[SCM] PostGIS branch master updated. 3.6.0rc2-528-gbea3ec551
Fri Jun 12 16:58:48 PDT 2026
the project "PostGIS".
       via  bea3ec551bbf119d2d7663b11b0ab5632c093233 (commit)
       via  19662fc34a6bc4997a3019da981d27a49e6bf86f (commit)
      from  c7ae53a031b86aaa1a4c57a9affbc8693ea48c6a (commit)
revisions in full, below.
commit bea3ec551bbf119d2d7663b11b0ab5632c093233
Author: Regina Obe <lr at pcorp.us>
Date:   Fri Jun 12 19:58:14 2026 -0400
    Update pot for translation
diff --git a/doc/po/templates/postgis-manual.pot b/doc/po/templates/postgis-manual.pot
index 2cd6f8083..49a8f4e11 100644
--- a/doc/po/templates/postgis-manual.pot
+++ b/doc/po/templates/postgis-manual.pot
@@ -6,7 +6,7 @@ msgid ""
 msgstr ""
 "Project-Id-Version: PACKAGE VERSION\n"
 "Report-Msgid-Bugs-To: https://bugs.kde.org\n"
-"POT-Creation-Date: 2025-11-13 16:23+0000\n"
+"POT-Creation-Date: 2026-06-12 20:29+0000\n"
 "PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
 "Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
 "Language-Team: LANGUAGE <kde-i18n-doc at kde.org>\n"
@@ -3156,6 +3156,25 @@ msgstr ""
 msgid ", <xref linkend=\"GetRingEdges\"/>, <xref linkend=\"ST_Azimuth\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Find pairs of topology vertex/segment that are closer than tolerated distance"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns a relation in which each tuple is a pair of vertex/segment where the "
+"vertex is NOT an endpoint of the segment but the distance between them is "
+"below the given tolerance."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.7"
+msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Topology Processing"
@@ -7591,7 +7610,7 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Return the 1-based Nth element geometry of an input geometry which is a "
-"GEOMETRYCOLLECTION, MULTIPOINT, MULTILINESTRING, MULTICURVE, MULTI)POLYGON, "
+"GEOMETRYCOLLECTION, MULTIPOINT, MULTILINESTRING, MULTICURVE, MULTIPOLYGON, "
 "or POLYHEDRALSURFACE. Otherwise, returns NULL."
 msgstr ""
@@ -8234,8 +8253,8 @@ msgstr ""
 #, no-c-format
 msgid ""
 "Index is 1-based as for OGC specs since version 0.8.0. Backward indexing "
-"(negative index) is not in OGC Previous versions implemented this as 0-based "
-"instead."
+"(negative index) is not in OGC. Previous versions implemented this as 0-"
+"based instead."
 msgstr ""
 #. Tag: para
@@ -9245,6 +9264,46 @@ msgid ""
 "linkend=\"ST_ClusterWithinWin\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Window function that returns a tree id for each input geometry, clustering "
+"input geometries into connected trees using the Minimum Spanning Tree "
+"algorithm."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"A window function that builds connected graphs of line strings based on the "
+"Minimum Spanning Tree (MST) of the input geometries. The return value is the "
+"cluster number that the geometry argument participates in, or zero if it is "
+"not part of the minimum tree."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <link xlink:href=\"https://en.wikipedia.org/wiki/"
+"Minimum_spanning_tree\">Minimum Spanning Tree</link> connects all geometries "
+"in the window partition such that the total length of the connecting lines "
+"is minimized. If the graph is not fully connected (e.g. infinite distance "
+"between some geometries), it produces a Minimum Spanning Forest, and each "
+"connected component is assigned a unique tree ID."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Requires GEOS >= 3.15.0"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_ClusterKMeans\"/>, <xref "
