[SCM] PostGIS branch master updated. 3.6.0rc2-618-g63cbf4f06
Thu Jun 18 14:14:14 PDT 2026
the project "PostGIS".
       via  63cbf4f069afebe50cb520b7abe6440c898842e9 (commit)
      from  96571149829e3a65f8ad7b4c488b8d1ca4666137 (commit)
revisions in full, below.
commit 63cbf4f069afebe50cb520b7abe6440c898842e9
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Fri Jun 19 00:25:55 2026 +0400
    raster: fix import, warp, and GDAL log handling
    Fix raster behavior covering ST_ReclassExact band ownership, Float16 pixel-line writes, legacy GDAL signed-byte imports, mixed nodata/no-nodata warps, zero-band warp nodata allocation, and GDAL credential-bearing log redaction.
    No extension upgrade SQL is required because SQL definitions and catalog-visible objects are unchanged.
    Closes https://github.com/postgis/postgis/pull/894
diff --git a/NEWS b/NEWS
index af7656e13..2e4b7cac6 100644
--- a/NEWS
+++ b/NEWS
@@ -104,6 +104,9 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
  - #4828, geometry_columns handles NOT VALID SRID checks without errors (Darafei Praliaskouski)
  - #6048, [raster] ST_Clip no longer crashes when clipping sparse band
           selections (Darafei Praliaskouski)
+ - GH-894, [raster] Fix Float16 import, mixed nodata warping,
+          band replacement cleanup, GDAL credential redaction, and Python
+          GDAL compatibility (Darafei Praliaskouski)
  - #5645, Docs: keep code operators ("=>") intact in translated manuals
           by enforcing verbatim CSS (Darafei Praliaskouski)
  - #5593, Docs: render manual images with GraphicsMagick without temporary files,
diff --git a/raster/rt_core/rt_band.c b/raster/rt_core/rt_band.c
index 2cbe92ead..0fb95d1f8 100644
--- a/raster/rt_core/rt_band.c
+++ b/raster/rt_core/rt_band.c
@@ -1080,6 +1080,12 @@ rt_band_set_pixel_line(
 			memcpy(ptr, vals, (size_t)size * len);
 			break;
+		case PT_16BF: {
+			uint16_t *ptr = (uint16_t *) data;
+			ptr += offset;
+			memcpy(ptr, vals, (size_t)size * len);
+			break;
 		case PT_32BUI: {
 			uint32_t *ptr = (uint32_t *) data;
 			ptr += offset;
diff --git a/raster/rt_core/rt_warp.c b/raster/rt_core/rt_warp.c
index f5854fd0f..2cdda3c1e 100644
--- a/raster/rt_core/rt_warp.c
+++ b/raster/rt_core/rt_warp.c
@@ -30,6 +30,8 @@
 #include "../../postgis_config.h"
+#include <math.h>
 #include "librtcore.h"
 #include "librtcore_internal.h"
@@ -163,6 +165,9 @@ rt_raster rt_raster_gdal_warp(
 	char *dst_options[] = {"SUBCLASS=VRTWarpedDataset", NULL};
 	_rti_warp_arg arg = NULL;
+	int nodata_count = 0;
+	int has_nodata_count = 0;
 	GDALRasterBandH band;
 	rt_band rtband = NULL;
 	rt_pixtype pt = PT_END;
@@ -179,8 +184,19 @@ rt_raster rt_raster_gdal_warp(
 	int ul_user = 0;
