[SCM] PostGIS branch stable-3.2 updated. 3.2.10-85-gb7d2b6038e
Mon Jul 27 12:08:50 PDT 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  b7d2b6038e674dfea02e41b067e4776de3c60c55 (commit)
       via  180a77f361177564109b39ec58f3dbd557bd37f3 (commit)
       via  6ab484dc748f5f8cf7212899f6cef59d881ce963 (commit)
       via  a761dc4d47a4138161b0f33a193ea804d31afc45 (commit)
      from  15c7d6378e5de6629a392495ac226513bdfd8752 (commit)
revisions in full, below.
commit b7d2b6038e674dfea02e41b067e4776de3c60c55
Merge: 15c7d6378e 180a77f361
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 12:08:49 2026 -0700
    Merge pull request 'Backport safety fixes to stable-3.2' (!541) from Komzpa/postgis:backport/20260726-stable-3.2-safety-fixes into stable-3.2
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/541
commit 180a77f361177564109b39ec58f3dbd557bd37f3
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Jul 26 21:35:41 2026 +0400
    Drop master-only NURBS validator from stable GSERIALIZED port
    Stable branches do not define NURBSCURVETYPE, so the NURBS-specific validator from the master GSERIALIZED hardening patch is not a branch-capability match. Keep the payload checks for geometry types present on the stable line.
    (cherry picked from commit de00ccc19b0fee48f8dbbc8b521510382624c099)
    (cherry picked from commit ef6a551e0a2a3420ad5106579c0126e56152c0ec)
diff --git a/liblwgeom/gserialized2.c b/liblwgeom/gserialized2.c
index e27940fecb..78995b4825 100644
--- a/liblwgeom/gserialized2.c
+++ b/liblwgeom/gserialized2.c
@@ -440,37 +440,6 @@ gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwfl
 		break;
-	case NURBSCURVETYPE: {
-		uint32_t nweights, nknots;
-		size_t weight_bytes, knot_bytes, point_bytes;
-		consumed = 6 * sizeof(uint32_t);
-		if (!gserialized2_range_available(data_ptr, data_end, consumed))
-			lwerror("%s: GSERIALIZED NURBS header exceeds payload size", __func__);
-			return LW_FAILURE;
-		nweights =
-		    gserialized2_read_uint32_checked(data_ptr + 3 * sizeof(uint32_t), data_end, "NURBS weight count");
-		nknots =
-		    gserialized2_read_uint32_checked(data_ptr + 4 * sizeof(uint32_t), data_end, "NURBS knot count");
-		if (gserialized2_checked_mul((size_t)nweights, sizeof(double), &weight_bytes) == LW_FAILURE ||
-		    gserialized2_checked_mul((size_t)nknots, sizeof(double), &knot_bytes) == LW_FAILURE)
-			lwerror("%s: GSERIALIZED NURBS vector size overflows", __func__);
-		if (gserialized2_pointarray_payload_size(count, lwflags, &point_bytes) == LW_FAILURE)
-		if (gserialized2_checked_add(consumed, weight_bytes, &consumed) == LW_FAILURE ||
-		    gserialized2_checked_add(consumed, knot_bytes, &consumed) == LW_FAILURE ||
-		    gserialized2_checked_add(consumed, point_bytes, &consumed) == LW_FAILURE)
-			lwerror("%s: GSERIALIZED NURBS size overflows", __func__);
-		break;
 	default:
 		lwerror("Unknown geometry type: %d - %s", type, lwtype_name(type));
 		return LW_FAILURE;
commit 6ab484dc748f5f8cf7212899f6cef59d881ce963
Date:   Sun Jul 26 16:14:42 2026 +0300
    Fix raster geotransform invalid reads
    Port the stable-applicable part of the Valgrind finding: RASTER_getGeotransform read raster offsets after destroying the deserialized raster. The rt_band_init_value zero-cell fix from master does not apply because stable-3.5 does not have that helper.
