[SCM] PostGIS branch stable-3.3 updated. 3.3.10-99-g1928f0a1bf
git at osgeo.org
git at osgeo.org
Mon Jul 27 16:41:14 PDT 2026
the project "PostGIS".
The branch, stable-3.3 has been updated
via 1928f0a1bf0b818585a355102f74224698fe3a6a (commit)
via 576de179abca6a601eb37db960e82b6e403c526d (commit)
via 6a0c5aeada44f49ec6cab7190b119cd886757246 (commit)
via 84b3358ade193097c197a96f5772d6b403709721 (commit)
from 0203ccda5302c1f129589b654652767fd71b8bc9 (commit)
revisions in full, below.
commit 1928f0a1bf0b818585a355102f74224698fe3a6a
Merge: 0203ccda53 576de179ab
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 16:41:12 2026 -0700
Merge pull request 'Use GEOSSplit for ST_Split on stable 3.3' (!547) from Komzpa/postgis:codex/stsplit-geos315-stable-3.3 into stable-3.3
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/547
commit 576de179abca6a601eb37db960e82b6e403c526d
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jul 28 01:24:04 2026 +0400
NEWS: use original ST_Split reference on stable 3.3
diff --git a/NEWS b/NEWS
index c4bd746cbd..60c37d68ac 100644
--- a/NEWS
+++ b/NEWS
@@ -8,7 +8,7 @@ PostGIS 3.3.11
(Regina Obe)
- #6094, [upgrade] Avoid legacy string literal warnings in downgrade checks
with standard_conforming_strings off (Darafei Praliaskouski)
- - GT-547, Fix ST_Split recursion with GEOS 3.15 (Paul Ramsey)
+ - #5916, Fix ST_Split recursion with GEOS 3.15 (Paul Ramsey)
- Flatgeobuf schema mismatch vulnerability (NeuroWinter)
- #5899, pg_upgrade issue for non-standard geography SRID (Paul Ramsey)
- #5916, ST_Split hang with very large ordinates (Paul Ramsey)
commit 6a0c5aeada44f49ec6cab7190b119cd886757246
Date: Mon Jul 27 05:57:41 2026 +0400
Rerun Woodie after runner network exhaustion
commit 84b3358ade193097c197a96f5772d6b403709721
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date: Tue Jun 30 12:05:14 2026 -0700
Use GEOSSplit where available for ST_Split
(cherry picked from commit 370c6a160a21d46b0768fb70ea0d75292cc475d0)
index 48bd45c034..c4bd746cbd 100644
--- a/NEWS
+++ b/NEWS
@@ -8,6 +8,7 @@ PostGIS 3.3.11
(Regina Obe)
+ - GT-547, Fix ST_Split recursion with GEOS 3.15 (Paul Ramsey)
diff --git a/liblwgeom/cunit/cu_wrapx.c b/liblwgeom/cunit/cu_wrapx.c
index a5ca09a285..cde804577e 100644
--- a/liblwgeom/cunit/cu_wrapx.c
+++ b/liblwgeom/cunit/cu_wrapx.c
@@ -83,9 +83,11 @@ static void test_lwgeom_wrapx(void)
lwgeom_free(tmp);
CU_ASSERT_FATAL(ret != NULL);
obt_wkt = lwgeom_to_ewkt(ret);
- tmp = lwgeom_from_wkt(
- "MULTILINESTRING((0 0,8 0),(-2 0,0 0))",
- LW_PARSER_CHECK_NONE);
+#if POSTGIS_GEOS_VERSION < 31500
+ tmp = lwgeom_from_wkt("MULTILINESTRING((0 0,8 0),(-2 0,0 0))", LW_PARSER_CHECK_NONE);
+#else
+ tmp = lwgeom_from_wkt("LINESTRING(-2 0,0 0,8 0)", LW_PARSER_CHECK_NONE);
+#endif
tmp2 = lwgeom_normalize(tmp);
