[SCM] PostGIS branch master updated. 3.6.0rc2-504-g18d5a182e
git at osgeo.org
git at osgeo.org
Mon Jun 8 07:45:26 PDT 2026
the project "PostGIS".
via 18d5a182ec414673f583da21ac1d9975f19e967d (commit)
via 75870db9056ff0a905df53181e7a42448386d328 (commit)
via 8d491659bd0ed42baedcf96ff3c741611ffa43c4 (commit)
from 65e0811847b3a6572ce496bd219ba69dc62e364f (commit)
revisions in full, below.
commit 18d5a182ec414673f583da21ac1d9975f19e967d
Author: Loïc Bartoletti <loic.bartoletti at oslandia.com>
Date: Mon Jun 8 12:51:30 2026 +0200
build: add FreeBSD docbook-ns xsl path to configure search list
diff --git a/configure.ac b/configure.ac
index fbc92932b..4de164b61 100644
--- a/configure.ac
+++ b/configure.ac
@@ -322,6 +322,7 @@ if test "x$XSLBASE" = "x"; then
/usr/share/sgml/docbook/stylesheet/xsl/nwalsh
/opt/local/share/xsl/docbook-xsl
/usr/local/opt/docbook-xsl/docbook-xsl
+ /usr/local/share/xsl/docbook-ns
/usr/local/share/xsl/docbook-xsl
/usr/share/xsl/docbook-xsl
commit 75870db9056ff0a905df53181e7a42448386d328
Date: Mon Jun 8 12:42:08 2026 +0200
fix(loader): initialize pgfieldlens and pgfieldtypmods to NULL in ShpDumperCreate
diff --git a/loader/pgsql2shp-core.c b/loader/pgsql2shp-core.c
index 0d6e43486..47d2daf11 100644
--- a/loader/pgsql2shp-core.c
+++ b/loader/pgsql2shp-core.c
@@ -1177,6 +1177,8 @@ ShpDumperCreate(SHPDUMPERCONFIG *config)
state->dbffieldnames = NULL;
state->dbffieldtypes = NULL;
state->pgfieldnames = NULL;
+ state->pgfieldlens = NULL;
+ state->pgfieldtypmods = NULL;
state->message[0] = '\0';
colmap_init(&state->column_map);
commit 8d491659bd0ed42baedcf96ff3c741611ffa43c4
Date: Fri Jun 5 08:07:16 2026 +0200
ci: replace cirrus-ci by github actions
diff --git a/.cirrus.yml b/.cirrus.yml
deleted file mode 100644
index bf74e73ba..000000000
--- a/.cirrus.yml
+++ /dev/null
@@ -1,158 +0,0 @@
-task:
- # only_if: $CIRRUS_BRANCH =~ 'pull/.*'
- name: FreeBSD
- alias: test-freebsd
- env:
- CIRRUS_CLONE_DEPTH: 1
- CCACHE_DIR: "/tmp/ccache_dir"
- NCPU: 2
- MAKEJOBS: "-j${NCPU}"
- CC: "ccache clang"
- CXX: "ccache clang++"
- CCACHE_MAXSIZE: 1
- CCACHE_COMPRESS: 1
- CCACHE_STATIC_PREFIX: "/usr/local"
- CCACHE_NOSTATS: 1
- CCACHE_TEMPDIR: "/tmp"
- BASEFS: "${CIRRUS_WORKING_DIR}/test_bulk"
- freebsd_cache:
- folder: ${CCACHE_DIR}
- pkg_bootstrap_script:
- sed -i.bak -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' /etc/pkg/FreeBSD.conf
- ASSUME_ALWAYS_YES=yes pkg bootstrap -f
- pkg_cache:
- folder: /var/cache/pkg
- populate_script:
- pkg fetch -udy autoconf automake bison cunit docbook gdal geos gmake iconv json-c libtool libxml2 libxslt pkgconf postgresql17-contrib postgresql17-server proj protobuf-c sfcgal
- install_pkgs_script:
- env IGNORE_OSVERSION=yes pkg update -f
- env IGNORE_OSVERSION=yes pkg install -y autoconf automake bison cunit docbook gdal geos gmake iconv json-c libtool libxml2 libxslt pkgconf postgresql17-contrib postgresql17-server proj protobuf-c sfcgal
