[PostGIS] #6084: Winnie failing on fuzzy tests
trac at osgeo.org
Sun Jun 21 13:21:21 PDT 2026
Reporter: robe | Owner: robe
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 3.7.0
Component: QA/buildbots | Version: 3.6.x
Resolution: fixed | Keywords:
Changes (by Darafei Praliaskouski <me@…>):
* resolution: => fixed
* status: new => closed
Comment:
In [changeset:"633a4c5663021efbd2ad8fa11f6a0e93ccda226d/git" 633a4c5/git]:
{{{#!CommitTicketReference repository="git"
revision="633a4c5663021efbd2ad8fa11f6a0e93ccda226d"
Use xml2-config for fuzzer libxml links
Prefer xml2-config for libxml2 linker flags in the standalone fuzzer smoke
build while still allowing pkg-config as a fallback. This lets Windows
buildbot environments with a private libxml2 installation provide the
required library directory for geojson_import_fuzzer.
Closes #6084
Closes https://github.com/postgis/postgis/pull/1080
Ticket URL: <https://trac.osgeo.org/postgis/ticket/6084#comment:1>
