[SCM] PostGIS branch master updated. 3.7.0beta1-116-gbad06afc2b
Mon Jul 27 23:52:48 PDT 2026
the project "PostGIS".
       via  bad06afc2b7e21631b55765d159c24a08c68c51f (commit)
       via  31c435e1d4b7ac8095796e037dda599ee62aaaac (commit)
      from  8cd5f6a7e670fcd7e37f7887f3b619de33ef85f1 (commit)
revisions in full, below.
commit bad06afc2b7e21631b55765d159c24a08c68c51f
Merge: 8cd5f6a7e6 31c435e1d4
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date:   Mon Jul 27 23:52:47 2026 -0700
    Merge pull request 'ci: install parser generators for armhf portability' (!583) from Komzpa/postgis:codex/armhf-portability-builddeps into master
    The armhf portability job can rebuild generated parser sources when checkout timestamps make the grammar newer than the committed C file. Its foreign Debian dependency block did not install yacc-compatible parser generators, so that path failed before compilation with `No yacc found, cannot build parser`.
    Install bison and flex in the shared foreign-image preparation block so armhf and s390x portability jobs carry the same source-generation tools wherever they land.
    Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/583
commit 31c435e1d4b7ac8095796e037dda599ee62aaaac
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Tue Jul 28 07:47:34 2026 +0400
diff --git a/.woodpecker/portability.yml b/.woodpecker/portability.yml
index 2a68a7df3e..be156cec1f 100644
--- a/.woodpecker/portability.yml
+++ b/.woodpecker/portability.yml
@@ -32,6 +32,7 @@ variables:
     apt-get update
     apt-get install -y --no-install-recommends \
       autoconf automake libtool build-essential ca-certificates pkg-config \
+      bison flex \
       postgresql postgresql-server-dev-all \
       libcunit1-dev libgeos-dev libproj-dev libgdal-dev libjson-c-dev \
       libprotobuf-c-dev protobuf-c-compiler libxml2-dev gettext zlib1g-dev
Summary of changes:
 .woodpecker/portability.yml | 1 +
 1 file changed, 1 insertion(+)
hooks/post-receive
