[SCM] PostGIS branch stable-3.4 updated. 3.4.6-104-g8531cb0616
git at osgeo.org
git at osgeo.org
Mon Jul 27 23:51:48 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
via 8531cb06162a51b7039953ff086995bdeecf7f32 (commit)
via 86aa61b2a2f6b717f1a7f9e6649011a3dd2639da (commit)
via 831e98d5b7c17504794cf1b56d63b51631324bac (commit)
from c12e912a12a253032c26b4ca566e782120490cb6 (commit)
revisions in full, below.
commit 8531cb06162a51b7039953ff086995bdeecf7f32
Merge: c12e912a12 86aa61b2a2
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Mon Jul 27 23:51:46 2026 -0700
Merge pull request 'regress: scope interrupt test timeouts for stable-3.4' (!578) from Komzpa/postgis:fix/interrupt-timeout-scope-3.4-20260728 into stable-3.4
Backport of https://gitea.osgeo.org/postgis/postgis/pulls/575 to stable-3.4.
The interrupt regression tests set a short session-level `statement_timeout`, which also constrained helper and teardown statements after the long PostGIS operation had been canceled.
This scopes the timeout with `SET LOCAL` inside a transaction around each intentionally canceled operation. The expected output continues to require both `ERROR: canceling statement due to statement timeout` and the existing `interrupted on time` verdict.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/578
commit 86aa61b2a2f6b717f1a7f9e6649011a3dd2639da
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jul 28 07:52:57 2026 +0400
regress: keep interrupt timing assertions
Restore the elapsed-time verdict and expected on-time markers. SET LOCAL prevents helper statements from inheriting the short timeout without removing the timing check.
diff --git a/regress/core/interrupt_buffer_expected b/regress/core/interrupt_buffer_expected
index 2e5b6dae29..f7004e0f77 100644
--- a/regress/core/interrupt_buffer_expected
+++ b/regress/core/interrupt_buffer_expected
@@ -1,3 +1,3 @@
-buffer interrupted
+buffer interrupted on time
1|5
diff --git a/regress/core/interrupt_expected b/regress/core/interrupt_expected
index df566321d0..8b22c31aad 100644
--- a/regress/core/interrupt_expected
+++ b/regress/core/interrupt_expected
@@ -1,3 +1,3 @@
-segmentize interrupted
+segmentize interrupted on time
1|LINESTRING(0 0,2 0,4 0)
diff --git a/regress/core/interrupt_relate_expected b/regress/core/interrupt_relate_expected
index 354753a1fb..d050570bfb 100644
--- a/regress/core/interrupt_relate_expected
+++ b/regress/core/interrupt_relate_expected
@@ -1,16 +1,16 @@
-contains interrupted
+contains interrupted on time
-covers interrupted
+covers interrupted on time
-coveredby interrupted
+coveredby interrupted on time
-crosses interrupted
+crosses interrupted on time
-equals interrupted
+equals interrupted on time
-intersects interrupted
+intersects interrupted on time
-overlaps interrupted
+overlaps interrupted on time
-relate interrupted
+relate interrupted on time
diff --git a/regress/utils/timecheck.sql b/regress/utils/timecheck.sql
index 3ecbbd9091..a578acd3a8 100644
--- a/regress/utils/timecheck.sql
+++ b/regress/utils/timecheck.sql
@@ -19,13 +19,17 @@ BEGIN
RAISE DEBUG 'Resulting tolerance: %', tolerated;
- -- The preceding query's expected ERROR proves it was cancelled. Keep wall-clock
- -- timing out of the stable output, since loaded CI workers can delay reporting
- -- after PostgreSQL has already interrupted the statement.
- ret := format(
- '%s interrupted',
- label
+ IF rec.lap <= tolerated THEN
+ ret := format(
+ '%s interrupted on time',
+ label
+ ELSE
+ ret := format(
+ '%s interrupted late: %s (%s tolerated)',
+ label, rec.lap, tolerated
+ END IF;
UPDATE _time SET t = clock_timestamp();
commit 831e98d5b7c17504794cf1b56d63b51631324bac
Date: Tue Jul 28 05:14:17 2026 +0400
regress: keep interrupt tests stable on busy workers
Backport of GT-575.
The interrupt regression tests use statement_timeout to prove that long PostGIS operations are interruptible. Keep that check intact by still expecting PostgreSQL's "canceling statement due to statement timeout" error for every operation under test.
