[SCM] PostGIS branch master updated. 3.6.0rc2-547-g6f66e39d8
git at osgeo.org
git at osgeo.org
Wed Jun 17 15:06:46 PDT 2026
the project "PostGIS".
via 6f66e39d8aaf7261bcf4f5b7ce10c9b727fc7168 (commit)
via 73871012be232126e6fcb6eb22009842e9b6d9a7 (commit)
from 5ec62d6985632cc603289b2e7af5efa693d683ca (commit)
revisions in full, below.
commit 6f66e39d8aaf7261bcf4f5b7ce10c9b727fc7168
Merge: 5ec62d698 73871012b
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jun 18 02:03:07 2026 +0400
Merge PR #892: add TWKB and raster OSS-Fuzz targets
Adds OSS-Fuzz harnesses for TWKB import and serialized raster deserialization, shared fuzzer allocation/error handling helpers, checked-in seed corpus archives, and build wiring for raster-enabled fuzz targets.
Also hardens TWKB truncation, overlong varint, and impossible element-count handling covered by the new fuzzer and CUnit regression inputs.
commit 73871012be232126e6fcb6eb22009842e9b6d9a7
Date: Wed Jun 17 23:43:11 2026 +0400
fuzzers: add TWKB and raster input targets
diff --git a/GNUmakefile.in b/GNUmakefile.in
index 8b007271c..e65fd23e4 100644
--- a/GNUmakefile.in
+++ b/GNUmakefile.in
@@ -83,6 +83,9 @@ check: check-unit docs-check check-lint check-spell
ifeq (@SUPPORT_POSTGRESQL@,yes)
check: check-regress
endif
+ifeq (@RASTER@,raster)
+check: check-fuzzers
+endif
# The "lint" tests do not depend on specific code configurations
# but solely on the source code state
@@ -95,6 +98,16 @@ check-news:
$(top_srcdir)/utils/check_news.sh $(top_srcdir)
check-unit check-regress: all
+check-fuzzers: all
+ mkdir -p fuzzers
+ fuzzer_out=`mktemp -d "$${TMPDIR:-/tmp}/postgis-fuzzer-check.XXXXXX"`; \
+ trap 'rm -rf "$${fuzzer_out}"' EXIT HUP INT TERM; \
+ $(MAKE) -C fuzzers -f $(abspath $(top_srcdir))/fuzzers/Makefile \
+ POSTGIS_BUILD_DIR="$(CURDIR)" \
+ FUZZER_OUT="$${fuzzer_out}" \
+ check
+endif
check-regress: export POSTGIS_REGRESS_DB ?= postgis_reg-$(POSTGIS_MAJOR_VERSION).$(POSTGIS_MINOR_VERSION)
diff --git a/NEWS b/NEWS
index 54811e708..4cd72746a 100644
--- a/NEWS
+++ b/NEWS
@@ -52,6 +52,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
- GH-885, [topology] Avoid GMP overflow in ring orientation for very large
finite coordinates (Darafei Praliaskouski)
+ - GH-892, Add OSS-Fuzz coverage for TWKB and serialized raster inputs,
+ including guards for malformed TWKB reads and counts (Darafei Praliaskouski)
- Build PostgreSQL extension modules with `-fno-semantic-interposition` when
available so LTO can optimize same-DSO calls to exported PostGIS
entry points directly instead of routing through the module PLT; in
diff --git a/fuzzers/Makefile b/fuzzers/Makefile
index 5eeb2438e..01b324312 100644
--- a/fuzzers/Makefile
+++ b/fuzzers/Makefile
@@ -1,10 +1,81 @@
+FUZZER_SRC_DIR ?= $(abspath $(dir $(lastword $(MAKEFILE_LIST))))
+POSTGIS_BUILD_DIR ?= $(abspath ..)
+FUZZER_OUT ?= /tmp
+FUZZER_WORK ?= $(FUZZER_OUT)/postgis-fuzzer-check
+FUZZER_SOURCES := $(notdir $(wildcard $(FUZZER_SRC_DIR)/*_fuzzer.cpp $(FUZZER_SRC_DIR)/*_fuzzer.c))
+FUZZER_NAMES := $(basename $(FUZZER_SOURCES))
+SEED_CORPORA := $(wildcard $(FUZZER_SRC_DIR)/*_seed_corpus.zip)
+POSTGIS_CONFIGURED_LDFLAGS := $(shell sed -n 's/^LDFLAGS = //p' $(POSTGIS_BUILD_DIR)/liblwgeom/Makefile 2>/dev/null | sed 1q)
+POSTGIS_FUZZER_LDFLAGS = $(POSTGIS_CONFIGURED_LDFLAGS) $(LDFLAGS)
+.PHONY: clean dummyfuzzers check check-corpus
clean:
$(RM) -f *.o *.a
-fuzzingengine.o: fuzzingengine.c
+fuzzingengine.o: $(FUZZER_SRC_DIR)/fuzzingengine.c
$(CC) $(CFLAGS) -c -o $@ $<
dummyfuzzers: fuzzingengine.o
+ mkdir -p "$(FUZZER_OUT)"
$(AR) r libFuzzingEngine.a fuzzingengine.o