    Ported-from: https://gitea.osgeo.org/postgis/postgis/commit/5692dfe21b854899ee738f278651e58e63532652
    (cherry picked from commit 0181cd4411467c12ac96a935bacb7da98ddac027)
    (cherry picked from commit 9a28f6f533371ab341ef560cca869b235e839812)
    (cherry picked from commit eb93d7f3165a29937e0ea77d31d0afc05ab30ca7)
    (cherry picked from commit cee7083a3767adeb890272a16b7c762f7383ca6b)
diff --git a/NEWS b/NEWS
index 4c6cedf531..6eb559d0b3 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,8 @@ PostGIS 3.2.11
  - GT-522, Reject malformed GSERIALIZED payload counts before deserializing
    geometry data (Darafei Praliaskouski)
+ - GT-523, [raster] Fix invalid reads in geotransform property access
+   (Darafei Praliaskouski)
  - #6094, [upgrade] Avoid legacy string literal warnings in downgrade checks
    with standard_conforming_strings off (Darafei Praliaskouski)
  - [upgrade] Fix ST_TileEnvelope upgrade marker syntax
diff --git a/raster/rt_pg/rtpg_raster_properties.c b/raster/rt_pg/rtpg_raster_properties.c
index 032e4975e9..c2717585e0 100644
--- a/raster/rt_pg/rtpg_raster_properties.c
+++ b/raster/rt_pg/rtpg_raster_properties.c
@@ -445,10 +445,8 @@ Datum RASTER_getGeotransform(PG_FUNCTION_ARGS)
     double jmag;
     double theta_i;
     double theta_ij;
     double xoffset;
     double yoffset;
     TupleDesc result_tuple; /* for returning a composite */
     Datum values[VALUES_LENGTH];
@@ -478,6 +476,8 @@ Datum RASTER_getGeotransform(PG_FUNCTION_ARGS)
             rt_raster_get_y_skew(raster),
             rt_raster_get_y_scale(raster),
             &imag, &jmag, &theta_i, &theta_ij) ;
+    xoffset = rt_raster_get_x_offset(raster);
+    yoffset = rt_raster_get_y_offset(raster);
     rt_raster_destroy(raster);
     PG_FREE_IF_COPY(pgraster, 0);
@@ -501,8 +501,8 @@ Datum RASTER_getGeotransform(PG_FUNCTION_ARGS)
     values[1] = Float8GetDatum(jmag);
     values[2] = Float8GetDatum(theta_i);
     values[3] = Float8GetDatum(theta_ij);
-    values[4] = Float8GetDatum(rt_raster_get_x_offset(raster));
-    values[5] = Float8GetDatum(rt_raster_get_y_offset(raster));
+    values[4] = Float8GetDatum(xoffset);
+    values[5] = Float8GetDatum(yoffset);
     memset(nulls, FALSE, sizeof(bool) * VALUES_LENGTH);
commit a761dc4d47a4138161b0f33a193ea804d31afc45
Date:   Sun Jul 26 14:43:56 2026 +0400
    Harden GSERIALIZED payload readers
    (cherry picked from commit 62cff7ebdd8a76e61231b379026a41dd6e49b436)
index 6c6396e6d9..4c6cedf531 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,8 @@ PostGIS 3.2.11
 * Bug Fixes *
+ - GT-522, Reject malformed GSERIALIZED payload counts before deserializing
+   geometry data (Darafei Praliaskouski)
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index 66cc0a55e8..4afe2294c7 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -1252,6 +1252,47 @@ test_gserialized1_peek_first_point(void)
 	CU_ASSERT(peek1_point_helper("POLYGON((0 0, 1 1, 1 0, 0 0))", &p) == LW_FAILURE);
+static void
+assert_gserialized1_malformed_rejected(GSERIALIZED *g)
+	LWGEOM *geom;
+	GBOX box;
+	POINT4D point;
+	memset(&box, 0, sizeof(box));
+	memset(&point, 0, sizeof(point));
+	cu_error_msg_reset();
+	geom = lwgeom_from_gserialized1(g);
+	CU_ASSERT_PTR_NULL(geom);
+	CU_ASSERT_NOT_EQUAL(strlen(cu_error_msg), 0);
+	CU_ASSERT_TRUE(gserialized1_is_empty(g));
+	CU_ASSERT_EQUAL(gserialized1_peek_gbox_p(g, &box), LW_FAILURE);
+	CU_ASSERT_EQUAL(gserialized1_peek_first_point(g, &point), LW_FAILURE);
+static void
+test_gserialized1_malformed_declared_size(void)
+	LWGEOM *lwgeom = lwgeom_from_wkt("POINT(1 1)", LW_PARSER_CHECK_NONE);
+	GSERIALIZED *g;
+	size_t size = 0;
+	CU_ASSERT_PTR_NOT_NULL_FATAL(lwgeom);
+	g = gserialized1_from_lwgeom(lwgeom, &size);
+	CU_ASSERT_PTR_NOT_NULL_FATAL(g);
+	LWSIZE_SET(g->size, 0);
+	assert_gserialized1_malformed_rejected(g);
+	LWSIZE_SET(g->size, offsetof(GSERIALIZED, data) - 1);
+	lwfree(g);
+	lwgeom_free(lwgeom);