- projsync --system-directory --source-id us_noaa
- projsync --system-directory --source-id ch_swisstopo
- ccache_setup_script:
- env IGNORE_OSVERSION=yes pkg install -y ccache-static
- ccache --max-size=${CCACHE_MAXSIZE}
- patch_script:
- find . -name "*.pl" | xargs sed -i -r 's|/usr/bin/perl|/usr/bin/env perl|'
- build_script:
- ./autogen.sh
- ./configure PKG_CONFIG=/usr/local/bin/pkgconf CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" LDFLAGS="-L/usr/local/lib" --with-libiconv-prefix=/usr/local --without-gui --with-topology --without-raster --with-sfcgal=/usr/local/bin/sfcgal-config --with-protobuf
- service postgresql oneinitdb
- service postgresql onestart
- su postgres -c "createuser -s `whoami`"
- gmake ${MAKEJOBS} || { service postgresql onestop; exit 1; }
- gmake ${MAKEJOBS} install || { service postgresql onestop; exit 1; }
- ccache -s
- test_script:
- show_regression_diffs() {
- local tmpdir="${PGIS_REG_TMPDIR:-/tmp/pgis_reg}"
- local found=0
- for f in "${tmpdir}"/*_diff; do
- [ -f "${f}" ] || continue
- if [ "${found}" -eq 0 ]; then
- echo "---- BEGIN REGRESSION DIFFS (${tmpdir}) ----"
- fi
- found=1
- echo "---- ${f} ----"
- cat "${f}"
- done
- echo "No regression diff files found in ${tmpdir}"
- else
- echo "---- END REGRESSION DIFFS ----"
- fi
- gmake ${MAKEJOBS} check RUNTESTFLAGS="-v --extension --dumprestore" || {
- service postgresql onestop
- exit 1
- freebsd_instance:
- cpu: ${NCPU}
- memory: 8G
- matrix:
- - name: 14.3-RELEASE
- freebsd_instance:
- image_family: freebsd-14-3
-task:
- name: macOS
- alias: test-macos
- macos_instance:
- image: ghcr.io/cirruslabs/macos-runner:sonoma
- env:
- CCACHE_DIR: "$HOME/.ccache"
- CCACHE_MAXSIZE: 1
- PG: "17"
- HOMEBREW_PREFIX: "/opt/homebrew"
- PATH: "${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin:${HOMEBREW_PREFIX}/bin:${HOMEBREW_PREFIX}/sbin:${HOMEBREW_PREFIX}/opt/ccache/libexec:$PATH"
- setup_script:
- brew update
- brew install ccache autoconf automake libtool pkg-config gdal geos icu4c json-c libpq libxml2 proj protobuf-c sfcgal cunit docbook docbook-xsl postgresql@${PG} gettext
- brew link --force gettext
- ccache --max-size=$CCACHE_MAXSIZE
- sudo ln -sfn ${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin/postgres /usr/local/bin/postgres
- test_script:
- local found=0
- fi
- found=1
- cat "${f}"
- done
- else
- fi
- export PGCONFIG="${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin/pg_config"
- export CFLAGS="-I${HOMEBREW_PREFIX}/opt/gettext/include \
- -I${HOMEBREW_PREFIX}/opt/postgresql@${PG}/include \
- -I${HOMEBREW_PREFIX}/include -Wno-nullability-completeness"
- export LDFLAGS="-L${HOMEBREW_PREFIX}/opt/gettext/lib \
- -L${HOMEBREW_PREFIX}/opt/postgresql@${PG}/lib"
- export CXXFLAGS="-std=c++17"
- ./autogen.sh
- ./configure --without-gui \