- CXX="${CXX}" CXXFLAGS="-L. ${CXXFLAGS}" SRC=/tmp OUT=/tmp ./build_google_oss_fuzzers.sh
- OUT=/tmp ./build_seed_corpus.sh
+ CC="${CC}" CXX="${CXX}" CXXFLAGS="-L$(CURDIR) ${CXXFLAGS}" LDFLAGS="$(POSTGIS_FUZZER_LDFLAGS)" POSTGIS_BUILD_DIR="$(POSTGIS_BUILD_DIR)" SRC="$(FUZZER_SRC_DIR)" OUT="$(FUZZER_OUT)" $(FUZZER_SRC_DIR)/build_google_oss_fuzzers.sh
+ OUT="$(FUZZER_OUT)" $(FUZZER_SRC_DIR)/build_seed_corpus.sh
+check:
+ @cxx="$${CXX:-$(CXX)}"; \
+ set -- $${cxx}; \
+ if [ "$$#" -eq 0 ] || ! command -v "$$1" >/dev/null 2>&1 || ! "$$@" --version >/dev/null 2>&1; then \
+ echo "C++ compiler '$${cxx}' not available; skipping fuzzer smoke check."; \
+ elif ! command -v pkg-config >/dev/null 2>&1 || ! pkg-config --exists json-c proj libxml-2.0; then \
+ echo "pkg-config metadata for fuzzer dependencies not found; skipping fuzzer smoke check."; \
+ elif ! command -v geos-config >/dev/null 2>&1 || ! command -v gdal-config >/dev/null 2>&1; then \
+ echo "GEOS/GDAL fuzzer dependency helpers not found; skipping fuzzer smoke check."; \
+ else \
+ set -e; \
+ if { command -v python3 >/dev/null 2>&1 && python3 -m zipfile --help >/dev/null 2>&1; } || \
+ { command -v unzip >/dev/null 2>&1 && unzip -v >/dev/null 2>&1; }; then \
+ $(MAKE) check-corpus; \
+ else \
+ echo "No seed corpus zip extractor found; running fuzzer smoke check without corpus replay."; \
+ $(MAKE) dummyfuzzers; \
+ for fuzzer in $(FUZZER_NAMES); do \
+ "$(FUZZER_OUT)/$${fuzzer}"; \
+ done; \
+ fi; \
+ fi
+check-corpus: dummyfuzzers
+ @set -e; \
+ done
+ @set -e; \
+ if command -v python3 >/dev/null 2>&1 && python3 -m zipfile --help >/dev/null 2>&1; then \
+ extract_zip=python3; \
+ elif command -v unzip >/dev/null 2>&1 && unzip -v >/dev/null 2>&1; then \
+ extract_zip=unzip; \
+ else \
+ echo "No seed corpus zip extractor found. Install python3 or unzip, then rerun check-corpus."; \
+ exit 1; \
+ fi; \
+ rm -rf "$(FUZZER_WORK)"; \
+ mkdir -p "$(FUZZER_WORK)"; \
+ trap 'rm -rf "$(FUZZER_WORK)"' EXIT HUP INT TERM; \
+ for corpus in $(SEED_CORPORA) __none__; do \
+ if [ "$${corpus}" = "__none__" ]; then \
+ continue; \
+ fi; \
+ corpus_name=$$(basename "$${corpus}"); \
+ fuzzer=$${corpus_name%_seed_corpus.zip}; \
+ corpus_dir="$(FUZZER_WORK)/$${fuzzer}"; \
+ mkdir -p "$${corpus_dir}"; \
+ if [ "$${extract_zip}" = "python3" ]; then \
+ python3 -m zipfile -e "$${corpus}" "$${corpus_dir}"; \
+ else \
+ unzip -qq "$${corpus}" -d "$${corpus_dir}"; \
+ fi; \
+ find "$${corpus_dir}" -type f -print | while IFS= read -r seed; do \
+ "$(FUZZER_OUT)/$${fuzzer}" "$${seed}"; \
+ done; \
+ done
diff --git a/fuzzers/README.md b/fuzzers/README.md
index 0c167e4f3..738b91d5b 100644
--- a/fuzzers/README.md
+++ b/fuzzers/README.md
@@ -27,12 +27,16 @@ The `oss-fuzz` project `Dockerfile` should call this script during image build.
## Local Workflow
-### Simulate Dummy Fuzzer Build
+### Simulate Dummy Fuzzer Build And Check
```bash
-make dummyfuzzers
+make check
+When `python3` or `unzip` is available, this also replays the checked-in seed
+corpus archives. Hosts without an archive extractor still run a no-input smoke
+check for each fuzzer.
Artifacts are created in `/tmp`:
- `/tmp/*_fuzzer`
@@ -45,6 +49,12 @@ Run one fuzzer locally:
/tmp/wkt_import_fuzzer a_file_name
+Require checked-in seed corpus replay:
+```bash
+make check-corpus
### Run OSS-Fuzz Locally
```bash
diff --git a/fuzzers/build_google_oss_fuzzers.sh b/fuzzers/build_google_oss_fuzzers.sh
index 4f1435c24..1cc825413 100755
--- a/fuzzers/build_google_oss_fuzzers.sh
+++ b/fuzzers/build_google_oss_fuzzers.sh
@@ -17,23 +17,65 @@ if [ "$CXX" == "" ]; then
exit 1
fi
-SRC_DIR=$(dirname $0)/..
