[SCM] PostGIS branch stable-3.2 updated. 3.2.10-91-g4532c8359d
Mon Jul 27 16:41:31 PDT 2026
the project "PostGIS".
The branch, stable-3.2 has been updated
       via  4532c8359dafc46578eed7805b21934e7466f0e5 (commit)
       via  51aa8b3219954a889a004df789195fbb45ef75e1 (commit)
       via  8bb569d4b2ec5994bf74803f86037abba893051d (commit)
       via  4dc85a753bfde50331e82afa4fa891feda2cdc33 (commit)
      from  9f9b53dedc8d3b21ca4da135acf95a50182f3f39 (commit)
revisions in full, below.
commit 4532c8359dafc46578eed7805b21934e7466f0e5
Merge: 9f9b53dedc 51aa8b3219
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 16:41:29 2026 -0700
    Merge pull request 'Use GEOSSplit for ST_Split on stable 3.2' (!548) from Komzpa/postgis:codex/stsplit-geos315-stable-3.2 into stable-3.2
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/548
diff --cc NEWS
index 6eb559d0b3,ff9b0345dc..39ee48a6c7
--- a/NEWS
+++ b/NEWS
@@@ -3,12 -3,9 +3,13 @@@ PostGIS 3.2.1
  * Bug Fixes *
 + - GT-522, Reject malformed GSERIALIZED payload counts before deserializing
 +   geometry data (Darafei Praliaskouski)
 + - GT-523, [raster] Fix invalid reads in geotransform property access
 +   (Darafei Praliaskouski)
   - #6094, [upgrade] Avoid legacy string literal warnings in downgrade checks
     with standard_conforming_strings off (Darafei Praliaskouski)
+  - #5916, Fix ST_Split recursion with GEOS 3.15 (Paul Ramsey)
   - [upgrade] Fix ST_TileEnvelope upgrade marker syntax
   - #5899, pg_upgrade issue for non-standard geography SRID (Paul Ramsey)
commit 51aa8b3219954a889a004df789195fbb45ef75e1
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 28 01:24:20 2026 +0400
    NEWS: use original ST_Split reference on stable 3.2
diff --git a/NEWS b/NEWS
index 4975d6a512..ff9b0345dc 100644
--- a/NEWS
+++ b/NEWS
@@ -5,7 +5,7 @@ PostGIS 3.2.11
- - GT-548, Fix ST_Split recursion with GEOS 3.15 (Paul Ramsey)
commit 8bb569d4b2ec5994bf74803f86037abba893051d
Date:   Mon Jul 27 05:57:48 2026 +0400
    Rerun Woodie after runner network exhaustion
commit 4dc85a753bfde50331e82afa4fa891feda2cdc33
Author: Paul Ramsey <pramsey at cleverelephant.ca>
Date:   Tue Jun 30 12:05:14 2026 -0700
    Use GEOSSplit where available for ST_Split
    (cherry picked from commit 370c6a160a21d46b0768fb70ea0d75292cc475d0)
index 6c6396e6d9..4975d6a512 100644
--- a/NEWS
+++ b/NEWS
@@ -5,6 +5,7 @@ PostGIS 3.2.11
+ - GT-548, Fix ST_Split recursion with GEOS 3.15 (Paul Ramsey)
diff --git a/liblwgeom/cunit/cu_wrapx.c b/liblwgeom/cunit/cu_wrapx.c
index a5ca09a285..cde804577e 100644
--- a/liblwgeom/cunit/cu_wrapx.c
+++ b/liblwgeom/cunit/cu_wrapx.c
@@ -83,9 +83,11 @@ static void test_lwgeom_wrapx(void)
 	lwgeom_free(tmp);
 	CU_ASSERT_FATAL(ret != NULL);
 	obt_wkt = lwgeom_to_ewkt(ret);
-	tmp = lwgeom_from_wkt(
-					"MULTILINESTRING((0 0,8 0),(-2 0,0 0))",
-					LW_PARSER_CHECK_NONE);
+#if POSTGIS_GEOS_VERSION < 31500
+	tmp = lwgeom_from_wkt("MULTILINESTRING((0 0,8 0),(-2 0,0 0))", LW_PARSER_CHECK_NONE);
+#else