 ** Used by test harness to register the tests in this file.
@@ -1286,4 +1327,5 @@ void gserialized1_suite_setup(void)
 	PG_ADD_TEST(suite, test_gbox_same_2d);
 	PG_ADD_TEST(suite, test_signum_macro);
 	PG_ADD_TEST(suite, test_gserialized1_peek_first_point);
+	PG_ADD_TEST(suite, test_gserialized1_malformed_declared_size);
diff --git a/liblwgeom/cunit/cu_gserialized2.c b/liblwgeom/cunit/cu_gserialized2.c
index 6f8217c15a..3dc36a09a4 100644
--- a/liblwgeom/cunit/cu_gserialized2.c
+++ b/liblwgeom/cunit/cu_gserialized2.c
@@ -509,6 +509,133 @@ test_gserialized2_peek_first_point(void)
 	CU_ASSERT(peek2_point_helper("POLYGON((0 0, 1 1, 1 0, 0 0))", &p) == LW_FAILURE);
+static GSERIALIZED *
+gserialized2_from_hexbytes(const char *hex)
+	uint8_t *bytes;
+	size_t size;
+	GSERIALIZED *g;
+	size = strlen(hex) / 2;
+	bytes = bytes_from_hexbytes(hex, strlen(hex));
+	g = lwalloc(size);
+	memcpy(g, bytes, size);
+	lwfree(bytes);
+	return g;
+static void
+test_gserialized2_malformed_collection_count(void)
+	const char *hex =
+	    "8001000000000044000000000000803f0000000000000040"
+	    "070000000200000001000000f03f000000000000f03f";
+	GSERIALIZED *g = gserialized2_from_hexbytes(hex);
+	LWGEOM *geom;
+	geom = lwgeom_from_gserialized2(g);
+	lwfree(g);
+static void
+assert_gserialized2_malformed_rejected(GSERIALIZED *g)
+	LWGEOM *geom;
+	GBOX box;
+	POINT4D point;
+	CU_ASSERT_TRUE(gserialized2_is_empty(g));
+	CU_ASSERT_EQUAL(gserialized2_peek_gbox_p(g, &box), LW_FAILURE);
+	CU_ASSERT_EQUAL(gserialized2_peek_first_point(g, &point), LW_FAILURE);
+static void
+test_gserialized2_malformed_declared_size(void)
+	const char *declared_size_0 =
+	    "0000000000000044000000000000803f0000000000000040"
+	const char *declared_size_23 =
+	    "5c00000000000044000000000000803f0000000000000040"
+	GSERIALIZED *g;
+	g = gserialized2_from_hexbytes(declared_size_0);
+	assert_gserialized2_malformed_rejected(g);
+	lwfree(g);
+	g = gserialized2_from_hexbytes(declared_size_23);
+	lwfree(g);
+static void
+test_gserialized2_malformed_short_allocation(void)
+#if defined(POSTGIS_ASAN_ALLOCATOR_SIZE)
+	const char *hex = "8001000000000044";
+	uint8_t *bytes = bytes_from_hexbytes(hex, strlen(hex));
+	GSERIALIZED *g = malloc(strlen(hex) / 2);
+	memcpy(g, bytes, strlen(hex) / 2);
+	free(g);
+	lwfree(bytes);
+#else
+	CU_PASS("shorter-than-declared allocation validation requires AddressSanitizer allocation metadata");
+#endif
+static void
+test_gserialized2_wkb_roundtrip_float_rounded_box(void)
+	const char *hex =
+	    "0102000000030000000000000000000000000000f03f0000000000000040"
+	    "0101000000000000000f03f0000000000000040000000000000f03f";
+	size_t wkb_size = strlen(hex) / 2;
+	uint8_t *wkb = bytes_from_hexbytes(hex, strlen(hex));
+	LWGEOM *input = lwgeom_from_wkb(wkb, wkb_size, LW_PARSER_CHECK_NONE);
+	GSERIALIZED *serialized;
+	LWGEOM *roundtrip;
+	size_t serialized_size = 0;
+	GBOX input_box;
+	GBOX roundtrip_box;
+	CU_ASSERT_PTR_NOT_NULL_FATAL(input);
+	serialized = gserialized2_from_lwgeom(input, &serialized_size);
+	CU_ASSERT_PTR_NOT_NULL_FATAL(serialized);
+	roundtrip = lwgeom_from_gserialized2(serialized);
+	CU_ASSERT_PTR_NOT_NULL_FATAL(roundtrip);
+	CU_ASSERT_EQUAL(serialized_size, LWSIZE_GET(serialized->size));
+	CU_ASSERT_PTR_NOT_NULL(input->bbox);
+	CU_ASSERT_PTR_NOT_NULL(roundtrip->bbox);
+	CU_ASSERT_FALSE(gbox_same(input->bbox, roundtrip->bbox));
+	CU_ASSERT_EQUAL(lwgeom_calculate_gbox_cartesian(input, &input_box), LW_SUCCESS);
+	CU_ASSERT_EQUAL(lwgeom_calculate_gbox_cartesian(roundtrip, &roundtrip_box), LW_SUCCESS);
+	CU_ASSERT_TRUE(gbox_same(&input_box, &roundtrip_box));
+	lwgeom_free(input);
+	lwgeom_free(roundtrip);
+	lwfree(serialized);
+	lwfree(wkb);
@@ -527,4 +654,8 @@ void gserialized2_suite_setup(void)
 	PG_ADD_TEST(suite, test_gserialized2_peek_gbox_p_fails_for_unsupported_cases);
 	PG_ADD_TEST(suite, test_gserialized2_extended_flags);
 	PG_ADD_TEST(suite, test_gserialized2_peek_first_point);
+	PG_ADD_TEST(suite, test_gserialized2_malformed_collection_count);
+	PG_ADD_TEST(suite, test_gserialized2_malformed_declared_size);
+	PG_ADD_TEST(suite, test_gserialized2_malformed_short_allocation);
+	PG_ADD_TEST(suite, test_gserialized2_wkb_roundtrip_float_rounded_box);
diff --git a/liblwgeom/gserialized1.c b/liblwgeom/gserialized1.c
index 1a87ccf527..e4f7c57ce3 100644
--- a/liblwgeom/gserialized1.c
+++ b/liblwgeom/gserialized1.c
@@ -30,13 +30,37 @@
 #include "gserialized1.h"
 #include <stddef.h>
+#if defined(__has_feature)
+#if __has_feature(address_sanitizer)
+#define POSTGIS_ASAN_ALLOCATOR_SIZE 1
+#endif
+#endif
+#if defined(__SANITIZE_ADDRESS__)
+#endif
+#include <sanitizer/allocator_interface.h>
+#endif
 * GSERIALIZED metadata utility functions.
