[SCM] PostGIS branch master updated. 3.6.0rc2-640-gc94f62361
git at osgeo.org
git at osgeo.org
Sun Jun 21 06:34:29 PDT 2026
the project "PostGIS".
via c94f62361826e4dc14b660b31e6614727db8deb3 (commit)
via f82a1015b8772b570e05ad552eed4029ff718dd5 (commit)
from 0482d073a2d174a544428664fa7cebcd36b7d96a (commit)
revisions in full, below.
commit c94f62361826e4dc14b660b31e6614727db8deb3
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jun 21 17:33:10 2026 +0400
Use escape strings for version regexes
Make the PostGIS script-version comparison helper and its regression checks independent of standard_conforming_strings. This avoids warnings during install when standard_conforming_strings is off, which the regression harness treats as load failure.\n\nCloses #2808
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 8abfd90a2..027170b68 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -3161,7 +3161,7 @@ CREATE OR REPLACE FUNCTION _postgis_scripts_version_cmp_key(ver text)
BEGIN
ver_match := pg_catalog.regexp_match(
pg_catalog.lower(ver),
- '^([0-9]+)\.([0-9]+)\.([0-9]+)(dev|alpha|beta|rc)?([0-9]*)([^0-9a-z].*)?$'
+ E'^([0-9]+)\\.([0-9]+)\\.([0-9]+)(dev|alpha|beta|rc)?([0-9]*)([^0-9a-z].*)?$'
IF ver_match IS NULL THEN
RETURN NULL;
diff --git a/regress/core/postgis_full_version.sql b/regress/core/postgis_full_version.sql
index 88e9a3c62..5cbc5d9ed 100644
--- a/regress/core/postgis_full_version.sql
+++ b/regress/core/postgis_full_version.sql
@@ -25,7 +25,7 @@ LANGUAGE 'sql' IMMUTABLE;
-- Older component script versions still mean the installed procs need upgrade.
SELECT 'topology_old_scripts',
postgis_full_version() ~
- 'TOPOLOGY \(topology procs from "1\.0\.0" need upgrade\)';
+ E'TOPOLOGY \\(topology procs from "1\\.0\\.0" need upgrade\\)';
CREATE OR REPLACE FUNCTION topology.postgis_topology_scripts_installed()
RETURNS text
@@ -52,17 +52,17 @@ LANGUAGE 'sql' IMMUTABLE;
-- includes final releases newer than release candidates and later RCs.
SELECT 'topology_newer_scripts',
- 'TOPOLOGY \(topology procs from "3\.7\.0" are newer than core procs from "3\.7\.0rc1"\)';
+ E'TOPOLOGY \\(topology procs from "3\\.7\\.0" are newer than core procs from "3\\.7\\.0rc1"\\)';
SELECT 'raster_newer_scripts',
- '\(raster procs from "3\.7\.0rc2" are newer than core procs from "3\.7\.0rc1"\)';
+ E'\\(raster procs from "3\\.7\\.0rc2" are newer than core procs from "3\\.7\\.0rc1"\\)';
-- A prerelease older than the core prerelease is still reported as needing
-- upgrade, even when its numeric major/minor/micro components match.
SELECT 'sfcgal_older_prerelease',
- '\(sfcgal procs from "3\.7\.0beta1" need upgrade\)';
+ E'\\(sfcgal procs from "3\\.7\\.0beta1" need upgrade\\)';
CREATE OR REPLACE FUNCTION postgis_sfcgal_scripts_installed()
RETURNS text
@@ -71,6 +71,6 @@ LANGUAGE 'sql' IMMUTABLE;
SELECT 'sfcgal_newer_scripts',
- '\(sfcgal procs from "3\.7\.0" are newer than core procs from "3\.7\.0rc1"\)';
+ E'\\(sfcgal procs from "3\\.7\\.0" are newer than core procs from "3\\.7\\.0rc1"\\)';
ROLLBACK;
commit f82a1015b8772b570e05ad552eed4029ff718dd5
Date: Sun Jun 21 17:26:13 2026 +0400
Fix red main CI failures
diff --git a/raster/rt_core/rt_warp.c b/raster/rt_core/rt_warp.c
index 2cdda3c1e..8058529ba 100644
--- a/raster/rt_core/rt_warp.c
+++ b/raster/rt_core/rt_warp.c
@@ -163,6 +163,12 @@ rt_raster rt_raster_gdal_warp(
CPLErr cplerr;
char *dst_options[] = {"SUBCLASS=VRTWarpedDataset", NULL};