+if [ "$CC" == "" ]; then
+ echo "CC env var not defined"
+ exit 1
+fi
+POSTGIS_SOURCE_DIR="${POSTGIS_SOURCE_DIR:-$(cd "$(dirname "$0")/.." && pwd)}"
+POSTGIS_BUILD_DIR="${POSTGIS_BUILD_DIR:-$POSTGIS_SOURCE_DIR}"
+FUZZERS_DIR="$POSTGIS_SOURCE_DIR/fuzzers"
JSON_C_LIBS=$(pkg-config --libs json-c)
GEOS_LIBS=$(geos-config --clibs)
PROJ_XML2_LIBS=$(pkg-config --libs proj libxml-2.0)
+GDAL_CFLAGS=$(gdal-config --cflags)
+GDAL_LIBS=$(gdal-config --libs)
POSTGIS_FUZZER_LIBS="$JSON_C_LIBS $GEOS_LIBS $PROJ_XML2_LIBS"
POSTGIS_PACKAGE_RUNTIME_LIBS="${POSTGIS_PACKAGE_RUNTIME_LIBS:-1}"
+target_cflags()
+ case "$1" in
+ raster_deserialize_fuzzer)
+ echo "-I$POSTGIS_SOURCE_DIR/raster/rt_core -I$POSTGIS_BUILD_DIR/raster/rt_core -I$POSTGIS_SOURCE_DIR/raster -I$POSTGIS_BUILD_DIR/raster -I$POSTGIS_SOURCE_DIR -I$POSTGIS_BUILD_DIR $GDAL_CFLAGS"
+ esac
+target_libs()
+ case "$1" in
+ echo "$POSTGIS_BUILD_DIR/raster/rt_core/librtcore.a $GDAL_LIBS"
+ esac
build_fuzzer()
fuzzerName=$1
sourceFilename=$2
- shift
- shift
+ extension=${sourceFilename##*.}
+ objectFile=""
echo "Building fuzzer $fuzzerName"
- $CXX $CXXFLAGS -std=c++11 -I$SRC_DIR/liblwgeom \
- $sourceFilename $* -o $OUT/$fuzzerName \
- -lFuzzingEngine -lstdc++ $SRC_DIR/liblwgeom/.libs/liblwgeom.a $POSTGIS_FUZZER_LIBS
+ if [ "$extension" = "c" ]; then
+ objectFile=$(mktemp)
+ "$CC" $CFLAGS -I"$POSTGIS_SOURCE_DIR/liblwgeom" -I"$POSTGIS_BUILD_DIR/liblwgeom" $(target_cflags "$fuzzerName") \
+ -c "$sourceFilename" -o "$objectFile"
+ sourceFilename=$objectFile
+ fi
+ "$CXX" $CXXFLAGS -std=c++11 -I"$POSTGIS_SOURCE_DIR/liblwgeom" -I"$POSTGIS_BUILD_DIR/liblwgeom" \
+ "$sourceFilename" -o "$OUT/$fuzzerName" \
+ $LDFLAGS \
+ -lFuzzingEngine -lstdc++ $(target_libs "$fuzzerName") \
+ "$POSTGIS_BUILD_DIR/liblwgeom/.libs/liblwgeom.a" $POSTGIS_FUZZER_LIBS
+ if [ "$objectFile" != "" ]; then
+ rm -f "$objectFile"
+ fi
package_runtime_libs()
@@ -66,13 +108,22 @@ package_runtime_libs()
fi
-fuzzerFiles=$(dirname $0)/*.cpp
-for F in $fuzzerFiles; do
- fuzzerName=$(basename $F .cpp)
- build_fuzzer $fuzzerName $F
+for F in "$FUZZERS_DIR"/*.cpp; do
+ [ -e "$F" ] || continue
+ fuzzerName=$(basename "$F" .cpp)
+ build_fuzzer "$fuzzerName" "$F"
done
-cp $(dirname $0)/*.dict $(dirname $0)/*.options $(dirname $0)/*.zip $OUT/
+for F in "$FUZZERS_DIR"/*_fuzzer.c; do
+ fuzzerName=$(basename "$F" .c)
+done
+for artifact in "$FUZZERS_DIR"/*.dict "$FUZZERS_DIR"/*.options "$FUZZERS_DIR"/*.zip; do
+ [ -e "$artifact" ] || continue
+ cp "$artifact" "$OUT/"
+done
if [ "$POSTGIS_PACKAGE_RUNTIME_LIBS" != "0" ]; then
diff --git a/fuzzers/build_oss_fuzz.sh b/fuzzers/build_oss_fuzz.sh
index 5b65ddcda..b733bf1a8 100755
--- a/fuzzers/build_oss_fuzz.sh
+++ b/fuzzers/build_oss_fuzz.sh
@@ -28,7 +28,7 @@ fi
export CXXFLAGS="$CXXFLAGS -std=c++11"
POSTGIS_OSS_FUZZ_CONFIGURE_FLAGS=(
--enable-static
- --without-raster
+ --with-raster
--without-protobuf
--enable-debug
@@ -36,10 +36,8 @@ POSTGIS_OSS_FUZZ_CONFIGURE_FLAGS=(
cd "$SRC_DIR"
./autogen.sh
./configure CC="$CC" CXX="$CXX" "${POSTGIS_OSS_FUZZ_CONFIGURE_FLAGS[@]}"
-cd liblwgeom
-make clean -s
-make -j"$(nproc)" -s
-cd ..
+make -C liblwgeom -j"$(nproc)" -s
+make -C raster corelib -j"$(nproc)" -s
bash ./fuzzers/build_google_oss_fuzzers.sh
bash ./fuzzers/build_seed_corpus.sh
diff --git a/fuzzers/install_oss_fuzz_build_deps.sh b/fuzzers/install_oss_fuzz_build_deps.sh
index dd3475745..2740687f4 100755
--- a/fuzzers/install_oss_fuzz_build_deps.sh
+++ b/fuzzers/install_oss_fuzz_build_deps.sh
@@ -17,7 +17,7 @@ export DEBIAN_FRONTEND="${DEBIAN_FRONTEND:-noninteractive}"
apt-get update
apt-get install -y --no-install-recommends \
make autoconf automake libtool bison flex g++ postgresql-server-dev-all \
- libgeos-dev libproj-dev libxml2-dev pkg-config libjson-c-dev \
- libc++-dev libc++abi-dev patchelf
+ libgeos-dev libproj-dev libxml2-dev pkg-config libjson-c-dev libgmp-dev \
+ libgdal-dev libc++-dev libc++abi-dev patchelf
rm -rf /var/lib/apt/lists/*
diff --git a/fuzzers/liblwgeom_fuzzer.hpp b/fuzzers/liblwgeom_fuzzer.hpp
new file mode 100644
index 000000000..c44f6e526
--- /dev/null
+++ b/fuzzers/liblwgeom_fuzzer.hpp
@@ -0,0 +1,164 @@
+ * Project: PostGIS
+ * Purpose: Shared liblwgeom fuzzer support
+ * Copyright (C) 2026 Darafei Praliaskouski <me at komzpa.net>
+ * This program is free software; you can redistribute it and/or
+ * modify it under the terms of the GNU General Public License
+ * as published by the Free Software Foundation; either version 2
+ * of the License, or (at your option) any later version.
