[SCM] PostGIS branch master updated. 3.6.0rc2-585-g014d02c42
git at osgeo.org
git at osgeo.org
Thu Jun 18 05:23:33 PDT 2026
the project "PostGIS".
via 014d02c42befac740f904b1cceca52391b671097 (commit)
via cff529aa81f12c0dc12b2b273a0e836e38c3f122 (commit)
from 857652e24926f169f74f0caf921e674bb65f5d8b (commit)
revisions in full, below.
commit 014d02c42befac740f904b1cceca52391b671097
Merge: 857652e24 cff529aa8
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Thu Jun 18 16:18:43 2026 +0400
Merge PR #959: Stabilize NURBS approximation regression output
Apply explicit two-decimal ST_AsText output for the high-tolerance NURBS approximation regression so SFCGAL/CGAL precision drift does not fail otherwise unrelated CI runs.
Validation: GitHub CI green on cff529aa81f12c0dc12b2b273a0e836e38c3f122; local git diff --check upstream/master..HEAD passed; local make -C sfcgal/regress check RUNTESTFLAGS='--verbose --extension' TESTS="/home/kom/proj/osgeo/postgis/sfcgal/regress/nurbs.sql" passed, including automatic upgrade rerun.
commit cff529aa81f12c0dc12b2b273a0e836e38c3f122
Date: Thu Jun 18 11:23:12 2026 +0400
diff --git a/sfcgal/regress/nurbs.sql b/sfcgal/regress/nurbs.sql
index a71fc9f54..bed1a0361 100644
--- a/sfcgal/regress/nurbs.sql
+++ b/sfcgal/regress/nurbs.sql
@@ -96,7 +96,7 @@ SELECT 'approximate_high_tol', ST_AsText(CG_NurbsCurveApproximate(
'LINESTRING(0 0, 1 2.1, 2 1.9, 3 3.2, 4 2.8, 5 1)'::geometry,
2,
0.5
+), 2);
-- Test approximation with 3D points
SELECT 'approximate_3d', ST_AsText(CG_NurbsCurveApproximate(
diff --git a/sfcgal/regress/nurbs_expected b/sfcgal/regress/nurbs_expected
index a7e2856fb..9ccee264f 100644
--- a/sfcgal/regress/nurbs_expected
+++ b/sfcgal/regress/nurbs_expected
@@ -10,6 +10,6 @@ ERROR: Data points must be a LINESTRING
ERROR: Need at least 4 data points for degree 3 interpolation
approximate_default|NURBSCURVE(DEGREE 3,CONTROLPOINTS(NURBSPOINT(WEIGHTEDPOINT(0 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(0.18 -0.15),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(1.49 4.36),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(3.33 1.33),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(4.34 0.83),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(5 0),WEIGHT 1)),KNOTS (KNOT(0,4),KNOT(0.46,1),KNOT(0.64,1),KNOT(1,4)))
approximate_max_ctrl|NURBSCURVE(DEGREE 3,CONTROLPOINTS(NURBSPOINT(WEIGHTEDPOINT(0 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(3.3 6.18),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(6.48 40.13),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(8.84 73.32),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(10 100),WEIGHT 1)),KNOTS (KNOT(0,4),KNOT(0.21,1),KNOT(1,4)))
-approximate_high_tol|NURBSCURVE(DEGREE 2,CONTROLPOINTS(NURBSPOINT(WEIGHTEDPOINT(0 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(-0.048424154393691 2.640915492953116),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(2.237552942255657 1.646186724700419),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(2.786598026195684 3.476253776863865),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(4.840573182610214 2.429625830321494),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(5 1),WEIGHT 1)),KNOTS (KNOT(0,3),KNOT(0.349154606588781,1),KNOT(0.512902297757245,1),KNOT(0.680173066921787,1),KNOT(1,3)))
+approximate_high_tol|NURBSCURVE(DEGREE 2,CONTROLPOINTS(NURBSPOINT(WEIGHTEDPOINT(0 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(-0.05 2.64),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(2.24 1.65),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(2.79 3.48),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(4.84 2.43),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT(5 1),WEIGHT 1)),KNOTS (KNOT(0,3),KNOT(0.35,1),KNOT(0.51,1),KNOT(0.68,1),KNOT(1,3)))
approximate_3d|NURBSCURVE Z (DEGREE 3,CONTROLPOINTS Z (NURBSPOINT(WEIGHTEDPOINT Z (0 0 0),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT Z (0.18 -0.15 -1.29),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT Z (1.49 4.36 3.35),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT Z (3.33 1.33 0.38),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT Z (4.34 0.83 -0.44),WEIGHT 1),NURBSPOINT(WEIGHTEDPOINT Z (5 0 0),WEIGHT 1)),KNOTS (KNOT(0,4),KNOT(0.46,1),KNOT(0.64,1),KNOT(1,4)))
ERROR: Need at least 4 data points for degree 3 approximation
Summary of changes:
sfcgal/regress/nurbs.sql | 2 +-
sfcgal/regress/nurbs_expected | 2 +-
2 files changed, 2 insertions(+), 2 deletions(-)
hooks/post-receive