 	rt_raster rast = NULL;
+	rt_raster nodata_src = NULL;
+	rt_raster data_src = NULL;
+	rt_raster nodata_warp = NULL;
+	rt_raster data_warp = NULL;
+	rt_raster src = NULL;
+	uint32_t *nodata_bands = NULL;
+	uint32_t *data_bands = NULL;
+	int *group_index = NULL;
+	int *group_has_nodata = NULL;
 	int i = 0;
 	int numBands = 0;
+	int nodata_pos = 0;
+	int data_pos = 0;
 	int subspatial = 0;
@@ -188,6 +204,155 @@ rt_raster rt_raster_gdal_warp(
 	assert(NULL != raster);
+	numBands = rt_raster_get_num_bands(raster);
+	for (i = 0; i < numBands; i++)
+		rtband = rt_raster_get_band(raster, i);
+		if (NULL == rtband)
+			rterror("rt_raster_gdal_warp: Could not get band %d for checking nodata state", i);
+			return NULL;
+		if (rt_band_get_hasnodata_flag(rtband) != FALSE)
+			has_nodata_count++;
+	if (has_nodata_count > 0 && has_nodata_count < numBands)
+		nodata_bands = rtalloc(sizeof(uint32_t) * has_nodata_count);
+		data_bands = rtalloc(sizeof(uint32_t) * (numBands - has_nodata_count));
+		group_index = rtalloc(sizeof(int) * numBands);
+		group_has_nodata = rtalloc(sizeof(int) * numBands);
+		if (nodata_bands == NULL || data_bands == NULL || group_index == NULL || group_has_nodata == NULL)
+			rterror("rt_raster_gdal_warp: Could not allocate mixed nodata band mapping");
+			rtdealloc(nodata_bands);
+			rtdealloc(data_bands);
+			rtdealloc(group_index);
+			rtdealloc(group_has_nodata);
+			return NULL;
+				nodata_bands[nodata_pos] = i;
+				group_index[i] = nodata_pos++;
+				group_has_nodata[i] = 1;
+			else
+				data_bands[data_pos] = i;
+				group_index[i] = data_pos++;
+				group_has_nodata[i] = 0;
+		nodata_src = rt_raster_from_band(raster, nodata_bands, has_nodata_count);
+		data_src = rt_raster_from_band(raster, data_bands, numBands - has_nodata_count);
+		if (nodata_src == NULL || data_src == NULL)
+			rterror("rt_raster_gdal_warp: Could not split mixed nodata raster");
+			if (nodata_src != NULL)
+				rt_raster_destroy(nodata_src);
+			if (data_src != NULL)
+				rt_raster_destroy(data_src);
+			return NULL;
+		nodata_warp = rt_raster_gdal_warp(nodata_src,
+						  src_srs,
+						  dst_srs,
+						  scale_x,
+						  scale_y,
+						  width,
+						  height,
+						  ul_xw,
+						  ul_yw,
+						  grid_xw,
+						  grid_yw,
+						  skew_x,
+						  skew_y,
+						  resample_alg,
+						  max_err);
+		data_warp = rt_raster_gdal_warp(data_src,
+						src_srs,
+						dst_srs,
+						scale_x,
+						scale_y,
+						width,
+						height,
+						ul_xw,
+						ul_yw,
+						grid_xw,
+						grid_yw,
+						skew_x,
+						skew_y,
+						resample_alg,
+						max_err);
+		if (nodata_warp == NULL || data_warp == NULL)
+			rterror("rt_raster_gdal_warp: Could not warp mixed nodata raster groups");
