[PostGIS] #6081: Test failure with SFCGAL 2.3.0
trac at osgeo.org
Mon Jun 15 00:31:56 PDT 2026
Reporter: Bas Couwenberg | Owner: Loïc Bartoletti
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 3.6.5
Component: sfcgal | Version: 3.6.x
Resolution: | Keywords:
Comment (by Bas Couwenberg):
Replying to [comment:1 robe]:
> Did you get a chance to test this with 3.7.0dev.
No, that's not in Debian.
With the changes from master the build still fails:
--- ./sfcgal/regress/alphashape_expected 2026-06-15
07:12:23.000000000 +0000
+++ /tmp/pgis_reg/test_172_out 2026-06-15 07:15:17.155198743 +0000
@@ -1,4 +1,4 @@
CG_AlphaShape_default|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4
6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2 9.8,5.7
9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,8.3 7.2,8.5 7.1,8.8 5.8,8.9 5.3,9.1
5,8.7 4.2,9 3,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3 1.8,4.3 1.9,3.7 2.3,3
2.2,2.8 3.3,2.3 3.6)))
CG_AlphaShape_hole|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3 6,2.4
2.2,2.8 3.3,2.3 3.6),(3.6 6.1,3.8 4.6,4.4 4.2,5.4 3.2,6.2 2.2,7.6 2.7,7.8
4.3,8.1 4.7,8.2 5.4,8.1 6,7.7 6.7,6.8 7.3,6 8.1,4.3 8,4 7.5,3.6 6.8,3.6
6.1)))
-CG_OptimalAlphaShape_default|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3
6,2.4 6.7,2.7 7.7,2.4 8.2,2.6 8.5,3.4 8.6,3.9 8.8,4.5 9,4.9 9.5,5.2
9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.3
6.4,8.8 5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5
1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6)))
-CG_OptimalAlphaShape_hole|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3
1.6,5.3 1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6),(3.6 6.1,3.8 4.6,4.4
4.2,4.8 3.4,5.4 3.2,5.5 2.6,6.2 2.2,7 2,7.6 2.7,8.1 2.9,7.8 4.3,8.1
4.7,8.2 5.4,8.1 6,7.7 6.7,6.8 7.3,6 8.1,5 8.6,4.3 8,4 7.5,3.6 6.8,3.6
6.1)))
+CG_OptimalAlphaShape_default|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3
9.8,5.7 9.7,6.4 9.7,7.2 9.5,7.6 8.8,7.5 8.4,7.5 7.7,8.3 7.2,8.5 7.1,8.8
5.8,8.9 5.3,9.1 5,8.7 4.2,9 3,8.8 2.9,8.4 1.9,7.8 1.6,7.3 1.6,6.5 1.6,5.3
+CG_OptimalAlphaShape_hole|MULTIPOLYGON(((2.3 3.6,2.6 4.4,2.7 5.4,2.3
1.8,4.3 1.9,3.7 2.3,3 2.2,2.8 3.3,2.3 3.6),(3.6 6.1,3.8 4.6,4.4 4.2,4.8
3.4,5.4 3.2,5.5 2.6,6.2 2.2,7 2,7.6 2.7,8.1 2.9,7.8 4.3,8.1 4.7,8.2
5.4,8.1 6,7.7 6.7,6.8 7.3,6 8.1,5 8.6,4.3 8,4 7.5,3.6 6.8,3.6 6.1)))
> I think I was running into same issue with our raspberry pi ci but that
seems all clear now.
> See #6068
That doesn't apply to 3.6.4 because it changes
`sfcgal/regress/alphashape_components*` which doesn't exist in 3.6.x which
has `sfcgal/regress/alphashape*`.
> So perhaps we need to backport some fixes. Although in that case, it
was only failing on the CG_OpitmalAlphaShape, but we mind have fixed the
other issues earlier on.
You may need to build your SFCGAL 2.3.0 with CGAL 6.2 as is the case in
Debian unstable.
Note that is broken on i386:
https://gitlab.com/sfcgal/SFCGAL/-/work_items/326
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6081#comment:2>
