[SCM] PostGIS branch master updated. 3.6.0rc2-501-g65e081184
Mon Jun 8 01:07:12 PDT 2026
the project "PostGIS".
       via  65e0811847b3a6572ce496bd219ba69dc62e364f (commit)
       via  7826c60d05d8875df8d1b2152eb5a7baadc94d9f (commit)
      from  8b7cbaa81af3561d34c0393fbc0e2d56d97be4ef (commit)
revisions in full, below.
commit 65e0811847b3a6572ce496bd219ba69dc62e364f
Merge: 8b7cbaa81 7826c60d0
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Mon Jun 8 12:06:48 2026 +0400
    Merge branch 'codex/postgis-skill-scope'
commit 7826c60d05d8875df8d1b2152eb5a7baadc94d9f
Date:   Mon May 4 08:54:27 2026 +0400
    docs: keep PostGIS skill scope specific
diff --git a/doc/SKILL.md b/doc/SKILL.md
deleted file mode 100644
index 5d2504c44..000000000
--- a/doc/SKILL.md
+++ /dev/null
@@ -1,67 +0,0 @@
-name: postgis-skill
-description: PostGIS-focused SQL tips, tricks and gotchas. Use when in need of dealing with geospatial data in Postgres.
-## Documentation
- - Make sure every create statement or CTE has descriptive comment `--` in front of it.
- - Write enough comments so you can deduce what was a requirement in the future and not walk in circles.
- - Every feature needs to have comprehensive up-to-date documentation near it.
-## Style
- - PostGIS functions follow their spelling from the manual (`st_segmentize` -> `ST_Segmentize`).
- - SQL is lowercase unless instructed otherwise.
- - Values in databases and layers should be absolute as much as possible: store "birthday" or "construction date" instead of "age".
- - Do not mix tabs and spaces in code.
- - Add empty lines between logical blocks.
- - Format the code nicely and consistently.
- - Call geometry column `geom`; geography column `geog`.
-## Indexing
- - Create brin for all columns when creating large table that will be used for ad-hoc queries.
- - If you have cache table that has a primary key, it makes sense to add values into `including` on same index for faster lookup.
-## Debugging
- - Make sure that error messages towards developer are better than just "500 Internal server error".
- - Don't stub stuff out with insane fallbacks (like lat/lon=0) - instead make the rest of the code work around data absence and inform user.
- - SQL files should to be idempotent: drop table if exists + create table as; add some comments to make people grasp queries faster.
- - Create both "up' and "down/rollback" migration when creating new migrations for ease of iteration.
- - Check `select postgis_full_version();` to see if all upgrades happened successfully.
- - Don't run one SQL file from other SQL file - this quickly becomes a mess with relative file paths.
-## Raster
- - Do not work with GDAL on the filesystem. Import things into database and deal with data there.
-## SQL gotchas
- - `sum(case when A then 1 else 0 end)` is just `count() filter (where A)`
- - `row_number() ...  = 1` can likely be redone as `order by + limit 1` (possibly with `distinct on` or `lateral`)
- - `exists(select 1 from ...)` is just `exists(select from ...)`
- - `tags ->> 'key' = 'value'`  is just `tags @> '{"key": "value"}` - works faster for indexes
- - you can't just create ordered table and then rely on it to be ordered on scan without `order by`
-## PostGIS gotchas
- - Do not use geometry typmod unless requested (things like `geometry(multilinestring, 4326)`) - use plain `geometry` or `geography` instead. This removes clutter of `ST_Multi` and errors via `ST_SetSRID`.
- - `ST_UnaryUnion(ST_Collect(geom))` is just `ST_Union(geom)`
- - `ST_Buffer(geom, 0)` should be `ST_MakeValid(geom)`
- - `select min(ST_Distance(..))` should be `select ST_Distance() ... order by a <-> b limit 1` to enable knn gist
- - `order by ST_Distance(c.geog, t.geog)` should be `order by c.geog <-> t.geog`
- - `ST_UnaryUnion` is a sign you're doing something wrong
- - `ST_MakeValid` is a sign you're doing something wrong on the previous step
- - be extra attintive when calling `ST_SetSRID`: check the actual projection of input data, check if it can be set correctly during input (`ST_GeomFromGeoJSON`, `EWKT`-style `SRID=4326;POINT(...`, `EWKB` allow that). Check if `ST_Transform` is needed instead.
- - when looking for relation between point and polygon, prefer `ST_Intersects` to other topology predicates
- - when generating complex geometry by walking raster or grid, may make sense to `ST_Simplify(geom, 0)`
- - to generate neighbourhoods of predictable size, use `ST_ClusterKMeans` with k=2 and `max_radius` set to your distance.
- - use `ST_AsEWKB` for binary representation instead of `ST_AsWKB` to keep SRID.
- - Choosing projection:
-    SRID=4326 (2D longlat) when input or output is longitude and latitude and coordinate value is to be shown to user.
-    SRID=3857 (2D Spherical Mercator) when output will be shown on web map, ST_AsMVT, or 2D KNN requests of short distance are to be executed.
-    SRID=4978 (3D XYZ) when performing internal computations, line-of-sight, clustering and averaging across antimeridian. Beware: only use 3D-aware operations, ST_Force3DZ on 2D CRS data before calling ST_Transform to it.
- - Instead of using `ST_Hexagon` / `ST_HexagonGrid` use `h3` extension.
- - When you know the data is going to be dumped in binary form, gzipped and moved around, consider using `ST_QuantizeCoordinates` if precision is known.
diff --git a/skills/postgis/SKILL.md b/skills/postgis/SKILL.md
new file mode 100644
index 000000000..7ee79755e
--- /dev/null
+++ b/skills/postgis/SKILL.md
@@ -0,0 +1,38 @@
+name: postgis
+description: PostGIS-specific SQL tips and gotchas. Use when working with geometry, geography, raster, projections, spatial indexes, or geospatial processing in PostgreSQL through PostGIS.