+"linkend=\"ST_ClusterIntersectingWin\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -10700,6 +10759,52 @@ msgid ""
 ", <xref linkend=\"ST_CoverageUnion\"/>, <xref linkend=\"ST_CoverageClean\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Computes the unique edges of a polygonal coverage."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns a MultiLineString representing the unique edges of a polygonal "
+"coverage. A polygonal coverage is a set of non-overlapping polygons where "
+"adjacent polygons have matching vertices along shared edges."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <parameter>edgetype</parameter> parameter can be used to select which "
+"edges are returned:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<emphasis role=\"bold\">0 (ALL)</emphasis> - all unique edges (default)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">1 (EXTERIOR)</emphasis> - only exterior edges (non-"
+"shared)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<emphasis role=\"bold\">2 (INTERIOR)</emphasis> - only interior edges "
+"(shared)"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_CoverageSimplify\"/>, <xref "
+"linkend=\"ST_CoverageUnion\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -14147,6 +14252,36 @@ msgid ""
 ", <xref linkend=\"ST_LocateAlong\"/>, <xref linkend=\"ST_LocateBetween\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Returns the interpolated measure of a geometry closest to a point in 3D."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Returns the interpolated measure value of a linear ZM geometry at the "
+"location closest to the given point, using 3D (XYZ) distance for the "
+"projection. Use this function when the geometry has significant Z variation, "
+"such as flight trajectories, where <xref linkend=\"ST_InterpolatePoint\"/> "
+"would give incorrect results by ignoring the Z dimension."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The line must have both Z and M dimensions. The point should have a Z "
+"dimension."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_AddMeasure\"/>, <xref linkend=\"ST_LocateAlong\"/>, "
+"<xref linkend=\"ST_LocateBetween\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid "Interpolates measures along a linear geometry."
@@ -14528,7 +14663,7 @@ msgid ""
 "Return area square feet and transform to Massachusetts state plane meters "
 "(EPSG:26986) to get square meters. Note this is in square feet because 2249 "
 "is Massachusetts State Plane Feet and transformed area is in square meters "
-"since EPSG:26986 is state plane Massachusetts meters"
+"since EPSG:26986 is state plane Massachusetts meters."
 msgstr ""
 #. Tag: para
@@ -15255,7 +15390,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Calculates the length or perimeter of a geometry on an ellipsoid. This is "
+"Calculates the length or perimeter of a geometry on a spheroid. This is "
 "useful if the coordinates of the geometry are in longitude/latitude and a "
 "length is desired without reprojection. The spheroid is specified by a text "
 "value as follows:"
@@ -18372,14 +18507,15 @@ msgstr ""
 #. Tag: title
 #, no-c-format
-msgid "Examples: 2.5Dish"
+msgid "Examples: 2.5D geometries"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"Note this is not a true intersection, compare to the same example using "
-"<xref linkend=\"ST_3DIntersection\"/>."
+"Note this is not a true 3D intersection. It uses 2.5D geometries (geometries "
+"with Z ordinates, but where calculations are performed in 2D). Compare to "
+"the same example using <xref linkend=\"ST_3DIntersection\"/>."
