[SCM] PostGIS branch master updated. 3.7.0beta1-123-g37ee184bfb
Tue Jul 28 02:39:16 PDT 2026
the project "PostGIS".
       via  37ee184bfb85bc02d4839fc0a7c296171614d7ac (commit)
      from  124f43a0a0d28052b7ccc398dd9915a91c4906f0 (commit)
revisions in full, below.
commit 37ee184bfb85bc02d4839fc0a7c296171614d7ac
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date:   Tue Jul 28 07:48:28 2026 +0000
    Translated PostGIS Manual using Weblate (Japanese)
    Currently translated at 88.0% (5267 of 5981 strings)
    Translation: postgis/PostGIS Manual
    Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index 0e5a590ded..bc4d9fdf00 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
 "Project-Id-Version: postgis 3.5\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
 "POT-Creation-Date: 2026-07-20 08:06+0000\n"
-"PO-Revision-Date: 2026-07-27 02:18+0000\n"
+"PO-Revision-Date: 2026-07-28 09:39+0000\n"
 "Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
 "Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
 "manual/ja/>\n"
@@ -7288,6 +7288,11 @@ msgid ""
 "and each function page documents the supported input types and conformance "
 "level."
 msgstr ""
+"PostGIS は新しい標準で定義されているジオメトリーファミリーに対応しています。"
+"SQL/MM 曲線ジオメトリーや OGC Simple Features Access 1.2 の多面体サーフェス、"
+"三角形、TIN があたります。これらのジオメトリーファミリーへの対応状況は関数ご"
+"とに決まっています、各関数のページで対応する入力タイプと適合水準について記載"
+"があります。"
 #. Tag: para
 #, no-c-format
Summary of changes:
 doc/po/ja/postgis-manual.po | 7 ++++++-
 1 file changed, 6 insertions(+), 1 deletion(-)
hooks/post-receive