+			if (nodata_warp != NULL)
+				rt_raster_destroy(nodata_warp);
+			if (data_warp != NULL)
+				rt_raster_destroy(data_warp);
+			return NULL;
+		rast = rt_raster_clone(nodata_warp, 0);
+		if (rast == NULL)
+			rterror("rt_raster_gdal_warp: Could not create mixed nodata output raster");
+			return NULL;
+			src = group_has_nodata[i] ? nodata_warp : data_warp;
+			if (rt_raster_copy_band(rast, src, group_index[i], i) < 0)
+				rterror("rt_raster_gdal_warp: Could not merge warped mixed nodata band");
+				rt_raster_destroy(rast);
+				return NULL;
+		RASTER_DEBUG(3, "rt_raster_gdal_warp: done");
+		return rast;
 	arg = _rti_warp_arg_init();
 	if (arg == NULL) {
 		rterror("rt_raster_gdal_warp: Could not initialize internal variables");
@@ -627,7 +792,6 @@ rt_raster rt_raster_gdal_warp(
 	/* add bands */
-	numBands = rt_raster_get_num_bands(raster);
 	for (i = 0; i < numBands; i++) {
 		if (NULL == rtband) {
@@ -656,6 +820,7 @@ rt_raster rt_raster_gdal_warp(
 		if (rt_band_get_hasnodata_flag(rtband) != FALSE) {
+			nodata_count++;
 			rt_band_get_nodata(rtband, &nodata);
 			if (GDALSetRasterNoDataValue(band, nodata) != CE_None)
 				rtwarn("rt_raster_gdal_warp: Could not set nodata value for band %d", i);
@@ -700,10 +865,17 @@ rt_raster rt_raster_gdal_warp(
 	arg->wopts->hDstDS = arg->dst.ds;
 	arg->wopts->pfnTransformer = arg->transform.func;
 	arg->wopts->pTransformerArg = arg->transform.arg.transform;
-	arg->wopts->papszWarpOptions = (char **) CPLMalloc(sizeof(char *) * 2);
+	arg->wopts->papszWarpOptions = (char **) CPLMalloc(sizeof(char *) * 3);
 	arg->wopts->papszWarpOptions[0] = (char *) CPLMalloc(sizeof(char) * (strlen("INIT_DEST=NO_DATA") + 1));
 	strcpy(arg->wopts->papszWarpOptions[0], "INIT_DEST=NO_DATA");
-	arg->wopts->papszWarpOptions[1] = NULL;
+#if POSTGIS_GDAL_VERSION >= 30302
+	arg->wopts->papszWarpOptions[1] = (char *) CPLMalloc(sizeof(char) * (strlen("UNIFIED_SRC_NODATA=PARTIAL") + 1));
+	strcpy(arg->wopts->papszWarpOptions[1], "UNIFIED_SRC_NODATA=PARTIAL");
+#else
+	arg->wopts->papszWarpOptions[1] = (char *) CPLMalloc(sizeof(char) * (strlen("UNIFIED_SRC_NODATA=NO") + 1));
+	strcpy(arg->wopts->papszWarpOptions[1], "UNIFIED_SRC_NODATA=NO");
+#endif
+	arg->wopts->papszWarpOptions[2] = NULL;
 	/* band mapping */
 	arg->wopts->nBandCount = numBands;
@@ -712,8 +884,12 @@ rt_raster rt_raster_gdal_warp(
 	for (i = 0; i < arg->wopts->nBandCount; i++)
 		arg->wopts->panDstBands[i] = arg->wopts->panSrcBands[i] = i + 1;
-	/* nodata mapping */
+	 * When every band declares nodata, pass the explicit vector to GDAL.
+	 * Mixed-band rasters keep their intrinsic per-band nodata metadata; a
+	 * synthetic value for bands without nodata can collide with valid pixels.