 msgstr ""
 #. Tag: para
@@ -18861,8 +18997,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 ", <xref linkend=\"ST_UnaryUnion\"/>, <xref linkend=\"ST_MemUnion\"/>, <xref "
-"linkend=\"ST_Intersection\"/>, <xref linkend=\"ST_Difference\"/>, <xref "
-"linkend=\"ST_SymDifference\"/>, <xref linkend=\"ST_ReducePrecision\"/>"
+"linkend=\"ST_Collect\"/>, <xref linkend=\"ST_Intersection\"/>, <xref "
+"linkend=\"ST_Difference\"/>, <xref linkend=\"ST_SymDifference\"/>, <xref "
+"linkend=\"ST_LineMerge\"/>"
 msgstr ""
 #. Tag: title
@@ -19311,6 +19448,86 @@ msgid ""
 "linkend=\"ST_SimplifyVW\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid ""
+"Returns a smoothed version of a geometry, using the Catmull-Rom spline "
+"algorithm"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Smoothes a linear or polygonal geometry using the <link xlink:href=\"https://"
+"en.wikipedia.org/wiki/Centripetal_Catmull%E2%80%93Rom_spline\">Catmull-Rom "
+"spline</link> algorithm. Unlike <xref linkend=\"ST_ChaikinSmoothing\"/>, "
+"this is an <emphasis>interpolating</emphasis> spline: the output curve "
+"passes through every original vertex. Between each pair of consecutive "
+"original vertices, <varname>nSegments</varname> - 1 new intermediate points "
+"are inserted."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The <varname>nSegments</varname> parameter controls the density of the "
+"output. With <varname>nSegments</varname> = 5 (the default), each original "
+"span is divided into 5 sub-segments (inserting 4 new points per span). The "
+"minimum value is 2."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"At least 4 input vertices are required to apply smoothing; geometries with "
+"fewer vertices are returned unchanged. Points and multipoints are always "
+"returned unchanged."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"The output vertex count grows as <literal>1 + (N-1) * nSegments</literal> "
+"for open lines, and <literal>1 + N * nSegments</literal> for closed rings, "
+"where N is the number of input vertices. For large geometries, use a "
+"simplification function on the result to reduce the number of points (see "
+"<xref linkend=\"ST_Simplify\"/>, <xref "
+"linkend=\"ST_SimplifyPreserveTopology\"/> and <xref "
+"linkend=\"ST_SimplifyVW\"/>)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Smoothing a 4-point collinear line with default nSegments=5:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Smoothing a Polygon using nSegments = 5 and 10:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "nSegments = 5"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "nSegments = 10"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Smoothing a LineString using nSegments = 5 and 10:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"ST_Simplify\"/>, <xref "
+"linkend=\"ST_SimplifyPreserveTopology\"/>, <xref linkend=\"ST_SimplifyVW\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -30192,6 +30409,24 @@ msgid ""
 "CG_StraightSkeleton (slower case)."
 msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"When <varname>projected</varname> is <varname>true</varname>, free endpoints "
+"of the medial axis are extended to reach the polygon boundary (projected "
+"medial axis). Requires SFCGAL 2.3.0+. When built against an older SFCGAL "
+"version, a notice is emitted and the non-projected result is returned "
+"instead."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Availability: 3.7.0 - <varname>projected</varname> parameter. Requires "
+"SFCGAL >= 2.3.0 for projected result; falls back to non-projected with a "
+"notice on older versions."
+msgstr ""
 #. Tag: para
 #, no-c-format
 msgid "A polygon and its approximate medial axis"
@@ -30202,6 +30437,215 @@ msgstr ""
 msgid ", <xref linkend=\"CG_StraightSkeletonPartition\"/>"
 msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Generate a flat (box) roof from a footprint polygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Generate a flat (box-shaped) roof as a 3D <varname>PolyhedralSurface Z</"
+"varname> from a 2D footprint polygon. The roof height above the ground plane "
+"is given by <varname>height</varname> (default 3.0)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.7.0 - requires SFCGAL >= 2.3.0."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"CG_GenerateGableRoof\"/>, <xref "
+"linkend=\"CG_GenerateSkillionRoof\"/>, <xref linkend=\"CG_GenerateRoof\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Generate a hipped roof from a footprint polygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Generate a hipped roof as a 3D <varname>PolyhedralSurface Z</varname> from a "
+"2D footprint polygon. All sides slope upward to meet at a ridge or apex. The "
+"roof height is given by <varname>height</varname> (default 3.0)."
