[PostGIS] #6082: Debbie failing on docbook ja building
trac at osgeo.org
Sun Jun 14 02:30:29 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.7.0
Component: documentation | Version: master
Keywords: |
https://debbie.postgis.net/job/PostGIS_Make_Dist/label=debbie/7462/consoleFull
02:58:39 Build postgis-out.pdf
02:59:28 xelatex failed
02:59:28 postgis-out.tex:30067: Undefined control sequence.
02:59:28 postgis-out.tex:30067: leading text: }
02:59:29
02:59:29 A possible reason for transformation failure is invalid DocBook
02:59:29 (as reported by xmllint)
02:59:29
02:59:29 Error: xelatex compilation failed
02:59:29 make[1]: *** [../../Makefile:428: postgis-3.7.0dev-ja.pdf] Error
1
02:59:29 make[1]: Leaving directory
'/var/lib/jenkins/workspace/PostGIS_Make_Dist/label/debbie/2259dee51e88ca4cd9301b529dd5334f681d9f8a/doc/po/ja'
02:59:29 make: *** [../Makefile.local:18: local-pdf-install] Error 2
02:59:29 make: Leaving directory
02:59:29 Build step 'Execute shell' marked build as failure
Woodie hasn't registered any errors though and also tests translations.
This started happening after I wiped out the old 3.6 release notes and
also did an update of template. But I think the template happened after,
so maybe it was the NEWS change. The english pdf is fine though so maybe
it's just an out-of-sync issue with weblate.
[e1dbdc5ff/git]
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6082>
