[SCM] PostGIS branch master updated. 3.7.0beta1-132-g7733d37ea0
git at osgeo.org
git at osgeo.org
Wed Jul 29 11:44:40 PDT 2026
the project "PostGIS".
via 7733d37ea04f187c318cff0e6e2f95e1dab7a92a (commit)
via 043885ba34311b6378c0fc34526f76a241d26bdc (commit)
from b0acf1ca83d9e5cae016dd69ed6dbbca48c3a7a2 (commit)
revisions in full, below.
commit 7733d37ea04f187c318cff0e6e2f95e1dab7a92a
Merge: b0acf1ca83 043885ba34
Author: Darafei Praliaskouski <komzpa at gmail.com>
Date: Wed Jul 29 11:44:29 2026 -0700
Merge pull request 'Move maintained Trac wiki notes into developer docs' (!625) from Komzpa/postgis:ai/trac-wiki-doc-migration-20260729 into master
Fold maintained Trac wiki guidance into the repository developer docs.
This moves durable development workflow notes out of Trac-only pages and into
the maintained documentation tree:
* Docker development container host-connectivity notes from `DevWikiDockerTesting`
* new SQL feature documentation checklist details from `DevWikiDocNewFeature`
* practical regression-test troubleshooting from `UsersWikiMakeCheckConsiderations`
* current documentation, source-code, package, and Windows-install links in the
manual and documentation README
The old `doc/trac-wiki/` pointer in `doc/README` is also removed because that
directory is not present in the current tree.
Validation:
* `git diff --check`
* `xmllint --noout doc/postgis.xml`
* checked that touched current-doc entry points no longer contain live
`trac.osgeo.org/postgis/wiki` links, except historical provenance notes
Reviewed-on: https://gitea.osgeo.org/postgis/postgis/pulls/625
commit 043885ba34311b6378c0fc34526f76a241d26bdc
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Wed Jul 29 22:38:25 2026 +0400
diff --git a/doc/README b/doc/README
index 84f183d6a1..dc0e308c19 100644
--- a/doc/README
+++ b/doc/README
@@ -61,8 +61,8 @@ manual at https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/developm
for layout roles, labels, textual-output policy, native geometry/EWKT output
handling, and the visual review procedure.
-To run garden tests against functions, follow these instructions on the PostGIS
-dev wiki: http://trac.osgeo.org/postgis/wiki/DevWikiGardenTest
+To run garden tests against functions, see the Garden Checks section in
+https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/development/testing/.
Manual example tests are opt-out. A parseable SQL ``programlisting`` with
expected output is tested by default. Add ``role="requires-external-state"`` when
@@ -155,5 +155,6 @@ features used elsewhere in the manual.
For contributor workflow, local testing, and garden checks, see
https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/development/.
-The audited Trac wiki migration record and recovered attachments live in
-``doc/trac-wiki/``.
+Historical Trac wiki material that is still maintained has been folded into the
+developer documentation under ``doc/development/``, the user manual, or the
+public website.
diff --git a/doc/administration.xml b/doc/administration.xml
index 20d4dcc416..a99ec44a60 100644
--- a/doc/administration.xml
+++ b/doc/administration.xml
@@ -223,7 +223,8 @@ string, and next time you'll need to drop the "next" suffix again:
symbol errors or bringing forward deprecated objects.
</para>
- <para>Supplementary instructions for windows users are available at <link xlink:href="http://trac.osgeo.org/postgis/wiki/UsersWikiWinUpgrade">Windows Hard upgrade</link>.</para>
+ <para>Supplementary instructions for windows users are available in the
+ <link xlink:href="https://postgis.net/documentation/getting_started/install_windows/">PostGIS Windows installation guide</link>.</para>
<para>
diff --git a/doc/development/contributing.md b/doc/development/contributing.md
index 58c265251a..89125da020 100644
--- a/doc/development/contributing.md
+++ b/doc/development/contributing.md
@@ -100,7 +100,9 @@ Patch submission basics:
* Follow [Coding style](style.md) for C naming, formatting, and Doxygen
comments before writing or submitting source patches.
* Add documentation in the same change when a feature adds or changes SQL
- user-visible behavior.
+ user-visible behavior. New SQL functions must follow the
+ [manual documentation workflow](manual.md#documenting-new-sql-features),
+ including `Availability:` notes and generated SQL comments.
* For SQL API, upgrade, and release-policy changes, read
[Release and upgrade rules](release/_index.md) before opening a pull request.
* Git patches sent by email are also accepted; see
diff --git a/doc/development/environment/docker.md b/doc/development/environment/docker.md
index ebbc046baa..6ee062e521 100644
--- a/doc/development/environment/docker.md
+++ b/doc/development/environment/docker.md
@@ -49,6 +49,30 @@ make -j"$(nproc)"
make check
+For interactive debugging, keep the container alive and enter it with:
+```sh
+docker exec -it postgis-dev /bin/bash
+pg_lsclusters
+`pg_lsclusters` shows which PostgreSQL major uses each port inside the
+container. To connect from the host, expose the matching port in `docker run`,
+allow PostgreSQL to listen beyond the container loopback interface, and reload
+the cluster:
+```sh
+export PGVER=15
+export PGPORT="$(grep ^port /etc/postgresql/${PGVER}/main/postgresql.conf | awk '{print $3}')"
+psql -d postgres -c "ALTER SYSTEM SET listen_addresses='*';"
+printf '%s\n' "host all all 0.0.0.0/0 scram-sha-256" >> "/etc/postgresql/${PGVER}/main/pg_hba.conf"
+psql -d postgres -c "ALTER ROLE postgres PASSWORD 'change-me';"
+service postgresql restart "${PGVER}"
+Use a stronger password and narrower `pg_hba.conf` rule on shared hosts. The
+example is intended for a short-lived local development container.