- --without-interrupt-tests \
- --with-topology \
- --without-raster \
- --with-sfcgal \
- --with-protobuf \
- --with-pgconfig=${PGCONFIG}
- brew services start postgresql@${PG}
- make -j$(sysctl -n hw.logicalcpu) || { brew services stop postgresql@${PG}; exit 1; }
- make -j$(sysctl -n hw.logicalcpu) check || {
- brew services stop postgresql@${PG}
- exit 1
- macos_cache:
- folders: ${CCACHE_DIR}
- upload_caches: macos
diff --git a/.github/workflows/ci-freebsd.yml b/.github/workflows/ci-freebsd.yml
new file mode 100644
index 000000000..93f7360fe
--- /dev/null
+++ b/.github/workflows/ci-freebsd.yml
@@ -0,0 +1,119 @@
+# GitHub Actions – FreeBSD CI
+# Replaces .cirrus.yml
+name: "CI (FreeBSD)"
+on:
+ push:
+ branches-ignore:
+ - 'master'
+ pull_request: ~
+jobs:
+ freebsd:
+ name: "FreeBSD ${{ matrix.version }}"
+ runs-on: ubuntu-latest
+ env:
+ CCACHE_DIR: "${{ github.workspace }}/.ccache"
+ CCACHE_MAXSIZE: "1G"
+ strategy:
+ fail-fast: false
+ matrix:
+ version:
+ - "14.3"
+ steps:
+ - uses: actions/checkout at 11bd71901bbe5b1630ceea73d27597364c9af683 # v4.2.2
+ with:
+ persist-credentials: false
+ - name: Cache ccache
+ uses: actions/cache at 27d5ce7f107fe9357f9df03efb73ab90386fccae # v5.0.5
+ with:
+ path: ${{ env.CCACHE_DIR }}
+ key: freebsd-${{ matrix.version }}-ccache-${{ github.sha }}
+ restore-keys: |
+ freebsd-${{ matrix.version }}-ccache-
+ - name: Build and test on FreeBSD
+ uses: vmactions/freebsd-vm at a6de9343ef5747433d9c25784c90e84998b9d69a # v1.4.6
+ with:
+ release: ${{ matrix.version }}
+ usesh: true
+ sync: rsync
+ copyback: true
+ prepare: |
+ sed -i.bak \
+ -e 's,pkg+http://pkg.FreeBSD.org/\${ABI}/quarterly,pkg+http://pkg.FreeBSD.org/\${ABI}/latest,' \
+ /etc/pkg/FreeBSD.conf
+ ASSUME_ALWAYS_YES=yes pkg bootstrap -f
+ env IGNORE_OSVERSION=yes pkg update -f
+ env IGNORE_OSVERSION=yes pkg install -y \
+ autoconf automake bison ccache-static cunit docbook \
+ gdal geos gmake iconv json-c libtool libxml2 libxslt \
+ pkgconf postgresql17-contrib postgresql17-server \
+ proj protobuf-c sfcgal
+ projsync --system-directory --source-id us_noaa
+ projsync --system-directory --source-id ch_swisstopo
+ run: |
+ set -e
+ export CC="ccache clang"
+ export CXX="ccache clang++"
+ export CCACHE_DIR="${{ github.workspace }}/.ccache"
+ export CCACHE_MAXSIZE="1G"
+ export CCACHE_COMPRESS=1
+ export CCACHE_STATIC_PREFIX="/usr/local"
+ export CCACHE_NOSTATS=1
+ export CCACHE_TEMPDIR="/tmp"
+ export MAKEJOBS="-j2"
+ ccache --max-size="${CCACHE_MAXSIZE}"
+ find . -name "*.pl" | xargs sed -i '' 's|/usr/bin/perl|/usr/bin/env perl|'
+ ./autogen.sh
+ ./configure \
+ PKG_CONFIG=/usr/local/bin/pkgconf \
+ CFLAGS="-isystem /usr/local/include -Wall -fno-omit-frame-pointer -Werror" \
+ LDFLAGS="-L/usr/local/lib" \
+ --with-libiconv-prefix=/usr/local \
+ --without-gui \
+ --with-topology \
+ --without-raster \
