bot and badge
inventories checkable instead of copying stale dashboard markup into
maintained prose.
+* [Pull request CI gating](ci-gating.md) explains why expensive pull-request
+ suites may be skipped, how upgrade ABI decisions are made, and how to force a
+ full run when the gate is wrong.
## Garden Checks
new file mode 100644
index 0000000000..8f7814219e
--- /dev/null
@@ -0,0 +1,122 @@
+title: "Pull Request CI Gating"
+date: 2026-07-27
+weight: 20
+geekdocHidden: false
+PostGIS pull requests keep the usual CI status contexts, but some expensive job
+bodies are skipped when the changed files cannot affect them. The gate exists
+to make pull-request testing proportional to the changed surface. It does not
+change integration-branch coverage.
+## What Is Gated
+The gate runs only for pull-request events. Pushes, tags, `master`, and
+`stable-*` integration branches run the full workflow set. If the gate cannot
+identify the pull-request base, compute the changed paths, build the ABI
+comparison trees, or compare symbols, it fails open and runs the suite.
+The gated pull-request bodies are:
+| CI surface | Gated body |
+| Woodpecker regression matrix | build, install, preinstall, extension-upgrade, and cluster-upgrade work in `.woodpecker/regress.yml` |
+| Woodpecker QA matrix | sanitizer and standard-conforming-strings-off work in `.woodpecker/qa.yml` |
+| GitHub Actions mirror workflows | Linux Docker, FreeBSD, macOS, MSYS2, and CodeQL build or analysis bodies |
+The status context still appears. A skipped body exits successfully after
+printing a `SKIP:` reason from `utils/ci_need_suite.py`.
+Documentation checks owned by `.woodpecker/docs.yml` are not reduced by this
+gate. Cheap setup steps that exist only to keep workflow structure intact may
+still run before the expensive body is skipped.
+## What Always Runs
+Pull requests run the relevant expensive body when they change CI, build, or
+test-control files, including `.woodpecker/*.yml`, `.github/workflows/*.yml`,
+`ci/**`, `configure.ac`, `autogen.sh`, `GNUmakefile.in`, `Makefile.in`,
+`*/Makefile.in`, `macros/**`, and `build-aux/**`.
+Subsystem source changes run the matching subsystem coverage:
+| Changed surface | Pull-request coverage |
+| `liblwgeom/**`, `libpgcommon/**`, `postgis/**`, `regress/core/**`, `regress/dumper/**`, `deps/**`, `sfcgal/**` | core build, CUnit, and core regression coverage |
+| `raster/**`, `extensions/postgis_raster/**` | raster regression and raster upgrade coverage |
+| `topology/**`, `extensions/postgis_topology/**` | topology regression and topology upgrade coverage |
+| `loader/**`, `regress/loader/**` | loader regression coverage |
+| `Version.config`, `extensions/**`, SQL template files, upgrade generators, `postgis_restore.pl`, `utils/check_all_upgrades.sh`, `utils/check_cluster_upgrade.sh` | extension, double-upgrade, locked-upgrade, cluster-upgrade, and platform workflow coverage |
+| `NEWS`, `utils/check_news.sh`, `utils/test_check_news.py` | NEWS checker coverage when that suite uses the gate |
+Unknown suites run rather than skip.
+## Upgrade And ABI Decisions
+Upgrade suites first check SQL-visible paths. Any change to extension SQL,
+upgrade generators, version metadata, restore helpers, or upgrade scripts runs
+the upgrade coverage without an ABI comparison.
+If no SQL-visible path changed but a compiled module source changed, the gate
+builds the merge base and pull-request head in temporary worktrees and compares
+the exported modules. It uses `abidiff` when available. In a Debian CI
+container running as root, it tries to install `abigail-tools` to get
+`abidiff`. If `abidiff` is unavailable, it falls back to
+`nm -D --defined-only`.
+The `nm` fallback has an important blind spot: it detects added and removed
+exported symbol names, but it cannot prove that a symbol's type, arguments, or
+ABI contract stayed compatible. Because of that blind spot, unchanged symbol
+names under the `nm` fallback still run the upgrade tests.
