[SCM] PostGIS branch master updated. 3.7.0beta1-99-ge609ba49b4
Mon Jul 27 16:34:09 PDT 2026
the project "PostGIS".
       via  e609ba49b4faa44e0a043614ef14a748cade8452 (commit)
       via  df6700a9ca189efc3c76e9bfbf8af668c85eec74 (commit)
      from  5dde209ddc5ee4b0f3e7c8bd7dd2013dc0a75a2f (commit)
revisions in full, below.
commit e609ba49b4faa44e0a043614ef14a748cade8452
Merge: 5dde209ddc df6700a9ca
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 16:34:08 2026 -0700
    Merge pull request 'Initialize GSERIALIZED peek test fixtures' (!569) from Komzpa/postgis:fix/gserialized-peek-valgrind-tests into master
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/569
commit df6700a9ca189efc3c76e9bfbf8af668c85eec74
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 28 02:24:34 2026 +0400
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index 2c215f1e22..a4ae770561 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -1159,10 +1159,13 @@ static void test_gserialized1_peek_gbox_p_fails_for_unsupported_cases(void)
 		GSERIALIZED* gser = lwalloc(expected_size);
 		uint8_t* ptr = (uint8_t*) gser;
-		ptr += 8; // Skip header
-		gserialized1_from_lwgeom_any(geom, ptr);
+		gser->size = expected_size << 2;
+		gserialized1_set_srid(gser, geom->srid);
 		gser->gflags = lwflags_get_g1flags(geom->flags);
+		ptr += 8; /* Skip header */
+		gserialized1_from_lwgeom_any(geom, ptr);
 		CU_ASSERT_FALSE(gserialized1_has_bbox(gser));
 		CU_ASSERT_EQUAL(LW_FAILURE, gserialized1_peek_gbox_p(gser, &box));
diff --git a/liblwgeom/cunit/cu_gserialized2.c b/liblwgeom/cunit/cu_gserialized2.c
index 6ffdc5badc..44be675094 100644
--- a/liblwgeom/cunit/cu_gserialized2.c
+++ b/liblwgeom/cunit/cu_gserialized2.c
@@ -449,10 +449,13 @@ static void test_gserialized2_peek_gbox_p_fails_for_unsupported_cases(void)
-		gserialized2_from_lwgeom_any(geom, ptr);
+		LWSIZE_SET(gser->size, expected_size);
+		gserialized2_set_srid(gser, geom->srid);
 		gser->gflags = lwflags_get_g2flags(geom->flags);
+		gserialized2_from_lwgeom_any(geom, ptr);
 		CU_ASSERT_FALSE(gserialized2_has_bbox(gser));
 		CU_ASSERT_EQUAL(LW_FAILURE, gserialized2_peek_gbox_p(gser, &box));
Summary of changes:
 liblwgeom/cunit/cu_gserialized1.c | 7 +++++--
 liblwgeom/cunit/cu_gserialized2.c | 7 +++++--
 2 files changed, 10 insertions(+), 4 deletions(-)
hooks/post-receive
