[SCM] PostGIS branch master updated. 3.6.0rc2-636-g986bb6a1a
git at osgeo.org
git at osgeo.org
Sat Jun 20 13:09:35 PDT 2026
the project "PostGIS".
via 986bb6a1a6a133be10c234b8b04bd7bf1025fa05 (commit)
from ea6edb5d5a44804bd0e3d2d05d76b220134fae1f (commit)
revisions in full, below.
commit 986bb6a1a6a133be10c234b8b04bd7bf1025fa05
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sat Jun 20 23:58:59 2026 +0400
Clarify newer component script version reporting
Compare installed topology, raster, and SFCGAL script versions against the core script version using PostGIS version suffix ordering: dev < alpha < beta < rc < final. When component scripts are newer than core scripts, report that direction explicitly instead of saying the component procs need upgrade.
Closes #2808
Closes https://github.com/postgis/postgis/pull/1057
diff --git a/NEWS b/NEWS
index e84f23d2a..121538c26 100644
--- a/NEWS
+++ b/NEWS
@@ -106,6 +106,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
- GH-888, [sfcgal] Avoid stale detoasted geometry access in
CG_Visibility empty-input handling for SFCGAL < 2.2
(Darafei Praliaskouski)
+ - #2808, Clarify postgis_full_version() output when installed component
+ scripts are newer than core scripts (Darafei Praliaskouski)
- #3179, Mark truncated libpgcommon PostgreSQL messages instead of silently
dropping the tail (Darafei Praliaskouski)
- #6003, Avoid size_t formats in liblwgeom logging/error wrappers for
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 7e5cd081b..8abfd90a2 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3153,6 +3153,42 @@ CREATE OR REPLACE FUNCTION postgis_scripts_released() RETURNS text
AS 'MODULE_PATHNAME'
LANGUAGE 'c' IMMUTABLE;
+CREATE OR REPLACE FUNCTION _postgis_scripts_version_cmp_key(ver text)
+ RETURNS int[]
+ AS $$
+ DECLARE
+ ver_match text[];
+ BEGIN
+ ver_match := pg_catalog.regexp_match(
+ pg_catalog.lower(ver),
+ '^([0-9]+)\.([0-9]+)\.([0-9]+)(dev|alpha|beta|rc)?([0-9]*)([^0-9a-z].*)?$'
+ IF ver_match IS NULL THEN
+ RETURN NULL;
+ END IF;
+ RETURN ARRAY[
+ ver_match[1]::int,
+ ver_match[2]::int,
+ ver_match[3]::int,
+ CASE coalesce(ver_match[4], '')
+ WHEN 'dev' THEN 0
+ WHEN 'alpha' THEN 1
+ WHEN 'beta' THEN 2
+ WHEN 'rc' THEN 3
+ ELSE 4
+ END,
+ CASE coalesce(ver_match[5], '')
+ WHEN '' THEN 0
+ ELSE ver_match[5]::int
+ END
+ EXCEPTION WHEN OTHERS THEN
+ RETURN NULL;
+ END
+ LANGUAGE 'plpgsql' IMMUTABLE STRICT;
CREATE OR REPLACE FUNCTION postgis_geos_version() RETURNS text
@@ -3326,6 +3362,8 @@ DECLARE
rast_lib_ver text := NULL;
rast_scr_ver text := NULL;
topo_scr_ver text := NULL;
+ relproc_int int[];
+ scr_ver_int int[];
json_lib_ver text;
protobuf_lib_ver text;
wagyu_lib_ver text;
@@ -3368,6 +3406,7 @@ BEGIN
SELECT @extschema at .postgis_scripts_installed() INTO dbproc;
SELECT @extschema at .postgis_scripts_released() INTO relproc;
SELECT @extschema at .postgis_lib_revision() INTO librev;
+ SELECT @extschema at ._postgis_scripts_version_cmp_key(relproc) INTO relproc_int;
BEGIN
SELECT topology.postgis_topology_scripts_installed() INTO topo_scr_ver;
EXCEPTION
@@ -3471,7 +3510,18 @@ BEGIN
IF topo_scr_ver IS NOT NULL THEN
fullver = fullver || ' TOPOLOGY';
IF topo_scr_ver != relproc THEN
- fullver = fullver || ' (topology procs from "' || topo_scr_ver || '" need upgrade)';
+ SELECT @extschema at ._postgis_scripts_version_cmp_key(topo_scr_ver) INTO scr_ver_int;
+ IF scr_ver_int IS NOT NULL AND relproc_int IS NOT NULL AND scr_ver_int > relproc_int THEN
+ fullver = pg_catalog.format(
+ '%s (topology procs from "%s" are newer than core procs from "%s")',
+ fullver,
+ topo_scr_ver,
+ relproc
+ ELSE
+ fullver = fullver || ' (topology procs from "' || topo_scr_ver || '" need upgrade)';
+ END IF;
END IF;
IF core_is_extension AND NOT EXISTS (
SELECT * FROM pg_catalog.pg_extension
@@ -3495,11 +3545,33 @@ BEGIN
END IF;
IF rast_scr_ver IS NOT NULL AND rast_scr_ver != relproc THEN
- fullver = fullver || ' (raster procs from "' || rast_scr_ver || '" need upgrade)';
+ SELECT @extschema at ._postgis_scripts_version_cmp_key(rast_scr_ver) INTO scr_ver_int;