+## Why Integration Branches Are Exempt
+`master` and every `stable-*` branch are release and backpatch integration
+surfaces. They need complete, comparable CI history even when an individual
+merge looked narrow during review. The gate therefore applies only to
+pull-request events. Once a change lands, push CI runs the full set.
+## How To Tell Whether A Pull Request Was Gated
+Open the CI job log for a skipped or unexpectedly short context and look for
+the `utils/ci_need_suite.py` verdict near the start of the job body.
+`RUN:` means the expensive body was kept. The line includes the file or rule
+that required the suite, or says that discovery failed open.
+`SKIP:` means the expensive body was intentionally skipped. The line includes
+the reason, such as no matching subsystem input or no upgrade-relevant change.
+On GitHub Actions mirror workflows, the "Check changed surface" step writes the
+skip decision and later expensive steps are marked skipped. On Woodpecker,
+matrix entries keep their workflow context and exit successfully after the
+`SKIP:` verdict.
+To reproduce a decision locally, fetch the pull-request base and run the same
+helper against the branch:
+```sh
+python3 utils/ci_need_suite.py install --target check --extension none --base upstream/master
+python3 utils/ci_need_suite.py extension-upgrade --target check --extension postgis --upgrade-surface --base upstream/master
+Status `0` means run. Status `78` means skip.
+## How To Force The Full Set
+For maintainers, the clean force path is to test the branch after it is merged
+or otherwise pushed to an integration ref, because non-pull-request events
+always run the full set.
+For a pull request that must prove the full matrix before merge, add a small
+explicit change to a CI or build-control file owned by the gate, such as a
+comment in `.woodpecker/regress.yml`, `.woodpecker/qa.yml`, or the affected
+GitHub workflow. CI/build-control changes match the always-run patterns and
+force the expensive pull-request bodies. Remove the temporary forcing change
+before merge if it is not part of the intended patch.
+If a forced run exposes that the gate skipped a suite it should have run, fix
+the glob or ABI rule in `utils/ci_need_suite.py` or
+`utils/check_upgrade_surface.py` instead of relying on the temporary forcing
+change.
diff --git a/doc/development/testing/ci.md b/doc/development/testing/ci.md
index 1e10da445d..cf12bd6215 100644
--- a/doc/development/testing/ci.md
+++ b/doc/development/testing/ci.md
@@ -126,7 +126,9 @@ readback.
## Relationship To Other Docs
Use [Testing and debugging](_index.md) for test commands and local validation
-workflows. Use [Release process](../release-process.md) for release-manager
-greenlight checks, Debbie release jobs, and branch-opening steps. Use
-[Website maintenance](../website.md) and the public website compatibility matrix
-for user-facing support status.
+workflows. Use [Pull request CI gating](ci-gating.md) for the changed-surface
+rules that can skip expensive pull-request bodies while keeping status contexts
+present. Use [Release process](../release-process.md) for release-manager
+greenlight checks, Debbie release jobs, and branch-opening steps. Use [Website
+maintenance](../website.md) and the public website compatibility matrix for
+user-facing support status.
commit 42b0d845a7c00848d501fdeacf3633e41fe68eb1
Date: Sun Jul 26 19:44:10 2026 +0400
index 601aebfc73..e8ae945aa7 100644
@@ -24,8 +24,23 @@ jobs:
- uses: actions/checkout at 11bd71901bbe5b1630ceea73d27597364c9af683 # v4.2.2
with:
persist-credentials: false
+ fetch-depth: 50
+ - name: Check changed surface
+ id: changed-surface
+ run: |
+ set +e
+ python3 utils/ci_need_suite.py github-ci
+ gate_status=$?