 static int gserialized1_read_gbox_p(const GSERIALIZED *g, GBOX *gbox);
+static int gserialized1_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end);
+static int gserialized1_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size);
+static size_t
+gserialized1_buffer_size(const GSERIALIZED *g)
+	size_t gsize = LWSIZE_GET(g->size);
+	size_t allocated_size = __sanitizer_get_allocated_size(g);
+	if (allocated_size > 0 && allocated_size < gsize)
+		return allocated_size;
+#endif
+	return gsize;
 lwflags_t gserialized1_get_lwflags(const GSERIALIZED *g)
@@ -132,6 +156,13 @@ static uint32_t gserialized1_header_size(const GSERIALIZED *gser)
 uint32_t gserialized1_get_type(const GSERIALIZED *g)
 	uint32_t *ptr;
+	size_t hsz = gserialized1_header_size(g);
+	size_t gsize = gserialized1_buffer_size(g);
+	if (gsize < hsz + sizeof(uint32_t))
+		lwerror("%s: GSERIALIZED too small for geometry type", __func__);
+		return 0;
 	ptr = (uint32_t*)(g->data);
 	if ( G1FLAGS_GET_BBOX(g->gflags) )
@@ -142,19 +173,19 @@ uint32_t gserialized1_get_type(const GSERIALIZED *g)
 int32_t gserialized1_get_srid(const GSERIALIZED *s)
-	int32_t srid = 0;
-	srid = srid | (s->srid[0] << 16);
-	srid = srid | (s->srid[1] << 8);
-	srid = srid | s->srid[2];
-	/* Only the first 21 bits are set. Slide up and back to pull
-	   the negative bits down, if we need them. */
-	srid = (srid<<11)>>11;
+	uint32_t srid = 0;
+	srid = srid | ((uint32_t)s->srid[0] << 16);
+	srid = srid | ((uint32_t)s->srid[1] << 8);
+	srid = srid | (uint32_t)s->srid[2];
+	/* Only the first 21 bits are set. Sign-extend without signed shift UB. */
+	if (srid & 0x00100000)
+		srid |= 0xFFE00000;
 	/* 0 is our internal unknown value. We'll map back and forth here for now */
 	if ( srid == 0 )
 		return SRID_UNKNOWN;
 	else
-		return srid;
+		return (int32_t)srid;
 void gserialized1_set_srid(GSERIALIZED *s, int32_t srid)
@@ -173,6 +204,204 @@ void gserialized1_set_srid(GSERIALIZED *s, int32_t srid)
 	s->srid[2] = (srid & 0x000000FF);
+static int
+gserialized1_range_available(const uint8_t *ptr, const uint8_t *end, size_t len)
+	return ptr <= end && len <= (size_t)(end - ptr);
+static int
+gserialized1_checked_mul(size_t a, size_t b, size_t *out)
+	if (a != 0 && b > SIZE_MAX / a)
+		return LW_FAILURE;
+	*out = a * b;
+	return LW_SUCCESS;
+static int
+gserialized1_checked_add(size_t a, size_t b, size_t *out)
+	if (b > SIZE_MAX - a)
+	*out = a + b;
+static int
+gserialized1_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end)
+	size_t hsz;
+	size_t gsize;
+	if (!g)
+	hsz = gserialized1_header_size(g);
+	gsize = gserialized1_buffer_size(g);
+	if (gsize < hsz)
+	if (start)
+		*start = (uint8_t *)g + hsz;
+	if (end)
+		*end = (uint8_t *)g + gsize;
+static uint32_t
+gserialized1_read_uint32_checked(uint8_t *ptr, uint8_t *end, const char *field)
+	uint32_t value = 0;
+	if (!gserialized1_range_available(ptr, end, sizeof(uint32_t)))
+		lwerror("%s: GSERIALIZED too small for %s", __func__, field);
+		return 0;
+	memcpy(&value, ptr, sizeof(uint32_t));
+	return value;
+static int
+gserialized1_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t *nbytes)
+	if (gserialized1_checked_mul((size_t)npoints, sizeof(double) * FLAGS_NDIMS(lwflags), nbytes) == LW_FAILURE)
+		lwerror("%s: GSERIALIZED point count overflows payload size", __func__);
+static int
+gserialized1_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
+	uint32_t type, count;
+	size_t consumed = 0;
+	if (!gserialized1_range_available(data_ptr, data_end, 2 * sizeof(uint32_t)))
+		lwerror("%s: GSERIALIZED geometry payload is too short", __func__);
+	type = gserialized1_read_uint32_checked(data_ptr, data_end, "geometry type");
+	count = gserialized1_read_uint32_checked(data_ptr + sizeof(uint32_t), data_end, "geometry count");