+	if (numBands > 0 && nodata_count == numBands) {
 		arg->wopts->padfSrcNoDataReal = (double *) CPLMalloc(numBands * sizeof(double));
 		arg->wopts->padfDstNoDataReal = (double *) CPLMalloc(numBands * sizeof(double));
 		arg->wopts->padfSrcNoDataImag = (double *) CPLMalloc(numBands * sizeof(double));
@@ -735,10 +911,7 @@ rt_raster rt_raster_gdal_warp(
 				_rti_warp_arg_destroy(arg);
 				return NULL;
-			if (!rt_band_get_hasnodata_flag(band))
-				arg->wopts->padfSrcNoDataReal[i] = -123456.789;
-			else
-				rt_band_get_nodata(band, &(arg->wopts->padfSrcNoDataReal[i]));
+			rt_band_get_nodata(band, &(arg->wopts->padfSrcNoDataReal[i]));
 			arg->wopts->padfDstNoDataReal[i] = arg->wopts->padfSrcNoDataReal[i];
 			arg->wopts->padfDstNoDataImag[i] = arg->wopts->padfSrcNoDataImag[i] = 0.0;
@@ -775,4 +948,3 @@ rt_raster rt_raster_gdal_warp(
 	return rast;
diff --git a/raster/rt_pg/rtpg_gdal.c b/raster/rt_pg/rtpg_gdal.c
index 09b3f51a1..41f357f8c 100644
--- a/raster/rt_pg/rtpg_gdal.c
+++ b/raster/rt_pg/rtpg_gdal.c
@@ -38,6 +38,8 @@
 #include <utils/guc.h> /* for ArrayType */
 #include <catalog/pg_type.h> /* for INT2OID, INT4OID, FLOAT4OID, FLOAT8OID and TEXTOID */
 #include <utils/memutils.h> /* For TopMemoryContext */
+#include <ctype.h>
+#include <strings.h>
@@ -1115,10 +1117,62 @@ static const char* const gdalErrorTypes[gdalErrorTypesSize] =
     "AWSSignatureDoesNotMatch"
+static void
+rtpg_gdal_redact_message(char *msg)
+	static const struct {
+		const char *text;
+		bool header_value;
+	} sensitive[] = {{"access_key=", false},
+			 {"access_token=", false},
+			 {"authorization:", true},
+			 {"cookie:", true},
+			 {"key=", false},
+			 {"password=", false},
+			 {"secret=", false},
+			 {"sig=", false},
+			 {"signature=", false},
+			 {"token=", false},
+			 {"x-amz-credential=", false},
+			 {"x-amz-security-token:", true},
+			 {"x-amz-security-token=", false}};
+	char *p;
+	size_t i;
+	for (p = msg; *p; p++)
+		for (i = 0; i < sizeof(sensitive) / sizeof(sensitive[0]); i++)
+			size_t n = strlen(sensitive[i].text);
+			char *v;
+			if (strncasecmp(p, sensitive[i].text, n) != 0)
+				continue;
+			v = p + n;
+			while (*v && isspace((unsigned char) *v))
+				v++;
+			while (*v && *v != '\r' && *v != '\n' &&
+			       (sensitive[i].header_value ||
+				(!isspace((unsigned char)*v) && *v != '&' && *v != ';' && *v != ',')))
+				*v = 'x';
+				v++;
+			p = v > p ? v - 1 : p;
+			break;
 static void
 ogrErrorHandler(CPLErr eErrClass, int err_no, const char* msg)
     const char* gdalErrType = "unknown type";
+    char *redacted = pstrdup(msg ? msg : "");
+    rtpg_gdal_redact_message(redacted);
     if (err_no >= 0 && err_no < gdalErrorTypesSize)
         gdalErrType = gdalErrorTypes[err_no];
@@ -1126,20 +1180,21 @@ ogrErrorHandler(CPLErr eErrClass, int err_no, const char* msg)
     switch (eErrClass)
     case CE_None:
-        elog(NOTICE, "GDAL %s [%d] %s", gdalErrType, err_no, msg);
+        elog(NOTICE, "GDAL %s [%d] %s", gdalErrType, err_no, redacted);
         break;
     case CE_Debug:
-        elog(DEBUG2, "GDAL %s [%d] %s", gdalErrType, err_no, msg);
+        elog(DEBUG2, "GDAL %s [%d] %s", gdalErrType, err_no, redacted);