From the host, connect to the PostgreSQL version whose container port you
exposed. For example, if PostgreSQL inside the container listens on `5436` and
the host port mapping is `6436:5436`, use:
diff --git a/doc/development/manual.md b/doc/development/manual.md
index dc902d667a..3249af9f43 100644
--- a/doc/development/manual.md
+++ b/doc/development/manual.md
@@ -111,6 +111,21 @@ For a new function:
one self-contained query and let the visual-example manifest supply the
figure to HTML and PDF.
+Before submitting the patch, verify that the documentation feeds every public
+surface generated from it:
+```sh
+make -C doc comments
+make -C doc html
+The comments target regenerates `postgis_comments.sql`,
+`raster_comments.sql`, `topology_comments.sql`, and `sfcgal_comments.sql` from
+the reference text. These comments are what users see through database clients
+such as psql, pgAdmin, and other tools that display PostgreSQL object comments,
+so the `refpurpose`, signatures, and examples should make sense outside the
+HTML manual too.
Run `make -C regress visual-examples` before building HTML or PDF. It verifies
every runnable example and automatically generates a figure for geometry found
in the result or in SQL literals. The staged PostGIS library supplies the SVG
diff --git a/doc/development/testing/_index.md b/doc/development/testing/_index.md
index 47c9a8becf..506c9da840 100644
--- a/doc/development/testing/_index.md
+++ b/doc/development/testing/_index.md
@@ -57,6 +57,29 @@ When testing against several PostgreSQL installs, put the target PostgreSQL
client binaries first in `PATH` and set `PGPORT`, `PGUSER`, and `PGHOST`
explicitly.
+If the harness connects to the wrong cluster, inspect the active PostgreSQL
+binary and connection settings before changing the test:
+```sh
+which pg_config
+pg_config --version
+env | grep '^PG'
+The test cluster must allow the selected user to connect locally and create the
+temporary regression database. A local throw-away test cluster often uses a
+topmost `pg_hba.conf` rule such as:
+```text
+host all all 127.0.0.1/32 trust
+Use a narrower or password-based rule on shared machines, then reload the
+cluster before rerunning the tests. On Windows or mixed checkout environments,
+unexpected diffs in otherwise unchanged `_expected` files can come from line
+endings; normalize the affected regression files before treating the output as
+a behavior change.
### Sandboxed Regression Roles
Continuous integration workers are frequently configured with sandboxed
diff --git a/doc/installation.xml b/doc/installation.xml
index 3e1a01d894..cc5526ac45 100644
--- a/doc/installation.xml
+++ b/doc/installation.xml
@@ -33,9 +33,10 @@ in each individual database you want to use it in.
In many cases compilation is only necessary if you want the most
bleeding edge versions or you are a package maintainer.
</para>
- <para>This section includes general compilation instructions, if you are compiling for Windows etc
- or another OS, you may find additional more detailed help at <link xlink:href="https://trac.osgeo.org/postgis/wiki/UsersWikiInstall">PostGIS User contributed compile guides</link> and <link xlink:href="http://trac.osgeo.org/postgis/wiki/DevWikiMain">PostGIS Dev Wiki</link>.</para>
- <para>Pre-Built Packages for various OS are listed in <link xlink:href="https://trac.osgeo.org/postgis/wiki/UsersWikiPackages">PostGIS Pre-built Packages</link></para>
+ <para>This section includes general compilation instructions. If you are compiling for Windows
+ or another operating system, see the <link xlink:href="https://postgis.net/documentation/getting_started/">PostGIS getting started guides</link>
+ and the <link xlink:href="https://gitea.osgeo.org/postgis/postgis/src/branch/master/doc/development/environment/">development environment guides</link>.</para>
+ <para>Pre-Built Packages for various OS are listed in the <link xlink:href="https://postgis.net/documentation/getting_started/">PostGIS getting started guides</link></para>
<para>If you are a windows user, you can get stable builds via Stackbuilder or <link xlink:href="https://postgis.net/windows_downloads">PostGIS Windows download site</link>
We also have <link xlink:href="https://postgis.net/windows_downloads">very bleeding-edge windows experimental builds</link> that are built usually once or twice a week or whenever anything exciting happens. You can
use these to experiment with the in progress releases of PostGIS</para>
@@ -525,7 +526,7 @@ sh autogen.sh
<note>
<para>
If you obtained PostGIS from the
- <link xlink:href="https://trac.osgeo.org/postgis/wiki/CodeRepository">
+ <link xlink:href="https://postgis.net/development/source_code/">
code repository
</link>
, the first step is really to run the script
Summary of changes:
doc/README | 9 +++++----
doc/administration.xml | 3 ++-
doc/development/contributing.md | 4 +++-
doc/development/environment/docker.md | 24 ++++++++++++++++++++++++
doc/development/manual.md | 15 +++++++++++++++
doc/development/testing/_index.md | 23 +++++++++++++++++++++++
doc/installation.xml | 9 +++++----
7 files changed, 77 insertions(+), 10 deletions(-)
hooks/post-receive
