[SCM] PostGIS branch master updated. 3.6.0rc2-609-gea6867474
Thu Jun 18 09:29:33 PDT 2026
the project "PostGIS".
       via  ea686747486090d3da1a40e5b753671699b4177d (commit)
       via  defcb5edcd9d02ad5743e9c03a175a1b37b7b03c (commit)
      from  663d846350266125cbed07fa50e3b534cfc4fe81 (commit)
revisions in full, below.
commit ea686747486090d3da1a40e5b753671699b4177d
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Jun 18 20:27:54 2026 +0400
    upgrade: clarify incomplete deprecated cleanup errors
    Report a PostGIS-specific diagnostic when a repeated upgrade cannot rename a replaced function because a deprecated alias from an earlier partial cleanup still exists.
    Add a focused create_upgrade generator check for that replaced-function error path.
    Closes https://github.com/postgis/postgis/pull/970
    Closes #5487
diff --git a/NEWS b/NEWS
index 2184d6798..0b6caaaeb 100644
--- a/NEWS
+++ b/NEWS
@@ -58,6 +58,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
 * Bug Fixes *
+ - #5487, Improve error detail for repeated upgrades after an incomplete
+          deprecated-function cleanup (Darafei Praliaskouski)
  - GH-899, [raster] Honor PostgreSQL interrupts in long-running GDAL
           progress callbacks (Darafei Praliaskouski)
  - #5975, Initialize skipped union-find cluster ids deterministically
diff --git a/utils/Makefile.in b/utils/Makefile.in
index 090bbedfd..42f1dd4b1 100644
--- a/utils/Makefile.in
+++ b/utils/Makefile.in
@@ -123,7 +123,10 @@ check-regress:
 check: check-unit
-check-unit: postgis_restore-check
+create_upgrade_replaced_function_errors_check:
+	srcdir=$(srcdir) PERL=$(PERL) $(SHELL) $(srcdir)/check_create_upgrade_replaced_function_errors.sh
+check-unit: postgis_restore-check create_upgrade_replaced_function_errors_check
 installdir:
 	@mkdir -p $(DESTDIR)$(bindir)
diff --git a/utils/check_create_upgrade_replaced_function_errors.sh b/utils/check_create_upgrade_replaced_function_errors.sh
new file mode 100644
index 000000000..caa5d375d
--- /dev/null
+++ b/utils/check_create_upgrade_replaced_function_errors.sh
@@ -0,0 +1,30 @@
+#!/bin/sh
+set -e
+TMPDIR="${TMPDIR:-/tmp}/check_create_upgrade_replaced_function_errors.$$"
+trap 'rm -rf "${TMPDIR}"' EXIT
+mkdir -p "${TMPDIR}"
+cat > "${TMPDIR}/postgis.sql" <<'SQL'
+-- INSTALL VERSION: 3.7.0dev
+-- Availability: 1.0.0
+-- Changed: 3.1.0 add a default argument
+-- Replaces ST_Test(geometry) deprecated in 3.1.0
+CREATE OR REPLACE FUNCTION ST_Test(geometry, float8 DEFAULT 0.0) RETURNS geometry
+AS 'MODULE_PATHNAME', 'ST_Test'
+LANGUAGE 'c' IMMUTABLE STRICT PARALLEL SAFE;
+SQL
+"${PERL:-perl}" "${srcdir:-.}/create_upgrade.pl" "${TMPDIR}/postgis.sql" > "${TMPDIR}/upgrade.sql"
+# The duplicate-function branch turns a PostgreSQL rename collision from a
+# partially completed upgrade into an actionable PostGIS diagnostic.
+grep -Fq \
+	"PostGIS upgrade cannot rename replaced function st_test(geometry): leftover deprecated function st_test_deprecated_by_postgis_301(geometry) already exists" \
+	"${TMPDIR}/upgrade.sql"
+grep -Fq \
+	"retry SELECT postgis_extensions_upgrade()" \
diff --git a/utils/create_upgrade.pl b/utils/create_upgrade.pl
index 38826cfe6..b10ecc61e 100644
--- a/utils/create_upgrade.pl
+++ b/utils/create_upgrade.pl
@@ -505,6 +505,12 @@ EOF
     EXCEPTION
     WHEN undefined_function THEN
         RAISE DEBUG 'Replaced function $name($args) does not exist';
+    WHEN duplicate_function THEN
+        -- The target name is left behind when an earlier upgrade could not drop
+        -- a deprecated function still referenced by user objects.