         break;
     case CE_Warning:
-        elog(WARNING, "GDAL %s [%d] %s", gdalErrType, err_no, msg);
+        elog(WARNING, "GDAL %s [%d] %s", gdalErrType, err_no, redacted);
         break;
     case CE_Failure:
     case CE_Fatal:
     default:
-        elog(ERROR, "GDAL %s [%d] %s", gdalErrType, err_no, msg);
+        elog(ERROR, "GDAL %s [%d] %s", gdalErrType, err_no, redacted);
         break;
+    pfree(redacted);
     return;
@@ -1152,4 +1207,3 @@ rtpg_gdal_set_cpl_debug(bool value, void *extra)
     CPLSetErrorHandler(value ? ogrErrorHandler : NULL);
     CPLSetCurrentErrorHandlerCatchDebug(value);
diff --git a/raster/rt_pg/rtpg_mapalgebra.c b/raster/rt_pg/rtpg_mapalgebra.c
index 865fb3a55..ba34e6323 100644
--- a/raster/rt_pg/rtpg_mapalgebra.c
+++ b/raster/rt_pg/rtpg_mapalgebra.c
@@ -4139,12 +4139,14 @@ Datum RASTER_reclass_exact(PG_FUNCTION_ARGS) {
 		elog(ERROR, "Band reclassification failed");
 	/* replace old band with new band */
-	if (rt_raster_replace_band(raster, newband, bandnum-1) == NULL) {
+	band = rt_raster_replace_band(raster, newband, bandnum-1);
+	if (band == NULL) {
 		rt_band_destroy(newband);
 		rt_raster_destroy(raster);
 		PG_FREE_IF_COPY(pgraster, 0);
 		elog(ERROR, "Could not replace raster band of index %d with reclassified band", bandnum);
+	rt_band_destroy(band);
 	pgrtn = rt_raster_serialize(raster);
diff --git a/raster/scripts/python/pixval.py b/raster/scripts/python/pixval.py
index 44c953cd0..79ad14c5a 100755
--- a/raster/scripts/python/pixval.py
+++ b/raster/scripts/python/pixval.py
@@ -31,7 +31,6 @@ import sys
 def pt2fmt(pt):
     fmttypes = {
         gdalc.GDT_Byte: 'B',
-        gdalc.GDT_Int8: 'B',
         gdalc.GDT_Int16: 'h',
         gdalc.GDT_UInt16: 'H',
         gdalc.GDT_Int32: 'i',
@@ -39,6 +38,8 @@ def pt2fmt(pt):
         gdalc.GDT_Float32: 'f',
         gdalc.GDT_Float64: 'f'
+    if hasattr(gdalc, 'GDT_Int8'):
+        fmttypes[gdalc.GDT_Int8] = 'b'
     if hasattr(gdalc, 'GDT_Float16'):
         fmttypes[gdalc.GDT_Float16] = 'e'
     return fmttypes.get(pt, 'x')
diff --git a/raster/scripts/python/raster2pgsql.py b/raster/scripts/python/raster2pgsql.py
index 7d227b413..82423568d 100755
--- a/raster/scripts/python/raster2pgsql.py
+++ b/raster/scripts/python/raster2pgsql.py
@@ -214,7 +214,6 @@ def gdt2pt(gdt):
     """Translate GDAL data type to WKT Raster pixel type."""
     pixtypes = {
         gdalc.GDT_Byte    : { 'name': 'PT_8BUI',  'id':  4 },
-        gdalc.GDT_Int8    : { 'name': 'PT_8BSI',  'id':  3 },
         gdalc.GDT_Int16   : { 'name': 'PT_16BSI', 'id':  5 },
         gdalc.GDT_UInt16  : { 'name': 'PT_16BUI', 'id':  6 },
         gdalc.GDT_Int32   : { 'name': 'PT_32BSI', 'id':  7 },
@@ -223,6 +222,8 @@ def gdt2pt(gdt):
         gdalc.GDT_Float64 : { 'name': 'PT_64BF',  'id': 11 }
+        pixtypes[gdalc.GDT_Int8] = { 'name': 'PT_8BSI',  'id':  3 }
         pixtypes[gdalc.GDT_Float16] = { 'name': 'PT_16BF', 'id': 9 }
@@ -232,6 +233,26 @@ def gdt2pt(gdt):
     return pixtypes.get(gdt, 13)
+def band_is_signed_byte(band):
+    """Return True for legacy GDAL signed-byte bands exposed as GDT_Byte."""