+ set -e
+ if test "${gate_status}" = 78; then
+ echo "skip=true" >> "${GITHUB_OUTPUT}"
+ exit 0
+ fi
+ exit "${gate_status}"
- name: Cache ccache
+ if: steps.changed-surface.outputs.skip != 'true'
uses: actions/cache at 27d5ce7f107fe9357f9df03efb73ab90386fccae # v5.0.5
with:
path: ${{ env.CCACHE_DIR }}
@@ -34,6 +49,7 @@ jobs:
freebsd-${{ matrix.version }}-ccache-
- name: Build and test on FreeBSD
uses: vmactions/freebsd-vm at a6de9343ef5747433d9c25784c90e84998b9d69a # v1.4.6
with:
release: ${{ matrix.version }}
index 67c0cc1d4d..e1d67b5b89 100644
@@ -21,8 +21,23 @@ jobs:
with:
+ fetch-depth: 50
+ run: |
+ set +e
+ gate_status=$?
+ set -e
+ exit 0
+ fi
with:
@@ -31,6 +46,7 @@ jobs:
macos-ccache-
- name: Install dependencies
run: |
brew update
brew install \
@@ -45,6 +61,7 @@ jobs:
sudo ln -sfn "${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin/postgres" /usr/local/bin/postgres
env:
CC: "ccache clang"
CXX: "ccache clang++"
index 82646b0bac..fae239715b 100644
@@ -47,8 +47,24 @@ jobs:
- name: 'Check Out'
uses: actions/checkout at v6
+ with:
+ fetch-depth: 50
+ run: |
+ set +e
+ gate_status=$?
+ set -e
+ exit 0
+ fi
- name: 'Prepare Image'
run: |
set -e
retry() {
@@ -89,13 +105,14 @@ jobs:
docker build --pull=false -t pgtest .
- name: 'Build & Test'
run: |
echo "/tmp/logbt-coredumps/core.%p.%E" | sudo tee /proc/sys/kernel/core_pattern
ci_env=`bash .github/codecov_env.bash`
docker run -e RUNTESTFLAGS=-v $ci_env --name pgtest-${GITHUB_RUN_NUMBER} pgtest
- name: 'Clean Up Image'
- if: ${{ success() }}
+ if: ${{ success() && steps.changed-surface.outputs.skip != 'true' }}
run: |
docker rm pgtest-${GITHUB_RUN_NUMBER}
index ff3fa0261f..6909620cb1 100644
@@ -2,7 +2,7 @@ name: "CodeQL"
on:
push:
- pull_request:
+ pull_request: ~
concurrency:
group: ${{ github.workflow }}-${{ github.head_ref || github.ref }}
@@ -38,9 +38,25 @@ jobs:
steps:
- name: Checkout repository
+ with:
+ fetch-depth: 50
+ run: |
+ set +e
+ gate_status=$?
+ set -e
+ exit 0
+ fi
# Initializes the CodeQL tools for scanning.
- name: Initialize CodeQL
uses: github/codeql-action/init at v3
with:
languages: ${{ matrix.language }}
@@ -52,17 +68,20 @@ jobs:
# queries: security-extended,security-and-quality
run: |
sudo apt-get update
sudo apt-get install -y g++ autoconf automake libgeos-dev libproj-dev libgdal-dev libjson-c-dev libsfcgal-dev gettext libxml2-dev postgresql-server-dev-16 postgresql-client-16 libprotobuf-c-dev libprotoc-dev protobuf-c-compiler clang-19
- name: Build
run: |
./autogen.sh
./configure
make -j$(nproc)
- name: Perform CodeQL Analysis
uses: github/codeql-action/analyze at v3
with:
category: "/language:${{matrix.language}}"
index 51a68c14be..2026c0edb8 100644
@@ -1,5 +1,7 @@
-on: [push, pull_request]
+on:
+ push:
+ pull_request: ~
jobs:
mingw:
@@ -19,7 +21,23 @@ jobs:
# see https://github.com/msys2/setup-msys2
- name: checkout
+ with:
+ fetch-depth: 50
+ shell: bash
+ run: |
+ set +e
+ gate_status=$?
