[SCM] PostGIS branch master updated. 3.6.0rc2-589-gea9c759b0
git at osgeo.org
git at osgeo.org
Thu Jun 18 05:40:20 PDT 2026
the project "PostGIS".
via ea9c759b0b8d6c9b27fa5e12c5bb0be8b3405c66 (commit)
via 8c034d0faef7819f920cb4d921068217f679c1cd (commit)
from 9b9950de1262a24c41e9e4d647627b1816a6ac52 (commit)
revisions in full, below.
commit ea9c759b0b8d6c9b27fa5e12c5bb0be8b3405c66
Merge: 9b9950de1 8c034d0fa
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jun 18 16:37:46 2026 +0400
Merge PR #900: Fix SFCGAL regression gating and roof checks
Gate polygon-repair regression tests on the CGAL version that provides the exercised behavior, keep SFCGAL 2.3-only regression selection together, and add generic roof-generation checks against the specialized wrappers.
commit 8c034d0faef7819f920cb4d921068217f679c1cd
Date: Tue Jun 16 23:37:32 2026 +0400
sfcgal: fix regression gating and roof checks
diff --git a/sfcgal/regress/roofgeneration.sql b/sfcgal/regress/roofgeneration.sql
index 106f5105e..50b11ab16 100644
--- a/sfcgal/regress/roofgeneration.sql
+++ b/sfcgal/regress/roofgeneration.sql
@@ -13,4 +13,10 @@ SELECT 'generic_hipped', ST_AsText(CG_GenerateRoof('POLYGON((0 0,4 0,4 4,0 4,0 0
SELECT 'generic_flat', ST_AsText(CG_GenerateRoof('POLYGON((0 0,4 0,4 4,0 4,0 0))', 'FLAT', 2.0, 30.0, 0));
SELECT 'generic_gable_3d', ST_CoordDim(CG_GenerateRoof('POLYGON((0 0,4 0,4 4,0 4,0 0))', 'GABLE', 2.0, 30.0, 0));
SELECT 'generic_skillion_3d', ST_CoordDim(CG_GenerateRoof('POLYGON((0 0,4 0,4 4,0 4,0 0))', 'SKILLION', 2.0, 30.0, 0));
+SELECT 'generic_gable_matches_specialized',
+ ST_AsText(CG_GenerateRoof('POLYGON((0 0,4 0,4 4,0 4,0 0))', 'GABLE', 5.0, 15.0, 0)) =
+ ST_AsText(CG_GenerateGableRoof('POLYGON((0 0,4 0,4 4,0 4,0 0))', 5.0, 15.0));
+SELECT 'generic_skillion_matches_specialized',
+ ST_AsText(CG_GenerateRoof('POLYGON((0 0,4 0,4 4,0 4,0 0))', 'SKILLION', 5.0, 15.0, 0)) =
+ ST_AsText(CG_GenerateSkillionRoof('POLYGON((0 0,4 0,4 4,0 4,0 0))', 5.0, 15.0, 0));
SELECT 'invalid_type', CG_GenerateRoof('POLYGON((0 0,4 0,4 4,0 4,0 0))', 'DOME', 2.0, 30.0, 0);
diff --git a/sfcgal/regress/roofgeneration_expected b/sfcgal/regress/roofgeneration_expected
index d67b1e24d..d90fef96f 100644
--- a/sfcgal/regress/roofgeneration_expected
+++ b/sfcgal/regress/roofgeneration_expected
@@ -8,4 +8,6 @@ generic_hipped|POLYHEDRALSURFACE Z (((0 4 0,4 4 0,4 0 0,0 0 0,0 4 0)),((0 4 0,0
generic_flat|POLYHEDRALSURFACE Z (((0 0 0,0 4 0,4 4 0,4 0 0,0 0 0)),((0 0 2,4 0 2,4 4 2,0 4 2,0 0 2)),((0 0 0,0 0 2,0 4 2,0 4 0,0 0 0)),((0 4 0,0 4 2,4 4 2,4 4 0,0 4 0)),((4 4 0,4 4 2,4 0 2,4 0 0,4 4 0)),((4 0 0,4 0 2,0 0 2,0 0 0,4 0 0)))
generic_gable_3d|3
generic_skillion_3d|3
+generic_gable_matches_specialized|t
+generic_skillion_matches_specialized|t
ERROR: CG_GenerateRoof: unknown roof type 'DOME', expected FLAT, HIPPED, GABLE or SKILLION
diff --git a/sfcgal/regress/tests.mk.in b/sfcgal/regress/tests.mk.in
index 89b2e4627..c1c39d069 100644
--- a/sfcgal/regress/tests.mk.in
+++ b/sfcgal/regress/tests.mk.in
@@ -49,13 +49,15 @@ ifeq ($(shell expr "$(POSTGIS_SFCGAL_VERSION)" ">=" 20300),1)
TESTS += \
$(top_srcdir)/sfcgal/regress/alphashape_components.sql \
$(top_srcdir)/sfcgal/regress/roofgeneration.sql \
- $(top_srcdir)/sfcgal/regress/polygonrepair.sql \
$(top_srcdir)/sfcgal/regress/approximatemedialaxis_projected.sql \
$(top_srcdir)/sfcgal/regress/nurbs.sql
- ifeq ($(shell expr "$(POSTGIS_CGAL_VERSION)" ">=" 601),1)
- TESTS += $(top_srcdir)/sfcgal/regress/polygonrepair_union.sql
- else
- TESTS += $(top_srcdir)/sfcgal/regress/polygonrepair_union_pre61.sql
+ ifeq ($(shell expr "$(POSTGIS_CGAL_VERSION)" ">=" 600),1)
+ TESTS += $(top_srcdir)/sfcgal/regress/polygonrepair.sql
+ ifeq ($(shell expr "$(POSTGIS_CGAL_VERSION)" ">=" 601),1)
+ TESTS += $(top_srcdir)/sfcgal/regress/polygonrepair_union.sql
+ else
+ TESTS += $(top_srcdir)/sfcgal/regress/polygonrepair_union_pre61.sql
+ endif
endif
else
TESTS += \
Summary of changes:
sfcgal/regress/roofgeneration.sql | 6 ++++++
sfcgal/regress/roofgeneration_expected | 2 ++
sfcgal/regress/tests.mk.in | 12 +++++++-----
3 files changed, 15 insertions(+), 5 deletions(-)
hooks/post-receive
