[SCM] PostGIS branch master updated. 3.6.0rc2-620-gb8c7b0142
git at osgeo.org
git at osgeo.org
Fri Jun 19 00:37:42 PDT 2026
the project "PostGIS".
via b8c7b014233d32d61b75dee622fc76c215949427 (commit)
from 6f291bf547cf9b1834cfa63a779899f6ede4aeba (commit)
revisions in full, below.
commit b8c7b014233d32d61b75dee622fc76c215949427
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Jun 19 10:49:37 2026 +0400
fuzzers: pass configured include paths to smoke builds
The standalone fuzzer smoke build compiles liblwgeom headers outside the liblwgeom Makefile, so it also needs the dependency include paths discovered by configure. Reuse the configured CPPFLAGS while dropping liblwgeom-local Make variables that are only valid inside that directory.
Closes #6083
Closes https://github.com/postgis/postgis/pull/984
diff --git a/NEWS b/NEWS
index 24b7e37b5..080ac74fd 100644
--- a/NEWS
+++ b/NEWS
@@ -62,6 +62,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
* Bug Fixes *
+ - #6083, Pass configured dependency include paths to fuzzer smoke builds
+ (Darafei Praliaskouski)
- #3103, Add regression coverage for exact-schema find_srid and
geometry_columns lookups (Darafei Praliaskouski)
- #5655, [doc] Skip XML validation during `make check` when xsltproc is
diff --git a/fuzzers/Makefile b/fuzzers/Makefile
index 51c4ed5e2..ebe7077e2 100644
--- a/fuzzers/Makefile
+++ b/fuzzers/Makefile
@@ -6,7 +6,11 @@ FUZZER_WORK ?= $(FUZZER_OUT)/postgis-fuzzer-check
FUZZER_SOURCES := $(notdir $(wildcard $(FUZZER_SRC_DIR)/*_fuzzer.cpp $(FUZZER_SRC_DIR)/*_fuzzer.c))
FUZZER_NAMES := $(basename $(FUZZER_SOURCES))
SEED_CORPORA := $(wildcard $(FUZZER_SRC_DIR)/*_seed_corpus.zip)
+# The standalone fuzzer smoke build includes liblwgeom.h outside liblwgeom's
+# Makefile, so it must inherit the configured dependency include paths.
+POSTGIS_CONFIGURED_CPPFLAGS := $(shell sed -n 's/^CPPFLAGS = //p' $(POSTGIS_BUILD_DIR)/liblwgeom/Makefile 2>/dev/null | sed 's/$$(RYU_INCLUDE)//g; s/-I$$(builddir)//g; s/-I$$(srcdir)//g' | sed 1q)
POSTGIS_CONFIGURED_LDFLAGS := $(shell sed -n 's/^LDFLAGS = //p' $(POSTGIS_BUILD_DIR)/liblwgeom/Makefile 2>/dev/null | sed 1q)
+POSTGIS_FUZZER_CPPFLAGS = $(POSTGIS_CONFIGURED_CPPFLAGS) $(CPPFLAGS)
POSTGIS_FUZZER_LDFLAGS = $(POSTGIS_CONFIGURED_LDFLAGS) $(LDFLAGS)
.PHONY: clean dummyfuzzers check check-corpus
@@ -20,7 +24,7 @@ fuzzingengine.o: $(FUZZER_SRC_DIR)/fuzzingengine.c
dummyfuzzers: fuzzingengine.o
mkdir -p "$(FUZZER_OUT)"