+ set -e
+ exit 0
+ fi
- name: '${{ matrix.icon }} Setup MSYS2'
uses: msys2/setup-msys2 at v2
with:
msystem: ${{ matrix.sys }}
@@ -42,6 +60,7 @@ jobs:
postgresql:p
- name: '🚧 Build TOOL'
run: |
MSYSTEM= /${{ matrix.sys }}/bin/initdb -D D:/a/_tmp/psql
MSYSTEM= /${{ matrix.sys }}/bin/pg_ctl -D D:/a/_tmp/psql -l logfile start
index 2befd93b63..f647055826 100644
@@ -41,6 +41,7 @@ steps:
QA_MODE: usan_clang
commands:
- <<: *steps-env
+ - python3 $${SRCDIR}/utils/ci_need_suite.py qa; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
- cd "$${BUILDDIR}"
@@ -60,6 +61,7 @@ steps:
commands:
- <<: *steps-env
- cd "$${BUILDDIR}"
index e8402be479..155a4713bb 100644
@@ -18,6 +18,7 @@ variables:
+ - python3 $${SRCDIR}/utils/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}" --upgrade-surface; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
- cd "$${BUILDDIR}"
@@ -30,6 +31,7 @@ variables:
- make -j1
- cd "$${BUILDDIR}"
@@ -84,6 +86,7 @@ steps:
commands:
- <<: *steps-env
+ - python3 $${SRCDIR}/utils/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}"; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
@@ -95,6 +98,7 @@ steps:
commands:
- <<: *steps-env
@@ -106,6 +110,8 @@ steps:
- matrix:
commands:
+ - export SRCDIR=$${CI_WORKSPACE}
- <<: *steps-env
@@ -119,6 +125,8 @@ steps:
- matrix:
commands:
new file mode 100755
index 0000000000..7ee61548bb
--- /dev/null
@@ -0,0 +1,265 @@
+#!/usr/bin/env python3
+"""Check whether a change touches the PostGIS upgrade-relevant surface.
+The verdict is conservative. Status 78 means the expensive upgrade suite may be
+skipped. Status 0 means it must run, including every uncertain condition.
+from __future__ import annotations
+import argparse
+import fnmatch
+import os
+import shutil
+import subprocess
+import sys
+from pathlib import Path
+SQL_VISIBLE_GLOBS = (
+ "Version.config",
+ "extensions/**",
+ "postgis/*.sql.in",
+ "raster/rt_pg/*.sql.in",
+ "topology/*.sql.in",
+ "topology/**/*.sql.in",
+ "sfcgal/**/*.sql.in",
+ "utils/create_upgrade.pl",
+ "utils/create_unpackaged.pl",
+ "utils/create_extension_unpackage.pl",
+ "utils/postgis_restore.pl",
+ "utils/postgis_restore.pl.in",
+MODULE_GLOBS = (
+ "liblwgeom/**",
+ "postgis/**",
+ "raster/rt_pg/**",
+ "topology/**",
+ "sfcgal/**",
+MODULE_PATTERNS = (
+ "liblwgeom/.libs/liblwgeom-*.so*",
+ "postgis/.libs/postgis-*.so*",
+ "postgis/postgis-*.so*",
+ "raster/rt_pg/.libs/postgis_raster-*.so*",
+ "raster/rt_pg/postgis_raster-*.so*",
+ "topology/.libs/postgis_topology-*.so*",
+ "topology/postgis_topology-*.so*",
+ "sfcgal/.libs/postgis_sfcgal-*.so*",
+ "sfcgal/postgis_sfcgal-*.so*",
+def run(args: list[str], cwd: Path | None = None, check: bool = True) -> subprocess.CompletedProcess[str]:
+ return subprocess.run(
+ args,
+ cwd=cwd,
+ check=check,
+ text=True,
+ stdout=subprocess.PIPE,
+ stderr=subprocess.STDOUT,
+def git(args: list[str], check: bool = True) -> str:
+ return run(["git", *args], check=check).stdout
+def match_any(path: str, globs: tuple[str, ...]) -> str | None:
+ for pattern in globs:
+ if fnmatch.fnmatch(path, pattern):