+## Naming
+ - Spell PostGIS functions as they appear in the manual (`st_segmentize` -> `ST_Segmentize`).
+ - Call geometry columns `geom`; call geography columns `geog`.
+## Checks
+ - Check `select postgis_full_version();` to confirm the installed PostGIS, GEOS, PROJ, GDAL, and SFCGAL versions when debugging extension behavior.
+## Raster
+ - Do not work with GDAL on the filesystem. Import things into database and deal with data there.
+## Gotchas
+ - Do not use geometry typmod unless requested (things like `geometry(multilinestring, 4326)`) - use plain `geometry` or `geography` instead. This removes clutter of `ST_Multi` and errors via `ST_SetSRID`.
+ - `ST_UnaryUnion(ST_Collect(geom))` is just `ST_Union(geom)`.
+ - `ST_Buffer(geom, 0)` should be `ST_MakeValid(geom)` when invalid geometry must be repaired, but first prefer fixing the source of invalid geometry upstream.
+ - `select min(ST_Distance(..))` should be `select ST_Distance() ... order by a <-> b limit 1` to enable knn gist.
+ - `order by ST_Distance(c.geog, t.geog)` should be `order by c.geog <-> t.geog`.
+ - `ST_UnaryUnion` is a sign you're doing something wrong.
+ - Needing `ST_MakeValid` is a sign you're doing something wrong on the previous step.
+ - Be extra attentive when calling `ST_SetSRID`: first check the actual projection of input data. Prefer setting the SRID during input when the source format supports it, for example with `ST_GeomFromGeoJSON`, EWKT like `SRID=4326;POINT(1 2)`, or EWKB; use `ST_Transform` instead if reprojection is needed.
+ - When looking for relation between point and polygon, prefer `ST_Intersects` to other topology predicates.
+ - When generating complex geometry by walking raster or grid, it may make sense to `ST_Simplify(geom, 0)`.
+ - To generate neighbourhoods of predictable size, use `ST_ClusterKMeans` with `k = 2` and `max_radius` set to your distance.
+ - Use `ST_AsEWKB` for binary representation instead of `ST_AsWKB` to keep SRID.
+ - Choosing projection:
+    SRID=4326 (2D longlat) when input or output is longitude and latitude and coordinate value is to be shown to user.
+    SRID=3857 (2D Spherical Mercator) when output will be shown on web map, ST_AsMVT, or 2D KNN requests of short distance are to be executed.
+    SRID=4978 (3D XYZ) when performing internal computations, line-of-sight, clustering and averaging across antimeridian. Beware: only use 3D-aware operations, ST_Force3DZ on 2D CRS data before calling ST_Transform to it.
+ - Instead of using `ST_Hexagon` / `ST_HexagonGrid`, use the `h3` extension.
+ - When you know the data is going to be dumped in binary form, gzipped and moved around, consider using `ST_QuantizeCoordinates` if precision is known.
diff --git a/skills/sql-programming/SKILL.md b/skills/sql-programming/SKILL.md
index 000000000..ef035204e
--- /dev/null
+++ b/skills/sql-programming/SKILL.md
@@ -0,0 +1,39 @@
+name: sql-programming
+description: General SQL programming, formatting, debugging, and query-shaping tips. Use for SQL work that is not specifically about PostGIS spatial data.
+## Documentation
+ - Make sure every create statement or CTE has a descriptive comment `--` in front of it.
+ - Write enough comments so you can deduce what was a requirement in the future and not walk in circles.
+ - Every feature needs to have comprehensive up-to-date documentation near it.
+## Style
+ - SQL is lowercase unless instructed otherwise.
+ - Values in databases and layers should be absolute as much as possible: store "birthday" or "construction date" instead of "age".
+ - Do not mix tabs and spaces in code.
+ - Add empty lines between logical blocks.
+ - Format the code nicely and consistently.
+## Indexing
+ - Consider BRIN indexes for very large naturally ordered tables that will be used for ad-hoc range queries.
+ - If you have a cache table that has a primary key, it can make sense to add frequently read values into `including` on the same index for faster lookup.
+## Debugging
+ - Make sure error messages towards developers are better than just "500 Internal Server Error".
+ - Don't stub stuff out with insane fallbacks like `lat = 0` and `lon = 0`; instead make the rest of the code work around data absence and inform the user.
+ - SQL files should be idempotent: drop table if exists + create table as; add comments to make queries faster to grasp.
+ - Create both "up" and "down/rollback" migrations when the project expects reversible migrations.
+ - Don't run one SQL file from another SQL file - this quickly becomes a mess with relative file paths.
+## SQL Gotchas
+ - `sum(case when A then 1 else 0 end)` is just `count() filter (where A)`.
+ - `row_number() ... = 1` can likely be redone as `order by + limit 1` (possibly with `distinct on` or `lateral`).
+ - `exists(select 1 from ...)` is just `exists(select from ...)`.
+ - `tags ->> 'key' = 'value'` is just `tags @> '{"key": "value"}'` - works faster with indexes.
+ - You can't create an ordered table and then rely on it to be ordered on scan without `order by`.
Summary of changes:
 doc/SKILL.md                    | 67 -----------------------------------------
 skills/postgis/SKILL.md         | 38 +++++++++++++++++++++++
 skills/sql-programming/SKILL.md | 39 ++++++++++++++++++++++++
 3 files changed, 77 insertions(+), 67 deletions(-)
 delete mode 100644 doc/SKILL.md
 create mode 100644 skills/postgis/SKILL.md
 create mode 100644 skills/sql-programming/SKILL.md
hooks/post-receive