+	switch (type)
+	case POINTTYPE:
+		if (count > 1)
+			lwerror("%s: invalid point count %u", __func__, count);
+		/* fall through */
+	case LINETYPE:
+	case CIRCSTRINGTYPE:
+	case TRIANGLETYPE: {
+		size_t point_bytes;
+		if (gserialized1_pointarray_payload_size(count, lwflags, &point_bytes) == LW_FAILURE)
+		consumed = 2 * sizeof(uint32_t) + point_bytes;
+		break;
+	case POLYGONTYPE: {
+		size_t ring_counts_size, ring_counts_padded_size, point_bytes_sum = 0;
+		uint8_t *ring_counts = data_ptr + 2 * sizeof(uint32_t);
+		uint32_t i;
+		if (gserialized1_checked_mul((size_t)count, sizeof(uint32_t), &ring_counts_size) == LW_FAILURE)
+			lwerror("%s: GSERIALIZED ring count overflows payload size", __func__);
+		ring_counts_padded_size = ring_counts_size + ((count % 2) ? sizeof(uint32_t) : 0);
+		if (!gserialized1_range_available(ring_counts, data_end, ring_counts_padded_size))
+			lwerror("%s: GSERIALIZED polygon ring table exceeds payload size", __func__);
+		for (i = 0; i < count; i++)
+			size_t ring_point_bytes;
+			uint32_t npoints = gserialized1_read_uint32_checked(
+			    ring_counts + i * sizeof(uint32_t), data_end, "ring point count");
+			if (gserialized1_pointarray_payload_size(npoints, lwflags, &ring_point_bytes) == LW_FAILURE)
+			if (gserialized1_checked_add(point_bytes_sum, ring_point_bytes, &point_bytes_sum) == LW_FAILURE)
+				lwerror("%s: GSERIALIZED polygon coordinate size overflows", __func__);
+		consumed = 2 * sizeof(uint32_t) + ring_counts_padded_size;
+		if (gserialized1_checked_add(consumed, point_bytes_sum, &consumed) == LW_FAILURE)
+			lwerror("%s: GSERIALIZED polygon size overflows", __func__);
+		break;
+	case MULTIPOINTTYPE:
+	case MULTILINETYPE:
+	case MULTIPOLYGONTYPE:
+	case COMPOUNDTYPE:
+	case CURVEPOLYTYPE:
+	case MULTICURVETYPE:
+	case MULTISURFACETYPE:
+	case POLYHEDRALSURFACETYPE:
+	case TINTYPE:
+	case COLLECTIONTYPE: {
+		uint32_t i;
+		uint8_t *subgeom_ptr = data_ptr + 2 * sizeof(uint32_t);
+		lwflags_t subflags = lwflags;
+		FLAGS_SET_BBOX(subflags, 0);
+			size_t subsize = 0;
+			uint32_t subtype =
+			    gserialized1_read_uint32_checked(subgeom_ptr, data_end, "collection subtype");
+			if (!lwcollection_allows_subtype(type, subtype))
+				lwerror("Invalid subtype (%s) for collection type (%s)",
+					lwtype_name(subtype),
+					lwtype_name(type));
+			if (gserialized1_validate_geometry_buffer(subgeom_ptr, data_end, subflags, &subsize) ==
+			    LW_FAILURE)
+			if (subsize == 0)
+				lwerror("%s: GSERIALIZED collection member has zero size", __func__);
+			subgeom_ptr += subsize;
+		consumed = (size_t)(subgeom_ptr - data_ptr);
+		break;
+	default:
+		lwerror("Unknown geometry type: %d - %s", type, lwtype_name(type));
+	if (!gserialized1_range_available(data_ptr, data_end, consumed))
+		lwerror("%s: GSERIALIZED geometry payload exceeds declared size", __func__);
+	if (size)
+		*size = consumed;
 static size_t gserialized1_is_empty_recurse(const uint8_t *p, int *isempty);
@@ -203,13 +432,17 @@ static size_t gserialized1_is_empty_recurse(const uint8_t *p, int *isempty)
 int gserialized1_is_empty(const GSERIALIZED *g)
-	uint8_t *p = (uint8_t*)g;
+	uint8_t *p, *end;
 	int isempty = 0;
 	assert(g);
-	p += 8; /* Skip varhdr and srid/flags */
-	if(gserialized1_has_bbox(g))
-		p += gserialized1_box_size(g); /* Skip the box */
+	if (gserialized1_payload_bounds(g, &p, &end) == LW_FAILURE)
+		lwerror("%s: invalid GSERIALIZED header size", __func__);
+		return LW_TRUE;
+	if (gserialized1_validate_geometry_buffer(p, end, gserialized1_get_lwflags(g), NULL) == LW_FAILURE)
+		return LW_TRUE;
 	gserialized1_is_empty_recurse(p, &isempty);
 	return isempty;
@@ -254,6 +487,8 @@ int gserialized1_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
 	/* Null input! */