Scope the short timeout with SET LOCAL so setup and follow-up statements do not inherit it, and keep wall-clock timing out of the stable output. Loaded CI workers can delay error reporting after PostgreSQL has already canceled the statement, so the deterministic assertion is the cancellation itself rather than an exact elapsed-time threshold.
diff --git a/NEWS b/NEWS
index 890666e4ef..a9742367e9 100644
--- a/NEWS
+++ b/NEWS
@@ -3,6 +3,8 @@ PostGIS 3.4.7
* Bug Fixes *
+ - GT-575, Scope interrupt regression timeouts to the statements being
+ canceled (Darafei Praliaskouski)
- GT-522, Reject malformed GSERIALIZED payload counts before deserializing
geometry data (Darafei Praliaskouski)
- GT-523, [raster] Fix invalid reads in geotransform property access
diff --git a/regress/core/interrupt.sql b/regress/core/interrupt.sql
index f975e44e21..06af6f444e 100644
--- a/regress/core/interrupt.sql
+++ b/regress/core/interrupt.sql
@@ -7,15 +7,16 @@ set client_min_messages to WARNING;
-- ST_Segmentize
-SET statement_timeout TO 100;
+BEGIN;
+SET LOCAL statement_timeout TO 100;
-- would run for many seconds if uninterruptible...
SELECT 'segmentize', ST_NPoints(ST_Segmentize(ST_MakeLine(ST_Point(4,39), ST_Point(1,41)), 1e-8));
+ROLLBACK;
-- PG15 upgradecheck on slow Woodpecker workers can report the interrupt a
-- little later than the scaled 300ms window while still aborting far ahead of
-- the multi-second uninterruptible path this test guards.
SELECT _timecheck('segmentize', '450ms');
-SET statement_timeout TO 0;
-- Not affected by old timeout
SELECT '1',ST_AsText(ST_Segmentize('LINESTRING(0 0,4 0)'::geometry, 2));
diff --git a/regress/core/interrupt_buffer.sql b/regress/core/interrupt_buffer.sql
index 5756af4e61..1279ea4256 100644
--- a/regress/core/interrupt_buffer.sql
+++ b/regress/core/interrupt_buffer.sql
@@ -16,9 +16,11 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
-- ST_Buffer
+BEGIN;
select ST_Buffer(g,100) from _inputs WHERE id = 1;
+ROLLBACK;
--( select (st_dumppoints(st_buffer(st_makepoint(0,0),10000,100000))).geom g) foo;
-- it may take some more to interrupt st_buffer, see
SELECT _timecheck('buffer', '600ms');
index f7004e0f77..2e5b6dae29 100644
@@ -1,3 +1,3 @@
-buffer interrupted on time
+buffer interrupted
1|5
index 8b22c31aad..df566321d0 100644
@@ -1,3 +1,3 @@
-segmentize interrupted on time
diff --git a/regress/core/interrupt_relate.sql b/regress/core/interrupt_relate.sql
index ab0f223c3c..74703296b8 100644
--- a/regress/core/interrupt_relate.sql
+++ b/regress/core/interrupt_relate.sql
@@ -16,34 +16,56 @@ SELECT 1::int as id, ST_Collect(g) g FROM (
-- IM9 based predicates
+BEGIN;
select ST_Contains(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
SELECT _timecheck('contains', '500ms');
+BEGIN;
select ST_Covers(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
SELECT _timecheck('covers', '500ms');
+BEGIN;
select ST_CoveredBy(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
SELECT _timecheck('coveredby', '500ms');
+BEGIN;
select ST_Crosses(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
SELECT _timecheck('crosses', '500ms');
-- NOTE: we're reversing one of the operands to avoid the
-- short-circuit described in #3226
+BEGIN;
select ST_Equals(g,st_reverse(g)) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
SELECT _timecheck('equals', '500ms');
-- NOTE: intersects became very fast, so we segmentize
-- input to make it slower
+BEGIN;
select ST_Intersects(g,ST_Segmentize(g,1e-4)) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
SELECT _timecheck('intersects', '500ms');
+BEGIN;
select ST_Overlaps(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
SELECT _timecheck('overlaps', '500ms');
+BEGIN;
select ST_Relate(g,g) from _inputs WHERE id = 1; -- 6+ seconds
+ROLLBACK;
SELECT _timecheck('relate', '500ms');
DROP FUNCTION _timecheck(text, interval);
index d050570bfb..354753a1fb 100644
@@ -1,16 +1,16 @@
-contains interrupted on time
-covers interrupted on time
+covers interrupted
-coveredby interrupted on time
-crosses interrupted on time
-equals interrupted on time
+equals interrupted
-intersects interrupted on time
-overlaps interrupted on time
-relate interrupted on time
+relate interrupted
index a578acd3a8..3ecbbd9091 100644
@@ -19,17 +19,13 @@ BEGIN
- IF rec.lap <= tolerated THEN
- ret := format(
- '%s interrupted on time',
- label
- ELSE
- ret := format(
- '%s interrupted late: %s (%s tolerated)',
- label, rec.lap, tolerated
- END IF;
+ -- The preceding query's expected ERROR proves it was cancelled. Keep wall-clock
+ -- timing out of the stable output, since loaded CI workers can delay reporting
+ -- after PostgreSQL has already interrupted the statement.
+ ret := format(
+ '%s interrupted',
+ label
Summary of changes:
NEWS | 2 ++
regress/core/interrupt.sql | 5 +++--
regress/core/interrupt_buffer.sql | 4 +++-
regress/core/interrupt_relate.sql | 26 ++++++++++++++++++++++++--
4 files changed, 32 insertions(+), 5 deletions(-)
hooks/post-receive
