[SCM] PostGIS branch master updated. 3.7.0beta1-101-gf7c211c2f1
git at osgeo.org
git at osgeo.org
Mon Jul 27 16:34:37 PDT 2026
the project "PostGIS".
via f7c211c2f14f0b74a8da35d5ef9de9bc962de4cc (commit)
via 597b988de28c4455a3861f2d522a4b9771db47d9 (commit)
from e609ba49b4faa44e0a043614ef14a748cade8452 (commit)
revisions in full, below.
commit f7c211c2f14f0b74a8da35d5ef9de9bc962de4cc
Merge: e609ba49b4 597b988de2
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 16:34:36 2026 -0700
Merge pull request 'Fix fuzzer corpus builder mkdir on Windows' (!567) from Komzpa/postgis:fix/fuzzer-seed-builder-mingw-mkdir into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/567
commit 597b988de28c4455a3861f2d522a4b9771db47d9
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jul 28 02:23:40 2026 +0400
diff --git a/fuzzers/build_gserialized_seed_corpus.cpp b/fuzzers/build_gserialized_seed_corpus.cpp
index f3fa8ef2cd..d3d374cea1 100644
--- a/fuzzers/build_gserialized_seed_corpus.cpp
+++ b/fuzzers/build_gserialized_seed_corpus.cpp
@@ -22,6 +22,10 @@
#include <sys/stat.h>
#include <sys/types.h>
+#ifdef _WIN32
+#include <direct.h>
+#endif
#include <fstream>
#include <string>
@@ -37,7 +41,15 @@ extern "C" GSERIALIZED *gserialized1_from_lwgeom(LWGEOM *geom, size_t *size);
static int
mkdir_if_needed(const std::string &path)
- if (mkdir(path.c_str(), 0777) == 0 || errno == EEXIST)
+ int result;
+#ifdef _WIN32
+ result = _mkdir(path.c_str());
+#else
+ result = mkdir(path.c_str(), 0777);
+#endif
+ if (result == 0 || errno == EEXIST)
return 1;
perror(path.c_str());
return 0;
Summary of changes:
fuzzers/build_gserialized_seed_corpus.cpp | 14 +++++++++++++-
1 file changed, 13 insertions(+), 1 deletion(-)
hooks/post-receive