 	if ( ! ( g && gbox ) ) return LW_FAILURE;
+	if (gserialized1_buffer_size(g) < offsetof(GSERIALIZED, data) + gserialized1_box_size(g))
 	/* Initialize the flags on the box */
 	gbox->flags = gserialized1_get_lwflags(g);
@@ -298,7 +533,16 @@ int gserialized1_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
 int
 gserialized1_peek_gbox_p(const GSERIALIZED *g, GBOX *gbox)
-	uint32_t type = gserialized1_get_type(g);
+	uint32_t type;
+	uint8_t *geometry_start = NULL;
+	uint8_t *geometry_end = NULL;
+	if (gserialized1_payload_bounds(g, &geometry_start, &geometry_end) == LW_FAILURE)
+	if (gserialized1_validate_geometry_buffer(geometry_start, geometry_end, gserialized1_get_lwflags(g), NULL) ==
+	    LW_FAILURE)
+	type = gserialized1_get_type(g);
 	/* Peeking doesn't help if you already have a box or are geodetic */
 	if ( G1FLAGS_GET_GEODETIC(g->gflags) || G1FLAGS_GET_BBOX(g->gflags) )
@@ -491,11 +735,14 @@ gserialized1_copy_point(double *dptr, lwflags_t flags, POINT4D *out_point)
 int
 gserialized1_peek_first_point(const GSERIALIZED *g, POINT4D *out_point)
-	uint8_t *geometry_start = ((uint8_t *)g->data);
-	if (gserialized1_has_bbox(g))
-		geometry_start += gserialized1_box_size(g);
+	    LW_FAILURE)
 	uint32_t isEmpty = (((uint32_t *)geometry_start)[1]) == 0;
 	if (isEmpty)
@@ -1454,14 +1701,19 @@ LWGEOM* lwgeom_from_gserialized1(const GSERIALIZED *g)
 	assert(g);
 	srid = gserialized1_get_srid(g);
-	lwtype = gserialized1_get_type(g);
 	lwflags = gserialized1_get_lwflags(g);
-	LWDEBUGF(4, "Got type %d (%s), srid=%d", lwtype, lwtype_name(lwtype), srid);
+	if (gserialized1_payload_bounds(g, &data_ptr, NULL) == LW_FAILURE)
+		return NULL;
+		data_ptr, (uint8_t *)g + gserialized1_buffer_size(g), lwflags, NULL) == LW_FAILURE)
+		return NULL;
+	lwtype = gserialized1_get_type(g);
-	data_ptr = (uint8_t*)g->data;
-	if (FLAGS_GET_BBOX(lwflags))
-		data_ptr += gbox_serialized_size(lwflags);
+	LWDEBUGF(4, "Got type %d (%s), srid=%d", lwtype, lwtype_name(lwtype), srid);
 	lwgeom = lwgeom_from_gserialized1_buffer(data_ptr, lwflags, &size);
@@ -1495,6 +1747,8 @@ const float * gserialized1_get_float_box_p(const GSERIALIZED *g, size_t *ndims)
 		*ndims = G1FLAGS_NDIMS_BOX(g->gflags);
 	if (!g) return NULL;
 	if (!G1FLAGS_GET_BBOX(g->gflags)) return NULL;
+		return NULL;
 	return (const float *)(g->data);
@@ -1604,4 +1858,3 @@ GSERIALIZED* gserialized1_drop_gbox(GSERIALIZED *g)
 	return g_out;
index ddf8250ed4..e27940fecb 100644
@@ -48,18 +48,43 @@
 #include "gserialized2.h"
 #include <stddef.h>
+#endif
+#endif
+#endif
+#endif
 static int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox);
+static int gserialized2_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end);
+static int gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size);
+static size_t
+gserialized2_buffer_size(const GSERIALIZED *g)
+#endif
+	return gsize;
 lwflags_t gserialized2_get_lwflags(const GSERIALIZED *g)
 	lwflags_t lwflags = 0;
 	uint8_t gflags = g->gflags;
+	size_t gsize = gserialized2_buffer_size(g);
 	FLAGS_SET_Z(lwflags, G2FLAGS_GET_Z(gflags));
 	FLAGS_SET_M(lwflags, G2FLAGS_GET_M(gflags));
 	FLAGS_SET_BBOX(lwflags, G2FLAGS_GET_BBOX(gflags));
@@ -67,6 +92,11 @@ lwflags_t gserialized2_get_lwflags(const GSERIALIZED *g)
 	if (G2FLAGS_GET_EXTENDED(gflags))
 		uint64_t xflags = 0;
+		if (gsize < offsetof(GSERIALIZED, data) + sizeof(uint64_t))
+			lwerror("%s: GSERIALIZED too small for extended flags", __func__);
+			return lwflags;
 		memcpy(&xflags, g->data, sizeof(uint64_t));
 		FLAGS_SET_SOLID(lwflags, xflags & G2FLAG_X_SOLID);
@@ -185,24 +215,31 @@ uint32_t gserialized2_max_header_size(void)
 uint32_t gserialized2_get_type(const GSERIALIZED *g)
 	uint8_t *ptr = gserialized2_get_geometry_p(g);
+	size_t hsz = gserialized2_header_size(g);
+		return 0;