+        RAISE EXCEPTION 'PostGIS upgrade cannot rename replaced function $name($args): leftover deprecated function ${replacement} already exists'
+            USING DETAIL = 'A previous upgrade likely left ${replacement} because a user object still depends on it.',
+                  HINT = 'Run SELECT postgis_full_version(); and inspect objects depending on functions named *_deprecated_by_postgis_*. Drop or update those objects, then retry SELECT postgis_extensions_upgrade().';
     WHEN OTHERS THEN
         GET STACKED DIAGNOSTICS detail := PG_EXCEPTION_DETAIL;
         RAISE EXCEPTION 'Attempting to rename replaced function $name($args) got % (%)', SQLERRM, SQLSTATE
@@ -1062,4 +1068,3 @@ END
 LANGUAGE 'plpgsql';
commit defcb5edcd9d02ad5743e9c03a175a1b37b7b03c
Date:   Thu Jun 18 20:24:43 2026 +0400
    raster: honor registered interrupts in GDAL progress
    Register a postgis_raster liblwgeom interrupt callback so raster-only backends can propagate PostgreSQL cancel and death requests into long-running GDAL progress callbacks.
    Restore any previously registered callback on module unload.
    Closes https://github.com/postgis/postgis/pull/899
index ce02af436..2184d6798 100644
--- a/NEWS
+++ b/NEWS
 * Bug Fixes *
+ - GH-899, [raster] Honor PostgreSQL interrupts in long-running GDAL
+          progress callbacks (Darafei Praliaskouski)
  - GH-885, [topology] Avoid GMP overflow in ring orientation for very large
diff --git a/raster/rt_core/rt_gdal.c b/raster/rt_core/rt_gdal.c
index ff01c1d66..f41c246f4 100644
--- a/raster/rt_core/rt_gdal.c
+++ b/raster/rt_core/rt_gdal.c
@@ -68,6 +68,9 @@ rt_util_gdal_progress_func(double dfComplete, const char *pszMessage, void *pPro
 	(void)dfComplete;
 	(void)pszMessage;
+	if (_lwgeom_interrupt_callback)
+		(*_lwgeom_interrupt_callback)();
 	if (_lwgeom_interrupt_requested)
 		// rtwarn("%s interrupted at %g", (const char*)pProgressArg, dfComplete);
@@ -307,4 +310,3 @@ int rt_raster_gdal_contour(
 	/* Done */
 	return TRUE;
diff --git a/raster/rt_pg/rtpostgis.c b/raster/rt_pg/rtpostgis.c
index 49089b70e..663fe8552 100644
--- a/raster/rt_pg/rtpostgis.c
+++ b/raster/rt_pg/rtpostgis.c
@@ -137,6 +137,7 @@
 #include "utils/builtins.h"
 #include "utils/memutils.h"
 #include "utils/elog.h"
+#include "miscadmin.h"
 /* PostGIS */
 #include "postgis_config.h"
@@ -149,6 +150,18 @@
 #include "rtpostgis.h"
 #include "rtpg_internal.h"
+static void
+rtpg_interrupt_liblwgeom_callback(void)
+#ifdef WIN32
+	if (UNBLOCKED_SIGNAL_QUEUE())
+		pgwin32_dispatch_queued_signals();
+#endif
+	if (QueryCancelPending || ProcDiePending)
+		lwgeom_request_interrupt();
+static lwinterrupt_callback *prev_liblwgeom_interrupt_callback = NULL;
 #ifndef __GNUC__
 # define __attribute__ (x)
@@ -715,6 +728,7 @@ _PG_init(void) {
 	/* Install liblwgeom handlers */
 	pg_install_lwgeom_handlers();
+	prev_liblwgeom_interrupt_callback = lwgeom_register_interrupt_callback(rtpg_interrupt_liblwgeom_callback);
 	/* Install rtcore handlers */
 	rt_set_handlers_options(rt_pg_alloc, rt_pg_realloc, rt_pg_free,
@@ -847,6 +861,9 @@ _PG_fini(void) {
 	elog(NOTICE, "Goodbye from PostGIS Raster %s", POSTGIS_VERSION);
+	lwgeom_register_interrupt_callback(prev_liblwgeom_interrupt_callback);
+	prev_liblwgeom_interrupt_callback = NULL;
 	/* Clean up */
 	pfree(env_postgis_gdal_enabled_drivers);
 	pfree(boot_postgis_gdal_enabled_drivers);
@@ -859,6 +876,3 @@ _PG_fini(void) {
 	/* Revert back to old context */
 	MemoryContextSwitchTo(old_context);
Summary of changes:
 NEWS                                               |  4 +++
 raster/rt_core/rt_gdal.c                           |  4 ++-
 raster/rt_pg/rtpostgis.c                           | 20 ++++++++++++---
 utils/Makefile.in                                  |  5 +++-
 ...heck_create_upgrade_replaced_function_errors.sh | 30 ++++++++++++++++++++++
 utils/create_upgrade.pl                            |  7 ++++-
 6 files changed, 64 insertions(+), 6 deletions(-)
 create mode 100644 utils/check_create_upgrade_replaced_function_errors.sh
hooks/post-receive