+	tmp = lwgeom_from_wkt("LINESTRING(-2 0,0 0,8 0)", LW_PARSER_CHECK_NONE);
+#endif
 	tmp2 = lwgeom_normalize(tmp);
 	lwgeom_free(tmp);
 	exp_wkt = lwgeom_to_ewkt(tmp2);
diff --git a/liblwgeom/lwgeom_geos_split.c b/liblwgeom/lwgeom_geos_split.c
index 5592492af9..b41a4946c4 100644
--- a/liblwgeom/lwgeom_geos_split.c
+++ b/liblwgeom/lwgeom_geos_split.c
@@ -111,13 +111,23 @@ lwline_split_by_line(const LWLINE* lwline_in, const LWGEOM* blade_in)
 		return NULL;
-	gdiff = GEOSDifference(g1,g2);
+#if POSTGIS_GEOS_VERSION >= 31500
+	/* GEOS 3.15 added an explicit splitter. Older GEOS relies on the
+	 * side-effect of GEOSDifference returning the input split at the
+	 * crossing points of the (non-overlapping) blade. */
+	gdiff = GEOSSplit(g1, g2);
+#else
+	gdiff = GEOSDifference(g1, g2);
+#endif
 	GEOSGeom_destroy(g1);
 	GEOSGeom_destroy(g2);
 	if (gdiff == NULL)
+		lwerror("GEOSSplit: %s", lwgeom_geos_errmsg);
+#else
 		lwerror("GEOSDifference: %s", lwgeom_geos_errmsg);
+#endif
 		return NULL;
@@ -353,6 +363,68 @@ lwline_split(const LWLINE* lwline_in, const LWGEOM* blade_in)
 static LWGEOM*
 lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
+	/* GEOS 3.15 splits polygons directly, filtering out the pieces that
+	 * fall inside holes for us. On older GEOS we reproduce that logic by
+	 * polygonizing the boundary unioned with the blade and discarding the
+	 * pieces whose point-on-surface is not contained by the input (#else). */
+	LWGEOM *split;
+	LWCOLLECTION *out;
+	GEOSGeometry *g1;
+	GEOSGeometry *g2;
+	GEOSGeometry *gsplit;
+	int hasZ = FLAGS_GET_Z(lwpoly_in->flags);
+	initGEOS(lwgeom_geos_error, lwgeom_geos_error);
+	g1 = LWGEOM2GEOS((LWGEOM *)lwpoly_in, 0);
+	if (NULL == g1)
+		lwerror("LWGEOM2GEOS: %s", lwgeom_geos_errmsg);
+		return NULL;
+	g2 = LWGEOM2GEOS(blade_in, 0);
+	if (NULL == g2)
+		GEOSGeom_destroy(g1);
+		return NULL;
+	gsplit = GEOSSplit(g1, g2);
+	GEOSGeom_destroy(g2);
+	if (NULL == gsplit)
+		return NULL;
+	split = GEOS2LWGEOM(gsplit, hasZ);
+	GEOSGeom_destroy(gsplit);
+	if (NULL == split)
+		lwerror("GEOS2LWGEOM: %s", lwgeom_geos_errmsg);
+		return NULL;
+	/* GEOSSplit always returns a collection, but wrap defensively */
+	out = lwgeom_as_lwcollection(split);
+	if (!out)
+		LWGEOM **components = lwalloc(sizeof(LWGEOM *));
+		components[0] = split;
+		out = lwcollection_construct(COLLECTIONTYPE, lwpoly_in->srid, NULL, 1, components);
+	else
+		lwgeom_set_srid((LWGEOM *)out, lwpoly_in->srid);
+		out->type = COLLECTIONTYPE;
+	return (LWGEOM *)out;
+#else
 	LWCOLLECTION* out;
 	GEOSGeometry* g1;
 	GEOSGeometry* g2;
@@ -491,6 +563,7 @@ lwpoly_split_by_line(const LWPOLY* lwpoly_in, const LWGEOM* blade_in)
 	GEOSGeom_destroy(polygons);
 	return (LWGEOM*)out;
+#endif /* POSTGIS_GEOS_VERSION >= 31500 */
 static LWGEOM*
Summary of changes:
 NEWS                          |  1 +
 liblwgeom/cunit/cu_wrapx.c    |  8 +++--
 liblwgeom/lwgeom_geos_split.c | 77 +++++++++++++++++++++++++++++++++++++++++--
 3 files changed, 81 insertions(+), 5 deletions(-)
hooks/post-receive
