[SCM] PostGIS branch master updated. 3.6.0rc2-621-g09b3ea63d
git at osgeo.org
git at osgeo.org
Fri Jun 19 11:58:11 PDT 2026
the project "PostGIS".
via 09b3ea63d5ac7db56787588c618cb7d4149f95a2 (commit)
from b8c7b014233d32d61b75dee622fc76c215949427 (commit)
revisions in full, below.
commit 09b3ea63d5ac7db56787588c618cb7d4149f95a2
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Fri Jun 19 22:56:27 2026 +0400
liblwgeom: harden malformed WKB and TWKB parsing
Bound recursive TWKB collection descent to match the WKB parser, reject TWKB delta-coordinate accumulation that would overflow int64_t, and reject malformed WKB NURBSCURVE control-point counts before allocating point and weight arrays.
References https://oss-fuzz.com/testcase-detail/5121296892231680
References https://oss-fuzz.com/testcase-detail/4803520482836480
References https://oss-fuzz.com/testcase-detail/5155658945855488
Closes https://github.com/postgis/postgis/pull/985
diff --git a/NEWS b/NEWS
index 080ac74fd..0788a58d2 100644
--- a/NEWS
+++ b/NEWS
@@ -62,6 +62,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
* Bug Fixes *
+ - Fix WKB and TWKB parser resource exhaustion on malformed input
+ (Darafei Praliaskouski)
- #6083, Pass configured dependency include paths to fuzzer smoke builds
- #3103, Add regression coverage for exact-schema find_srid and
diff --git a/liblwgeom/cunit/cu_in_twkb.c b/liblwgeom/cunit/cu_in_twkb.c
index 5fb4197f0..71c38585d 100644
--- a/liblwgeom/cunit/cu_in_twkb.c
+++ b/liblwgeom/cunit/cu_in_twkb.c
@@ -13,10 +13,12 @@
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
+#include <limits.h>
#include "CUnit/Basic.h"
#include "liblwgeom_internal.h"
#include "cu_tester.h"
+#include "varint.h"
** Global variable to hold TWKB strings
@@ -306,6 +308,82 @@ test_twkb_in_count_exceeds_payload(void)
cu_error_msg_reset();
+static void
+test_twkb_in_deep_collection(void)
+ const size_t ngeoms = 201;
+ const size_t twkb_size = ngeoms * 3 + 2;
+ uint8_t *twkb = lwalloc(twkb_size);
+ LWGEOM *geom;
+ size_t i;
+ for (i = 0; i < ngeoms; i++)
+ /* GEOMETRYCOLLECTION with default precision and one child. */
+ twkb[3 * i] = 0x07;
+ twkb[3 * i + 1] = 0x00;
+ twkb[3 * i + 2] = 0x01;
+ twkb[3 * ngeoms] = 0x01; /* POINT with default precision. */
+ twkb[3 * ngeoms + 1] = 0x10; /* Empty geometry. */
+ cu_error_msg_reset();
+ geom = lwgeom_from_twkb(twkb, twkb_size, LW_PARSER_CHECK_NONE);
+ /* Recursive collection parsing must reject hostile nesting before the C
+ * stack becomes the effective input validator.
+ ASSERT_STRING_EQUAL(cu_error_msg, "Geometry has too many chained collections");
+ CU_ASSERT_PTR_NULL(geom);
+ lwfree(twkb);
+static void
+test_twkb_in_coordinate_overflow(void)
+ const uint8_t twkb[] = {0x03, 0x00, 0x16, 0x16, 0x16, 0x16, 0x16, 0x2f, 0x00, 0x00, 0x3d, 0x00, 0x00,
+ 0x00, 0x00, 0x00, 0x16, 0x16, 0x16, 0x16, 0x16, 0x23, 0x06, 0x02, 0x7e, 0x84,
+ 0x83, 0x84, 0x84, 0x84, 0x84, 0xae, 0xee, 0xff, 0x01, 0xf9, 0xff, 0xff, 0xff,
+ 0xff, 0xef, 0x16, 0x16, 0xff, 0x16, 0x16, 0x16, 0x23, 0x06, 0x02, 0x7e, 0x84,
+ 0xff, 0xef, 0xff, 0xff, 0x01, 0xff, 0x02, 0x00, 0x79, 0xb0};
+ LWGEOM *geom;
+ geom = lwgeom_from_twkb(twkb, sizeof(twkb), LW_PARSER_CHECK_NONE);
+ /* Delta-encoded coordinates must not rely on signed integer overflow to
+ * wrap hostile inputs into the int64_t accumulator range.