$(AR) r libFuzzingEngine.a fuzzingengine.o
- CC="${CC}" CXX="${CXX}" CXXFLAGS="-L$(CURDIR) ${CXXFLAGS}" LDFLAGS="$(POSTGIS_FUZZER_LDFLAGS)" POSTGIS_BUILD_DIR="$(POSTGIS_BUILD_DIR)" SRC="$(FUZZER_SRC_DIR)" OUT="$(FUZZER_OUT)" $(FUZZER_SRC_DIR)/build_google_oss_fuzzers.sh
+ CC="${CC}" CXX="${CXX}" CPPFLAGS="$(POSTGIS_FUZZER_CPPFLAGS)" CXXFLAGS="-L$(CURDIR) ${CXXFLAGS}" LDFLAGS="$(POSTGIS_FUZZER_LDFLAGS)" POSTGIS_BUILD_DIR="$(POSTGIS_BUILD_DIR)" SRC="$(FUZZER_SRC_DIR)" OUT="$(FUZZER_OUT)" $(FUZZER_SRC_DIR)/build_google_oss_fuzzers.sh
OUT="$(FUZZER_OUT)" $(FUZZER_SRC_DIR)/build_seed_corpus.sh
check:
diff --git a/fuzzers/build_google_oss_fuzzers.sh b/fuzzers/build_google_oss_fuzzers.sh
index 1cc825413..b4161bd69 100755
--- a/fuzzers/build_google_oss_fuzzers.sh
+++ b/fuzzers/build_google_oss_fuzzers.sh
@@ -33,11 +33,20 @@ GDAL_LIBS=$(gdal-config --libs)
POSTGIS_FUZZER_LIBS="$JSON_C_LIBS $GEOS_LIBS $PROJ_XML2_LIBS"
POSTGIS_PACKAGE_RUNTIME_LIBS="${POSTGIS_PACKAGE_RUNTIME_LIBS:-1}"
+target_local_cflags()
+ case "$1" in
+ raster_deserialize_fuzzer)
+ echo "-I$POSTGIS_SOURCE_DIR/raster/rt_core -I$POSTGIS_BUILD_DIR/raster/rt_core -I$POSTGIS_SOURCE_DIR/raster -I$POSTGIS_BUILD_DIR/raster -I$POSTGIS_SOURCE_DIR -I$POSTGIS_BUILD_DIR"
+ esac
target_cflags()
case "$1" in
- echo "-I$POSTGIS_SOURCE_DIR/raster/rt_core -I$POSTGIS_BUILD_DIR/raster/rt_core -I$POSTGIS_SOURCE_DIR/raster -I$POSTGIS_BUILD_DIR/raster -I$POSTGIS_SOURCE_DIR -I$POSTGIS_BUILD_DIR $GDAL_CFLAGS"
+ echo "$GDAL_CFLAGS"
esac
@@ -62,12 +71,12 @@ build_fuzzer()
if [ "$extension" = "c" ]; then
objectFile=$(mktemp)
- "$CC" $CFLAGS -I"$POSTGIS_SOURCE_DIR/liblwgeom" -I"$POSTGIS_BUILD_DIR/liblwgeom" $(target_cflags "$fuzzerName") \
+ "$CC" $CFLAGS -I"$POSTGIS_SOURCE_DIR/liblwgeom" -I"$POSTGIS_BUILD_DIR/liblwgeom" $(target_local_cflags "$fuzzerName") $CPPFLAGS $(target_cflags "$fuzzerName") \
-c "$sourceFilename" -o "$objectFile"
sourceFilename=$objectFile
fi
- "$CXX" $CXXFLAGS -std=c++11 -I"$POSTGIS_SOURCE_DIR/liblwgeom" -I"$POSTGIS_BUILD_DIR/liblwgeom" \
+ "$CXX" $CXXFLAGS -std=c++11 -I"$POSTGIS_SOURCE_DIR/liblwgeom" -I"$POSTGIS_BUILD_DIR/liblwgeom" $CPPFLAGS \
"$sourceFilename" -o "$OUT/$fuzzerName" \
$LDFLAGS \
-lFuzzingEngine -lstdc++ $(target_libs "$fuzzerName") \
Summary of changes:
NEWS | 2 ++
fuzzers/Makefile | 6 +++++-
fuzzers/build_google_oss_fuzzers.sh | 15 ++++++++++++---
3 files changed, 19 insertions(+), 4 deletions(-)
hooks/post-receive