+#ifndef POSTGIS_LIBLWGEOM_FUZZER_HPP
+#define POSTGIS_LIBLWGEOM_FUZZER_HPP
+#include <setjmp.h>
+#include <stdarg.h>
+#include <stddef.h>
+#include <stdlib.h>
+extern "C" {
+#include "liblwgeom.h"
+static jmp_buf postgis_lwgeom_fuzzer_jmp_buf;
+static void **postgis_lwgeom_fuzzer_ptrs = NULL;
+static size_t postgis_lwgeom_fuzzer_count = 0;
+static size_t postgis_lwgeom_fuzzer_capacity = 0;
+#define POSTGIS_LWGEOM_FUZZER_SETJMP() setjmp(postgis_lwgeom_fuzzer_jmp_buf)
+static int
+postgis_lwgeom_fuzzer_track_add(void *ptr)
+ void **new_ptrs;
+ size_t new_capacity;
+ if (postgis_lwgeom_fuzzer_count == postgis_lwgeom_fuzzer_capacity)
+ new_capacity = postgis_lwgeom_fuzzer_capacity ? postgis_lwgeom_fuzzer_capacity * 2 : 64;
+ new_ptrs = (void **)realloc(postgis_lwgeom_fuzzer_ptrs, new_capacity * sizeof(void *));
+ if (new_ptrs == NULL)
+ return 0;
+ postgis_lwgeom_fuzzer_ptrs = new_ptrs;
+ postgis_lwgeom_fuzzer_capacity = new_capacity;
+ postgis_lwgeom_fuzzer_ptrs[postgis_lwgeom_fuzzer_count++] = ptr;
+ return 1;
+static void
+postgis_lwgeom_fuzzer_track_remove(void *ptr)
+ for (size_t i = 0; i < postgis_lwgeom_fuzzer_count; i++)
+ if (postgis_lwgeom_fuzzer_ptrs[i] == ptr)
+ postgis_lwgeom_fuzzer_ptrs[i] = postgis_lwgeom_fuzzer_ptrs[--postgis_lwgeom_fuzzer_count];
+ return;
+static void
+postgis_lwgeom_fuzzer_cleanup_allocations(void)
+ free(postgis_lwgeom_fuzzer_ptrs[i]);
+ postgis_lwgeom_fuzzer_count = 0;
+static void *
+postgis_lwgeom_fuzzer_malloc(size_t size)
+ void *ptr = malloc(size);
+ if (ptr != NULL && !postgis_lwgeom_fuzzer_track_add(ptr))
+ free(ptr);
+ return NULL;
+ return ptr;
+static void *
+postgis_lwgeom_fuzzer_realloc(void *ptr, size_t size)
+ void *new_ptr;
+ if (ptr == NULL)
+ return postgis_lwgeom_fuzzer_malloc(size);
+ if (size == 0)
+ postgis_lwgeom_fuzzer_track_remove(ptr);
+ free(ptr);
+ return NULL;
+ new_ptr = realloc(ptr, size);
+ if (new_ptr == NULL)
+ return NULL;
+ postgis_lwgeom_fuzzer_ptrs[i] = new_ptr;
+ return new_ptr;
+ if (!postgis_lwgeom_fuzzer_track_add(new_ptr))
+ free(new_ptr);
+ return NULL;
+ return new_ptr;
+static void
+postgis_lwgeom_fuzzer_free(void *ptr)
+ if (ptr == NULL)
+ return;
+ free(ptr);
+extern "C" {
+static void
+postgis_lwgeom_fuzzer_noticereporter(const char *, va_list)
+static void
+postgis_lwgeom_fuzzer_errorreporter(const char *, va_list)
+ postgis_lwgeom_fuzzer_cleanup_allocations();
+ longjmp(postgis_lwgeom_fuzzer_jmp_buf, 1);
+static void
+postgis_lwgeom_fuzzer_debuglogger(int, const char *, va_list)
+static void
+postgis_lwgeom_fuzzer_initialize(void)
+ /* liblwgeom reports parser errors through the configured error reporter.
+ * Track liblwgeom allocations so longjmp error paths release allocations
+ * made before the jump.
+ lwgeom_set_handlers(postgis_lwgeom_fuzzer_malloc,
+ postgis_lwgeom_fuzzer_realloc,
+ postgis_lwgeom_fuzzer_free,
+ postgis_lwgeom_fuzzer_errorreporter,
+ postgis_lwgeom_fuzzer_noticereporter);
+ lwgeom_set_debuglogger(postgis_lwgeom_fuzzer_debuglogger);
+#endif
diff --git a/fuzzers/raster_deserialize_fuzzer.c b/fuzzers/raster_deserialize_fuzzer.c
index 000000000..cb69254f0
--- /dev/null
+++ b/fuzzers/raster_deserialize_fuzzer.c
@@ -0,0 +1,185 @@
+ * Purpose: Raster serialized input fuzzer
+#include <stdint.h>
+#include <string.h>
+#include "librtcore.h"
+#include "rt_serialize.h"
+static jmp_buf jmpBuf;
+static void *current_serialized = NULL;
+static void
+cleanup_serialized(void)
+ free(current_serialized);
+ current_serialized = NULL;
+static void
+rt_message_handler_noop(const char *fmt, va_list ap)
+ (void)fmt;
+ (void)ap;
+static void
+rt_error_handler(const char *fmt, va_list ap)
+ (void)fmt;
+ (void)ap;
+ cleanup_serialized();
+ longjmp(jmpBuf, 1);
+int
+LLVMFuzzerInitialize(int *argc, char ***argv)
+ (void)argc;
+ (void)argv;
+ rt_set_handlers(malloc, realloc, free, rt_error_handler, rt_message_handler_noop, rt_message_handler_noop);
+ return 0;
+static int
+checked_add(size_t *total, size_t value, size_t limit)
+ if (value > limit || *total > limit - value)
+ return 0;
+ *total += value;
+ return 1;
+static int
+has_complete_serialized_raster(const uint8_t *buf, size_t len)
+ struct rt_raster_serialized_t header;
+ size_t pos = sizeof(header);
+ /* rt_raster_deserialize() accepts a pointer but no buffer length. Before
+ * calling it, walk the serialized layout far enough to prove each band,
+ * nodata value, optional out-db path, pixel payload, and 8-byte padding byte
+ * is inside the fuzzer-provided buffer.
