[SCM] PostGIS branch master updated. 3.6.0rc2-619-g6f291bf54
Thu Jun 18 15:17:39 PDT 2026
the project "PostGIS".
       via  6f291bf547cf9b1834cfa63a779899f6ede4aeba (commit)
      from  63cbf4f069afebe50cb520b7abe6440c898842e9 (commit)
revisions in full, below.
commit 6f291bf547cf9b1834cfa63a779899f6ede4aeba
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Thu Jun 18 16:46:37 2026 +0400
    Improve point-only GeometryCollection predicate fast paths
    References #4749
    Closes https://github.com/postgis/postgis/pull/966
diff --git a/NEWS b/NEWS
index 2e4b7cac6..24b7e37b5 100644
--- a/NEWS
+++ b/NEWS
@@ -57,6 +57,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           (Sandro Santilli)
  - #3743, [raster] Document and test raster2pgsql -s FROM_SRID:SRID
           reprojection support (Darafei Praliaskouski)
+ - #4749, Use point-in-polygon predicate fast paths for point-only
+          GeometryCollections (Darafei Praliaskouski)
 * Bug Fixes *
diff --git a/postgis/lwgeom_geos_predicates.c b/postgis/lwgeom_geos_predicates.c
index 87d34a694..2a283e17c 100644
--- a/postgis/lwgeom_geos_predicates.c
+++ b/postgis/lwgeom_geos_predicates.c
@@ -18,13 +18,13 @@
+ * Copyright 2026 Darafei Praliaskouski <me at komzpa.net>
  * Copyright 2009-2014 Sandro Santilli <strk at kbt.io>
  * Copyright 2008 Paul Ramsey <pramsey at cleverelephant.ca>
  * Copyright 2001-2003 Refractions Research Inc.
 #include "../postgis_config.h"
 /* PostgreSQL */
@@ -73,20 +73,98 @@ is_poly(const GSERIALIZED *g)
- * Utility to quickly check for point geometries
+ * Cheap type gate for geometries that may become point-like.
 static inline uint8_t
-is_point(const GSERIALIZED *g)
+is_point_or_collection(const GSERIALIZED *g)
 	int type = gserialized_get_type(g);
-	return type == POINTTYPE || type == MULTIPOINTTYPE;
+	return type == POINTTYPE || type == MULTIPOINTTYPE || type == COLLECTIONTYPE;
+/* Avoid homogenizing mixed collections just to discover that PIP cannot use them. */
+static uint8_t
+lwgeom_is_pointlike(const LWGEOM *lwgeom)
+	const LWCOLLECTION *lwcol;
+	uint32_t i;
+	if (lwgeom->type == POINTTYPE || lwgeom->type == MULTIPOINTTYPE)
+		return LW_TRUE;
+	if (lwgeom->type != COLLECTIONTYPE)
+		return LW_FALSE;
+	lwcol = (const LWCOLLECTION *)lwgeom;
+	if (lwcol->ngeoms == 0)
+		return LW_FALSE;
+	for (i = 0; i < lwcol->ngeoms; i++)
+		if (!lwgeom_is_pointlike(lwcol->geoms[i]))
+			return LW_FALSE;
+	return LW_TRUE;
+ * Return an owned point/multipoint LWGEOM for direct point inputs or for
+ * GeometryCollections whose children are all points.
+static LWGEOM *
+pointlike_lwgeom_from_gserialized(const GSERIALIZED *g)
+	int type = gserialized_get_type(g);
+	LWGEOM *lwgeom;
+	LWGEOM *hgeom;
+	if (type == POINTTYPE || type == MULTIPOINTTYPE)
+		return lwgeom_from_gserialized(g);
+	if (type != COLLECTIONTYPE)
+		return NULL;
+	lwgeom = lwgeom_from_gserialized(g);
+	if (!lwgeom_is_pointlike(lwgeom))
+		lwgeom_free(lwgeom);
+		return NULL;
+	hgeom = lwgeom_homogenize(lwgeom);
+	if (!hgeom)
+		return NULL;
+	if (hgeom->type == POINTTYPE || hgeom->type == MULTIPOINTTYPE)
+		return hgeom;
+	lwgeom_free(hgeom);
+	return NULL;
+typedef bool (*itree_pip_predicate)(const IntervalTree *itree, const LWGEOM *lwpoints);
+static bool
+try_itree_pointlike_pip(FunctionCallInfo fcinfo,
+			const GSERIALIZED *gpoints,
+			SHARED_GSERIALIZED *shared_gpoly,
+			itree_pip_predicate predicate,
+			bool *result)
+	LWGEOM *lwpt = pointlike_lwgeom_from_gserialized(gpoints);
+	IntervalTree *itree;
+	if (!lwpt)
+		return false;
+	itree = GetIntervalTree(fcinfo, shared_gpoly);
+	*result = predicate(itree, lwpt);
+	lwgeom_free(lwpt);
+	return true;
 PG_FUNCTION_INFO_V1(ST_Intersects);
 Datum ST_Intersects(PG_FUNCTION_ARGS)
@@ -98,6 +176,7 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
 	int8_t result;
 	GBOX box1, box2;
 	PrepGeomCache *prep_cache;
+	bool pip_result;
 	gserialized_error_if_srid_mismatch(geom1, geom2, __func__);
@@ -117,20 +196,18 @@ Datum ST_Intersects(PG_FUNCTION_ARGS)
-	 * Short-circuit 2: if the geoms are a point and a polygon,
-	 * call the itree_pip_intersects function.
