[PostGIS] #6108: Reconcile PostGIS Docker build environment repositories under Gitea/Woodie
PostGIS trac at osgeo.org
Tue Jul 28 16:06:40 PDT 2026
  Reporter:  komzpa        |      Owner:  komzpa
      Type:  task          |     Status:  new
  Priority:  medium        |  Milestone:
 Component:  QA/buildbots  |    Version:  master
Resolution:                |   Keywords:  docker woodie gitea ci build-env
Comment (by robe):
 I like the renamed idea to just rename it build-env and merge the two
 under gitea.  Yah the simularity between docker-postgis and postgis-docker
 always annoyed me.
 Replying to [comment:2 strk]:
 > I agree on the principle of consolidating those repositories, but
 shouldn't we also take the chance to move the postgis/docker-postgis to
 Gitea too ? At least nobody needs a Microsoft account to contribute to the
 user-facing image ? I'd also rename it to drop the "docker" part,
 replacing it with "oci" (
 https://en.wikipedia.org/wiki/Open_Container_Initiative )
 This is not our decision to make.  If you really want it, you should
 suggest it to @ImreSamu who has been doing 95% of the work on it.  Things
 live where it is most useful for the people doing the brunt of the work on
 it to work on it.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6108#comment:3>