+ if (len < sizeof(header))
+ return 0;
+ memcpy(&header, buf, sizeof(header));
+ if (header.numBands > 256)
+ return 0;
+ for (uint16_t i = 0; i < header.numBands; i++)
+ if (pos >= len)
+ return 0;
+ const uint8_t band_type = buf[pos];
+ const rt_pixtype pixtype = (rt_pixtype)(band_type & BANDTYPE_PIXTYPE_MASK);
+ const int pixbytes = rt_pixtype_size(pixtype);
+ if (pixbytes <= 0)
+ return 0;
+ /* Band type byte, nodata padding bytes, and nodata value. */
+ if (!checked_add(&pos, 1, len))
+ return 0;
+ if (!checked_add(&pos, (size_t)(pixbytes - 1), len))
+ return 0;
+ if (!checked_add(&pos, (size_t)pixbytes, len))
+ return 0;
+ if (BANDTYPE_IS_OFFDB(band_type))
+ /* Out-db band number plus NUL-terminated path. */
+ return 0;
+ const void *nul = memchr(buf + pos, '\0', len - pos);
+ if (nul == NULL)
+ return 0;
+ const size_t path_len = (const uint8_t *)nul - (buf + pos);
+ if (!checked_add(&pos, path_len + 1, len))
+ return 0;
+ else
+ /* Inline raster data is width * height pixels in this band's
+ * pixel type.
+ const size_t pixels = (size_t)header.width * (size_t)header.height;
+ if (header.width != 0 && pixels / header.width != header.height)
+ return 0;
+ if (pixbytes > 0 && pixels > len / (size_t)pixbytes)
+ return 0;
+ if (!checked_add(&pos, pixels * (size_t)pixbytes, len))
+ return 0;
+ while (pos % 8 != 0)
+ return 0;
+ return 1;
+static void
+destroy_raster_with_bands(rt_raster raster)
+ uint16_t num_bands;
+ if (raster == NULL)
+ return;
+ num_bands = rt_raster_get_num_bands(raster);
+ for (uint16_t i = 0; i < num_bands; i++)
+ rt_band band = rt_raster_get_band(raster, i);
+ if (band != NULL)
+ rt_band_destroy(band);
+ rt_raster_destroy(raster);
+int
+LLVMFuzzerTestOneInput(const uint8_t *buf, size_t len)
+ if (setjmp(jmpBuf))
+ return 0;
+ if (!has_complete_serialized_raster(buf, len))
+ return 0;
+ current_serialized = malloc(len);
+ if (current_serialized == NULL)
+ return 0;
+ memcpy(current_serialized, buf, len);
+ rt_raster raster = rt_raster_deserialize(current_serialized, 0);
+ destroy_raster_with_bands(raster);
+ return 0;
diff --git a/fuzzers/raster_deserialize_fuzzer.options b/fuzzers/raster_deserialize_fuzzer.options
index 000000000..60a51fcba
--- /dev/null
+++ b/fuzzers/raster_deserialize_fuzzer.options
@@ -0,0 +1,2 @@
+[libfuzzer]
+max_len = 100000
diff --git a/fuzzers/raster_deserialize_fuzzer_seed_corpus.zip b/fuzzers/raster_deserialize_fuzzer_seed_corpus.zip
index 000000000..92e3dd60d
Binary files /dev/null and b/fuzzers/raster_deserialize_fuzzer_seed_corpus.zip differ
diff --git a/fuzzers/twkb_import_fuzzer.cpp b/fuzzers/twkb_import_fuzzer.cpp
index 000000000..d662667b2
--- /dev/null
+++ b/fuzzers/twkb_import_fuzzer.cpp
@@ -0,0 +1,56 @@
+ * Purpose: TWKB input fuzzer
+extern "C" {
+#include "geos_stub.h"
+#include "proj_stub.h"
+#include "liblwgeom_fuzzer.hpp"
+extern "C" int
+LLVMFuzzerInitialize(int * /*argc*/, char *** /*argv*/)
+ postgis_lwgeom_fuzzer_initialize();
+ return 0;
+extern "C" int LLVMFuzzerTestOneInput(const uint8_t *buf, size_t len);
+int
+ /* Avoid inputs too short to contain TWKB metadata. If the metadata says an
+ * extended precision byte follows, make sure that byte exists too.
+ if (len < 2)
+ return 0;
+ if ((buf[1] & 0x08) && len < 3)
+ return 0;
+ if (POSTGIS_LWGEOM_FUZZER_SETJMP())
+ return 0;
+ LWGEOM *lwgeom = lwgeom_from_twkb(buf, len, LW_PARSER_CHECK_NONE);
+ lwgeom_free(lwgeom);
+ return 0;
diff --git a/fuzzers/twkb_import_fuzzer.options b/fuzzers/twkb_import_fuzzer.options
--- /dev/null
+++ b/fuzzers/twkb_import_fuzzer.options
@@ -0,0 +1,2 @@
+[libfuzzer]
+max_len = 100000
diff --git a/fuzzers/twkb_import_fuzzer_seed_corpus.zip b/fuzzers/twkb_import_fuzzer_seed_corpus.zip
index 000000000..3c26fad6e
Binary files /dev/null and b/fuzzers/twkb_import_fuzzer_seed_corpus.zip differ
diff --git a/fuzzers/wkb_import_fuzzer.cpp b/fuzzers/wkb_import_fuzzer.cpp
index 48ff539ad..f1d1c7eb9 100644
--- a/fuzzers/wkb_import_fuzzer.cpp
+++ b/fuzzers/wkb_import_fuzzer.cpp
@@ -26,95 +26,33 @@
* DEALINGS IN THE SOFTWARE.
