[PostGIS] #5487: Confusing error when upgrading from partially upgraded database
PostGIS trac at osgeo.org
Thu Jun 18 09:29:35 PDT 2026
  Reporter:  strk     |      Owner:  strk
      Type:  defect   |     Status:  closed
  Priority:  medium   |  Milestone:  PostGIS 3.5.7
 Component:  upgrade  |    Version:  master
Resolution:  fixed    |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"ea686747486090d3da1a40e5b753671699b4177d/git"
 ea686747/git]:
 {{{#!CommitTicketReference repository="git"
 revision="ea686747486090d3da1a40e5b753671699b4177d"
 upgrade: clarify incomplete deprecated cleanup errors
 Report a PostGIS-specific diagnostic when a repeated upgrade cannot rename
 a replaced function because a deprecated alias from an earlier partial
 cleanup still exists.
 Add a focused create_upgrade generator check for that replaced-function
 error path.
 Closes https://github.com/postgis/postgis/pull/970
 Closes #5487
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5487#comment:9>
