[PostGIS] #6083: Compile error on fuzzing engine on winnie
PostGIS trac at osgeo.org
Fri Jun 19 00:37:44 PDT 2026
  Reporter:  robe     |      Owner:  komzpa
      Type:  defect   |     Status:  closed
  Priority:  blocker  |  Milestone:  PostGIS 3.7.0
 Component:  postgis  |    Version:  master
Resolution:  fixed    |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  assigned => closed
Comment:
 In [changeset:"b8c7b014233d32d61b75dee622fc76c215949427/git"
 b8c7b014/git]:
 {{{#!CommitTicketReference repository="git"
 revision="b8c7b014233d32d61b75dee622fc76c215949427"
 fuzzers: pass configured include paths to smoke builds
 The standalone fuzzer smoke build compiles liblwgeom headers outside the
 liblwgeom Makefile, so it also needs the dependency include paths
 discovered by configure. Reuse the configured CPPFLAGS while dropping
 liblwgeom-local Make variables that are only valid inside that directory.
 Closes #6083
 Closes https://github.com/postgis/postgis/pull/984
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6083#comment:3>
