[SCM] PostGIS branch master updated. 3.6.0rc2-545-g5ec62d698
git at osgeo.org
git at osgeo.org
Wed Jun 17 11:45:59 PDT 2026
the project "PostGIS".
via 5ec62d6985632cc603289b2e7af5efa693d683ca (commit)
via 435ad25bf7d4e27e1fe4f583a7bdaf19d4cb3f32 (commit)
via d0a4c994ad7291cf4bf85ee556a43a8c3af43b64 (commit)
via d01c6a3d91ab6018daf086cde59e0e23faaa9389 (commit)
via 52eb39e6c6fea9ae4aef600f171f6d9aa38ee561 (commit)
from d622df60655e5c4ba4cd77dcfdf07b76c47b4016 (commit)
revisions in full, below.
commit 5ec62d6985632cc603289b2e7af5efa693d683ca
Merge: d622df606 435ad25bf
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Wed Jun 17 22:43:02 2026 +0400
Merge remote-tracking branch 'gh/pr/885/head'
commit 435ad25bf7d4e27e1fe4f583a7bdaf19d4cb3f32
Date: Wed Jun 17 01:22:25 2026 +0400
test: place GMP libs after liblwgeom
diff --git a/NEWS b/NEWS
index 443712616..54811e708 100644
--- a/NEWS
+++ b/NEWS
@@ -50,6 +50,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
* Bug Fixes *
+ - GH-885, [topology] Avoid GMP overflow in ring orientation for very large
+ finite coordinates (Darafei Praliaskouski)
- Build PostgreSQL extension modules with `-fno-semantic-interposition` when
available so LTO can optimize same-DSO calls to exported PostGIS
entry points directly instead of routing through the module PLT; in
diff --git a/liblwgeom/cunit/Makefile.in b/liblwgeom/cunit/Makefile.in
index 6a206e9b2..3999c5523 100644
--- a/liblwgeom/cunit/Makefile.in
+++ b/liblwgeom/cunit/Makefile.in
@@ -22,7 +22,8 @@ LIBTOOL = @LIBTOOL@
CUNIT_LDFLAGS=@CUNIT_LDFLAGS@
CUNIT_CPPFLAGS = -I$(srcdir)/.. -I$(builddir)/.. @CUNIT_CPPFLAGS@ @CPPFLAGS@
CFLAGS=$(CUNIT_CPPFLAGS) @CFLAGS@
-LDFLAGS = @GEOS_LDFLAGS@ @PROJ_LDFLAGS@ @GMP_LIBS@ $(CUNIT_LDFLAGS)
+LDFLAGS = @GEOS_LDFLAGS@ @PROJ_LDFLAGS@ $(CUNIT_LDFLAGS)
+LIBLWGEOM_LDFLAGS = @GMP_LIBS@
VPATH = $(srcdir)
@@ -108,7 +109,7 @@ endif
# Build the main unit test executable
cu_tester: ../liblwgeom.la $(OBJS) cu_tester.h
- $(LIBTOOL) --mode=link $(CC) $(CFLAGS) -o $@ $(OBJS) $(LDFLAGS) -static ../liblwgeom.la
+ $(LIBTOOL) --mode=link $(CC) $(CFLAGS) -o $@ $(OBJS) $(LDFLAGS) -static ../liblwgeom.la $(LIBLWGEOM_LDFLAGS)
# Command to build each of the .o files
$(OBJS): %.o: %.c
commit d0a4c994ad7291cf4bf85ee556a43a8c3af43b64
Date: Wed Jun 17 00:36:20 2026 +0400
test: link CUnit GMP libs through LDFLAGS
index 65c05d890..6a206e9b2 100644
@@ -22,7 +22,7 @@ LIBTOOL = @LIBTOOL@
-LDFLAGS = @GEOS_LDFLAGS@ @PROJ_LDFLAGS@ $(CUNIT_LDFLAGS)
+LDFLAGS = @GEOS_LDFLAGS@ @PROJ_LDFLAGS@ @GMP_LIBS@ $(CUNIT_LDFLAGS)
VPATH = $(srcdir)
@@ -108,7 +108,7 @@ endif
- $(LIBTOOL) --mode=link $(CC) $(CFLAGS) -o $@ $(OBJS) $(LDFLAGS) -static ../liblwgeom.la @GMP_LIBS@
$(OBJS): %.o: %.c
commit d01c6a3d91ab6018daf086cde59e0e23faaa9389
Date: Wed Jun 17 00:10:33 2026 +0400
liblwgeom: link CUnit tester with GMP
index 14e41aed3..65c05d890 100644
+ $(LIBTOOL) --mode=link $(CC) $(CFLAGS) -o $@ $(OBJS) $(LDFLAGS) -static ../liblwgeom.la @GMP_LIBS@
$(OBJS): %.o: %.c
commit 52eb39e6c6fea9ae4aef600f171f6d9aa38ee561
Date: Thu Jun 11 07:43:43 2026 +0400
Avoid GMP overflow in topology ring orientation
index 791be060e..14e41aed3 100644
@@ -58,6 +58,7 @@ OBJS= \
cu_split.o \
cu_stringbuffer.o \
cu_triangulate.o \
+ cu_topo.o \
cu_homogenize.o \
cu_force_dims.o \
cu_force_sfs.o \
diff --git a/liblwgeom/cunit/cu_tester.c b/liblwgeom/cunit/cu_tester.c
index a32c3f41a..33c1aa26f 100644
--- a/liblwgeom/cunit/cu_tester.c
+++ b/liblwgeom/cunit/cu_tester.c
@@ -72,6 +72,7 @@ extern void sfcgal_suite_setup(void);
extern void split_suite_setup(void);
extern void stringbuffer_suite_setup(void);
extern void tree_suite_setup(void);
+extern void topo_suite_setup(void);
extern void triangulate_suite_setup(void);
extern void varint_suite_setup(void);
extern void wkt_out_suite_setup(void);
@@ -128,6 +129,7 @@ PG_SuiteSetup setupfuncs[] = {algorithms_suite_setup,
stringbuffer_suite_setup,
surface_suite_setup,
tree_suite_setup,
+ topo_suite_setup,
triangulate_suite_setup,
twkb_out_suite_setup,
varint_suite_setup,
diff --git a/liblwgeom/cunit/cu_topo.c b/liblwgeom/cunit/cu_topo.c
new file mode 100644
index 000000000..490b95058
--- /dev/null
+++ b/liblwgeom/cunit/cu_topo.c
@@ -0,0 +1,55 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * This is free software; you can redistribute and/or modify it under
+ * the terms of the GNU General Public Licence. See the COPYING file.