+	 * Short-circuit 2: if one geometry is polygonal and the other is a
+	 * point or point-only collection, use the IntervalTree PIP fast path.
-	if ((is_point(geom1) && is_poly(geom2)) ||
-	    (is_point(geom2) && is_poly(geom1)))
+	if (is_point_or_collection(geom1) && is_poly(geom2) &&
+	    try_itree_pointlike_pip(fcinfo, geom1, shared_geom2, itree_pip_intersects, &pip_result))
-		SHARED_GSERIALIZED *shared_gpoly = is_poly(geom1) ? shared_geom1 : shared_geom2;
-		SHARED_GSERIALIZED *shared_gpoint = is_point(geom1) ? shared_geom1 : shared_geom2;
-		const GSERIALIZED *gpoint = shared_gserialized_get(shared_gpoint);
-		LWGEOM *lwpt = lwgeom_from_gserialized(gpoint);
-		IntervalTree *itree = GetIntervalTree(fcinfo, shared_gpoly);
-		bool result = itree_pip_intersects(itree, lwpt);
-		lwgeom_free(lwpt);
-		PG_RETURN_BOOL(result);
+		PG_RETURN_BOOL(pip_result);
+	else if (is_point_or_collection(geom2) && is_poly(geom1) &&
+		 try_itree_pointlike_pip(fcinfo, geom2, shared_geom1, itree_pip_intersects, &pip_result))
 	initGEOS(lwpgnotice, lwgeom_geos_error);
@@ -504,6 +581,7 @@ Datum contains(PG_FUNCTION_ARGS)
 	GEOSGeometry *g1, *g2;
 	GBOX box1, box2;
+	bool pip_result;
@@ -525,17 +603,13 @@ Datum contains(PG_FUNCTION_ARGS)
-	** Short-circuit 2: if geom2 is a point and geom1 is a polygon
-	** call the point-in-polygon function.
+	** Short-circuit 2: if geom1 is polygonal and geom2 is a point
+	** or point-only collection, use the IntervalTree PIP fast path.
-	if (is_poly(geom1) && is_point(geom2))
+	if (is_poly(geom1) && is_point_or_collection(geom2) &&
+	    try_itree_pointlike_pip(fcinfo, geom2, shared_geom1, itree_pip_contains, &pip_result))
-		const GSERIALIZED *gpoint = shared_gserialized_get(shared_geom2);
-		IntervalTree *itree = GetIntervalTree(fcinfo, shared_geom1);
-		bool result = itree_pip_contains(itree, lwpt);
@@ -585,6 +659,7 @@ Datum within(PG_FUNCTION_ARGS)
 	GBOX box1, box2;
+	bool pip_result;
@@ -606,17 +681,13 @@ Datum within(PG_FUNCTION_ARGS)
-	** Short-circuit 2: if geom2 is a polygon and geom1 is a point
+	** Short-circuit 2: if geom2 is polygonal and geom1 is a point
-	if (is_poly(geom2) && is_point(geom1))
+	if (is_poly(geom2) && is_point_or_collection(geom1) &&
+	    try_itree_pointlike_pip(fcinfo, geom1, shared_geom2, itree_pip_contains, &pip_result))
-		const GSERIALIZED *gpoint = shared_gserialized_get(shared_geom1);
-		IntervalTree *itree = GetIntervalTree(fcinfo, shared_geom2);
@@ -729,6 +800,7 @@ Datum covers(PG_FUNCTION_ARGS)
 	int8_t result;
 	GBOX box1, box2;
+	bool pip_result;
 	POSTGIS_DEBUGF(3, "Covers: type1: %d, type2: %d", gserialized_get_type(geom1), gserialized_get_type(geom2));
@@ -751,17 +823,13 @@ Datum covers(PG_FUNCTION_ARGS)
-	 * Short-circuit 2: if geom2 is a point and geom1 is a polygon
-	 * call the point-in-polygon function.