+    pixel_type = band.GetMetadataItem('PIXELTYPE', 'IMAGE_STRUCTURE')
+    return band.DataType == gdalc.GDT_Byte and pixel_type is not None and pixel_type.upper() == 'SIGNEDBYTE'
+def band2pt(band):
+    """Translate a GDAL raster band to WKT Raster pixel type."""
+    if band_is_signed_byte(band):
+        return { 'name': 'PT_8BSI', 'id': 3 }
+    return gdt2pt(band.DataType)
+def band2numpy(band):
+    """Translate a GDAL raster band to NumPy data type."""
+        return numpy.int8
+    return pt2numpy(band.DataType)
 def pt2numpy(pt):
     """Translate GDAL data type to NumPy data type"""
     ptnumpy = {
@@ -243,6 +264,8 @@ def pt2numpy(pt):
         gdalc.GDT_Float32: numpy.float32,
         gdalc.GDT_Float64: numpy.float64
+        ptnumpy[gdalc.GDT_Int8] = numpy.int8
         ptnumpy[gdalc.GDT_Float16] = numpy.float16
     return ptnumpy.get(pt, numpy.uint8)
@@ -250,6 +273,7 @@ def pt2numpy(pt):
 def pt2fmt(pt):
     """Returns binary data type specifier for given pixel type."""
     fmttypes = {
+        3: 'b', # PT_8BSI
         4: 'B', # PT_8BUI
         5: 'h', # PT_16BSI
         6: 'H', # PT_16BUI
@@ -265,6 +289,7 @@ def pt2fmt(pt):
 def fmt2printfmt(fmt):
     """Returns printf-like formatter for given binary data type specifier."""
     fmttypes = {
+        'b': '%d', # PT_8BSI
         'B': '%d', # PT_8BUI
         'h': '%d', # PT_16BSI
         'H': '%d', # PT_16BUI
@@ -530,7 +555,7 @@ def collect_pixel_types(ds, band_from, band_to):
     pt =[]
     for i in range(band_from, band_to):
         band = ds.GetRasterBand(i)
-        pixel_type = gdt2pt(band.DataType)['name'][3:]
+        pixel_type = band2pt(band)['name'][3:]
         pt.append(pixel_type)
     return pt
@@ -746,7 +771,7 @@ def wkblify_band_header(options, band):
         nodata = 0
     # Encode pixel type
-    pixtype = gdt2pt(band.DataType)['id']
+    pixtype = band2pt(band)['id']
     hexwkb += wkblify('B', pixtype + first4bits)
     # Encode nodata value (or Zero, if nodata unavailable)
@@ -805,7 +830,7 @@ def wkblify_band(options, band, level, xoff, yoff, read_block_size, block_size,
         # XXX: Use for debugging only
         #dump_block_numpy(pixels)
-        out_pixels = numpy.zeros((block_size[1], block_size[0]), pt2numpy(band.DataType))
+        out_pixels = numpy.zeros((block_size[1], block_size[0]), band2numpy(band))
         logit('MSG: Read valid source:\t%d x %d\n' % (len(pixels[0]), len(pixels)))
         logit('MSG: Write into block:\t%d x %d\n' % (len(out_pixels[0]), len(out_pixels)))
diff --git a/raster/test/regress/rt_gdalwarp.sql b/raster/test/regress/rt_gdalwarp.sql
index abee24978..ad5b44638 100644
--- a/raster/test/regress/rt_gdalwarp.sql
+++ b/raster/test/regress/rt_gdalwarp.sql
