[SCM] PostGIS branch master updated. 3.6.0rc2-535-gc8ea8a68f
git at osgeo.org
git at osgeo.org
Tue Jun 16 11:51:50 PDT 2026
the project "PostGIS".
via c8ea8a68f1b56b142988a8d1e61656a73f5084f5 (commit)
from 2259dee51e88ca4cd9301b529dd5334f681d9f8a (commit)
revisions in full, below.
commit c8ea8a68f1b56b142988a8d1e61656a73f5084f5
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Tue Jun 16 18:35:05 2026 +0400
Fix SFCGAL 2.3 alphashape regression output
diff --git a/sfcgal/regress/alphashape.sql b/sfcgal/regress/alphashape.sql
index 6f3d18fc3..15b5e47c1 100644
--- a/sfcgal/regress/alphashape.sql
+++ b/sfcgal/regress/alphashape.sql
@@ -4,6 +4,6 @@ SELECT 'CG_AlphaShape_hole',
ST_AsText(ST_Normalize(ST_Multi(CG_AlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))', allow_holes => true))),2);
SELECT 'CG_OptimalAlphaShape_default',
- ST_AsText(ST_Normalize(ST_Multi(CG_OptimalAlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))'))),2);
+ ST_AsText(ST_Normalize(ST_Multi(CG_OptimalAlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))'))),2) IN ('MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,
7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.8 5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6)))', 'MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.3 6.4,8.8 5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6)))');
SELECT 'CG_OptimalAlphaShape_hole',
- ST_AsText(ST_Normalize(ST_Multi(CG_OptimalAlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))', allow_holes => true))),2);
+ ST_AsText(ST_Normalize(ST_Multi(CG_OptimalAlphaShape('MultiPoint ((6.3 8.4),(7.6 8.8),(6.8 7.3),(5.3 1.8),(9.1 5),(8.1 7),(8.8 2.9),(2.4 8.2),(3.2 5.1),(3.7 2.3),(2.7 5.4),(8.4 1.9),(7.5 8.7),(4.4 4.2),(7.7 6.7),(9 3),(3.6 6.1),(3.2 6.5),(8.1 4.7),(8.8 5.8),(6.8 7.3),(4.9 9.5),(8.1 6),(8.7 5),(7.8 1.6),(7.9 2.1),(3 2.2),(7.8 4.3),(2.6 8.5),(4.8 3.4),(3.5 3.5),(3.6 4),(3.1 7.9),(8.3 2.9),(2.7 8.4),(5.2 9.8),(7.2 9.5),(8.5 7.1),(7.5 8.4),(7.5 7.7),(8.1 2.9),(7.7 7.3),(4.1 4.2),(8.3 7.2),(2.3 3.6),(8.9 5.3),(2.7 5.7),(5.7 9.7),(2.7 7.7),(3.9 8.8),(6 8.1),(8 7.2),(5.4 3.2),(5.5 2.6),(6.2 2.2),(7 2),(7.6 2.7),(8.4 3.5),(8.7 4.2),(8.2 5.4),(8.3 6.4),(6.9 8.6),(6 9),(5 8.6),(4.3 8),(3.6 7.3),(3.6 6.8),(4 7.5),(2.4 6.7),(2.3 6),(2.6 4.4),(2.8 3.3),(4 3.2),(4.3 1.9),(6.5 1.6),(7.3 1.6),(3.8 4.6),(3.1 5.9),(3.4 8.6),(4.5 9),(6.4 9.7))', allow_holes => true))),2) IN ('MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4
9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.8 5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6),(3.6 6.1,3.8 4.6,4.4 4.2,4.8 3.4,5.4 3.2,5.5 2.6,6.2 2.2,7 2,7.6 2.7,8.1 2.9,7.8 4.3,8.1 4.7,8.2 5.4,8.1 6,7.7 6.7,6.8 7.3,6 8.1,5 8.6,4.3 8,4 7.5,3.6 6.8,3.6 6.1)))', 'MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.3 6.4,8.8 5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6),(3.6 6.1,3.8 4.6,4.4 4.2,4.8 3.4,5.4 3.2,5.5 2.6,6.2 2.2,7 2,7.6 2.7,8.1 2.9,7.8 4.3,8.1 4.7,8.2 5.4,8.1 6,7.7 6.7,6.8 7.3,6 8.1,5 8.6,4.3 8,4 7.5,3.6 6.8,3.6 6.1)))');
diff --git a/sfcgal/regress/alphashape_expected b/sfcgal/regress/alphashape_expected
index 6f24a3db0..4361c47ee 100644
--- a/sfcgal/regress/alphashape_expected
+++ b/sfcgal/regress/alphashape_expected
@@ -1,4 +1,4 @@
CG_AlphaShape_default|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,8.3 7.2,8.5 7.1,8.8 5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6)))
CG_AlphaShape_hole|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,8.3 7.2,8.5 7.1,8.8 5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6),(3.6 6.1,3.8 4.6,4.4 4.2,5.4 3.2,6.2 2.2,7.6 2.7,7.8 4.3,8.1 4.7,8.2 5.4,8.1 6,7.7 6.7,6.8 7.3,6 8.1,4.3 8,4 7.5,3.6 6.8,3.6 6.1)))
-CG_OptimalAlphaShape_default|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.3 6.4,8.8 5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6)))
-CG_OptimalAlphaShape_hole|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.3 6.4,8.8 5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6),(3.6 6.1,3.8 4.6,4.4 4.2,4.8 3.4,5.4 3.2,5.5 2.6,6.2 2.2,7 2,7.6 2.7,8.1 2.9,7.8 4.3,8.1 4.7,8.2 5.4,8.1 6,7.7 6.7,6.8 7.3,6 8.1,5 8.6,4.3 8,4 7.5,3.6 6.8,3.6 6.1)))
+CG_OptimalAlphaShape_default|t
+CG_OptimalAlphaShape_hole|t
Summary of changes:
sfcgal/regress/alphashape.sql | 4 ++--
sfcgal/regress/alphashape_expected | 4 ++--
2 files changed, 4 insertions(+), 4 deletions(-)
hooks/post-receive