 	return *((uint32_t*)(ptr));
 int32_t gserialized2_get_srid(const GSERIALIZED *g)
-	int32_t srid = 0;
-	srid = srid | (g->srid[0] << 16);
-	srid = srid | (g->srid[1] << 8);
-	srid = srid | (g->srid[2]);
+	srid = srid | ((uint32_t)g->srid[0] << 16);
+	srid = srid | ((uint32_t)g->srid[1] << 8);
+	srid = srid | (uint32_t)g->srid[2];
 	if (srid == 0)
 	else
-		return srid;
 void gserialized2_set_srid(GSERIALIZED *g, int32_t srid)
@@ -221,6 +258,235 @@ void gserialized2_set_srid(GSERIALIZED *g, int32_t srid)
 	g->srid[2] = (srid & 0x000000FF);
+static int
+gserialized2_range_available(const uint8_t *ptr, const uint8_t *end, size_t len)
+static int
+gserialized2_checked_mul(size_t a, size_t b, size_t *out)
+	*out = a * b;
+static int
+gserialized2_checked_add(size_t a, size_t b, size_t *out)
+	*out = a + b;
+static int
+gserialized2_payload_bounds(const GSERIALIZED *g, uint8_t **start, uint8_t **end)
+	size_t hsz;
+	size_t gsize;
+	if (!g)
+	hsz = gserialized2_header_size(g);
+	gsize = gserialized2_buffer_size(g);
+	if (gsize < hsz)
+	if (start)
+	if (end)
+static uint32_t
+gserialized2_read_uint32_checked(uint8_t *ptr, uint8_t *end, const char *field)
+	if (!gserialized2_range_available(ptr, end, sizeof(uint32_t)))
+		return 0;
+	return value;
+static int
+gserialized2_pointarray_payload_size(uint32_t npoints, lwflags_t lwflags, size_t *nbytes)
+	if (gserialized2_checked_mul((size_t)npoints, sizeof(double) * FLAGS_NDIMS(lwflags), nbytes) == LW_FAILURE)
+static int
+gserialized2_validate_geometry_buffer(uint8_t *data_ptr, uint8_t *data_end, lwflags_t lwflags, size_t *size)
+	if (!gserialized2_range_available(data_ptr, data_end, 2 * sizeof(uint32_t)))
+	type = gserialized2_read_uint32_checked(data_ptr, data_end, "geometry type");
+	count = gserialized2_read_uint32_checked(data_ptr + sizeof(uint32_t), data_end, "geometry count");
+	switch (type)
+	case POINTTYPE:
+		if (count > 1)
+	case LINETYPE:
+		if (gserialized2_pointarray_payload_size(count, lwflags, &point_bytes) == LW_FAILURE)
+		break;
+		uint32_t i;
+		if (gserialized2_checked_mul((size_t)count, sizeof(uint32_t), &ring_counts_size) == LW_FAILURE)
+		if (!gserialized2_range_available(ring_counts, data_end, ring_counts_padded_size))
+			uint32_t npoints = gserialized2_read_uint32_checked(
+			if (gserialized2_pointarray_payload_size(npoints, lwflags, &ring_point_bytes) == LW_FAILURE)
+			if (gserialized2_checked_add(point_bytes_sum, ring_point_bytes, &point_bytes_sum) == LW_FAILURE)
+		if (gserialized2_checked_add(consumed, point_bytes_sum, &consumed) == LW_FAILURE)
+		break;
+	case TINTYPE:
+		uint32_t i;
+			    gserialized2_read_uint32_checked(subgeom_ptr, data_end, "collection subtype");
+			if (gserialized2_validate_geometry_buffer(subgeom_ptr, data_end, subflags, &subsize) ==
+			    LW_FAILURE)
+			if (subsize == 0)
+		break;
+	case NURBSCURVETYPE: {
+		uint32_t nweights, nknots;
+		size_t weight_bytes, knot_bytes, point_bytes;
+		consumed = 6 * sizeof(uint32_t);
+		if (!gserialized2_range_available(data_ptr, data_end, consumed))
+			lwerror("%s: GSERIALIZED NURBS header exceeds payload size", __func__);
+		nweights =
+		    gserialized2_read_uint32_checked(data_ptr + 3 * sizeof(uint32_t), data_end, "NURBS weight count");
+		nknots =
+		    gserialized2_read_uint32_checked(data_ptr + 4 * sizeof(uint32_t), data_end, "NURBS knot count");
+		if (gserialized2_checked_mul((size_t)nweights, sizeof(double), &weight_bytes) == LW_FAILURE ||
+		    gserialized2_checked_mul((size_t)nknots, sizeof(double), &knot_bytes) == LW_FAILURE)
+			lwerror("%s: GSERIALIZED NURBS vector size overflows", __func__);
+		if (gserialized2_checked_add(consumed, weight_bytes, &consumed) == LW_FAILURE ||
+		    gserialized2_checked_add(consumed, knot_bytes, &consumed) == LW_FAILURE ||