+ --with-sfcgal=/usr/local/bin/sfcgal-config \
+ --with-protobuf
+ service postgresql oneinitdb
+ service postgresql onestart
+ su postgres -c "createuser -s $(whoami)"
+ gmake ${MAKEJOBS} || { service postgresql onestop; exit 1; }
+ gmake ${MAKEJOBS} install || { service postgresql onestop; exit 1; }
+ ccache -s
+ show_regression_diffs() {
+ local tmpdir="${PGIS_REG_TMPDIR:-/tmp/pgis_reg}"
+ local found=0
+ for f in "${tmpdir}"/*_diff; do
+ [ -f "${f}" ] || continue
+ if [ "${found}" -eq 0 ]; then
+ echo "---- BEGIN REGRESSION DIFFS (${tmpdir}) ----"
+ fi
+ found=1
+ echo "---- ${f} ----"
+ cat "${f}"
+ done
+ echo "No regression diff files found in ${tmpdir}"
+ else
+ echo "---- END REGRESSION DIFFS ----"
+ fi
+ gmake ${MAKEJOBS} check RUNTESTFLAGS="-v --extension --dumprestore" || {
+ service postgresql onestop
+ exit 1
diff --git a/.github/workflows/ci-macos.yml b/.github/workflows/ci-macos.yml
index 000000000..27c3cd565
--- /dev/null
+++ b/.github/workflows/ci-macos.yml
@@ -0,0 +1,98 @@
+# GitHub Actions – macOS CI
+name: "CI (macOS)"
+on:
+ push:
+ branches-ignore:
+ - 'master'
+ pull_request: ~
+jobs:
+ macos:
+ name: "macOS"
+ runs-on: macos-latest
+ env:
+ PG: "17"
+ HOMEBREW_PREFIX: "/opt/homebrew"
+ steps:
+ with:
+ with:
+ key: macos-ccache-${{ github.sha }}
+ restore-keys: |
+ macos-ccache-
+ - name: Install dependencies
+ run: |
+ brew update
+ brew install \
+ autoconf automake libtool pkg-config \
+ ccache \
+ gdal geos icu4c json-c libpq libxml2 \
+ proj protobuf-c sfcgal cunit \
+ docbook docbook-xsl \
+ postgresql@${PG} gettext
+ brew link --force gettext
+ sudo ln -sfn "${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin/postgres" /usr/local/bin/postgres
+ env:
+ CC: "ccache clang"
+ CXX: "ccache clang++"
+ run: |
+ export PATH="${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin:${HOMEBREW_PREFIX}/bin:${HOMEBREW_PREFIX}/sbin:${HOMEBREW_PREFIX}/opt/ccache/libexec:${PATH}"
+ export PGCONFIG="${HOMEBREW_PREFIX}/opt/postgresql@${PG}/bin/pg_config"
+ export CFLAGS="-I${HOMEBREW_PREFIX}/opt/gettext/include -I${HOMEBREW_PREFIX}/opt/postgresql@${PG}/include -I${HOMEBREW_PREFIX}/include -Wno-nullability-completeness"
+ export LDFLAGS="-L${HOMEBREW_PREFIX}/opt/gettext/lib -L${HOMEBREW_PREFIX}/opt/postgresql@${PG}/lib"
+ export CXXFLAGS="-std=c++17"
+ local found=0
+ fi
+ found=1
+ cat "${f}"
+ done
+ else
+ fi
+ ./autogen.sh
+ ./configure \
+ --without-gui \
+ --without-interrupt-tests \
+ --with-topology \
+ --with-sfcgal \
+ --with-protobuf \
+ --with-pgconfig="${PGCONFIG}"
+ brew services start "postgresql@${PG}"
+ make -j$(sysctl -n hw.logicalcpu) || { brew services stop "postgresql@${PG}"; exit 1; }
+ sudo make install || { brew services stop "postgresql@${PG}"; exit 1; }
+ make -j$(sysctl -n hw.logicalcpu) check RUNTESTFLAGS="-v --extension --dumprestore" || {
+ brew services stop "postgresql@${PG}"
+ exit 1
