[PostGIS] #2623: pgsql2shp creates a dbf with 0 records when the table only has a geometry column
PostGIS trac at osgeo.org
Sun Jun 21 10:58:37 PDT 2026
column
  Reporter:  winkey               |      Owner:  robe
      Type:  defect               |     Status:  closed
  Priority:  medium               |  Milestone:  PostGIS Fund Me
 Component:  utils/loader-dumper  |    Version:  2.0.x
Resolution:  fixed                |   Keywords:
Changes (by Darafei Praliaskouski <me@…>):
 * resolution:   => fixed
 * status:  new => closed
Comment:
 In [changeset:"c4bae99fc25aabfc512dd0c14f1474b66b3e7730/git"
 c4bae99f/git]:
 {{{#!CommitTicketReference repository="git"
 revision="c4bae99fc25aabfc512dd0c14f1474b66b3e7730"
 Generate pgsql2shp DBF id for geometry-only dumps
 When pgsql2shp exports a result with a geometry or geography column but no
 DBF attributes, add a generated integer GID field and populate it for each
 output record so the DBF record count remains aligned with the SHP
 records.
 Propagate the generated-field warning to callers and guard dumper state
 allocation failures in the CLI and GUI paths.
 Closes #2623
 Closes https://github.com/postgis/postgis/pull/1019
Ticket URL: <https://trac.osgeo.org/postgis/ticket/2623#comment:10>
