[SCM] PostGIS branch stable-3.4 updated. 3.4.6-108-g9a1766d29a
git at osgeo.org
git at osgeo.org
Tue Jul 28 12:55:02 PDT 2026
the project "PostGIS".
The branch, stable-3.4 has been updated
via 9a1766d29af52e467c9f3eab5239d7fd04111175 (commit)
via 43111558ae11cfa1b7011a7e0f578c7655dfb526 (commit)
from ec59a26b9f35de7b2125aa40caac58dbd8116d14 (commit)
revisions in full, below.
commit 9a1766d29af52e467c9f3eab5239d7fd04111175
Merge: ec59a26b9f 43111558ae
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Tue Jul 28 12:54:56 2026 -0700
Merge pull request 'regress: assert the plan in computed_columns on stable-3.4' (!614) from Komzpa/postgis:fix/computed-columns-plan-stable-3.4-20260728 into stable-3.4
Backports the computed_columns planner assertion from master commit 5740442609069f82eb2384c045929548c665aa50 to stable-3.4.
The regression compared two adjacent wall-clock measurements to prove that a stored generated column was read instead of recomputed. Under CI load, unrelated buffer or autovacuum timing could reverse that comparison even when the generated-column behavior was correct.
This replaces the timing race with an EXPLAIN-based assertion that the stored generated-column query does not call ST_Buffer while the ad-hoc query does. The expected output shape remains unchanged.
The NEWS entry cites GT-582, the pull request where the fix was recorded on master: https://gitea.osgeo.org/postgis/postgis/pulls/582.
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/614
commit 43111558ae11cfa1b7011a7e0f578c7655dfb526
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jul 28 07:11:39 2026 +0400
regress: assert the plan, not the clock, in computed_columns
The test asserted that a query using a stored generated column finishes in fewer
microseconds than one recomputing ST_Buffer, timed with clock_timestamp around two
EXECUTEs. That is a race between two adjacent measurements living in a correctness
suite: uniform load slows both sides equally and it survives, but an autovacuum or a
cold buffer state on one side is enough to lose it. Woodie caught it doing exactly
that -- one step log has the test passing at line 1207 and failing at line 1617 of
the same run, with only the first t flipping to f.
The intent is sound and is a property of the plan, not of the clock: a stored
generated column should be read rather than recomputed. So ask the planner. Both
directions are asserted, because checking only that the computed-column query avoids
ST_Buffer would still pass if the comparison stopped meaning anything.
Verified on PostgreSQL 18.4 with GEOS 3.15.0beta2: three runs idle and three under a
load average of 21 on 32 cores, all passing, where the old assertion is exactly the
thing that varies. It is also nine times cheaper -- 213 ms against 1954 ms -- because
it no longer runs both heavy queries an extra time purely to time them.
(cherry picked from commit 5740442609069f82eb2384c045929548c665aa50)
diff --git a/NEWS b/NEWS
index 0c2d3d10a3..86a12e5f66 100644
--- a/NEWS
+++ b/NEWS
@@ -7,6 +7,9 @@ PostGIS 3.4.7
clean under Valgrind (Darafei Praliaskouski)
- GT-575, Scope interrupt regression timeouts to the statements being
canceled (Darafei Praliaskouski)
+ - GT-582, Make the computed-columns regression test assert the query plan
+ instead of racing two stopwatches, so it no longer fails at random under
+ CI load (Darafei Praliaskouski)
- GT-522, Reject malformed GSERIALIZED payload counts before deserializing
geometry data (Darafei Praliaskouski)
- GT-523, [raster] Fix invalid reads in geotransform property access
diff --git a/regress/core/computed_columns.sql b/regress/core/computed_columns.sql
index b60b4e3c0c..417a73de17 100644
--- a/regress/core/computed_columns.sql
+++ b/regress/core/computed_columns.sql
@@ -1,12 +1,16 @@
CREATE SCHEMA testc;
-CREATE OR REPLACE FUNCTION testc.compute_exection_time(param_sql text) RETURNS interval
+-- Does the plan for this query call the named function? The point of a stored generated column
+-- is that the value is read rather than recomputed, and that is a property of the plan. Timing the
+-- two queries against each other instead makes the test a race between adjacent measurements, which
+-- an autovacuum or a cold buffer on one side is enough to lose.
+CREATE OR REPLACE FUNCTION testc.plan_calls(param_sql text, fname text) RETURNS boolean
AS $$
-DECLARE var_start_time timestamptz; var_end_time timestamptz;
+DECLARE var_line text; var_found boolean := false;
BEGIN
-var_start_time = clock_timestamp();
-EXECUTE param_sql;
-var_end_time = clock_timestamp();
-RETURN var_end_time - var_start_time;
+FOR var_line IN EXECUTE 'EXPLAIN (COSTS OFF) ' || param_sql LOOP
+ IF var_line ILIKE '%' || fname || '%' THEN var_found := true; END IF;
+END LOOP;
+RETURN var_found;
END;
$$ language plpgsql;
@@ -48,9 +52,9 @@ CREATE INDEX gix_random_way_buffer_geom
analyze testc.random_points;
analyze testc.streets;
--- time using computed column should always be less than adhoc
-SELECT testc.compute_exection_time('SELECT COUNT(*) FROM testc.random_points AS p INNER JOIN testc.streets AS s ON ST_Contains(p.way_buffer, s.geom)') <
-testc.compute_exection_time('SELECT COUNT(*) FROM testc.random_points AS p INNER JOIN testc.streets AS s ON ST_Contains(ST_Buffer(p.geom, 500), s.geom);');
+-- the computed column is read, not recomputed, while the ad-hoc form does call ST_Buffer
+SELECT NOT testc.plan_calls('SELECT COUNT(*) FROM testc.random_points AS p INNER JOIN testc.streets AS s ON ST_Contains(p.way_buffer, s.geom)', 'st_buffer')
+AND testc.plan_calls('SELECT COUNT(*) FROM testc.random_points AS p INNER JOIN testc.streets AS s ON ST_Contains(ST_Buffer(p.geom, 500), s.geom)', 'st_buffer');
-- confirm results are the same
SELECT (SELECT COUNT(*) FROM testc.random_points AS p INNER JOIN testc.streets AS s ON ST_Contains(p.way_buffer, s.geom) ) =
Summary of changes:
NEWS | 3 +++
regress/core/computed_columns.sql | 22 +++++++++++++---------
2 files changed, 16 insertions(+), 9 deletions(-)
hooks/post-receive
