[SCM] PostGIS branch master updated. 3.6.0rc2-611-g8868c689e
Thu Jun 18 09:57:17 PDT 2026
the project "PostGIS".
       via  8868c689e96dc91c50a0549aac3d7bf5b8b6238e (commit)
      from  d56c04e9a8e23f5f6ebddc1f9a0269b230838abf (commit)
revisions in full, below.
commit 8868c689e96dc91c50a0549aac3d7bf5b8b6238e
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Jun 18 20:55:30 2026 +0400
    regress: cover find_srid duplicate-table lookups
    Add ticket coverage for exact-schema find_srid calls, dotted table-name lookup, and geometry_columns rows when two schemas contain same-named geometry tables.
    Closes https://github.com/postgis/postgis/pull/951
    Closes #3103
diff --git a/NEWS b/NEWS
index ebfe62cef..33f074411 100644
--- a/NEWS
+++ b/NEWS
@@ -58,6 +58,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
 * Bug Fixes *
+ - #3103, Add regression coverage for exact-schema find_srid and
+          geometry_columns lookups (Darafei Praliaskouski)
  - #5655, [doc] Skip XML validation during `make check` when xsltproc is
           unavailable (Darafei Praliaskouski)
  - #5487, Improve error detail for repeated upgrades after an incomplete
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 7da7f4c1f..3e0533a76 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1584,6 +1584,26 @@ SELECT f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, t
  ORDER BY f_table_name, f_geometry_column;
 DROP TABLE IF EXISTS test5829, test5978;
+-- #3103, geometry_columns/find_srid exact-match behavior
+CREATE SCHEMA test3103a;
+CREATE SCHEMA test3103b;
+CREATE TABLE test3103a.geomtab (geom geometry(Point, 4326));
+CREATE TABLE test3103b.geomtab (geom geometry(Point, 3857));
+SELECT '#3103.1', find_srid('test3103a', 'geomtab', 'geom');
+SELECT '#3103.2', find_srid('', 'test3103b.geomtab', 'geom');
+SELECT '#3103.3', f_table_schema, srid
+  FROM geometry_columns
+ WHERE f_table_name = 'geomtab'
+   AND f_geometry_column = 'geom'
+ ORDER BY srid;
+DROP TABLE test3103a.geomtab;
+DROP TABLE test3103b.geomtab;
+DROP SCHEMA test3103a;
+DROP SCHEMA test3103b;
 -- #4828, geometry_columns should ignore pending NOT VALID SRID checks
 CREATE TABLE test4828 (
@@ -1643,4 +1663,3 @@ DROP TABLE IF EXISTS fault6028;
 -- #5357
 SELECT '#5357', ST_AsText(ST_LineFromEncodedPolyline('__nphBgcoeiA?@', 6), 6);
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index dcdffa995..9c3451edd 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -490,6 +490,10 @@ public.test5978.geometry SRID:4326 TYPE:POINT DIMS:2
 public|test5829|geom|2|4326|GEOMETRY
 public|test5978|geometry|2|4326|POINT
 public|test5978|shape|2|4326|POINT
+#3103.1|4326
+#3103.2|3857
+#3103.3|test3103b|3857
+#3103.3|test3103a|4326
 #4828|4326
 #5987|LINESTRING(20 20,20.1 20,20.2 19.9)|LINESTRING(20 20,20.1 20,20.2 19.9)
 #5962|MULTIPOINT((1 1),(3 4))|POINT(1 1)
Summary of changes:
 NEWS                          |  2 ++
 regress/core/tickets.sql      | 21 ++++++++++++++++++++-
 regress/core/tickets_expected |  4 ++++
 3 files changed, 26 insertions(+), 1 deletion(-)
hooks/post-receive