+ return pattern
+ return None
+def resolve_base(base: str | None, head: str) -> tuple[str, list[str]]:
+ cmd = ["python3", "utils/ci_changed_paths.py", "--head", head]
+ if base:
+ cmd.extend(["--base", base])
+ result = run(cmd, check=False)
+ if result.returncode != 0:
+ raise RuntimeError(result.stdout.strip() or "changed path helper failed")
+ paths = [line for line in result.stdout.splitlines() if line]
+ resolved_base = base
+ if not resolved_base:
+ for candidate in ("refs/ci-target/master", "upstream/master", "origin/master", "master"):
+ if run(["git", "rev-parse", "--verify", candidate], check=False).returncode == 0:
+ resolved_base = candidate
+ break
+ raise RuntimeError("no base ref available for symbol comparison")
+ merge_base = git(["merge-base", resolved_base, head]).strip()
+ if not merge_base:
+ raise RuntimeError(f"no merge base between {resolved_base} and {head}")
+ return merge_base, paths
+def build_tree(ref: str, root: Path, name: str) -> Path:
+ tree = root / name / "src"
+ build = root / name / "build"
+ if tree.exists():
+ shutil.rmtree(tree)
+ if build.exists():
+ shutil.rmtree(build)
+ run(["git", "worktree", "add", "--detach", str(tree), ref])
+ build.mkdir(parents=True, exist_ok=True)
+ configure = [
+ str(tree / "configure"),
+ "--with-library-minor-version",
+ "--without-raster",
+ "--without-topology",
+ "--without-sfcgal",
+ "--without-protobuf",
+ "--disable-spellcheck-tests",
+ run([str(tree / "autogen.sh")], cwd=tree)
+ run(configure, cwd=build)
+ run(["make", "-j1", "SUBDIRS=liblwgeom libpgcommon postgis"], cwd=build)
+ return build
+def module_files(build: Path) -> list[Path]:
+ files: list[Path] = []
+ for pattern in MODULE_PATTERNS:
+ files.extend(build.glob(pattern))
+ return sorted(path for path in files if path.is_file())
+def relative_module_map(build: Path) -> dict[str, Path]:
+ result: dict[str, Path] = {}
+ for path in module_files(build):
+ rel = str(path.relative_to(build))
+ result[rel] = path
+ return result
+def symbol_set(path: Path) -> set[str]:
+ output = run(["nm", "-D", "--defined-only", str(path)]).stdout
+ symbols: set[str] = set()
+ for line in output.splitlines():
+ parts = line.split()
+ if len(parts) >= 3:
+ symbols.add(parts[-1])
+ return symbols
+def compare_symbols(base_build: Path, head_build: Path) -> tuple[bool, str]:
+ abidiff = ensure_abidiff()
+ base_modules = relative_module_map(base_build)
+ head_modules = relative_module_map(head_build)
+ names = sorted(set(base_modules) | set(head_modules))
+ if not names:
+ return True, "no built modules found for comparison"
+ for name in names:
+ if name not in base_modules:
+ return True, f"exported module added: {name}"
+ if name not in head_modules:
+ return True, f"exported module removed: {name}"
+ if abidiff:
+ diff = run([abidiff, str(base_modules[name]), str(head_modules[name])], check=False)
+ if diff.returncode not in (0,):
+ return True, f"abidiff reports ABI change in {name}"
+ else:
+ base_symbols = symbol_set(base_modules[name])
+ head_symbols = symbol_set(head_modules[name])
+ if base_symbols != head_symbols:
+ added = sorted(head_symbols - base_symbols)
+ removed = sorted(base_symbols - head_symbols)
+ sample = (removed or added)[0]
+ direction = "removed" if removed else "added"
+ return True, f"defined symbol {direction} in {name}: {sample}"
+ if not abidiff:
+ return True, "abidiff is unavailable; nm fallback found no added or removed symbols but cannot prove signatures unchanged"
+ return False, "no SQL-visible path or exported ABI change"
+def ensure_abidiff() -> str | None:
+ abidiff = shutil.which("abidiff")
+ if abidiff:
+ print(f"INFO: using abidiff at {abidiff}")
+ return abidiff
+ if os.geteuid() != 0 or not shutil.which("apt-get"):
+ print("INFO: abidiff is unavailable and cannot be installed by this user")
+ return None
+ install = run(
+ "sh",
+ "-c",
+ "apt-get update && apt-get install -y --no-install-recommends abigail-tools && rm -rf /var/lib/apt/lists/*",
+ check=False,
+ if install.returncode != 0:
+ print("INFO: installing abigail-tools failed; falling back to nm")
+ print(install.stdout)
+ return None
+ if abidiff:
+ print(f"INFO: installed abidiff at {abidiff}")
+ else:
+ print("INFO: abigail-tools install completed but abidiff is still unavailable")
+ return abidiff
+def main() -> int:
+ parser = argparse.ArgumentParser(description=__doc__)
+ parser.add_argument("--base")
+ parser.add_argument("--head", default="HEAD")
+ "--work-dir",
+ default=os.environ.get("TMPDIR", ".tmp") + "/upgrade-surface",
+ args = parser.parse_args()
+ try:
+ merge_base, paths = resolve_base(args.base, args.head)
+ except Exception as exc:
+ print(f"RUN: upgrade-surface discovery failed open: {exc}")
+ return 0
+ if not paths:
+ print("RUN: changed-path list is empty; failing open")
+ return 0
+ for path in paths:
+ pattern = match_any(path, SQL_VISIBLE_GLOBS)
+ if pattern:
+ print(f"RUN: {path} matches SQL-visible upgrade pattern {pattern}")
+ return 0
+ if not any(match_any(path, MODULE_GLOBS) for path in paths):
+ print("SKIP: no upgrade-relevant change (no SQL-visible path or module source changed)")
+ return 78
+ root = Path(args.work_dir).resolve()
+ root.mkdir(parents=True, exist_ok=True)
+ try:
+ base_build = build_tree(merge_base, root, "base")
+ head_build = build_tree(args.head, root, "head")
+ needs_upgrade, reason = compare_symbols(base_build, head_build)
+ print(f"RUN: symbol comparison failed open: {exc}")
+ return 0
+ finally:
+ for tree in (root / "base" / "src", root / "head" / "src"):
+ if tree.exists():
+ run(["git", "worktree", "remove", "--force", str(tree)], check=False)
+ if needs_upgrade:
+ print(f"RUN: {reason}")
+ return 0
+ print(f"SKIP: no upgrade-relevant change ({reason})")
+ return 78
+if __name__ == "__main__":
+ raise SystemExit(main())
diff --git a/utils/ci_changed_paths.py b/utils/ci_changed_paths.py
index 0000000000..f1daf6c17a
--- /dev/null
+++ b/utils/ci_changed_paths.py
@@ -0,0 +1,100 @@
+"""Report paths changed by the current CI build.
+The script is intentionally conservative. If it cannot identify a pull-request
+base, it prints the reason and exits with status 2 so callers can fail open.
