[SCM] PostGIS branch master updated. 3.6.0rc2-641-g3b1b4aae0
git at osgeo.org
git at osgeo.org
Sun Jun 21 06:45:03 PDT 2026
the project "PostGIS".
via 3b1b4aae021865171c25a37bcfc929e6e4d7a74b (commit)
from c94f62361826e4dc14b660b31e6614727db8deb3 (commit)
revisions in full, below.
commit 3b1b4aae021865171c25a37bcfc929e6e4d7a74b
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jun 21 17:43:55 2026 +0400
Move typmod bit helpers into libpgcommon
The geometry and geography typmod bit-field helpers are PostgreSQL extension concerns, not liblwgeom public API. Move them to libpgcommon and relocate the CUnit coverage to the postgis helper test harness.
Closes #3158
Closes https://github.com/postgis/postgis/pull/1089
diff --git a/NEWS b/NEWS
index a9843c1aa..e4ac634d8 100644
--- a/NEWS
+++ b/NEWS
@@ -58,6 +58,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
* Enhancements *
+ - #3158, Move geometry and geography typmod bit helpers out of the
+ public liblwgeom header (Darafei Praliaskouski)
- #2116, [raster] Add ST_Value nearest-neighbor boundary options
- #2804, #4315, [raster] Support two-argument ST_MapAlgebra callbacks
diff --git a/liblwgeom/cunit/cu_gserialized1.c b/liblwgeom/cunit/cu_gserialized1.c
index 23f3b9743..e4f38666e 100644
--- a/liblwgeom/cunit/cu_gserialized1.c
+++ b/liblwgeom/cunit/cu_gserialized1.c
@@ -18,61 +18,6 @@
#include "gserialized1.c" /* for gserialized_peek_gbox_p */
#include "cu_tester.h"
-static void test_typmod_macros(void)
- int32_t typmod = 0;
- int32_t srid = 4326;
- int type = 6;
- int z = 1;
- int rv;
- TYPMOD_SET_SRID(typmod,srid);
- rv = TYPMOD_GET_SRID(typmod);
- CU_ASSERT_EQUAL(rv, srid);
- srid = -5005;
- srid = 999999;
- srid = -999999;
- srid = SRID_UNKNOWN;
- srid = 0;
- srid = 1;
- TYPMOD_SET_TYPE(typmod,type);
- rv = TYPMOD_GET_TYPE(typmod);
- CU_ASSERT_EQUAL(rv,type);
- TYPMOD_SET_Z(typmod);
- rv = TYPMOD_GET_Z(typmod);
- CU_ASSERT_EQUAL(rv,z);
- rv = TYPMOD_GET_M(typmod);
- CU_ASSERT_EQUAL(rv,0);
static void test_flags_macros(void)
uint8_t flags = 0;
@@ -1282,7 +1227,6 @@ void gserialized1_suite_setup(void);
CU_pSuite suite = CU_add_suite("serialization/deserialization v1", NULL, NULL);
- PG_ADD_TEST(suite, test_typmod_macros);
PG_ADD_TEST(suite, test_flags_macros);
PG_ADD_TEST(suite, test_serialized1_srid);
PG_ADD_TEST(suite, test_gserialized1_from_lwgeom_size);
diff --git a/liblwgeom/liblwgeom.h.in b/liblwgeom/liblwgeom.h.in
index da1514458..17efdce61 100644
--- a/liblwgeom/liblwgeom.h.in
+++ b/liblwgeom/liblwgeom.h.in
@@ -181,25 +181,6 @@ typedef enum LWORD_T {
#define FLAGS_GET_ZM(flags) (FLAGS_GET_M(flags) + FLAGS_GET_Z(flags) * 2)
#define FLAGS_NDIMS_BOX(flags) (FLAGS_GET_GEODETIC(flags) ? 3 : FLAGS_NDIMS(flags))
-* Macros for manipulating the 'typemod' int. An int32_t used as follows:
-* Plus/minus = Top bit.
-* Spare bits = Next 2 bits.
-* SRID = Next 21 bits.
-* TYPE = Next 6 bits.
-* ZM Flags = Bottom 2 bits.