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Generate a gable roof from a footprint polygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Generate a gable roof as a 3D <varname>PolyhedralSurface Z</varname> from a "
+"2D footprint polygon. Two opposite sides are vertical gable ends; the other "
+"two sides slope to a horizontal ridge. <varname>height</varname> sets the "
+"ridge height above the ground (default 3.0) and <varname>slope_angle</"
+"varname> controls the pitch in degrees (default 30.0). The SRID of the input "
+"geometry is preserved."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+", <xref linkend=\"CG_GenerateHippedRoof\"/>, <xref "
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Generate a skillion (single-slope) roof from a footprint polygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Generate a skillion (single-slope, shed-style) roof as a 3D "
+"<varname>PolyhedralSurface Z</varname> from a 2D footprint polygon. The "
+"entire roof surface slopes in one direction. <varname>height</varname> sets "
+"the maximum ridge height (default 3.0), <varname>slope_angle</varname> sets "
+"the pitch in degrees (default 30.0), and <varname>primary_edge_index</"
+"varname> selects which polygon edge defines the high side (0-based, default "
+"0)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"When the combination of <varname>height</varname> and <varname>slope_angle</"
+"varname> would cause a side wall to vanish (the slope reaches the far edge "
+"before the full height is achieved), that face is omitted from the result. "
+"This means the number of output patches can vary depending on the parameters "
+"— a lower height relative to the footprint depth produces more faces than a "
+"taller, steeper configuration."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Height 2.0 produces 6 faces (all walls present); height 4.0 produces 5 faces "
+"(one side wall is filtered out because the slope reaches the far edge before "
+"the full height)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"linkend=\"CG_GenerateGableRoof\"/>, <xref linkend=\"CG_GenerateRoof\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Generate a roof of the requested type from a footprint polygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Generate a roof as a 3D <varname>PolyhedralSurface Z</varname> from a 2D "
+"footprint polygon. The <varname>roof_type</varname> parameter selects the "
+"roof style (default <literal>'HIPPED'</literal>):"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<varname>FLAT</varname> — flat box roof."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<varname>HIPPED</varname> — hipped roof (all sides slope to apex)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>GABLE</varname> — gable roof (two sloping sides, two vertical ends)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "<varname>SKILLION</varname> — single-slope (shed) roof."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>height</varname> sets the roof height (default 3.0), "
+"<varname>slope_angle</varname> sets the pitch in degrees (default 30.0), and "
+"<varname>primary_edge_index</varname> selects the reference edge for "
+"skillion roofs (default 0)."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"linkend=\"CG_GenerateGableRoof\"/>, <xref "
+"linkend=\"CG_GenerateSkillionRoof\"/>"
+msgstr ""
+#. Tag: refpurpose
+#, no-c-format
+msgid "Repair an invalid polygon or multipolygon."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"Repair an invalid polygon or multipolygon using CGAL's 2D Polygon Repair "
+"algorithm. Returns a <varname>MultiPolygon</varname>."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "The <varname>rule</varname> parameter controls the repair strategy:"
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>EVEN_ODD</varname> (default) — areas covered an odd number of times "
+"are kept. Available with CGAL 6.0+."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>NON_ZERO</varname> — areas with non-zero winding number are kept. "
+"Requires CGAL 6.1+."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>UNION</varname> — union of all input polygons. Requires CGAL 6.1+."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ""
+"<varname>INTERSECTION</varname> — intersection of all input polygons. "
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid "Availability: 3.7.0 - requires SFCGAL >= 2.3.0 and CGAL >= 6.0."
+msgstr ""
+#. Tag: para
+#, no-c-format
+msgid ", <xref linkend=\"ST_MakeValid\"/>"
+msgstr ""
 #. Tag: refpurpose
 #, no-c-format
 msgid ""
@@ -32882,45 +33326,21 @@ msgstr ""
 #. Tag: title
 #, no-c-format
-msgid "PostGIS 3.6.0rc2"
+msgid "PostGIS 3.7.0beta1"
 msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "2025/08/25"
+msgid "2026/06/xx"
 msgstr ""
 #. Tag: para
 #, no-c-format
 msgid ""
-"This version requires PostgreSQL 12-18beta3, GEOS 3.8 or higher, and Proj "
-"6.1+. To take advantage of all features, GEOS 3.14+ is needed. To take "
-"advantage of all SFCGAL features, SFCGAL 2.2+ is needed."
