[PostGIS] #6081: Test failure with SFCGAL 2.3.0
trac at osgeo.org
Sun Jun 14 02:36:47 PDT 2026
Reporter: Bas Couwenberg | Owner: Loïc Bartoletti
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: sfcgal | Version: 3.6.x
Resolution: | Keywords:
Comment (by robe):
Did you get a chance to test this with 3.7.0dev. I think I was running
into same issue with our raspberry pi ci but that seems all clear now.
See #6068
So perhaps we need to backport some fixes. Although in that case, it was
only failing on the CG_OpitmalAlphaShape, but we mind have fixed the other
issues earlier on.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6081#comment:1>