+ ASSERT_STRING_EQUAL(cu_error_msg, "twkb_parse_state_accum_coord: TWKB coordinate delta overflows int64_t");
+static void
+test_twkb_in_linestring_coordinate_overflow(void)
+ uint8_t twkb[64] = {0x02, 0x00, 0x02};
+ uint8_t *pos = twkb + 3;
+ LWGEOM *geom;
+ pos += varint_s64_encode_buf(INT64_MAX, pos);
+ pos += varint_s64_encode_buf(0, pos);
+ pos += varint_s64_encode_buf(1, pos);
+ geom = lwgeom_from_twkb(twkb, (size_t)(pos - twkb), LW_PARSER_CHECK_NONE);
** Used by test harness to register the tests in this file.
@@ -324,4 +402,7 @@ void twkb_in_suite_setup(void)
PG_ADD_TEST(suite, test_twkb_in_truncated_extended_dims);
PG_ADD_TEST(suite, test_twkb_in_overlong_varint);
PG_ADD_TEST(suite, test_twkb_in_count_exceeds_payload);
+ PG_ADD_TEST(suite, test_twkb_in_deep_collection);
+ PG_ADD_TEST(suite, test_twkb_in_coordinate_overflow);
+ PG_ADD_TEST(suite, test_twkb_in_linestring_coordinate_overflow);
diff --git a/liblwgeom/cunit/cu_in_wkb.c b/liblwgeom/cunit/cu_in_wkb.c
index c855dccf3..2b9066ae8 100644
--- a/liblwgeom/cunit/cu_in_wkb.c
+++ b/liblwgeom/cunit/cu_in_wkb.c
@@ -283,6 +283,22 @@ test_wkb_fuzz(void)
lwfree(wkb5);
+static void
+test_wkb_in_nurbscurve_count_exceeds_payload(void)
+ const uint8_t wkb[] = {
+ 0x01, 0x15, 0x00, 0x00, 0x40, 0x01, 0x00, 0x00, 0x00, 0xc4, 0x0c, 0xb7, 0x07, 0x21, 0xc7};
+ LWGEOM *geom;
+ geom = lwgeom_from_wkb(wkb, sizeof(wkb), LW_PARSER_CHECK_NONE);
+ ASSERT_STRING_EQUAL(cu_error_msg, "WKB structure does not match expected size!");
@@ -304,4 +320,5 @@ void wkb_in_suite_setup(void)
PG_ADD_TEST(suite, test_wkb_in_multisurface);
PG_ADD_TEST(suite, test_wkb_in_malformed);
PG_ADD_TEST(suite, test_wkb_fuzz);
+ PG_ADD_TEST(suite, test_wkb_in_nurbscurve_count_exceeds_payload);
diff --git a/liblwgeom/lwin_twkb.c b/liblwgeom/lwin_twkb.c
index 1262dd999..04261848d 100644
--- a/liblwgeom/lwin_twkb.c
+++ b/liblwgeom/lwin_twkb.c
@@ -24,11 +24,14 @@
#include <math.h>
#include "lwgeom_log.h"
#include "varint.h"
#define TWKB_IN_MAXCOORDS 4
+/** Max depth in a geometry. Matches the WKB parser recursion limit. */
+#define LW_PARSER_MAX_DEPTH 200
* Used for passing the parse state between the parsing functions.
@@ -42,6 +45,8 @@ typedef struct
uint32_t check; /* Simple validity checks on geometries */
uint32_t lwtype; /* Current type we are handling */
+ uint8_t depth; /* Current recursion level, to prevent stack overflows */
+ uint8_t error; /* A hard parse error was found */
uint8_t has_bbox;
uint8_t has_size;
@@ -157,6 +162,23 @@ twkb_parse_state_has_min_bytes(twkb_parse_state *s, uint32_t count, size_t min_b
return LW_TRUE;
+static inline int
+twkb_parse_state_accum_coord(twkb_parse_state *s, int coord_index)
+ const int64_t delta = twkb_parse_state_varint(s);
+ if ((delta > 0 && s->coords[coord_index] > INT64_MAX - delta) ||
+ (delta < 0 && s->coords[coord_index] < INT64_MIN - delta))
+ s->error = LW_TRUE;
+ lwerror("%s: TWKB coordinate delta overflows int64_t", __func__);
+ return LW_FALSE;
+ s->coords[coord_index] += delta;
+ return LW_TRUE;
static uint32_t lwtype_from_twkb_type(uint8_t twkb_type)
switch (twkb_type)
@@ -211,7 +233,9 @@ static POINTARRAY* ptarray_from_twkb_state(twkb_parse_state *s, uint32_t npoints
POINTARRAY *pa = NULL;
uint32_t ndims = s->ndims;
uint32_t i;
+ uint32_t j;
double *dlist;
+ double factors[TWKB_IN_MAXCOORDS];
LWDEBUG(2,"Entering ptarray_from_twkb_state");
LWDEBUGF(4,"Pointarray has %d points", npoints);