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Many thanks to our translation teams, in particular:"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Teramoto Ikuhiro (Japanese Team)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Daniel Nylander (Swedish Team)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Dapeng Wang, Zuo Chenwei from HighGo (Chinese Team)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid "Denys Kovshun (Ukrainian Team)"
+"This version requires GEOS 3.10 or higher. PostgreSQL 14-19beta1 required. "
+"Proj 6.1+ required. To take advantage of all features postgis extension "
+"features, GEOS 3.15+ is needed. To take advantage of all postgis_sfcgal "
+"extension features SFCGAL 2.2+ is needed."
 msgstr ""
 #. Tag: title
@@ -32930,68 +33350,7 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5799\">#5799</"
-"link>, make ST_TileEnvelope clips envelopes to tile plane extent (Paul "
-"Ramsey)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5829\">#5829</"
-"link>, remove constraint checking from geometry_columns view (Paul Ramsey)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3373\">#3373</"
-"link>, <link xlink:href=\"https://git.osgeo.org/gitea/postgis/postgis/"
-"pulls/255\">GT-255</link>, [topology] Support for upgrading domains (Ayo "
-"Adesugba, U.S. Census Bureau)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://git.osgeo.org/gitea/postgis/postgis/"
-"pulls/252\">GT-252</link>, ST_NumGeometries/ST_GeometryN treat TIN and "
-"PolyhedralSurface as unitary geometries, use ST_NumPatches/ST_PatchN for "
-"patch access (Loïc Bartoletti)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/3110\">#3110</"
-"pulls/242\">GT-242</link>, [topology] Support for bigint (Ayo Adesugba, U.S. "
-"Census Bureau)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5359\">#5359</"
-"link>, <link xlink:href=\"https://trac.osgeo.org/postgis/"
-"ticket/5897\">#5897</link>, <link xlink:href=\"https://git.osgeo.org/gitea/"
-"postgis/postgis/pulls/260\">GT-260</link> [tiger_geocoder] Use @extschema:"
-"extension@ for PG >= 16 to schema qualify dependent extensions, switch to "
-"use typmod for tiger tables (Regina Obe)"
-msgstr ""
-#. Tag: title
-#, no-c-format
-msgid "Removed / Deprecate signatures"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5498\">#5498</link> "
-"Drop st_approxquantile(raster, double precision), wasn't usable as it "
-"triggered is not unique error when used (Regina Obe)"
+msgid "Place holder"
 msgstr ""
 #. Tag: title
@@ -32999,112 +33358,6 @@ msgstr ""
 msgid "New Features"
 msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://github.com/postgis/postgis/pull/803\">GH-803</"
-"link>, [sfcgal] ADD CG_Simplify function (Loïc Bartoletti)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://github.com/postgis/postgis/pull/805\">GH-805</"
-"link>, [sfcgal] Add M support for SFCGAL >= 1.5.0 (Loïc Bartoletti)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://github.com/postgis/postgis/pull/801\">GH-801</"
-"link>, [sfcgal] ADD CG_3DAlphaWrapping function (Jean Felder)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5894\">#5894</"
-"link>, [topology] TotalTopologySize (Sandro Santilli)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5890\">#5890</"
-"link>, [topology] ValidateTopologyPrecision, MakeTopologyPrecise (Sandro "
-"Santilli)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5861\">#5861</"
-"link>, [topology] Add --drop-topology switch to pgtopo_import (Sandro "
-"Santilli)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/1247\">#1247</"
-"link>, [raster] ST_AsRasterAgg (Sandro Santilli)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5784\">#5784</"
-"pulls/223\">GT-223</link> Export circ_tree_distance_tree_internal for "
