[SCM] PostGIS branch stable-3.4 updated. 3.4.6-101-gc12e912a12
Mon Jul 27 16:41:03 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
       via  c12e912a12a253032c26b4ca566e782120490cb6 (commit)
       via  8fcb3c08b403c9038301c81e2a510d849039dade (commit)
       via  7c0fdbf6b6d734e19440b37a8603908a8d7a0c89 (commit)
       via  59c1243777e011fb9e027e5108167334259a0775 (commit)
       via  54dec6a88a3d5341b4d4fcb3e4e8ff9b7188f04b (commit)
      from  ff996f11cb5e7645510394ca6233a76374a12094 (commit)
revisions in full, below.
commit c12e912a12a253032c26b4ca566e782120490cb6
Merge: ff996f11cb 8fcb3c08b4
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 16:41:02 2026 -0700
    Merge pull request 'Use GEOSSplit for ST_Split on stable 3.4' (!546) from Komzpa/postgis:codex/stsplit-geos315-stable-3.4 into stable-3.4
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/546
diff --cc NEWS
index 17e4b51e17,c9dabaddd1..890666e4ef
--- a/NEWS
+++ b/NEWS
@@@ -3,14 -3,9 +3,15 @@@ PostGIS 3.4.
  * Bug Fixes *
 +  - GT-522, Reject malformed GSERIALIZED payload counts before deserializing
 +    geometry data (Darafei Praliaskouski)
 +  - GT-523, [raster] Fix invalid reads in geotransform property access
 +    (Darafei Praliaskouski)
 +  - GT-519, Reject invalid ST_LargestEmptyCircle boundaries before GEOS can
 +    spend unbounded time on them (Darafei Praliaskouski)
    - #6094, [upgrade] Avoid legacy string literal warnings in downgrade checks
      with standard_conforming_strings off (Darafei Praliaskouski)
+   - #5916, Fix ST_Split recursion with GEOS 3.15 (Paul Ramsey)
    - #6042, Skip downgrade checks when source extension libraries cannot
             be loaded in the current dependency environment
commit 8fcb3c08b403c9038301c81e2a510d849039dade
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 28 01:23:51 2026 +0400
    NEWS: use original ST_Split reference on stable 3.4
diff --git a/NEWS b/NEWS
index e219425587..c9dabaddd1 100644
--- a/NEWS
+++ b/NEWS
@@ -5,7 +5,7 @@ PostGIS 3.4.7
-  - GT-546, Fix ST_Split recursion with GEOS 3.15 (Paul Ramsey)
commit 7c0fdbf6b6d734e19440b37a8603908a8d7a0c89
Date:   Mon Jul 27 17:10:45 2026 +0400
    regress: relax stable 3.4 buffer interrupt timing
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index 949fc7e285..5756af4e61 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -21,7 +21,7 @@ SET statement_timeout TO 100;
 select ST_Buffer(g,100) from _inputs WHERE id = 1;
 --( select (st_dumppoints(st_buffer(st_makepoint(0,0),10000,100000))).geom g) foo;
 -- it may take some more to interrupt st_buffer, see
-SELECT _timecheck('buffer', '350ms');
+SELECT _timecheck('buffer', '600ms');
 -- Not affected by old timeout
 SELECT '1', ST_NPoints(ST_Buffer('POINT(4 0)'::geometry, 2, 1));
commit 59c1243777e011fb9e027e5108167334259a0775
Date:   Mon Jul 27 05:57:35 2026 +0400
    Rerun Woodie after runner network exhaustion
commit 54dec6a88a3d5341b4d4fcb3e4e8ff9b7188f04b
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jun 30 12:05:14 2026 -0700
    Use GEOSSplit where available for ST_Split
    (cherry picked from commit 370c6a160a21d46b0768fb70ea0d75292cc475d0)
index b62241c5d9..e219425587 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,7 @@ PostGIS 3.4.7
+  - GT-546, Fix ST_Split recursion with GEOS 3.15 (Paul Ramsey)
diff --git a/liblwgeom/cunit/cu_wrapx.c b/liblwgeom/cunit/cu_wrapx.c
index a5ca09a285..cde804577e 100644
