[PostGIS] #6082: Debbie failing on docbook ja building
PostGIS trac at osgeo.org
Thu Jun 18 08:18:29 PDT 2026
  Reporter:  robe           |      Owner:  robe
      Type:  defect         |     Status:  closed
  Priority:  medium         |  Milestone:  PostGIS 3.7.0
 Component:  documentation  |    Version:  master
Resolution:  fixed          |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"746769bc9603c34262f2a704369a5efda9ac4ebe/git" 746769b/git]:
 {{{#!CommitTicketReference repository="git"
 revision="746769bc9603c34262f2a704369a5efda9ac4ebe"
 doc: fix Japanese PDF listing arrows
 Replace non-ASCII arrows in the CG_GenerateSkillionRoof SQL program
 listing so the Japanese PDF build does not trip over undefined
 XeTeX/listings control sequences.
 Closes https://github.com/postgis/postgis/pull/928
 Closes #6082
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6082#comment:1>