-#define TYPMOD_GET_SRID(typmod) ((((typmod) & 0x0FFFFF00) - ((typmod) & 0x10000000)) >> 8)
-#define TYPMOD_SET_SRID(typmod, srid) ((typmod) = (((typmod) & 0xE00000FF) | ((srid & 0x001FFFFF)<<8)))
-#define TYPMOD_GET_TYPE(typmod) ((typmod & 0x000000FC)>>2)
-#define TYPMOD_SET_TYPE(typmod, type) ((typmod) = (typmod & 0xFFFFFF03) | ((type & 0x0000003F)<<2))
-#define TYPMOD_GET_Z(typmod) ((typmod & 0x00000002)>>1)
-#define TYPMOD_SET_Z(typmod) ((typmod) = typmod | 0x00000002)
-#define TYPMOD_GET_M(typmod) (typmod & 0x00000001)
-#define TYPMOD_SET_M(typmod) ((typmod) = typmod | 0x00000001)
-#define TYPMOD_GET_NDIMS(typmod) (2+TYPMOD_GET_Z(typmod)+TYPMOD_GET_M(typmod))
* Maximum allowed SRID value in serialized geometry.
* Currently we are using 21 bits (2097152) of storage for SRID.
diff --git a/libpgcommon/Makefile.in b/libpgcommon/Makefile.in
index 6f436e764..4fb9c3010 100644
--- a/libpgcommon/Makefile.in
+++ b/libpgcommon/Makefile.in
@@ -32,6 +32,7 @@ SA_OBJS = \
SA_HEADERS = \
lwgeom_pg.h \
+ lwgeom_pg_typmod.h \
lwgeom_transform.h \
lwgeom_cache.h \
gserialized_gist.h
@@ -68,4 +69,3 @@ $(SA_OBJS): %.o: %.c
$(CC) $(CFLAGS) -c -o $@ $<
$(SA_OBJS): ../postgis_config.h
diff --git a/libpgcommon/lwgeom_pg_typmod.h b/libpgcommon/lwgeom_pg_typmod.h
new file mode 100644
index 000000000..c7db7b913
--- /dev/null
+++ b/libpgcommon/lwgeom_pg_typmod.h
@@ -0,0 +1,50 @@
+ * PostGIS - Spatial Types for PostgreSQL
+ * http://postgis.net
+ * This file is part of PostGIS
+ * PostGIS is free software: you can redistribute it and/or modify
+ * it under the terms of the GNU General Public License as published by
+ * the Free Software Foundation, either version 2 of the License, or
+ * (at your option) any later version.
+ * PostGIS is distributed in the hope that it will be useful,
+ * but WITHOUT ANY WARRANTY; without even the implied warranty of
+ * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+ * GNU General Public License for more details.
+ * You should have received a copy of the GNU General Public License
+ * along with PostGIS. If not, see <http://www.gnu.org/licenses/>.
+ * Copyright 2026 Darafei Praliaskouski <me at komzpa.net>
+#ifndef LWGEOM_PG_TYPMOD_H
+#define LWGEOM_PG_TYPMOD_H 1
+ * Macros for manipulating the PostgreSQL typmod int32_t used by the
+ * PostGIS geometry and geography types:
+ * Plus/minus = Top bit.
+ * Spare bits = Next 2 bits.
+ * SRID = Next 21 bits.
+ * TYPE = Next 6 bits.
+ * ZM Flags = Bottom 2 bits.
+#define TYPMOD_GET_SRID(typmod) ((((typmod) & 0x0FFFFF00) - ((typmod) & 0x10000000)) >> 8)
+#define TYPMOD_SET_SRID(typmod, srid) ((typmod) = (((typmod) & 0xE00000FF) | ((srid & 0x001FFFFF) << 8)))
+#define TYPMOD_GET_TYPE(typmod) (((typmod) & 0x000000FC) >> 2)
+#define TYPMOD_SET_TYPE(typmod, type) ((typmod) = ((typmod) & 0xFFFFFF03) | (((type) & 0x0000003F) << 2))
+#define TYPMOD_GET_Z(typmod) (((typmod) & 0x00000002) >> 1)
+#define TYPMOD_SET_Z(typmod) ((typmod) = (typmod) | 0x00000002)
+#define TYPMOD_GET_M(typmod) ((typmod) & 0x00000001)
+#define TYPMOD_SET_M(typmod) ((typmod) = (typmod) | 0x00000001)
+#define TYPMOD_GET_NDIMS(typmod) (2 + TYPMOD_GET_Z(typmod) + TYPMOD_GET_M(typmod))
+#endif /* LWGEOM_PG_TYPMOD_H */
diff --git a/postgis/Makefile.in b/postgis/Makefile.in
index e292772c2..a3e2d46f5 100644
--- a/postgis/Makefile.in
+++ b/postgis/Makefile.in
@@ -273,6 +273,7 @@ distclean: clean
if [ -e "cunit/Makefile" ]; then make -C cunit distclean; fi