@@ -223,32 +247,26 @@ static POINTARRAY* ptarray_from_twkb_state(twkb_parse_state *s, uint32_t npoints
if (!twkb_parse_state_has_min_bytes(s, npoints, s->ndims))
return NULL;
+ factors[0] = s->factor;
+ factors[1] = s->factor;
+ j = 2;
+ if (s->has_z)
+ factors[j++] = s->factor_z;
+ if (s->has_m)
+ factors[j++] = s->factor_m;
pa = ptarray_construct(s->has_z, s->has_m, npoints);
dlist = (double*)(pa->serialized_pointlist);
for( i = 0; i < npoints; i++ )
- int j = 0;
- /* X */
- s->coords[j] += twkb_parse_state_varint(s);
- dlist[ndims*i + j] = s->coords[j] / s->factor;
- j++;
- /* Y */
- j++;
- /* Z */
- if ( s->has_z )
+ for (j = 0; j < ndims; j++)
- dlist[ndims*i + j] = s->coords[j] / s->factor_z;
- j++;
- /* M */
- if ( s->has_m )
- dlist[ndims*i + j] = s->coords[j] / s->factor_m;
- j++;
+ if (!twkb_parse_state_accum_coord(s, j))
+ ptarray_free(pa);
+ return NULL;
+ dlist[ndims * i + j] = s->coords[j] / factors[j];
@@ -295,7 +313,11 @@ static LWLINE* lwline_from_twkb_state(twkb_parse_state *s)
pa = ptarray_from_twkb_state(s, npoints);
if( pa == NULL )
+ if (s->error)
+ return NULL;
return lwline_construct_empty(SRID_UNKNOWN, s->has_z, s->has_m);
if( s->check & LW_PARSER_CHECK_MINPOINTS && pa->npoints < 2 )
@@ -343,7 +365,14 @@ static LWPOLY* lwpoly_from_twkb_state(twkb_parse_state *s)
/* Skip empty rings */
if( pa == NULL )
+ if (s->error)
+ lwpoly_free(poly);
+ return NULL;
continue;
/* Force first and last points to be the same. */
if( ! ptarray_is_closed_2d(pa) )
@@ -515,6 +544,7 @@ static LWCOLLECTION* lwcollection_from_twkb_state(twkb_parse_state *s)
uint32_t ngeoms, i;
LWGEOM *geom = NULL;
LWCOLLECTION *col = lwcollection_construct_empty(s->lwtype, SRID_UNKNOWN, s->has_z, s->has_m);
+ uint8_t start_depth = s->depth;
LWDEBUG(2,"Entering lwcollection_from_twkb_state");
@@ -539,16 +569,28 @@ static LWCOLLECTION* lwcollection_from_twkb_state(twkb_parse_state *s)
if (!twkb_parse_state_has_min_bytes(s, ngeoms, 2))
return col;
+ s->depth++;
+ if (s->depth >= LW_PARSER_MAX_DEPTH)
+ lwcollection_free(col);
+ lwerror("Geometry has too many chained collections");
+ s->depth = start_depth;
+ return NULL;
for ( i = 0; i < ngeoms; i++ )
geom = lwgeom_from_twkb_state(s);
- if ( lwcollection_add_lwgeom(col, geom) == NULL )
+ if (!geom || lwcollection_add_lwgeom(col, geom) == NULL)
- lwerror("Unable to add geometry (%p) to collection (%p)", (void *) geom, (void *) col);
+ lwgeom_free(geom);
return NULL;
+ s->depth--;
return col;
@@ -702,7 +744,7 @@ LWGEOM* lwgeom_from_twkb_state(twkb_parse_state *s)
break;
- if ( has_bbox )
+ if (has_bbox && geom)
geom->bbox = gbox_clone(&bbox);
return geom;
diff --git a/liblwgeom/lwin_wkb.c b/liblwgeom/lwin_wkb.c
index 762d5cd3a..83acb14c3 100644
--- a/liblwgeom/lwin_wkb.c
+++ b/liblwgeom/lwin_wkb.c
@@ -831,6 +831,10 @@ static LWNURBSCURVE* lwnurbscurve_from_wkb_state(wkb_parse_state *s)
degree, (unsigned long long)degree + 1, npoints);
return NULL;
+ const size_t min_point_size = 2 + (2 + (s->has_z ? 1 : 0) + (s->has_m ? 1 : 0)) * WKB_DOUBLE_SIZE;
+ wkb_parse_state_check(s, (size_t)npoints * min_point_size);
+ if (s->error)
+ return NULL;
/* Initialize points array */
if (npoints > 0) {
Summary of changes:
NEWS | 2 +
liblwgeom/cunit/cu_in_twkb.c | 81 +++++++++++++++++++++++++++++++++++++++
liblwgeom/cunit/cu_in_wkb.c | 17 +++++++++
liblwgeom/lwin_twkb.c | 90 ++++++++++++++++++++++++++++++++------------
liblwgeom/lwin_wkb.c | 4 ++
5 files changed, 170 insertions(+), 24 deletions(-)
hooks/post-receive