-#include <assert.h>
#include <stddef.h>
#include <stdint.h>
-#include <stdlib.h>
-#include <string.h>
-#include <setjmp.h>
-#include <set>
-extern "C"
-#include "liblwgeom.h"
+extern "C" {
-extern "C" int LLVMFuzzerInitialize(int* argc, char*** argv);
-// Keep active heap allocated memory corresponding to returns of allocator()
-// and reallocator()
-std::set<void*> oSetPointers;
-jmp_buf jmpBuf;
-extern "C"
+extern "C" int
- static void *
- allocator(size_t size)
- void *mem = malloc(size);
- oSetPointers.insert(mem);
- return mem;
- static void
- freeor(void *mem)
- oSetPointers.erase(mem);
- free(mem);
- static void *
- reallocator(void *mem, size_t size)
- void *ret = realloc(mem, size);
- oSetPointers.insert(ret);
- return ret;
- static void
- noticereporter(const char *, va_list )
- static void
- errorreporter(const char *, va_list )
- // Cleanup any heap-allocated memory still active
- for(std::set<void*>::iterator oIter = oSetPointers.begin();
- oIter != oSetPointers.end(); ++oIter )
- free(*oIter);
- oSetPointers.clear();
- // Abort everything to jump to setjmp() call
- longjmp(jmpBuf, 1);
- static void
- debuglogger(int, const char *, va_list)
-int LLVMFuzzerInitialize(int* /*argc*/, char*** /*argv*/)
- lwgeom_set_handlers(malloc, realloc, free, noticereporter, noticereporter);
- lwgeom_set_debuglogger(debuglogger);
return 0;
- if( setjmp(jmpBuf) )
- return 0;
- LWGEOM* lwgeom = lwgeom_from_wkb(buf, len, LW_PARSER_CHECK_NONE);
- lwgeom_free(lwgeom);
- //assert( oSetPointers.empty() );
- return 0;
+ return 0;
+ LWGEOM *lwgeom = lwgeom_from_wkb(buf, len, LW_PARSER_CHECK_NONE);
+ return 0;
diff --git a/fuzzers/wkt_import_fuzzer.cpp b/fuzzers/wkt_import_fuzzer.cpp
index 46b514818..79c2dd49b 100644
--- a/fuzzers/wkt_import_fuzzer.cpp
+++ b/fuzzers/wkt_import_fuzzer.cpp
@@ -26,85 +26,22 @@
#include <stddef.h>
#include <stdint.h>
#include <stdlib.h>
#include <string.h>
-#include <set>
-extern "C"
+extern "C" {
-jmp_buf jmpBuf;
-extern "C"
+extern "C" int
- static void *
- return mem;
- static void
- freeor(void *mem)
- free(mem);
- static void *
- return ret;
- static void
- static void
- free(*oIter);
- static void
return 0;
@@ -112,15 +49,18 @@ extern "C" int LLVMFuzzerTestOneInput(const uint8_t *buf, size_t len);
- char* pszWKT = static_cast<char*>(malloc( len + 1 ));
- memcpy(pszWKT, buf, len);
- pszWKT[len] = '\0';
- if( !setjmp(jmpBuf) )
- LWGEOM* lwgeom = lwgeom_from_wkt(pszWKT, LW_PARSER_CHECK_NONE);
- free(pszWKT);
- return 0;
+ char *pszWKT = static_cast<char *>(malloc(len + 1));
+ if (pszWKT == NULL)
+ return 0;
+ memcpy(pszWKT, buf, len);
+ pszWKT[len] = '\0';
+ if (!POSTGIS_LWGEOM_FUZZER_SETJMP())
+ LWGEOM *lwgeom = lwgeom_from_wkt(pszWKT, LW_PARSER_CHECK_NONE);
+ free(pszWKT);
+ return 0;
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index 02d2db374..5fb4197f0 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -3,6 +3,7 @@
* PostGIS - Spatial Types for PostgreSQL
* http://postgis.net
* Copyright 2010 Paul Ramsey <pramsey at cleverelephant.ca>
+ * Copyright 2026 Darafei Praliaskouski <me at komzpa.net>
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU General Public Licence. See the COPYING file.
@@ -222,7 +223,88 @@ static void test_twkb_in_precision(void)
precision = 0;
+static void
+test_twkb_in_truncated_extended_dims(void)
+ const uint8_t twkb[] = {
+ 0x01, /* POINT with default precision. */
+ 0x18 /* Empty geometry plus extended-dimension byte follows. */
+ LWGEOM *geom;
+ cu_error_msg_reset();
+ geom = lwgeom_from_twkb(twkb, sizeof(twkb), LW_PARSER_CHECK_NONE);
+ /* Truncated extended-dimension metadata used to be read before the bounds
+ * check. The expected contract is an ordinary TWKB size error, not an
+ * out-of-buffer read while constructing the header.
+ ASSERT_STRING_EQUAL(cu_error_msg, "twkb_parse_state_advance: TWKB structure does not match expected size!");
+ CU_ASSERT_PTR_NOT_NULL(geom);
+ if (geom != NULL)
+ lwgeom_free(geom);
+static void
+test_twkb_in_overlong_varint(void)
+ const uint8_t twkb[] = {0x02,
+ 0x00, /* LINESTRING with default precision. */
+ 0x80,
+ 0x80,
+ 0x80,
+ 0x80,
+ 0x80,
+ 0x80, /* Overlong point-count varint. */
+ 0x80,
+ 0x80,
+ 0x80,
+ 0x80,
+ 0x00};
+ LWGEOM *geom;
+ /* Varints longer than the uint64_t encoding space used to shift by more
+ * than the C type width before the parser could report malformed input.
+ ASSERT_STRING_EQUAL(cu_error_msg, "varint_u64_decode: varint exceeds 64 bits");
+ if (geom != NULL)
+static void
+test_twkb_in_count_exceeds_payload(void)
+ 0xff,
+ 0xff,
+ 0xff,
+ 0xff,
+ 0x0f, /* UINT32_MAX points. */
+ 0x00,
+ 0x00};
+ LWGEOM *geom;
+ /* Count fields are allocation sizes. Reject impossible counts before
+ * constructing point arrays from a buffer that cannot contain them.