+ '%s (raster procs from "%s" are newer than core procs from "%s")',
+ fullver,
+ rast_scr_ver,
+ relproc
+ ELSE
+ fullver = fullver || ' (raster procs from "' || rast_scr_ver || '" need upgrade)';
+ END IF;
END IF;
IF sfcgal_scr_ver IS NOT NULL AND sfcgal_scr_ver != relproc THEN
- fullver = fullver || ' (sfcgal procs from "' || sfcgal_scr_ver || '" need upgrade)';
+ SELECT @extschema at ._postgis_scripts_version_cmp_key(sfcgal_scr_ver) INTO scr_ver_int;
+ '%s (sfcgal procs from "%s" are newer than core procs from "%s")',
+ fullver,
+ sfcgal_scr_ver,
+ relproc
+ ELSE
+ fullver = fullver || ' (sfcgal procs from "' || sfcgal_scr_ver || '" need upgrade)';
+ END IF;
END IF;
-- Check for the presence of deprecated functions
diff --git a/regress/core/postgis_full_version.sql b/regress/core/postgis_full_version.sql
new file mode 100644
index 000000000..88e9a3c62
--- /dev/null
+++ b/regress/core/postgis_full_version.sql
@@ -0,0 +1,76 @@
+BEGIN;
+DO $$
+BEGIN
+ IF NOT EXISTS (
+ SELECT 1
+ FROM pg_catalog.pg_namespace
+ WHERE nspname = 'topology'
+ ) THEN
+ CREATE SCHEMA topology;
+ END IF;
+END;
+CREATE OR REPLACE FUNCTION postgis_scripts_released()
+RETURNS text
+AS $$ SELECT '3.7.0rc1'::text AS version $$
+LANGUAGE 'sql' IMMUTABLE;
+CREATE OR REPLACE FUNCTION topology.postgis_topology_scripts_installed()
+RETURNS text
+AS $$ SELECT '1.0.0'::text AS version $$
+-- Older component script versions still mean the installed procs need upgrade.
+SELECT 'topology_old_scripts',
+ postgis_full_version() ~
+ 'TOPOLOGY \(topology procs from "1\.0\.0" need upgrade\)';
+RETURNS text
+AS $$ SELECT '3.7.0'::text AS version $$
+CREATE OR REPLACE FUNCTION postgis_raster_scripts_installed()
+RETURNS text
+AS $$ SELECT '3.7.0rc2'::text AS version $$
+CREATE OR REPLACE FUNCTION postgis_sfcgal_full_version()
+RETURNS text
+AS $$ SELECT '999.0.0dev'::text AS version $$
+CREATE OR REPLACE FUNCTION postgis_sfcgal_scripts_installed()
+RETURNS text
+AS $$ SELECT '3.7.0beta1'::text AS version $$
+-- Newer component script versions are intentional in mixed-script installs:
+-- report them as newer than core, not as something that needs upgrade. This
+-- includes final releases newer than release candidates and later RCs.
+SELECT 'topology_newer_scripts',
+ 'TOPOLOGY \(topology procs from "3\.7\.0" are newer than core procs from "3\.7\.0rc1"\)';
+SELECT 'raster_newer_scripts',
+ '\(raster procs from "3\.7\.0rc2" are newer than core procs from "3\.7\.0rc1"\)';
+-- A prerelease older than the core prerelease is still reported as needing
+-- upgrade, even when its numeric major/minor/micro components match.
+SELECT 'sfcgal_older_prerelease',
+ '\(sfcgal procs from "3\.7\.0beta1" need upgrade\)';
+RETURNS text
+SELECT 'sfcgal_newer_scripts',
+ '\(sfcgal procs from "3\.7\.0" are newer than core procs from "3\.7\.0rc1"\)';
+ROLLBACK;
diff --git a/regress/core/postgis_full_version_expected b/regress/core/postgis_full_version_expected
index 000000000..8e3e2c8cd
--- /dev/null
+++ b/regress/core/postgis_full_version_expected
@@ -0,0 +1,5 @@
+topology_old_scripts|t
+topology_newer_scripts|t
+raster_newer_scripts|t
+sfcgal_older_prerelease|t
+sfcgal_newer_scripts|t
diff --git a/regress/core/tests.mk.in b/regress/core/tests.mk.in
index b6a87b629..73426ab2a 100644
--- a/regress/core/tests.mk.in
+++ b/regress/core/tests.mk.in
@@ -91,6 +91,7 @@ TESTS += \
$(top_srcdir)/regress/core/point_coordinates \
$(top_srcdir)/regress/core/polygonize \
$(top_srcdir)/regress/core/polyhedralsurface \
+ $(top_srcdir)/regress/core/postgis_full_version \
$(top_srcdir)/regress/core/postgis_type_name \
$(top_srcdir)/regress/core/quantize_coordinates \
$(top_srcdir)/regress/core/regress \
Summary of changes:
NEWS | 2 +
postgis/postgis.sql.in | 78 ++++++++++++++++++++++++++++--
regress/core/postgis_full_version.sql | 76 +++++++++++++++++++++++++++++
regress/core/postgis_full_version_expected | 5 ++
regress/core/tests.mk.in | 1 +
5 files changed, 159 insertions(+), 3 deletions(-)
create mode 100644 regress/core/postgis_full_version.sql
create mode 100644 regress/core/postgis_full_version_expected
hooks/post-receive
