[PostGIS] #5655: make check fails when you do not have docs building/testing requirements (build works)
trac at osgeo.org
Thu Jun 18 09:40:38 PDT 2026
(build works)
Reporter: strk | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.5.7
Component: build | Version: 3.4.x
Resolution: fixed | Keywords: documentation, testsuite
Changes (by Darafei Praliaskouski <me@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"d56c04e9a8e23f5f6ebddc1f9a0269b230838abf/git" d56c04e/git]:
{{{#!CommitTicketReference repository="git"
revision="d56c04e9a8e23f5f6ebddc1f9a0269b230838abf"
doc: skip XML checks without xsltproc
Let make check skip documentation XML validation when configure did not
find xsltproc, while direct check-xml still reports the missing
requirement.
Closes https://github.com/postgis/postgis/pull/919
Closes #5655
Ticket URL: <https://trac.osgeo.org/postgis/ticket/5655#comment:9>