+ "twkb_parse_state_has_min_bytes: TWKB element count exceeds remaining payload");
+ if (geom != NULL)
** Used by test harness to register the tests in this file.
@@ -239,4 +321,7 @@ void twkb_in_suite_setup(void)
PG_ADD_TEST(suite, test_twkb_in_multipolygon);
PG_ADD_TEST(suite, test_twkb_in_collection);
PG_ADD_TEST(suite, test_twkb_in_precision);
+ PG_ADD_TEST(suite, test_twkb_in_truncated_extended_dims);
+ PG_ADD_TEST(suite, test_twkb_in_overlong_varint);
+ PG_ADD_TEST(suite, test_twkb_in_count_exceeds_payload);
diff --git a/liblwgeom/lwin_twkb.c b/liblwgeom/lwin_twkb.c
index 72fc53306..1262dd999 100644
--- a/liblwgeom/lwin_twkb.c
+++ b/liblwgeom/lwin_twkb.c
@@ -2,6 +2,7 @@
* PostGIS is free software: you can redistribute it and/or modify
* it under the terms of the GNU General Public License as published by
@@ -22,7 +23,6 @@
#include <math.h>
#include "liblwgeom_internal.h"
#include "lwgeom_log.h"
@@ -81,7 +81,7 @@ LWGEOM* lwgeom_from_twkb_state(twkb_parse_state *s);
static inline void twkb_parse_state_advance(twkb_parse_state *s, size_t next)
- if( (s->pos + next) > s->twkb_end)
+ if (next > (size_t)(s->twkb_end - s->pos))
lwerror("%s: TWKB structure does not match expected size!", __func__);
// lwnotice("TWKB structure does not match expected size!");
@@ -125,7 +125,37 @@ static inline void twkb_parse_state_varint_skip(twkb_parse_state *s)
return;
+static inline uint32_t
+twkb_parse_state_uvarint32(twkb_parse_state *s)
+ uint64_t val = twkb_parse_state_uvarint(s);
+ if (val > UINT32_MAX)
+ lwerror("%s: TWKB count exceeds uint32_t", __func__);
+ return 0;
+ return (uint32_t)val;
+static inline int
+twkb_parse_state_has_min_bytes(twkb_parse_state *s, uint32_t count, size_t min_bytes)
+ const size_t remaining = (size_t)(s->twkb_end - s->pos);
+ /* TWKB counts are trusted only after proving that the remaining buffer can
+ * hold the smallest possible payload for that many elements. This rejects
+ * impossible allocation requests before constructors size their arrays.
+ if (min_bytes != 0 && count > remaining / min_bytes)
+ lwerror("%s: TWKB element count exceeds remaining payload", __func__);
+ return LW_FALSE;
+ return LW_TRUE;
static uint32_t lwtype_from_twkb_type(uint8_t twkb_type)
@@ -159,7 +189,14 @@ static uint32_t lwtype_from_twkb_type(uint8_t twkb_type)
static uint8_t byte_from_twkb_state(twkb_parse_state *s)
- uint8_t val = *(s->pos);
+ uint8_t val = 0;
+ /* CUnit records lwerror and continues, while PostgreSQL and the fuzzers
+ * abort through their error handlers. Keep the bounds check local so this
+ * byte helper is safe under both execution models.
+ if ((s->twkb_end - s->pos) >= WKB_BYTE_SIZE)
+ val = *(s->pos);
twkb_parse_state_advance(s, WKB_BYTE_SIZE);
return val;
@@ -183,6 +220,9 @@ static POINTARRAY* ptarray_from_twkb_state(twkb_parse_state *s, uint32_t npoints
if( npoints == 0 )
return ptarray_construct_empty(s->has_z, s->has_m, 0);
+ if (!twkb_parse_state_has_min_bytes(s, npoints, s->ndims))
+ return NULL;
pa = ptarray_construct(s->has_z, s->has_m, npoints);
dlist = (double*)(pa->serialized_pointlist);
for( i = 0; i < npoints; i++ )
@@ -246,7 +286,7 @@ static LWLINE* lwline_from_twkb_state(twkb_parse_state *s)
return lwline_construct_empty(SRID_UNKNOWN, s->has_z, s->has_m);
/* Read number of points */
- npoints = twkb_parse_state_uvarint(s);
+ npoints = twkb_parse_state_uvarint32(s);
if ( npoints == 0 )
@@ -281,7 +321,7 @@ static LWPOLY* lwpoly_from_twkb_state(twkb_parse_state *s)
return lwpoly_construct_empty(SRID_UNKNOWN, s->has_z, s->has_m);
/* Read number of rings */
- nrings = twkb_parse_state_uvarint(s);
+ nrings = twkb_parse_state_uvarint32(s);
/* Start w/ empty polygon */
poly = lwpoly_construct_empty(SRID_UNKNOWN, s->has_z, s->has_m);
@@ -292,10 +332,13 @@ static LWPOLY* lwpoly_from_twkb_state(twkb_parse_state *s)
if( nrings == 0 )
return poly;
+ if (!twkb_parse_state_has_min_bytes(s, nrings, 1))
+ return poly;
for( i = 0; i < nrings; i++ )
/* Ret number of points */
- uint32_t npoints = twkb_parse_state_uvarint(s);
+ uint32_t npoints = twkb_parse_state_uvarint32(s);
POINTARRAY *pa = ptarray_from_twkb_state(s, npoints);
/* Skip empty rings */
@@ -335,7 +378,7 @@ static LWPOLY* lwpoly_from_twkb_state(twkb_parse_state *s)
static LWCOLLECTION* lwmultipoint_from_twkb_state(twkb_parse_state *s)
- int ngeoms, i;
+ uint32_t ngeoms, i;
LWGEOM *geom = NULL;
LWCOLLECTION *col = lwcollection_construct_empty(s->lwtype, SRID_UNKNOWN, s->has_z, s->has_m);
@@ -345,9 +388,12 @@ static LWCOLLECTION* lwmultipoint_from_twkb_state(twkb_parse_state *s)
return col;
