[SCM] PostGIS branch master updated. 3.7.0beta1-103-g5e47d8c16f
git at osgeo.org
git at osgeo.org
Mon Jul 27 16:42:31 PDT 2026
the project "PostGIS".
via 5e47d8c16f78442f9a2c7fbb8953a3c89da6a4a2 (commit)
via 876b42753d19dfe7ab2c684db7801f2908e89e3c (commit)
from f7c211c2f14f0b74a8da35d5ef9de9bc962de4cc (commit)
revisions in full, below.
commit 5e47d8c16f78442f9a2c7fbb8953a3c89da6a4a2
Merge: f7c211c2f1 876b42753d
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 16:42:30 2026 -0700
Merge pull request 'Fix ST_MakePolygon with NULL holes' (!564) from Komzpa/postgis:fix/makepolygon-null-holes-master into master
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/564
commit 876b42753d19dfe7ab2c684db7801f2908e89e3c
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jul 28 01:47:19 2026 +0400
diff --git a/NEWS b/NEWS
index 089d6dc770..43aa95bd86 100644
--- a/NEWS
+++ b/NEWS
@@ -20,6 +20,8 @@ These are only changes since 3.7.0beta1.
(Arthur Bazin)
- GT-521, Reject malformed GSERIALIZED payload counts before deserializing
geometry data (Darafei Praliaskouski)
+ - GT-564, Avoid ST_MakePolygon failures with NULL hole array entries
+ (Darafei Praliaskouski)
* Enhancements *
diff --git a/postgis/lwgeom_functions_basic.c b/postgis/lwgeom_functions_basic.c
index f12b04b5c1..3c46eb9d1a 100644
--- a/postgis/lwgeom_functions_basic.c
+++ b/postgis/lwgeom_functions_basic.c
@@ -1583,8 +1583,8 @@ Datum LWGEOM_makepoly(PG_FUNCTION_ARGS)
LWPOLY *outpoly;
LWCURVEPOLY *outcurvepoly;
uint32 nholes = 0;
+ uint32 nitems = 0;
uint32 i;
- size_t offset = 0;
int has_curve_ring = LW_FALSE;
int32_t srid;
int has_z;
@@ -1607,31 +1607,34 @@ Datum LWGEOM_makepoly(PG_FUNCTION_ARGS)
/* Get input holes if any */
if (PG_NARGS() > 1)
+ ArrayIterator iterator;
+ Datum value;
+ bool isnull;
array = PG_GETARG_ARRAYTYPE_P(1);
- nholes = ArrayGetNItems(ARR_NDIM(array), ARR_DIMS(array));
- rings = lwalloc(sizeof(LWGEOM *) * (nholes + 1));
- holes = lwalloc(sizeof(LWLINE *) * nholes);
- for (i = 0; i < nholes; i++)
+ nitems = ArrayGetNItems(ARR_NDIM(array), ARR_DIMS(array));
+ rings = lwalloc(sizeof(LWGEOM *) * (nitems + 1));
+ holes = lwalloc(sizeof(LWLINE *) * nitems);
+ iterator = array_create_iterator(array, 0, NULL);
+ while (array_iterate(iterator, &value, &isnull))
-#if __GNUC__ > 4 || (__GNUC__ == 4 && __GNUC_MINOR__ >= 6)
-#pragma GCC diagnostic push
-#pragma GCC diagnostic ignored "-Wsign-compare"
-#endif
- GSERIALIZED *g = (GSERIALIZED *)(ARR_DATA_PTR(array) + offset);
-#pragma GCC diagnostic pop
-#endif
+ GSERIALIZED *g;
LWGEOM *hole;
- offset += INTALIGN(VARSIZE(g));
+ if (isnull)
+ continue;
+ g = (GSERIALIZED *)DatumGetPointer(value);
if (!lwgeom_is_makepoly_ring_type(gserialized_get_type(g)))
- lwpgerror("Hole %d is not a line", i);
+ lwpgerror("Hole %d is not a line", nholes);
hole = lwgeom_from_gserialized(g);
has_curve_ring |= hole->type != LINETYPE;
- rings[i + 1] = hole;
- holes[i] = lwgeom_as_lwline(hole);
+ rings[nholes + 1] = hole;
+ holes[nholes++] = lwgeom_as_lwline(hole);
+ array_free_iterator(iterator);
if (has_curve_ring)
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index dd22ce5a04..fd03131cee 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1808,3 +1808,8 @@ DROP TABLE IF EXISTS fault6028;
-- #5357
SELECT '#5357', ST_AsText(ST_LineFromEncodedPolyline('__nphBgcoeiA?@', 6), 6);
+-- ST_MakePolygon with NULL holes
+SELECT 'makepolygon-null-holes', ST_NPoints(ST_MakePolygon(
+ 'LINESTRING ZM (0 0 0 0,0 1 0 0,1 1 0 0,0 0 0 0)'::geometry,
+ ARRAY[NULL::geometry]));
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index c580547f4c..f6b6ec305c 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -525,3 +525,4 @@ public|test5978|shape|2|4326|POINT
#5938|1FF00F212|t
1|01030000209713000000000000
#5357|LINESTRING(38.903876 55.336448,38.903875 55.336448)
+makepolygon-null-holes|4
Summary of changes:
NEWS | 2 ++
postgis/lwgeom_functions_basic.c | 37 ++++++++++++++++++++-----------------
regress/core/tickets.sql | 5 +++++
regress/core/tickets_expected | 1 +
4 files changed, 28 insertions(+), 17 deletions(-)
hooks/post-receive
