[SCM] PostGIS branch master updated. 3.7.0beta1-97-g5dde209ddc
Mon Jul 27 16:33:25 PDT 2026
the project "PostGIS".
       via  5dde209ddc5ee4b0f3e7c8bd7dd2013dc0a75a2f (commit)
       via  97ff98eba363467b64e19ec0ecbc9d5b92426179 (commit)
      from  9251ab450b2b0b6e98f0c6e85855b0e4f48fd2df (commit)
revisions in full, below.
commit 5dde209ddc5ee4b0f3e7c8bd7dd2013dc0a75a2f
Merge: 9251ab450b 97ff98eba3
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 16:33:24 2026 -0700
    Merge pull request 'ci: preserve Woodpecker gate skip status' (!572) from Komzpa/postgis:fix/woodpecker-gate-status-78 into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/572
commit 97ff98eba363467b64e19ec0ecbc9d5b92426179
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 28 03:08:34 2026 +0400
diff --git a/.woodpecker/codeql.yml b/.woodpecker/codeql.yml
index 7c5a225fe3..8775546ee8 100644
--- a/.woodpecker/codeql.yml
+++ b/.woodpecker/codeql.yml
@@ -15,7 +15,7 @@ steps:
     image: repo.osgeo.org/postgis/build-test:debian13
     pull: true
     commands:
-      - python3 ci/dronie/codeql_should_run.py; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
+      - gate_status=0; python3 ci/dronie/codeql_should_run.py || gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
       - export CODEQL_TMP="$${CI_WORKSPACE}/.tmp/codeql"
       - export CODEQL_HOME="$${CODEQL_TMP}/codeql"
       - export CODEQL_DB="$${CODEQL_TMP}/db"
diff --git a/.woodpecker/qa.yml b/.woodpecker/qa.yml
index cbdd6831b5..24fdf4e4da 100644
--- a/.woodpecker/qa.yml
+++ b/.woodpecker/qa.yml
@@ -41,7 +41,7 @@ steps:
           QA_MODE: usan_clang
     commands:
       - <<: *steps-env
-      - python3 $${SRCDIR}/ci/ci_need_suite.py qa; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
+      - gate_status=0; python3 $${SRCDIR}/ci/ci_need_suite.py qa || gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
       - <<: *steps-start-postgresql
       - mkdir -p "$${BUILDDIR}"
       - cd "$${BUILDDIR}"
@@ -61,7 +61,7 @@ steps:
           QA_MODE: standard_conforming_strings_off
     commands:
       - <<: *steps-env
       - cd "$${BUILDDIR}"
diff --git a/.woodpecker/regress.yml b/.woodpecker/regress.yml
index f88575c4ff..75127b45dc 100644
--- a/.woodpecker/regress.yml
+++ b/.woodpecker/regress.yml
@@ -18,7 +18,7 @@ variables:
     - . ci/start-postgresql.sh
     - psql -c 'select version()' template1
   steps-pg-build: &steps-pg-build
-    - python3 $${SRCDIR}/ci/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}" --upgrade-surface; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
+    - gate_status=0; python3 $${SRCDIR}/ci/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}" --upgrade-surface || gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
     - cd "$${BUILDDIR}"
     - $${SRCDIR}/configure
@@ -31,7 +31,7 @@ variables:
     # make graph can otherwise race generation of files such as postgis.control.
     - make -j1
   steps-pg-test-all-upgrades: &steps-pg-test-all-upgrades
     - cd "$${BUILDDIR}"
     - export CHECK_FIFO=check-$${UPGRADE_EXTENSION}.fifo
     - export CHECK_LOG=check-$${UPGRADE_EXTENSION}.log
@@ -86,7 +86,7 @@ steps:
           REGRESS_SUITE: preinstall
     commands:
       - <<: *steps-env
-      - python3 $${SRCDIR}/ci/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}"; gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
+      - gate_status=0; python3 $${SRCDIR}/ci/ci_need_suite.py "$${REGRESS_SUITE}" --target "$${REGRESS_TARGET}" --extension "$${UPGRADE_EXTENSION}" || gate_status=$$?; if test "$${gate_status}" = 78; then exit 0; elif test "$${gate_status}" != 0; then exit "$${gate_status}"; fi
       - make -C "$${BUILDDIR}" $${REGRESS_TARGET}
@@ -98,7 +98,7 @@ steps:
           REGRESS_SUITE: install
     commands:
       - <<: *steps-env
       - make -C "$${BUILDDIR}" install
@@ -111,7 +111,7 @@ steps:
           REGRESS_SUITE: extension-upgrade
     commands:
       - export SRCDIR=$${CI_WORKSPACE}
       - <<: *steps-env
       - make -C "$${BUILDDIR}" staged-install
@@ -126,7 +126,7 @@ steps:
           REGRESS_SUITE: cluster-upgrade
     commands:
       - make -C build/pg$${PGVER} install
       - make -C build/pg$${SECOND_PGVER} install
       - export PGPORT=$$((20000 + ($${CI_PIPELINE_NUMBER:-0} % 1000) * 32 + ($${CI_WORKFLOW_NUMBER:-30} % 32)))
Summary of changes:
 .woodpecker/codeql.yml  |  2 +-
 .woodpecker/qa.yml      |  4 ++--
 .woodpecker/regress.yml | 12 ++++++------
 3 files changed, 9 insertions(+), 9 deletions(-)
hooks/post-receive