+import argparse
+import os
+import subprocess
+import sys
+def run_git(args: list[str], *, check: bool = True) -> subprocess.CompletedProcess[str]:
+ ["git", *args],
+ check=check,
+ text=True,
+ stderr=subprocess.PIPE,
+def resolve_base(explicit_base: str | None) -> str:
+ if explicit_base:
+ return explicit_base
+ for name in (
+ "CI_COMMIT_TARGET_BRANCH",
+ "WOODPECKER_PULL_REQUEST_TARGET",
+ "GITHUB_BASE_REF",
+ target = os.environ.get(name)
+ if target:
+ ref = f"refs/ci-target/{target}"
+ fetch = run_git(
+ ["fetch", "--no-tags", "origin", f"+refs/heads/{target}:{ref}"],
+ check=False,
+ if fetch.returncode == 0:
+ return ref
+ fetch = run_git(
+ ["fetch", "--no-tags", "upstream", f"+refs/heads/{target}:{ref}"],
+ check=False,
+ return ref
+ f"{name}={target} is set, but fetching that branch failed"
+ for candidate in ("upstream/master", "origin/master", "master"):
+ exists = run_git(["rev-parse", "--verify", candidate], check=False)
+ if exists.returncode == 0:
+ return candidate
+ raise RuntimeError("no pull-request target branch or local master ref found")
+def changed_paths(base: str, head: str) -> list[str]:
+ merge_base = run_git(["merge-base", base, head]).stdout.strip()
+ raise RuntimeError(f"no merge base between {base} and {head}")
+ diff = run_git(["diff", "--name-only", f"{merge_base}...{head}"]).stdout
+ return [line for line in diff.splitlines() if line]
+def main() -> int:
+ parser.add_argument("--base", help="base ref to diff against")
+ parser.add_argument("--head", default="HEAD", help="head ref to diff")
+ "--output",
+ type=Path,
+ help="write the changed path list here instead of stdout",
+ try:
+ base = resolve_base(args.base)
+ paths = changed_paths(base, args.head)
+ print(f"RUN: changed-path discovery failed open: {exc}", file=sys.stderr)
+ return 2
+ output = "\n".join(paths)
+ if output:
+ output += "\n"
+ if args.output:
+ args.output.write_text(output, encoding="utf-8")
+ else:
+ print(output, end="")
+ return 0
diff --git a/utils/ci_need_suite.py b/utils/ci_need_suite.py
index 0000000000..57a8569cec
--- /dev/null
+++ b/utils/ci_need_suite.py
@@ -0,0 +1,204 @@
+"""Decide whether an expensive CI suite is needed for this change.
+Exit status is part of the interface:
+* 0 means run the suite.
+* 78 means skip the expensive body; the CI step should exit successfully.
+Any ambiguity prints a RUN verdict and exits 0.
+import argparse
+import fnmatch
+import os
+import subprocess
+import sys
+CI_AND_BUILD_GLOBS = (
+ ".woodpecker/*.yml",
+ ".github/workflows/*.yml",
+ "ci/**",
+ "configure.ac",
+ "configure.in",
+ "autogen.sh",
+ "GNUmakefile.in",
+ "Makefile.in",
+ "*/Makefile.in",
+ "macros/**",
+ "build-aux/**",
+CORE_GLOBS = (
+ "liblwgeom/**",
+ "libpgcommon/**",
+ "postgis/**",
+ "regress/core/**",
+ "regress/dumper/**",
+ "deps/**",
+ "sfcgal/**",
+RASTER_GLOBS = (
+ "raster/**",
+ "extensions/postgis_raster/**",
+TOPOLOGY_GLOBS = (
+ "topology/**",
+ "extensions/postgis_topology/**",
+LOADER_GLOBS = (
+ "loader/**",
+ "regress/loader/**",
+UPGRADE_GLOBS = (
+ "Version.config",
+ "extensions/**",
+ "utils/check_all_upgrades.sh",
+ "utils/check_cluster_upgrade.sh",
+NEWS_GLOBS = (
+ "NEWS",
+ "utils/check_news.sh",
+ "utils/test_check_news.py",
+ return pattern
+ return None
+def changed_paths(base: str | None, head: str) -> tuple[list[str], str]:
+ if base:
+ result = subprocess.run(
+ cmd,
+ check=False,
+ text=True,
+ raise RuntimeError(result.stderr.strip() or "changed path helper failed")
+ return [line for line in result.stdout.splitlines() if line], result.stdout