check-unit:
+ $(MAKE) -C cunit check
check-regress:
diff --git a/postgis/cunit/cu_tester.c b/postgis/cunit/cu_tester.c
index eb6ba5b0d..6fe59a1d9 100644
--- a/postgis/cunit/cu_tester.c
+++ b/postgis/cunit/cu_tester.c
@@ -20,7 +20,7 @@
- * Copyright 2025 (C) Darafei Praliaskouski <me at komzpa.net>
+ * Copyright 2025-2026 (C) Darafei Praliaskouski <me at komzpa.net>
@@ -31,6 +31,8 @@
#include <math.h>
#include <string.h>
+#include "liblwgeom.h"
+#include "lwgeom_pg_typmod.h"
#include "../gserialized_estimate_support.h"
static ND_BOX
@@ -50,6 +52,65 @@ make_box(float minx, float miny, float minz, float minm, float maxx, float maxy,
return box;
+static void
+typmod_bitfield_roundtrip(void)
+ int32_t typmod = 0;
+ int32_t srid = 4326;
+ int type = 6;
+ int z = 1;
+ int rv;
+ TYPMOD_SET_SRID(typmod, srid);
+ rv = TYPMOD_GET_SRID(typmod);
+ CU_ASSERT_EQUAL(rv, srid);
+ srid = -5005;
+ srid = 999999;
+ srid = -999999;
+ srid = SRID_UNKNOWN;
+ srid = 0;
+ srid = 1;
+ TYPMOD_SET_TYPE(typmod, type);
+ rv = TYPMOD_GET_TYPE(typmod);
+ CU_ASSERT_EQUAL(rv, type);
+ TYPMOD_SET_Z(typmod);
+ rv = TYPMOD_GET_Z(typmod);
+ CU_ASSERT_EQUAL(rv, z);
+ rv = TYPMOD_GET_M(typmod);
+ CU_ASSERT_EQUAL(rv, 0);
+ TYPMOD_SET_M(typmod);
+ CU_ASSERT_EQUAL(rv, 1);
static void
histogram_budget_clamps(void)
@@ -151,11 +212,12 @@ main(void)
if (CU_initialize_registry() != CUE_SUCCESS)
return CU_get_error();
- suite = CU_add_suite("gserialized_histogram_helpers", NULL, NULL);
+ suite = CU_add_suite("postgis_helpers", NULL, NULL);
if (!suite)
goto cleanup;
- if (!CU_add_test(suite, "histogram budget clamps", histogram_budget_clamps) ||
+ if (!CU_add_test(suite, "typmod bitfield roundtrip", typmod_bitfield_roundtrip) ||
+ !CU_add_test(suite, "histogram budget clamps", histogram_budget_clamps) ||
!CU_add_test(suite, "histogram axis guards", histogram_axis_allocation_guards) ||
!CU_add_test(suite, "nd_stats value index guards", nd_stats_indexing_behaviour) ||
!CU_add_test(suite, "nd_box ratio edge cases", nd_box_ratio_cases))
diff --git a/postgis/gserialized_typmod.c b/postgis/gserialized_typmod.c
index 8e5f63b56..228097490 100644
--- a/postgis/gserialized_typmod.c
+++ b/postgis/gserialized_typmod.c
@@ -41,10 +41,10 @@
#include "catalog/pg_type.h" /* for CSTRINGOID */
#include "liblwgeom.h" /* For standard geometry types. */
-#include "lwgeom_pg.h" /* For debugging macros. */
-#include "geography.h" /* For utility functions. */
-#include "lwgeom_transform.h" /* for srid_is_latlon */
+#include "lwgeom_pg.h" /* For debugging macros. */
+#include "lwgeom_pg_typmod.h" /* For typmod bit-field accessors. */
+#include "geography.h" /* For utility functions. */
+#include "lwgeom_transform.h" /* for srid_is_latlon */
Datum geography_typmod_in(PG_FUNCTION_ARGS);
Datum geometry_typmod_in(PG_FUNCTION_ARGS);
@@ -462,4 +462,3 @@ Datum postgis_typmod_srid(PG_FUNCTION_ARGS)
PG_RETURN_INT32(0);
PG_RETURN_INT32(TYPMOD_GET_SRID(typmod));
Summary of changes:
NEWS | 2 ++
liblwgeom/cunit/cu_gserialized1.c | 56 --------------------------------
liblwgeom/liblwgeom.h.in | 19 -----------
libpgcommon/Makefile.in | 2 +-
libpgcommon/lwgeom_pg_typmod.h | 50 ++++++++++++++++++++++++++++
postgis/Makefile.in | 1 +
postgis/cunit/cu_tester.c | 68 +++++++++++++++++++++++++++++++++++++--
postgis/gserialized_typmod.c | 9 +++---
8 files changed, 123 insertions(+), 84 deletions(-)
create mode 100644 libpgcommon/lwgeom_pg_typmod.h
hooks/post-receive