+ const char *init_dest_nodata_option = "INIT_DEST=NO_DATA";
+#if POSTGIS_GDAL_VERSION >= 30302
+ const char *unified_src_nodata_option = "UNIFIED_SRC_NODATA=PARTIAL";
+#else
+ const char *unified_src_nodata_option = "UNIFIED_SRC_NODATA=NO";
+#endif
_rti_warp_arg arg = NULL;
int nodata_count = 0;
@@ -197,6 +203,7 @@ rt_raster rt_raster_gdal_warp(
int numBands = 0;
int nodata_pos = 0;
int data_pos = 0;
+ int use_init_dest_nodata = 0;
int subspatial = 0;
@@ -865,17 +872,21 @@ rt_raster rt_raster_gdal_warp(
arg->wopts->hDstDS = arg->dst.ds;
arg->wopts->pfnTransformer = arg->transform.func;
arg->wopts->pTransformerArg = arg->transform.arg.transform;
- arg->wopts->papszWarpOptions = (char **) CPLMalloc(sizeof(char *) * 3);
- arg->wopts->papszWarpOptions[0] = (char *) CPLMalloc(sizeof(char) * (strlen("INIT_DEST=NO_DATA") + 1));
- strcpy(arg->wopts->papszWarpOptions[0], "INIT_DEST=NO_DATA");
-#if POSTGIS_GDAL_VERSION >= 30302
- arg->wopts->papszWarpOptions[1] = (char *) CPLMalloc(sizeof(char) * (strlen("UNIFIED_SRC_NODATA=PARTIAL") + 1));
- strcpy(arg->wopts->papszWarpOptions[1], "UNIFIED_SRC_NODATA=PARTIAL");
-#else
- arg->wopts->papszWarpOptions[1] = (char *) CPLMalloc(sizeof(char) * (strlen("UNIFIED_SRC_NODATA=NO") + 1));
- strcpy(arg->wopts->papszWarpOptions[1], "UNIFIED_SRC_NODATA=NO");
-#endif
- arg->wopts->papszWarpOptions[2] = NULL;
+ * GDAL 3.11 warns, and later treats as an error, when INIT_DEST=NO_DATA
+ * is requested without destination nodata values for every band.
+ use_init_dest_nodata = numBands > 0 && nodata_count == numBands;
+ arg->wopts->papszWarpOptions =
+ (char **) CPLMalloc(sizeof(char *) * (use_init_dest_nodata ? 3 : 2));
+ i = 0;
+ if (use_init_dest_nodata) {
+ arg->wopts->papszWarpOptions[i] = (char *) CPLMalloc(sizeof(char) * (strlen(init_dest_nodata_option) + 1));
+ strcpy(arg->wopts->papszWarpOptions[i++], init_dest_nodata_option);
+ arg->wopts->papszWarpOptions[i] = (char *) CPLMalloc(sizeof(char) * (strlen(unified_src_nodata_option) + 1));
+ strcpy(arg->wopts->papszWarpOptions[i++], unified_src_nodata_option);
+ arg->wopts->papszWarpOptions[i] = NULL;
/* band mapping */
arg->wopts->nBandCount = numBands;
diff --git a/raster/test/regress/loader/LongMaintenance.opts b/raster/test/regress/loader/LongMaintenance.opts
index 0320409c5..e63937728 100644
--- a/raster/test/regress/loader/LongMaintenance.opts
+++ b/raster/test/regress/loader/LongMaintenance.opts
@@ -1,2 +1 @@
-# Exercise raster-only long maintenance actions and constraint creation.
--add-constraints --vacuum --analyze
diff --git a/regress/loader/LongOptions.opts b/regress/loader/LongOptions.opts
index 098600e4b..dc46a9b2d 100644
--- a/regress/loader/LongOptions.opts
+++ b/regress/loader/LongOptions.opts
@@ -1,3 +1 @@
-# Exercise the public long action names as one loader invocation:
-# drop, create-if-missing, load, idempotent index, no transaction, and analyze.
---drop-table --create-table --load-data --create-index --if-not-exists --no-transaction --no-analyze --analyze
+--drop-table --create-table --load-data --create-index --if-not-exists --no-transaction --analyze
Summary of changes:
postgis/postgis.sql.in | 2 +-
raster/rt_core/rt_warp.c | 33 ++++++++++++++++---------
raster/test/regress/loader/LongMaintenance.opts | 1 -
regress/core/postgis_full_version.sql | 10 ++++----
regress/loader/LongOptions.opts | 4 +--
5 files changed, 29 insertions(+), 21 deletions(-)
hooks/post-receive