+def run_upgrade_surface(base: str | None, head: str) -> int:
+ cmd = ["python3", "utils/check_upgrade_surface.py", "--head", head]
+ if base:
+ return subprocess.call(cmd)
+def need_for_suite(paths: list[str], suite: str, target: str, extension: str) -> tuple[bool, str]:
+ pattern = match_any(path, CI_AND_BUILD_GLOBS)
+ if pattern:
+ return True, f"{path} matches always-run CI/build pattern {pattern}"
+ if suite == "news":
+ pattern = match_any(path, NEWS_GLOBS)
+ if pattern:
+ return True, f"{path} matches NEWS checker pattern {pattern}"
+ return False, "no NEWS checker input changed"
+ if suite == "extension-upgrade" or "upgrade" in target or suite == "cluster-upgrade":
+ direct_globs = UPGRADE_GLOBS
+ if extension == "postgis_raster":
+ direct_globs = UPGRADE_GLOBS + RASTER_GLOBS
+ elif extension == "postgis_topology":
+ direct_globs = UPGRADE_GLOBS + TOPOLOGY_GLOBS
+ elif extension == "postgis_sfcgal":
+ direct_globs = UPGRADE_GLOBS + ("sfcgal/**", "extensions/postgis_sfcgal/**")
+ pattern = match_any(path, direct_globs)
+ if pattern:
+ return True, f"{path} matches upgrade-relevant pattern {pattern}"
+ return False, "no directly upgrade-relevant path changed"
+ if suite in {"preinstall", "install", "qa", "github-ci"}:
+ if suite == "github-ci":
+ pattern = match_any(path, UPGRADE_GLOBS)
+ if pattern:
+ return True, f"{path} matches upgrade-visible platform test pattern {pattern}"
+ for group, globs in (
+ ("core", CORE_GLOBS),
+ ("raster", RASTER_GLOBS),
+ ("topology", TOPOLOGY_GLOBS),
+ ("loader", LOADER_GLOBS),
+ pattern = match_any(path, globs)
+ if pattern:
+ return True, f"{path} matches {group} test pattern {pattern}"
+ return False, "no core, raster, topology, or loader test input changed"
+ return True, f"unknown suite {suite!r}; running"
+def main() -> int:
+ parser.add_argument("suite")
+ parser.add_argument("--target", default=os.environ.get("REGRESS_TARGET", ""))
+ parser.add_argument("--extension", default=os.environ.get("UPGRADE_EXTENSION", "none"))
+ parser.add_argument("--upgrade-surface", action="store_true")
+ if os.environ.get("CI_PIPELINE_EVENT") not in (None, "", "pull_request"):
+ print(f"RUN: {os.environ.get('CI_PIPELINE_EVENT')} event runs full CI")
+ return 0
+ if os.environ.get("GITHUB_EVENT_NAME") not in (None, "", "pull_request"):
+ print(f"RUN: {os.environ.get('GITHUB_EVENT_NAME')} event runs full CI")
+ return 0
+ try:
+ paths, _ = changed_paths(args.base, args.head)
+ print(f"RUN: changed-path discovery failed open: {exc}")
+ return 0
+ if not paths:
+ return 0
+ need, reason = need_for_suite(paths, args.suite, args.target, args.extension)
+ if need:
+ return 0
+ if args.upgrade_surface:
+ rc = run_upgrade_surface(args.base, args.head)
+ if rc == 78:
+ return 78
+ return 0
+ print(f"SKIP: {reason}")
+ return 78
Summary of changes:
.github/workflows/ci-freebsd.yml | 16 +++
.github/workflows/ci-macos.yml | 17 +++
.github/workflows/ci.yml | 19 ++-
.github/workflows/codeql.yml | 21 ++-
.github/workflows/msys.yml | 21 ++-
.woodpecker/qa.yml | 2 +
.woodpecker/regress.yml | 8 ++
ci/ci_changed_paths.py | 100 +++++++++++++
ci/ci_need_suite.py | 204 +++++++++++++++++++++++++++
doc/development/testing/_index.md | 3 +
doc/development/testing/ci-gating.md | 122 ++++++++++++++++
doc/development/testing/ci.md | 10 +-
utils/check_upgrade_surface.py | 265 +++++++++++++++++++++++++++++++++++
13 files changed, 801 insertions(+), 7 deletions(-)
create mode 100755 ci/ci_changed_paths.py
create mode 100755 ci/ci_need_suite.py
create mode 100644 doc/development/testing/ci-gating.md
create mode 100755 utils/check_upgrade_surface.py
hooks/post-receive