-"mobilitydb use (Maxime Schoemans)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"pulls/228\">GT-228</link> [sfcgal] Add new functions (Scale, Translate, "
-"Rotate, Buffer 3D and Straight Skeleton Partition) from SFCGAL 2 (Loïc "
-"Bartoletti)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"[raster] New GUC postgis.gdal_cpl_debug, enables GDAL debugging messages and "
-"routes them into the PostgreSQL logging system. (Paul Ramsey)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"<link xlink:href=\"https://trac.osgeo.org/postgis/ticket/5841\">#5841</"
-"link>, Change interrupt handling to remove use of pqsignal to support PG 18 "
-"(Paul Ramsey)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"Add ST_CoverageClean to edge match and gap remove polygonal coverages (Paul "
-"Ramsey) from GEOS 3.14 (Martin Davis)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"pulls/242\">GT-242</link> [topology] Support for bigint (Ayo Adesugba, U.S. "
-"Census Bureau)"
-msgstr ""
-#. Tag: para
-#, no-c-format
-msgid ""
-"[raster] Add ST_ReclassExact to quickly remap values in raster (Paul Ramsey)"
-msgstr ""
 #. Tag: title
 #, no-c-format
 msgid "Reporting Problems"
@@ -33298,7 +33551,8 @@ msgid ""
 "geometry value, they must be defined for each point in the geometry. If a "
 "geometry has Z or M ordinates the <emphasis role=\"bold\">coordinate "
 "dimension</emphasis> is 3D; if it has both Z and M the coordinate dimension "
-"is 4D."
+"is 4D. The coordinate dimension is at least 2, because every geometry has at "
+"least X and Y coordinates."
 msgstr ""
 #. Tag: para
@@ -33320,8 +33574,8 @@ msgstr ""
 msgid ""
 "The geometry <emphasis role=\"bold\">dimension</emphasis> is a property of "
 "geometry types. Point types have dimension 0, linear types have dimension 1, "
-"and polygonal types have dimension 2. Collections have the dimension of the "
-"maximum element dimension."
+"polygonal types have dimension 2, and solid types have dimension 3. "
+"Collections have the dimension of the maximum element dimension."
 msgstr ""
 #. Tag: para
@@ -33352,7 +33606,9 @@ msgid ""
 "role=\"bold\">boundary</emphasis> and <emphasis role=\"bold\">exterior</"
 "emphasis> are defined for each geometry type. Geometries are topologically "
 "closed, so they always contain their boundary. The boundary is a geometry of "
-"dimension one less than that of the geometry itself."
+"dimension one less than that of the geometry itself. For example, the "
+"boundary of a Polygon is its rings (LineStrings), the boundary of a "
+"LineString is its endpoints (Points), and the boundary of a Point is empty."
 msgstr ""
 #. Tag: para
@@ -33360,7 +33616,7 @@ msgstr ""
 msgid ""
 "The OGC geometry model defines validity rules for each geometry type. These "
 "rules ensure that geometry values represents realistic situations (e.g. it "
-"is possible to specify a polygon with a hole lying outside the shell, but "
+"is possible to specify a polygon with a hole lying outside its shell, but "
 "this makes no sense geometrically and is thus invalid). PostGIS also allows "
 "storing and manipulating invalid geometry values. This allows detecting and "
 "fixing them if needed. See <xref linkend=\"OGC_Validity\"/>"
@@ -33452,7 +33708,10 @@ msgstr ""
 #, no-c-format
 msgid ""
 "A MultiPolygon is a collection of non-overlapping, non-adjacent Polygons. "
-"Polygons in the collection may touch only at a finite number of points."
+"Polygons in the collection may touch only at a finite number of points. (Two "
+"polygons are adjacent if they share an edge. They touch if they share only "
+"points or edges on their boundaries). For more details on MultiPolygon "
+"validity, see <xref linkend=\"OGC_Validity\"/>."