--- a/liblwgeom/cunit/cu_wrapx.c
+++ b/liblwgeom/cunit/cu_wrapx.c
@@ -83,9 +83,11 @@ static void test_lwgeom_wrapx(void)
 	lwgeom_free(tmp);
 	CU_ASSERT_FATAL(ret != NULL);
 	obt_wkt = lwgeom_to_ewkt(ret);
-	tmp = lwgeom_from_wkt(
-					"MULTILINESTRING((0 0,8 0),(-2 0,0 0))",
-					LW_PARSER_CHECK_NONE);
+#if POSTGIS_GEOS_VERSION < 31500
+	tmp = lwgeom_from_wkt("MULTILINESTRING((0 0,8 0),(-2 0,0 0))", LW_PARSER_CHECK_NONE);
+#else
+	tmp = lwgeom_from_wkt("LINESTRING(-2 0,0 0,8 0)", LW_PARSER_CHECK_NONE);
+#endif
 	tmp2 = lwgeom_normalize(tmp);
 	lwgeom_free(tmp);
 	exp_wkt = lwgeom_to_ewkt(tmp2);
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index 3dba1d06dd..f8363c966b 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -111,13 +111,23 @@ lwline_split_by_line(const LWLINE* lwline_in, const LWGEOM* blade_in)
 		return NULL;
-	gdiff = GEOSDifference(g1,g2);
+#if POSTGIS_GEOS_VERSION >= 31500
+	/* GEOS 3.15 added an explicit splitter. Older GEOS relies on the
+	 * side-effect of GEOSDifference returning the input split at the
+	 * crossing points of the (non-overlapping) blade. */
+	gdiff = GEOSSplit(g1, g2);
+#else
+	gdiff = GEOSDifference(g1, g2);
+#endif
 	GEOSGeom_destroy(g1);
 	GEOSGeom_destroy(g2);
 	if (gdiff == NULL)
+		lwerror("GEOSSplit: %s", lwgeom_geos_errmsg);
+#else
 		lwerror("GEOSDifference: %s", lwgeom_geos_errmsg);
+#endif
 		return NULL;
@@ -353,6 +363,68 @@ lwline_split(const LWLINE* lwline_in, const LWGEOM* blade_in)
 static LWGEOM*
 lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
+	/* GEOS 3.15 splits polygons directly, filtering out the pieces that
+	 * fall inside holes for us. On older GEOS we reproduce that logic by
+	 * polygonizing the boundary unioned with the blade and discarding the
+	 * pieces whose point-on-surface is not contained by the input (#else). */
+	LWGEOM *split;
+	LWCOLLECTION *out;
+	GEOSGeometry *g1;
+	GEOSGeometry *g2;
+	GEOSGeometry *gsplit;
+	int hasZ = FLAGS_GET_Z(lwpoly_in->flags);
+	initGEOS(lwgeom_geos_error, lwgeom_geos_error);
+	g1 = LWGEOM2GEOS((LWGEOM *)lwpoly_in, 0);
+	if (NULL == g1)
+		lwerror("LWGEOM2GEOS: %s", lwgeom_geos_errmsg);
+		return NULL;
+	g2 = LWGEOM2GEOS(blade_in, 0);
+	if (NULL == g2)
+		GEOSGeom_destroy(g1);
+		return NULL;
+	gsplit = GEOSSplit(g1, g2);
+	GEOSGeom_destroy(g2);
+	if (NULL == gsplit)
+		return NULL;
+	split = GEOS2LWGEOM(gsplit, hasZ);
+	GEOSGeom_destroy(gsplit);
+	if (NULL == split)
+		lwerror("GEOS2LWGEOM: %s", lwgeom_geos_errmsg);
+		return NULL;
+	/* GEOSSplit always returns a collection, but wrap defensively */
+	out = lwgeom_as_lwcollection(split);
+	if (!out)
+		LWGEOM **components = lwalloc(sizeof(LWGEOM *));
+		components[0] = split;
+		out = lwcollection_construct(COLLECTIONTYPE, lwpoly_in->srid, NULL, 1, components);
+	else
+		lwgeom_set_srid((LWGEOM *)out, lwpoly_in->srid);
+		out->type = COLLECTIONTYPE;
+	return (LWGEOM *)out;
+#else
 	LWCOLLECTION* out;
 	GEOSGeometry* g1;
 	GEOSGeometry* g2;
@@ -491,6 +563,7 @@ lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
 	GEOSGeom_destroy(polygons);
 	return (LWGEOM*)out;
+#endif /* POSTGIS_GEOS_VERSION >= 31500 */
 static LWGEOM*
Summary of changes:
 NEWS                              |  1 +
 liblwgeom/cunit/cu_wrapx.c        |  8 ++--
 liblwgeom/lwgeom_geos_split.c     | 77 ++++++++++++++++++++++++++++++++++++++-
 regress/core/interrupt_buffer.sql |  2 +-
 4 files changed, 82 insertions(+), 6 deletions(-)
hooks/post-receive