@@ -887,3 +887,50 @@ SELECT
 	ST_Metadata(ST_Rescale(rast, 2, 2)) AS rescale,
 	ST_Metadata(ST_Resize(rast, 0.5, 0.5)) AS resize
 FROM foo;
+-- Mixed nodata/no-nodata bands keep declared nodata without treating no-nodata NaN as invalid
+WITH src AS (
+	SELECT ST_SetValue(
+		ST_AddBand(
+			ST_SetValue(
+				ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 2, 1, -1, 0, 0, 0), 1, '8BUI', 0, 0),
+				1, 1, 1, NULL
+			2, '64BF', 'NaN'::float8, NULL
+		2, 1, 1, 'NaN'::float8
+	) AS rast
+), warped AS (
+	SELECT ST_Resample(rast, 4, 4, NULL, NULL, 0, 0, 'NearestNeighbour', 0) AS rast
+	FROM src
+SELECT
+	ST_Value(rast, 1, 1, 1) IS NULL AS nodata_band_preserved,
+	ST_Value(rast, 1, 1, 1, FALSE) = ST_BandNoDataValue(rast, 1) AS nodata_raw_matches,
+	ST_Value(rast, 2, 1, 1) IS NULL AS nan_band_visible_value,
+	ST_Value(rast, 2, 1, 1, FALSE)::text AS nan_band_raw_value,
+	ST_BandNoDataValue(rast, 2) IS NULL AS nan_band_has_no_nodata
+FROM warped;
+WITH base AS (
+		ST_SetValue(
+			ST_SetValue(
+				ST_SetValue(ST_AddBand(ST_MakeEmptyRaster(2, 2, 0, 2, 1, -1, 0, 0, 0), 1, '32BF', 0, 0),
+				1, 1, 1, NULL),
+			1, 2, 1, 100),
+		1, 1, 2, 100),
+	1, 2, 2, 100) AS rast
+), mixed AS (
+	SELECT ST_AddBand(rast, 2, '64BF', 'NaN'::float8, NULL) AS rast
+	FROM base
+), warped AS (
+	SELECT
+		ST_Resample((SELECT rast FROM base), 4, 4, NULL, NULL, 0, 0, 'Bilinear', 0) AS single_rast,
+		ST_Resample(rast, 4, 4, NULL, NULL, 0, 0, 'Bilinear', 0) AS mixed_rast
+	FROM mixed
+SELECT
+	ST_Value(mixed_rast, 1, 2, 1) IS NULL = (ST_Value(single_rast, 1, 2, 1) IS NULL) AS mixed_bilinear_matches,
+	ST_BandNoDataValue(mixed_rast, 2) IS NULL AS mixed_bilinear_keeps_no_nodata
+FROM warped;
diff --git a/raster/test/regress/rt_gdalwarp_expected b/raster/test/regress/rt_gdalwarp_expected
index d6bc47c1f..9b2137743 100644
--- a/raster/test/regress/rt_gdalwarp_expected
+++ b/raster/test/regress/rt_gdalwarp_expected
@@ -107,3 +107,5 @@ NOTICE:  Raster has default geotransform. Adjusting metadata for use of GDAL War
 NOTICE:  Raster has default geotransform. Adjusting metadata for use of GDAL Warp API
 (0,0,5,5,2,-2,0,0,0,1)|(0,0,5,5,2,-2,0,0,0,1)
+t|t|f|NaN|t
+t|t
Summary of changes:
 NEWS                                     |   3 +
 raster/rt_core/rt_band.c                 |   6 +
 raster/rt_core/rt_warp.c                 | 192 +++++++++++++++++++++++++++++--
 raster/rt_pg/rtpg_gdal.c                 |  64 ++++++++++-
 raster/rt_pg/rtpg_mapalgebra.c           |   4 +-
 raster/scripts/python/pixval.py          |   3 +-
 raster/scripts/python/raster2pgsql.py    |  33 +++++-
 raster/test/regress/rt_gdalwarp.sql      |  47 ++++++++
 raster/test/regress/rt_gdalwarp_expected |   2 +
 9 files changed, 333 insertions(+), 21 deletions(-)
hooks/post-receive
