[PostGIS] #2808: Installing newer topology than version of PostGIS gives misleading upgrade message
PostGIS trac at osgeo.org
Sat Jun 20 13:09:37 PDT 2026
message
  Reporter:  robe      |      Owner:  strk
      Type:  defect    |     Status:  closed
  Priority:  low       |  Milestone:  PostGIS Fund Me
 Component:  topology  |    Version:  master
Resolution:  fixed     |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"986bb6a1a6a133be10c234b8b04bd7bf1025fa05/git" 986bb6a/git]:
 {{{#!CommitTicketReference repository="git"
 revision="986bb6a1a6a133be10c234b8b04bd7bf1025fa05"
 Clarify newer component script version reporting
 Compare installed topology, raster, and SFCGAL script versions against the
 core script version using PostGIS version suffix ordering: dev < alpha <
 beta < rc < final. When component scripts are newer than core scripts,
 report that direction explicitly instead of saying the component procs
 need upgrade.
 Closes #2808
 Closes https://github.com/postgis/postgis/pull/1057
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2808#comment:4>