+#include "CUnit/Basic.h"
+#include "CUnit/CUnit.h"
+#include "liblwgeom_internal.h"
+#include "topo/liblwgeom_topo.h"
+#include "cu_tester.h"
+static LWGEOM *
+lwgeom_from_text(const char *str)
+ LWGEOM_PARSER_RESULT r;
+ if (LW_FAILURE == lwgeom_parse_wkt(&r, (char *)str, LW_PARSER_CHECK_NONE))
+ return NULL;
+ return r.geom;
+static void
+test_lwt_IsTopoRingCCW_large_finite_coordinates(void)
+ LWGEOM *geom = lwgeom_from_text("POLYGON((0 1e308,1e308 0,0 0,0 1e308))");
+ LWPOLY *poly;
+ CU_ASSERT_PTR_NOT_NULL(geom);
+ if (!geom)
+ return;
+ poly = lwgeom_as_lwpoly(geom);
+ CU_ASSERT_PTR_NOT_NULL(poly);
+ if (!poly)
+ lwgeom_free(geom);
+ return;
+ CU_ASSERT_EQUAL(lwt_IsTopoRingCCW(poly->rings[0]), LW_FALSE);
+void
+topo_suite_setup(void)
+ CU_pSuite suite = CU_add_suite("topology", NULL, NULL);
+ PG_ADD_TEST(suite, test_lwt_IsTopoRingCCW_large_finite_coordinates);
diff --git a/liblwgeom/topo/lwgeom_topo.c b/liblwgeom/topo/lwgeom_topo.c
index 6d0144bb9..c7bfe1cee 100644
--- a/liblwgeom/topo/lwgeom_topo.c
+++ b/liblwgeom/topo/lwgeom_topo.c
@@ -38,6 +38,7 @@
#include <gmp.h>
#include <inttypes.h>
+#include <math.h>
static bool
_lwt_describe_point(const LWPOINT *pt, char *buf, size_t bufsize)
@@ -1888,27 +1889,49 @@ lwt_IsTopoRingCCW(const POINTARRAY *pa)
const POINT2D *P3;
mpf_t sum;
mpf_t tmp;
- double x0, x, y1, y2;
+ mpf_t x0;
+ mpf_t x;
+ mpf_t dy;
uint32_t i;
int ret;
if (! pa || pa->npoints < 3 )
return 0;
- mpf_init2(sum, 64);
- mpf_init2(tmp, 64);
- mpf_set_d(sum, 0.0);
P1 = getPoint2d_cp(pa, 0);
P2 = getPoint2d_cp(pa, 1);
- x0 = P1->x;
+ if (!isfinite(P1->x) || !isfinite(P1->y) || !isfinite(P2->x) || !isfinite(P2->y))
+ return ptarray_isccw(pa);
+ mpf_init2(sum, 64);
+ mpf_init2(tmp, 64);
+ mpf_init2(x0, 64);
+ mpf_init2(x, 64);
+ mpf_init2(dy, 64);
+ mpf_set_d(sum, 0.0);
+ mpf_set_d(x0, P1->x);
for ( i = 2; i < pa->npoints; i++ )
P3 = getPoint2d_cp(pa, i);
- x = P2->x - x0;
- y1 = P3->y;
- y2 = P1->y;
- mpf_set_d(tmp, x * (y2-y1));
+ if (!isfinite(P3->x) || !isfinite(P3->y))
+ mpf_clear(dy);
+ mpf_clear(x);
+ mpf_clear(x0);
+ mpf_clear(tmp);
+ mpf_clear(sum);
+ mpf_set_d(x, P2->x);
+ mpf_sub(x, x, x0);
+ mpf_set_d(dy, P1->y);
+ mpf_set_d(tmp, P3->y);
+ mpf_sub(dy, dy, tmp);
+ mpf_mul(tmp, x, dy);
mpf_add(sum, sum, tmp);
P1 = P2;
P2 = P3;
@@ -1916,6 +1939,9 @@ lwt_IsTopoRingCCW(const POINTARRAY *pa)
ret = mpf_cmp_ui(sum, 0) < 0;
+ mpf_clear(dy);
+ mpf_clear(x);
+ mpf_clear(x0);
mpf_clear(tmp);
mpf_clear(sum);
Summary of changes:
NEWS | 2 ++
liblwgeom/cunit/Makefile.in | 4 +++-
liblwgeom/cunit/cu_tester.c | 2 ++
liblwgeom/cunit/cu_topo.c | 55 ++++++++++++++++++++++++++++++++++++++++++++
liblwgeom/topo/lwgeom_topo.c | 42 ++++++++++++++++++++++++++-------
5 files changed, 96 insertions(+), 9 deletions(-)
create mode 100644 liblwgeom/cunit/cu_topo.c
hooks/post-receive
