[SCM] PostGIS branch master updated. 3.7.0beta1-125-g56a92ee3a0
git at osgeo.org
git at osgeo.org
Tue Jul 28 02:52:34 PDT 2026
the project "PostGIS".
via 56a92ee3a024fe187741b11b5a9b72cf51668a71 (commit)
via e70a5901f50450c468604e4b543bd56bc755b3c5 (commit)
from 37ee184bfb85bc02d4839fc0a7c296171614d7ac (commit)
revisions in full, below.
commit 56a92ee3a024fe187741b11b5a9b72cf51668a71
Merge: 37ee184bfb e70a5901f5
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Tue Jul 28 02:52:32 2026 -0700
Merge pull request 'Use house_num in ST_LineLocatePoint example' (!604) from Komzpa/postgis:agent/workshops-160-house-num into master
Use `house_num` for the estimated house-number output in the `ST_LineLocatePoint` documentation example.
This keeps the column name aligned with the example text, which approximates the street number of a house rather than identifying a street.
Closes https://github.com/postgis/postgis-workshops/issues/160
Validation:
- `xmllint --noout doc/postgis.xml`
- `git diff --check`
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/604
commit e70a5901f50450c468604e4b543bd56bc755b3c5
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jul 28 12:16:01 2026 +0400
Use house_num in line locate point example
diff --git a/doc/reference_lrs.xml b/doc/reference_lrs.xml
index 93f18292f8..2e9db17567 100644
--- a/doc/reference_lrs.xml
+++ b/doc/reference_lrs.xml
@@ -300,17 +300,17 @@ FROM street;
<para>This example approximates the street number of a house by locating the closest point on a street line. The subquery generates sample house and street data, and <function>ST_DWithin</function> excludes houses that are too far from the street.</para>
<programlisting>SELECT house_loc As as_text_house_loc,
- startstreet_num +
- CAST( (endstreet_num - startstreet_num)
- * ST_LineLocatePoint(street_line, house_loc) As integer) As street_num
+ start_house_num +
+ CAST( (end_house_num - start_house_num)
+ * ST_LineLocatePoint(street_line, house_loc) As integer) As house_num
FROM
(SELECT 'LINESTRING(1 2,3 4)'::geometry As street_line,
- ST_Point(x*1.01, y*1.03) As house_loc, 10 As startstreet_num,
- 20 As endstreet_num
+ ST_Point(x*1.01, y*1.03) As house_loc, 10 As start_house_num,
+ 20 As end_house_num
FROM generate_series(1, 3) x CROSS JOIN generate_series(2, 4) As y)
As foo
WHERE ST_DWithin(street_line, house_loc, 0.2);</programlisting>
-<screen> as_text_house_loc | street_num
+<screen> as_text_house_loc | house_num
POINT(1.01 2.06) | 10
POINT(2.02 3.09) | 15
Summary of changes:
doc/reference_lrs.xml | 12 ++++++------
1 file changed, 6 insertions(+), 6 deletions(-)
hooks/post-receive
