[SCM] PostGIS branch master updated. 3.6.0rc2-648-gc4bae99fc
git at osgeo.org
git at osgeo.org
Sun Jun 21 10:58:35 PDT 2026
the project "PostGIS".
via c4bae99fc25aabfc512dd0c14f1474b66b3e7730 (commit)
from a0b3925cf59cea943ac9bd1d2130692a559ff64f (commit)
revisions in full, below.
commit c4bae99fc25aabfc512dd0c14f1474b66b3e7730
Author: Darafei Praliaskouski <me at komzpa.net>
Date: Sun Jun 21 21:51:30 2026 +0400
Generate pgsql2shp DBF id for geometry-only dumps
When pgsql2shp exports a result with a geometry or geography column but no DBF attributes, add a generated integer GID field and populate it for each output record so the DBF record count remains aligned with the SHP records.
Propagate the generated-field warning to callers and guard dumper state allocation failures in the CLI and GUI paths.
Closes #2623
Closes https://github.com/postgis/postgis/pull/1019
diff --git a/NEWS b/NEWS
index d0f6e212d..7f37d0986 100644
--- a/NEWS
+++ b/NEWS
@@ -87,6 +87,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
(Darafei Praliaskouski)
- #2832, [raster] Avoid padding single-tile raster2pgsql overviews
when padding is not requested (Darafei Praliaskouski)
+ - #2623, Generate a pgsql2shp GID field when exporting geometry-only
+ shapefiles (Darafei Praliaskouski)
- Fix WKB and TWKB parser resource exhaustion on malformed input
- #6083, Pass configured dependency include paths to fuzzer smoke builds
diff --git a/loader/pgsql2shp-cli.c b/loader/pgsql2shp-cli.c
index 21ab0b7b1..4ce700521 100644
--- a/loader/pgsql2shp-cli.c
+++ b/loader/pgsql2shp-cli.c
@@ -178,6 +178,12 @@ main(int argc, char **argv)
state = ShpDumperCreate(config);
+ if (!state)
+ fprintf(stderr, "%s\n", _("Out of memory allocating dumper state"));
+ fflush(stderr);
+ exit(1);
ret = ShpDumperConnectDatabase(state);
if (ret != SHPDUMPEROK)
diff --git a/loader/pgsql2shp-core.c b/loader/pgsql2shp-core.c
index 47d2daf11..14da7a716 100644
--- a/loader/pgsql2shp-core.c
+++ b/loader/pgsql2shp-core.c
@@ -1161,6 +1161,9 @@ ShpDumperCreate(SHPDUMPERCONFIG *config)
/* Create a new state object and assign the config to it */
state = malloc(sizeof(SHPDUMPERSTATE));
+ if (!state)
+ return NULL;
state->config = config;
/* Set any state defaults */
@@ -1179,6 +1182,7 @@ ShpDumperCreate(SHPDUMPERCONFIG *config)
state->pgfieldnames = NULL;
state->pgfieldlens = NULL;
state->pgfieldtypmods = NULL;
+ state->generate_dbf_id = LW_FALSE;
state->message[0] = '\0';
colmap_init(&state->column_map);
@@ -1317,16 +1321,18 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
PGresult *res;
char buf[256];
- int gidfound = 0, i, j, ret, status;
+ int gidfound = 0, i, j, status;
+ int ret = SHPDUMPEROK;
stringbuffer_t sb;
char *quoted = NULL;
/* Open the column map if one was specified */
if (state->config->column_map_filename)
- ret = colmap_read(state->config->column_map_filename,
- &state->column_map, state->message, SHPDUMPERMSGLEN);
- if (!ret) return SHPDUMPERERR;
+ int colmap_ret = colmap_read(
+ state->config->column_map_filename, &state->column_map, state->message, SHPDUMPERMSGLEN);
+ if (!colmap_ret)
+ return SHPDUMPERERR;
/* If a user-defined query has been specified, create and point the state to our new table */
@@ -1787,6 +1793,25 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
+ if (state->geo_col_name && !state->fieldcount)
+ if (DBFAddField(state->dbf, "GID", FTInteger, 11, 0) == -1)
+ snprintf(
+ state->message, SHPDUMPERMSGLEN, _("Error: generated field GID could not be created."));
+ PQclear(res);
+ state->generate_dbf_id = LW_TRUE;
+ snprintf(buf,
+ sizeof(buf),
+ _("Warning: no DBF attributes found, generating a GID field for compatibility.\n"));