diff --git a/make_dist.sh b/make_dist.sh
index 601e62ac0..bda4c2ce4 100755
--- a/make_dist.sh
+++ b/make_dist.sh
@@ -63,7 +63,6 @@ rm -fv "$outdir"/make_dist.sh "$outdir"/HOWTO_RELEASE
echo "Removing ci files"
rm -rfv \
"$outdir"/ci \
- "$outdir"/.cirrus.yml \
"$outdir"/.clang-format \
"$outdir"/.dron*.yml \
"$outdir"/.github \
diff --git a/utils/ci-trac-line.sh b/utils/ci-trac-line.sh
index 744d74324..d0abef4f4 100755
--- a/utils/ci-trac-line.sh
+++ b/utils/ci-trac-line.sh
@@ -17,7 +17,8 @@ cat <<EOF
|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=bessie32&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=bessie32, alt=status, height="20", title='PG 10.1(branch), GDAL 2.1 branch, GEOS 3.6')]] || \\
|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
|| [[Image(https://debbie.postgis.net/buildStatus/icon?job=PostGIS_Worker_Run/label=berrie64&build=last:\${params.reference=refs/heads/stable-${VER}}, link=https://debbie.postgis.net/view/PostGIS/job/PostGIS_Worker_Run/label=berrie64?build=last:\${params.reference=refs/heads/stable-${VER}, alt=status, height="20", title='PG 12(branch), GDAL 2.4.0 branch, GEOS 3.7.1')]] || \\
-|| [[Image(https://api.cirrus-ci.com/github/postgis/postgis.svg?branch=stable-${VER}, link=https://cirrus-ci.com/github/postgis/postgis, alt=status, height="20", title='PG 13(branch), GDAL 3.5 branch, GEOS 3.12')]] || \\
+|| [[Image(https://github.com/postgis/postgis/actions/workflows/ci-freebsd.yml/badge.svg?branch=stable-${VER}, link=https://github.com/postgis/postgis/actions/workflows/ci-freebsd.yml?query=branch%3Astable-${VER}, alt=status, height="20", title='FreeBSD')]] || \\
+|| [[Image(https://github.com/postgis/postgis/actions/workflows/ci-macos.yml/badge.svg?branch=stable-${VER}, link=https://github.com/postgis/postgis/actions/workflows/ci-macos.yml?query=branch%3Astable-${VER}, alt=status, height="20", title='macOS')]] || \\
|| [[Image(https://gitlab.com/postgis/postgis/badges/stable-${VER}/pipeline.svg, link=https://gitlab.com/postgis/postgis/-/commits/stable-${VER}, alt=status, height="20", title='32/64 bit trixie, PG 15, GDAL 2.4.0, GEOS 3.7.1, PROJ 5.2.0')]] || \\
|| [[Image(https://www.ict.inaf.it/gitlab/postgis/postgis/badges/master/pipeline.svg?ref=refs/heads/${VER}, link=https://www.ict.inaf.it/gitlab/postgis/postgis/-/commits/${VER}, alt=inaf/${VER})]] ||
EOF
Summary of changes:
.cirrus.yml | 158 ---------------------------------------
.github/workflows/ci-freebsd.yml | 119 +++++++++++++++++++++++++++++
.github/workflows/ci-macos.yml | 98 ++++++++++++++++++++++++
configure.ac | 1 +
loader/pgsql2shp-core.c | 2 +
make_dist.sh | 1 -
utils/ci-trac-line.sh | 3 +-
7 files changed, 222 insertions(+), 160 deletions(-)
delete mode 100644 .cirrus.yml
create mode 100644 .github/workflows/ci-freebsd.yml
create mode 100644 .github/workflows/ci-macos.yml
hooks/post-receive