/* Read number of geometries */
- ngeoms = twkb_parse_state_uvarint(s);
+ ngeoms = twkb_parse_state_uvarint32(s);
LWDEBUGF(4,"Number of geometries %d", ngeoms);
+ if (s->has_idlist && !twkb_parse_state_has_min_bytes(s, ngeoms, 1))
+ return col;
/* It has an idlist, we need to skip that */
if ( s->has_idlist )
@@ -355,6 +401,9 @@ static LWCOLLECTION* lwmultipoint_from_twkb_state(twkb_parse_state *s)
twkb_parse_state_varint_skip(s);
+ if (!twkb_parse_state_has_min_bytes(s, ngeoms, s->ndims))
+ return col;
for ( i = 0; i < ngeoms; i++ )
geom = lwpoint_as_lwgeom(lwpoint_from_twkb_state(s));
@@ -373,7 +422,7 @@ static LWCOLLECTION* lwmultipoint_from_twkb_state(twkb_parse_state *s)
static LWCOLLECTION* lwmultiline_from_twkb_state(twkb_parse_state *s)
- int ngeoms, i;
@@ -383,10 +432,13 @@ static LWCOLLECTION* lwmultiline_from_twkb_state(twkb_parse_state *s)
return col;
LWDEBUGF(4,"Number of geometries %d",ngeoms);
+ return col;
@@ -394,6 +446,9 @@ static LWCOLLECTION* lwmultiline_from_twkb_state(twkb_parse_state *s)
+ if (!twkb_parse_state_has_min_bytes(s, ngeoms, 1))
+ return col;
geom = lwline_as_lwgeom(lwline_from_twkb_state(s));
@@ -412,7 +467,7 @@ static LWCOLLECTION* lwmultiline_from_twkb_state(twkb_parse_state *s)
static LWCOLLECTION* lwmultipoly_from_twkb_state(twkb_parse_state *s)
- int ngeoms, i;
@@ -422,9 +477,12 @@ static LWCOLLECTION* lwmultipoly_from_twkb_state(twkb_parse_state *s)
return col;
+ return col;
@@ -432,6 +490,9 @@ static LWCOLLECTION* lwmultipoly_from_twkb_state(twkb_parse_state *s)
+ return col;
geom = lwpoly_as_lwgeom(lwpoly_from_twkb_state(s));
@@ -451,7 +512,7 @@ static LWCOLLECTION* lwmultipoly_from_twkb_state(twkb_parse_state *s)
static LWCOLLECTION* lwcollection_from_twkb_state(twkb_parse_state *s)
- int ngeoms, i;
@@ -461,10 +522,13 @@ static LWCOLLECTION* lwcollection_from_twkb_state(twkb_parse_state *s)
return col;
+ return col;
@@ -472,6 +536,9 @@ static LWCOLLECTION* lwcollection_from_twkb_state(twkb_parse_state *s)
+ if (!twkb_parse_state_has_min_bytes(s, ngeoms, 2))
+ return col;
geom = lwgeom_from_twkb_state(s);
diff --git a/liblwgeom/varint.c b/liblwgeom/varint.c
index fca005364..5e62579e7 100644
--- a/liblwgeom/varint.c
+++ b/liblwgeom/varint.c
@@ -20,10 +20,10 @@
* Copyright (C) 2014 Sandro Santilli <strk at kbt.io>
* Copyright (C) 2013 Nicklas Avén
#include "varint.h"
@@ -120,6 +120,12 @@ varint_u64_decode(const uint8_t *the_start, const uint8_t *the_end, size_t *size
/* Hibit is set, so this isn't the last byte */
if (nByte & 0x80)
+ if (nShift >= 63)
+ *size = 0;
+ lwerror("%s: varint exceeds 64 bits", __func__);
+ return 0;
/* We get here when there is more to read in the input varInt */
/* Here we take the least significant 7 bits of the read */
/* byte and put it in the most significant place in the result variable. */
@@ -131,6 +137,12 @@ varint_u64_decode(const uint8_t *the_start, const uint8_t *the_end, size_t *size
else
+ if (nShift >= 64 || (nShift == 63 && nByte > 1))
+ *size = 0;
+ return 0;
/* move the "cursor" one step */
ptr++;
/* Move the last read byte to the most significant */
@@ -207,5 +219,3 @@ int8_t unzigzag8(uint8_t val)
((int8_t)(val >> 1)) :
(-1 * (int8_t)((val+1) >> 1));
Summary of changes:
GNUmakefile.in | 13 ++
NEWS | 2 +
fuzzers/Makefile | 77 ++++++++-
fuzzers/README.md | 14 +-
fuzzers/build_google_oss_fuzzers.sh | 73 ++++++--
fuzzers/build_oss_fuzz.sh | 8 +-
fuzzers/install_oss_fuzz_build_deps.sh | 4 +-
fuzzers/liblwgeom_fuzzer.hpp | 164 ++++++++++++++++++
fuzzers/raster_deserialize_fuzzer.c | 185 +++++++++++++++++++++
...r.options => raster_deserialize_fuzzer.options} | 0
fuzzers/raster_deserialize_fuzzer_seed_corpus.zip | Bin 0 -> 586 bytes
fuzzers/twkb_import_fuzzer.cpp | 56 +++++++
...t_fuzzer.options => twkb_import_fuzzer.options} | 0
fuzzers/twkb_import_fuzzer_seed_corpus.zip | Bin 0 -> 680 bytes
fuzzers/wkb_import_fuzzer.cpp | 90 ++--------
fuzzers/wkt_import_fuzzer.cpp | 98 +++--------
liblwgeom/cunit/cu_in_twkb.c | 85 ++++++++++
liblwgeom/lwin_twkb.c | 95 +++++++++--
liblwgeom/varint.c | 16 +-
19 files changed, 785 insertions(+), 195 deletions(-)
create mode 100644 fuzzers/liblwgeom_fuzzer.hpp
create mode 100644 fuzzers/raster_deserialize_fuzzer.c
copy fuzzers/{geojson_import_fuzzer.options => raster_deserialize_fuzzer.options} (100%)
create mode 100644 fuzzers/raster_deserialize_fuzzer_seed_corpus.zip
create mode 100644 fuzzers/twkb_import_fuzzer.cpp
copy fuzzers/{geojson_import_fuzzer.options => twkb_import_fuzzer.options} (100%)
create mode 100644 fuzzers/twkb_import_fuzzer_seed_corpus.zip
hooks/post-receive
