[SCM] PostGIS branch master updated. 3.6.0rc2-587-g9b9950de1
Thu Jun 18 05:36:18 PDT 2026
the project "PostGIS".
       via  9b9950de1262a24c41e9e4d647627b1816a6ac52 (commit)
       via  9cc6dac3d6d9c119667a438118cb4b5b6bb21c3b (commit)
      from  014d02c42befac740f904b1cceca52391b671097 (commit)
revisions in full, below.
commit 9b9950de1262a24c41e9e4d647627b1816a6ac52
Merge: 014d02c42 9cc6dac3d
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Jun 18 16:27:57 2026 +0400
    Merge PR #888: Fix SFCGAL visibility empty input handling
    Avoid stale detoasted geometry access in CG_Visibility empty-input compatibility handling for builds against SFCGAL before 2.2, while preserving the empty polygon result for empty inputs.
commit 9cc6dac3d6d9c119667a438118cb4b5b6bb21c3b
Date:   Tue Jun 16 17:15:54 2026 +0400
diff --git a/NEWS b/NEWS
index 4cd72746a..cf06261d4 100644
--- a/NEWS
+++ b/NEWS
@@ -54,6 +54,9 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           finite coordinates (Darafei Praliaskouski)
  - GH-892, Add OSS-Fuzz coverage for TWKB and serialized raster inputs,
           including guards for malformed TWKB reads and counts (Darafei Praliaskouski)
+ - GH-888, [sfcgal] Avoid stale detoasted geometry access in
+          CG_Visibility empty-input handling for SFCGAL < 2.2
+          (Darafei Praliaskouski)
  - Build PostgreSQL extension modules with `-fno-semantic-interposition` when
           available so LTO can optimize same-DSO calls to exported PostGIS
           entry points directly instead of routing through the module PLT; in
diff --git a/sfcgal/lwgeom_sfcgal.c b/sfcgal/lwgeom_sfcgal.c
index 5ee90f878..0289ccb21 100644
--- a/sfcgal/lwgeom_sfcgal.c
+++ b/sfcgal/lwgeom_sfcgal.c
@@ -19,6 +19,7 @@
  * Copyright 2012-2020 Oslandia <infos at oslandia.com>
+ * Copyright 2026 Darafei Praliaskouski <me at komzpa.net>
@@ -1232,22 +1233,30 @@ sfcgal_visibility_point(PG_FUNCTION_ARGS)
 	input0 = PG_GETARG_GSERIALIZED_P(0);
 	srid = gserialized_get_srid(input0);
 	input1 = PG_GETARG_GSERIALIZED_P(1);
-	polygon = POSTGIS2SFCGALGeometry(input0);
-	PG_FREE_IF_COPY(input0, 0);
-	point = POSTGIS2SFCGALGeometry(input1);
-	PG_FREE_IF_COPY(input1, 1);
 #if POSTGIS_SFCGAL_VERSION < 20200
+	 * SFCGAL < 2.2 needs PostGIS to preserve the empty-input result.
+	 * Check this before converting and freeing detoasted inputs, because
+	 * gserialized_is_empty() must not inspect a freed copy.
 	if (gserialized_is_empty(input0) || gserialized_is_empty(input1))
 		result = sfcgal_polygon_create();
 		output = SFCGALGeometry2POSTGIS(result, 0, srid);
 		sfcgal_geometry_delete(result);
+		PG_FREE_IF_COPY(input0, 0);
+		PG_FREE_IF_COPY(input1, 1);
 		PG_RETURN_POINTER(output);
 #endif
+	polygon = POSTGIS2SFCGALGeometry(input0);
+	point = POSTGIS2SFCGALGeometry(input1);
 	result = sfcgal_geometry_visibility_point(polygon, point);
 	sfcgal_geometry_delete(polygon);
 	sfcgal_geometry_delete(point);
@@ -1282,24 +1291,33 @@ sfcgal_visibility_segment(PG_FUNCTION_ARGS)
 	input2 = PG_GETARG_GSERIALIZED_P(2);
-	pointA = POSTGIS2SFCGALGeometry(input1);
-	pointB = POSTGIS2SFCGALGeometry(input2);
-	PG_FREE_IF_COPY(input2, 2);
 	if (gserialized_is_empty(input0) || gserialized_is_empty(input1) || gserialized_is_empty(input2))
+		PG_FREE_IF_COPY(input2, 2);
 #endif
+	pointA = POSTGIS2SFCGALGeometry(input1);
+	pointB = POSTGIS2SFCGALGeometry(input2);
 	result = sfcgal_geometry_visibility_segment(polygon, pointA, pointB);
 	sfcgal_geometry_delete(pointA);
Summary of changes:
 NEWS                   |  3 +++
 sfcgal/lwgeom_sfcgal.c | 38 ++++++++++++++++++++++++++++----------
 2 files changed, 31 insertions(+), 10 deletions(-)
hooks/post-receive
