[SCM] PostGIS branch master updated. 3.7.0beta1-130-gb0acf1ca83
git at osgeo.org
git at osgeo.org
Tue Jul 28 20:39:18 PDT 2026
the project "PostGIS".
via b0acf1ca83d9e5cae016dd69ed6dbbca48c3a7a2 (commit)
from f40b32c82fe127910724c5d19ebee6e44c402eb4 (commit)
revisions in full, below.
commit b0acf1ca83d9e5cae016dd69ed6dbbca48c3a7a2
Author: Teramoto Ikuhiro <yellow at affrc.go.jp>
Date: Wed Jul 29 01:56:58 2026 +0000
Translated PostGIS Manual using Weblate (Japanese)
Currently translated at 88.0% (5268 of 5981 strings)
Translation: postgis/PostGIS Manual
Translate-URL: https://weblate.osgeo.org/projects/postgis/postgis-manual/ja/
diff --git a/doc/po/ja/postgis-manual.po b/doc/po/ja/postgis-manual.po
index bc4d9fdf00..c7ac8ccb9a 100644
--- a/doc/po/ja/postgis-manual.po
+++ b/doc/po/ja/postgis-manual.po
@@ -10,7 +10,7 @@ msgstr ""
"Project-Id-Version: postgis 3.5\n"
"Report-Msgid-Bugs-To: https://bugs.kde.org\n"
"POT-Creation-Date: 2026-07-20 08:06+0000\n"
-"PO-Revision-Date: 2026-07-28 09:39+0000\n"
+"PO-Revision-Date: 2026-07-29 03:39+0000\n"
"Last-Translator: Teramoto Ikuhiro <teramoto.ikuhiro576 at naro.go.jp>\n"
"Language-Team: Japanese <https://weblate.osgeo.org/projects/postgis/postgis-"
"manual/ja/>\n"
@@ -7305,6 +7305,12 @@ msgid ""
"should not be read as OGC Simple Features or SQL/MM requirements unless the "
"specific function or format says so."
msgstr ""
+"PostGIS は幅広く使われている拡張と統合を含んでいます。PostGIS 拡張の例として"
+"は SRID メタデータを含んだ拡張書式の Extended WKT (EWKT)、Extended WKB (EWKB)"
+"、ジオグラフィー、ラスターが当てはまります。PostGIS はまた、GeoJSON、GML、"
+"KML といった他の標準データ交換書式の入出力に対応しています。これらの機能は別"
+"途文書化されていて、特定の関数や書式で書かれていない限りは、OGC Simple "
+"Features や SQL/MM 要求とは別と考えてください。"
#. Tag: para
#, no-c-format
Summary of changes:
doc/po/ja/postgis-manual.po | 8 +++++++-
1 file changed, 7 insertions(+), 1 deletion(-)
hooks/post-receive