lwgeom_free(tmp);
exp_wkt = lwgeom_to_ewkt(tmp2);
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index 3dba1d06dd..f8363c966b 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -111,13 +111,23 @@ lwline_split_by_line(const LWLINE* lwline_in, const LWGEOM* blade_in)
return NULL;
- gdiff = GEOSDifference(g1,g2);
+#if POSTGIS_GEOS_VERSION >= 31500
+ /* GEOS 3.15 added an explicit splitter. Older GEOS relies on the
+ * side-effect of GEOSDifference returning the input split at the
+ * crossing points of the (non-overlapping) blade. */
+ gdiff = GEOSSplit(g1, g2);
+#else
+ gdiff = GEOSDifference(g1, g2);
+#endif
GEOSGeom_destroy(g1);
GEOSGeom_destroy(g2);
if (gdiff == NULL)
+ lwerror("GEOSSplit: %s", lwgeom_geos_errmsg);
+#else
lwerror("GEOSDifference: %s", lwgeom_geos_errmsg);
+#endif
return NULL;
@@ -353,6 +363,68 @@ lwline_split(const LWLINE* lwline_in, const LWGEOM* blade_in)
static LWGEOM*
lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
+ /* GEOS 3.15 splits polygons directly, filtering out the pieces that
+ * fall inside holes for us. On older GEOS we reproduce that logic by
+ * polygonizing the boundary unioned with the blade and discarding the
+ * pieces whose point-on-surface is not contained by the input (#else). */
+ LWGEOM *split;
+ LWCOLLECTION *out;
+ GEOSGeometry *g1;
+ GEOSGeometry *g2;
+ GEOSGeometry *gsplit;
+ int hasZ = FLAGS_GET_Z(lwpoly_in->flags);
+ initGEOS(lwgeom_geos_error, lwgeom_geos_error);
+ g1 = LWGEOM2GEOS((LWGEOM *)lwpoly_in, 0);
+ if (NULL == g1)
+ lwerror("LWGEOM2GEOS: %s", lwgeom_geos_errmsg);
+ return NULL;
+ g2 = LWGEOM2GEOS(blade_in, 0);
+ if (NULL == g2)
+ GEOSGeom_destroy(g1);
+ return NULL;
+ gsplit = GEOSSplit(g1, g2);
+ GEOSGeom_destroy(g2);
+ if (NULL == gsplit)
+ return NULL;
+ split = GEOS2LWGEOM(gsplit, hasZ);
+ GEOSGeom_destroy(gsplit);
+ if (NULL == split)
+ lwerror("GEOS2LWGEOM: %s", lwgeom_geos_errmsg);
+ return NULL;
+ /* GEOSSplit always returns a collection, but wrap defensively */
+ out = lwgeom_as_lwcollection(split);
+ if (!out)
+ LWGEOM **components = lwalloc(sizeof(LWGEOM *));
+ components[0] = split;
+ out = lwcollection_construct(COLLECTIONTYPE, lwpoly_in->srid, NULL, 1, components);
+ else
+ lwgeom_set_srid((LWGEOM *)out, lwpoly_in->srid);
+ out->type = COLLECTIONTYPE;
+ return (LWGEOM *)out;
+#else
LWCOLLECTION* out;
GEOSGeometry* g1;
GEOSGeometry* g2;
@@ -491,6 +563,7 @@ lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
GEOSGeom_destroy(polygons);
return (LWGEOM*)out;
+#endif /* POSTGIS_GEOS_VERSION >= 31500 */
static LWGEOM*
Summary of changes:
NEWS | 1 +
liblwgeom/cunit/cu_wrapx.c | 8 +++--
liblwgeom/lwgeom_geos_split.c | 77 +++++++++++++++++++++++++++++++++++++++++--
3 files changed, 81 insertions(+), 5 deletions(-)
hooks/post-receive