+ if (SHPDUMPERMSGLEN > (strlen(state->message) + 1))
+ strncat(state->message, buf, SHPDUMPERMSGLEN - (strlen(state->message) + 1));
+ ret = SHPDUMPERWARN;
/* Now we have generated the field lists, grab some info about the table */
status = getTableInfo(state);
if (status == SHPDUMPERERR)
@@ -1956,7 +1981,7 @@ ShpDumperOpenTable(SHPDUMPERSTATE *state)
/* Generate the fetch query */
state->fetch_query = core_asprintf("FETCH %d FROM cur", state->config->fetchsize);
- return SHPDUMPEROK;
+ return ret;
@@ -2033,6 +2058,19 @@ int ShpLoaderGenerateShapeRow(SHPDUMPERSTATE *state)
+ if (state->generate_dbf_id)
+ if (!DBFWriteIntegerAttribute(state->dbf, state->currow, 0, state->currow + 1))
+ snprintf(state->message,
+ SHPDUMPERMSGLEN,
+ _("Error: generated GID for record %d could not be created"),
+ state->currow);
+ PQclear(state->fetchres);
/* Now process the geo field, if present */
if (state->geo_col_name)
diff --git a/loader/pgsql2shp-core.h b/loader/pgsql2shp-core.h
index 6b26702e3..564836d91 100644
--- a/loader/pgsql2shp-core.h
+++ b/loader/pgsql2shp-core.h
@@ -142,6 +142,9 @@ typedef struct shp_dumper_state
/* Number of non-spatial fields in DBF output file */
int fieldcount;
+ /* Generate a DBF id field when the source has no non-spatial fields */
+ int generate_dbf_id;
/* Number of rows in the database table */
int num_records;
diff --git a/loader/shp2pgsql-gui.c b/loader/shp2pgsql-gui.c
index 51307ccba..37a9a04d0 100644
--- a/loader/shp2pgsql-gui.c
+++ b/loader/shp2pgsql-gui.c
@@ -1864,6 +1864,9 @@ pgui_action_export(GtkWidget *widget, gpointer data)
/* Grab the SHPDUMPERCONFIG for this row */
gtk_tree_model_get(GTK_TREE_MODEL(export_table_list_store), &iter, EXPORT_POINTER_COLUMN, &gptr, -1);
dumper_table_config = (SHPDUMPERCONFIG *)gptr;
+ state = NULL;
+ output_shapefile = NULL;
+ orig_shapefile = dumper_table_config->shp_file;
pgui_logf("\n==============================");
pgui_logf("Exporting with configuration: %s, %s, %s", dumper_table_config->table, dumper_table_config->schema, dumper_table_config->shp_file);
@@ -1881,11 +1884,25 @@ pgui_action_export(GtkWidget *widget, gpointer data)
/* Create the state for each configuration */
state = ShpDumperCreate(dumper_table_config);
+ if (!state)
+ pgui_seterr(_("Out of memory allocating dumper state"));
+ pgui_raise_error_dialogue();
+ break;
state->config->conn = conn;
/* Save the original shapefile name, then create a temporary version containing the full path */
- orig_shapefile = dumper_table_config->shp_file;
output_shapefile = malloc(strlen(folder_path) + strlen(dumper_table_config->shp_file) + 2);
+ if (!output_shapefile)
+ pgui_seterr(_("Out of memory allocating output shapefile path"));
+ ShpDumperDestroy(state);
+ break;
strcpy(output_shapefile, folder_path);
strcat(output_shapefile, G_DIR_SEPARATOR_S);
strcat(output_shapefile, dumper_table_config->shp_file);
@@ -1987,6 +2004,7 @@ export_cleanup:
/* Reset shapefile back to original form (without full path) */
dumper_table_config->shp_file = orig_shapefile;
+ free(output_shapefile);
/* Get next entry */
is_valid = gtk_tree_model_iter_next(GTK_TREE_MODEL(export_table_list_store), &iter);
diff --git a/regress/dumper/null3d_expected.dbf b/regress/dumper/null3d_expected.dbf
index 3db507ed5..8c1feb282 100644
Binary files a/regress/dumper/null3d_expected.dbf and b/regress/dumper/null3d_expected.dbf differ
Summary of changes:
NEWS | 2 ++
loader/pgsql2shp-cli.c | 6 +++++
loader/pgsql2shp-core.c | 48 +++++++++++++++++++++++++++++++++----
loader/pgsql2shp-core.h | 3 +++
loader/shp2pgsql-gui.c | 20 +++++++++++++++-
regress/dumper/null3d_expected.dbf | Bin 33 -> 89 bytes
6 files changed, 73 insertions(+), 6 deletions(-)
hooks/post-receive