+	 * Short-circuit 2: if geom1 is polygonal and geom2 is a point
+	 * or point-only collection, use the IntervalTree PIP fast path.
+	    try_itree_pointlike_pip(fcinfo, geom2, shared_geom1, itree_pip_covers, &pip_result))
-		bool result = itree_pip_covers(itree, lwpt);
@@ -813,6 +881,7 @@ Datum coveredby(PG_FUNCTION_ARGS)
 	int8_t result;
 	GBOX box1, box2;
+	bool pip_result;
@@ -835,17 +904,13 @@ Datum coveredby(PG_FUNCTION_ARGS)
-	 * Short-circuit 2: if geom1 is a point and geom2 is a polygon
+	 * Short-circuit 2: if geom2 is polygonal and geom1 is a point
-	if (is_point(geom1) && is_poly(geom2))
+	    try_itree_pointlike_pip(fcinfo, geom1, shared_geom2, itree_pip_covers, &pip_result))
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index 3e0533a76..413a1b9f1 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1243,6 +1243,72 @@ SELECT 'equals212', ST_equals('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometry
 SELECT 'equals213', ST_equals('POLYGON((0 0, 0 10, 10 10, 10 0, 0 0))'::geometry,
 'GEOMETRYCOLLECTION (POLYGON((0 0, 10 0, 10 10, 0 10, 0 0)),MULTIPOINT(0 2, 5 5))'::geometry);
+-- #4749 point-only GeometryCollections in polygon predicates use the PIP path
+WITH g AS (
+	SELECT
+		'POLYGON((0 0,0 10,10 10,10 0,0 0))'::geometry AS poly,
+		'GEOMETRYCOLLECTION(GEOMETRYCOLLECTION(POINT(5 5)),MULTIPOINT((7 7),(8 8)))'::geometry AS pts_inside,
+		'GEOMETRYCOLLECTION(POINT(5 5),POINT(0 0))'::geometry AS pts_boundary,
+		'GEOMETRYCOLLECTION(POINT(5 5),POINT(11 11))'::geometry AS pts_outside
+SELECT '#4749.contains',
+	ST_Contains(poly, pts_inside),
+	ST_Contains(poly, pts_boundary),
+	ST_Contains(poly, pts_outside)
+FROM g;
+WITH g AS (
+	SELECT
+SELECT '#4749.within',
+	ST_Within(pts_inside, poly),
+	ST_Within(pts_boundary, poly),
+	ST_Within(pts_outside, poly)
+FROM g;
+WITH g AS (
+	SELECT
+SELECT '#4749.covers',
+	ST_Covers(poly, pts_inside),
+	ST_Covers(poly, pts_boundary),
+	ST_Covers(poly, pts_outside)
+FROM g;
+WITH g AS (
+	SELECT
+SELECT '#4749.coveredby',
+	ST_CoveredBy(pts_inside, poly),
+	ST_CoveredBy(pts_boundary, poly),
+	ST_CoveredBy(pts_outside, poly)
+FROM g;
+WITH g AS (
+	SELECT
+SELECT '#4749.intersects',
+	ST_Intersects(poly, pts_inside),
+	ST_Intersects(pts_boundary, poly),
+	ST_Intersects(poly, pts_outside)
+FROM g;
 -- #4299
 SELECT '#4299', ST_Disjoint(ST_GeneratePoints(g, 1000), ST_GeneratePoints(g, 1000))
 FROM (SELECT 'POLYGON((0 0,1 0,1 1,0 1,0 0))'::geometry AS g) AS f;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 9c3451edd..dc67b09d2 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -383,6 +383,11 @@ equals210|t
 equals211|t
 equals212|t
 equals213|t
+#4749.contains|t|t|f
+#4749.within|t|t|f
+#4749.covers|t|t|f
+#4749.coveredby|t|t|f
+#4749.intersects|t|t|t
 #4299|t
 #4304|t|t|t
 ERROR:  BOX3D_construct: args can not be empty points
Summary of changes:
 NEWS                             |   2 +
 postgis/lwgeom_geos_predicates.c | 169 +++++++++++++++++++++++++++------------
 regress/core/tickets.sql         |  66 +++++++++++++++
 regress/core/tickets_expected    |   5 ++
 4 files changed, 190 insertions(+), 52 deletions(-)
hooks/post-receive