+		    gserialized2_checked_add(consumed, point_bytes, &consumed) == LW_FAILURE)
+			lwerror("%s: GSERIALIZED NURBS size overflows", __func__);
+		break;
+	default:
+	if (size)
+		*size = consumed;
 static size_t gserialized2_is_empty_recurse(const uint8_t *p, int *isempty);
@@ -285,7 +551,14 @@ static size_t gserialized2_is_empty_recurse(const uint8_t *p, int *isempty)
 int gserialized2_is_empty(const GSERIALIZED *g)
 	int isempty = LW_TRUE;
-	uint8_t *p = gserialized2_get_geometry_p(g);
+	uint8_t *p, *end;
+	if (gserialized2_payload_bounds(g, &p, &end) == LW_FAILURE)
+		return LW_TRUE;
+	if (gserialized2_validate_geometry_buffer(p, end, gserialized2_get_lwflags(g), NULL) == LW_FAILURE)
+		return LW_TRUE;
 	gserialized2_is_empty_recurse(p, &isempty);
 	return isempty;
@@ -329,6 +602,8 @@ const float * gserialized2_get_float_box_p(const GSERIALIZED *g, size_t *ndims)
 	uint8_t *ptr = (uint8_t*)(g->data);
 	size_t bndims = G2FLAGS_NDIMS_BOX(g->gflags);
+	size_t box_offset = offsetof(GSERIALIZED, data);
+	size_t box_size = gserialized2_box_size(g);
 	if (ndims)
 		*ndims = bndims;
@@ -339,7 +614,13 @@ const float * gserialized2_get_float_box_p(const GSERIALIZED *g, size_t *ndims)
 	/* Advance past optional extended flags */
 	if (gserialized2_has_extended(g))
 		ptr += 8;
+		box_offset += 8;
+	if (gserialized2_buffer_size(g) < box_offset + box_size)
+		return NULL;
 	return (const float *)(ptr);
@@ -358,6 +639,8 @@ int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
 		int i = 0;
 		const float *fbox = gserialized2_get_float_box_p(g, NULL);
+		if (!fbox)
 		gbox->xmin = fbox[i++];
 		gbox->xmax = fbox[i++];
 		gbox->ymin = fbox[i++];
@@ -393,10 +676,20 @@ int gserialized2_read_gbox_p(const GSERIALIZED *g, GBOX *gbox)
 int
 gserialized2_peek_gbox_p(const GSERIALIZED *g, GBOX *gbox)
-	uint32_t type = gserialized2_get_type(g);
-	uint8_t *geometry_start = gserialized2_get_geometry_p(g);
-	double *dptr = (double *)(geometry_start);
-	int32_t *iptr = (int32_t *)(geometry_start);
+	uint32_t type;
+	double *dptr = NULL;
+	int32_t *iptr = NULL;
+	if (gserialized2_payload_bounds(g, &geometry_start, &geometry_end) == LW_FAILURE)
+	if (gserialized2_validate_geometry_buffer(geometry_start, geometry_end, gserialized2_get_lwflags(g), NULL) ==
+	    LW_FAILURE)
+	type = gserialized2_get_type(g);
+	dptr = (double *)(geometry_start);
+	iptr = (int32_t *)(geometry_start);
 	if (G2FLAGS_GET_GEODETIC(g->gflags) || G2FLAGS_GET_BBOX(g->gflags))
@@ -581,7 +874,14 @@ gserialized2_copy_point(double *dptr, lwflags_t flags, POINT4D *out_point)
 int
 gserialized2_peek_first_point(const GSERIALIZED *g, POINT4D *out_point)
+	    LW_FAILURE)
 	if (isEmpty)
@@ -1542,22 +1842,19 @@ LWGEOM* lwgeom_from_gserialized2(const GSERIALIZED *g)
 	assert(g);
 	srid = gserialized2_get_srid(g);
-	lwtype = gserialized2_get_type(g);
 	lwflags = gserialized2_get_lwflags(g);
-	/* Skip optional flags */
-	if (G2FLAGS_GET_EXTENDED(g->gflags))
+	if (gserialized2_payload_bounds(g, &data_ptr, NULL) == LW_FAILURE)
-		data_ptr += sizeof(uint64_t);
+		return NULL;
+		data_ptr, (uint8_t *)g + gserialized2_buffer_size(g), lwflags, NULL) == LW_FAILURE)
+		return NULL;
+	lwtype = gserialized2_get_type(g);
-	/* Skip over optional bounding box */
 	lwgeom = lwgeom_from_gserialized2_buffer(data_ptr, lwflags, &size, srid);
Summary of changes:
 NEWS                                  |   4 +
 liblwgeom/cunit/cu_gserialized1.c     |  42 +++++
 liblwgeom/cunit/cu_gserialized2.c     | 131 ++++++++++++++
 liblwgeom/gserialized1.c              | 301 +++++++++++++++++++++++++++++---
 liblwgeom/gserialized2.c              | 316 +++++++++++++++++++++++++++++++---
 raster/rt_pg/rtpg_raster_properties.c |   8 +-
 6 files changed, 749 insertions(+), 53 deletions(-)
hooks/post-receive