 msgstr ""
 #. Tag: title
@@ -33781,7 +34040,7 @@ msgid ""
 "The <varname>geometry</varname> data type is <emphasis>opaque</emphasis>, "
 "which means that all access is done via invoking functions on geometry "
 "values. Functions allow creating geometry objects, accessing or updating all "
-"internal fields, and compute new geometry values. PostGIS supports all the "
+"internal fields, and computing new geometry values. PostGIS supports all the "
 "functions specified in the OGC <link xlink:href=\"https://portal.ogc.org/"
 "files/?artifact_id=25354\"><emphasis>Simple feature access - Part 2: SQL "
 "option</emphasis></link> (SFS) specification, as well many others. See <xref "
@@ -34313,10 +34572,12 @@ msgstr ""
 #, no-c-format
 msgid ""
 "By default, all distance and area calculations are done on the spheroid. You "
-"should find that the results of calculations in local areas match up will "
+"should find that the results of calculations in local areas match up well "
 "with local planar results in good local projections. Over larger areas, the "
 "spheroidal calculations will be more accurate than any calculation done on a "
-"projected plane."
+"projected plane. The difference is that the spheroid takes into account the "
+"curvature and non-spherical shape of the Earth, whereas planar calculations "
+"assume a flat surface."
 msgstr ""
 #. Tag: para
@@ -35133,7 +35394,9 @@ msgstr ""
 #. Tag: para
 #, no-c-format
-msgid "The coordinate dimension (2, 3 or 4) of the column."
+msgid ""
+"The coordinate dimension (2, 3 or 4) of the column. The coordinate dimension "
+"is at least 2, representing X and Y coordinates."
 msgstr ""
 #. Tag: para
@@ -36480,10 +36743,11 @@ msgstr ""
 msgid ""
 "For example, consider a linear dataset representing a road network. It may "
 "be required to identify all road segments that cross each other, not at a "
-"point, but in a line (perhaps to validate some business rule). In this case "
-"<xref linkend=\"ST_Crosses\"/> does not provide the necessary spatial "
-"filter, since for linear features it returns <varname>true</varname> only "
-"where they cross at a point."
+"point, but in a line (perhaps to validate a business rule such as ensuring "
+"that no two different roads share a common segment). In this case <xref "
+"linkend=\"ST_Crosses\"/> does not provide the necessary spatial filter, "
+"since for linear features it returns <varname>true</varname> only where they "
+"cross at a point."
 msgstr ""
 #. Tag: para
@@ -37830,9 +38094,9 @@ msgstr ""
 #, no-c-format
 msgid ""
 "If the optional <code>gridSize</code> parameter is given (GEOS-3.9.0 or "
-"higher required), all result vertices are guaranteed to fall on a grid of "
-"the specified size. For the operation to give predictable results all the "
-"input vertices must fall already on the specified grid, see <xref "
+"higher required), all result vertices are guaranteed to fall on a snap-"
+"rounded grid of the specified size. Note that operations performed on a grid "
+"may contain small artifacts produced during grid alignment, see <xref "
 "linkend=\"ST_ReducePrecision\"/>."
 msgstr ""
commit 19662fc34a6bc4997a3019da981d27a49e6bf86f
Date:   Fri Jun 12 13:22:11 2026 -0400
    Flip winnie to by default build with sfcgal 2.3.0
diff --git a/ci/winnie/winnie_common.sh b/ci/winnie/winnie_common.sh
index 49f4050b9..1739cd7d7 100644
--- a/ci/winnie/winnie_common.sh
+++ b/ci/winnie/winnie_common.sh
@@ -15,7 +15,7 @@ if  [[ "${OVERRIDE}" == '' ]] ; then
 	export GEOS_VER=3.13.1
 	export GDAL_VER=3.9.2
 	export PROJ_VER=8.2.1
-	export SFCGAL_VER=2.1.0
+	export SFCGAL_VER=2.3.0
 	export CGAL_VER=6.0.1
 	export ICON_VER=1.17
 	export ZLIB_VER=1.2.13
Summary of changes:
 ci/winnie/winnie_common.sh          |   2 +-
 doc/po/templates/postgis-manual.pot | 716 ++++++++++++++++++++++++------------
 2 files changed, 491 insertions(+), 227 deletions(-)
hooks/post-receive
