[SCM] PostGIS branch master updated. 3.6.0rc2-653-g633a4c566
Sun Jun 21 13:21:17 PDT 2026
the project "PostGIS".
       via  633a4c5663021efbd2ad8fa11f6a0e93ccda226d (commit)
      from  65f051b339926d22ecfa5c2032d658178bb2a3e3 (commit)
revisions in full, below.
commit 633a4c5663021efbd2ad8fa11f6a0e93ccda226d
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sun Jun 21 03:03:40 2026 +0400
    Use xml2-config for fuzzer libxml links
    Prefer xml2-config for libxml2 linker flags in the standalone fuzzer smoke build while still allowing pkg-config as a fallback. This lets Windows buildbot environments with a private libxml2 installation provide the required library directory for geojson_import_fuzzer.
    Closes #6084
    Closes https://github.com/postgis/postgis/pull/1080
diff --git a/fuzzers/Makefile b/fuzzers/Makefile
index ebe7077e2..675e6176f 100644
--- a/fuzzers/Makefile
+++ b/fuzzers/Makefile
@@ -32,8 +32,10 @@ check:
 	set -- $${cxx}; \
 	if [ "$$#" -eq 0 ] || ! command -v "$$1" >/dev/null 2>&1 || ! "$$@" --version >/dev/null 2>&1; then \
 		echo "C++ compiler '$${cxx}' not available; skipping fuzzer smoke check."; \
-	elif ! command -v pkg-config >/dev/null 2>&1 || ! pkg-config --exists json-c proj libxml-2.0; then \
+	elif ! command -v pkg-config >/dev/null 2>&1 || ! pkg-config --exists json-c proj; then \
 		echo "pkg-config metadata for fuzzer dependencies not found; skipping fuzzer smoke check."; \
+	elif ! command -v xml2-config >/dev/null 2>&1 && ! pkg-config --exists libxml-2.0; then \
+		echo "libxml2 fuzzer dependency helper not found; skipping fuzzer smoke check."; \
 	elif ! command -v geos-config >/dev/null 2>&1 || ! command -v gdal-config >/dev/null 2>&1; then \
 		echo "GEOS/GDAL fuzzer dependency helpers not found; skipping fuzzer smoke check."; \
 	else \
diff --git a/fuzzers/build_google_oss_fuzzers.sh b/fuzzers/build_google_oss_fuzzers.sh
index b4161bd69..30a39a4c7 100755
--- a/fuzzers/build_google_oss_fuzzers.sh
+++ b/fuzzers/build_google_oss_fuzzers.sh
@@ -27,10 +27,15 @@ POSTGIS_BUILD_DIR="${POSTGIS_BUILD_DIR:-$POSTGIS_SOURCE_DIR}"
 FUZZERS_DIR="$POSTGIS_SOURCE_DIR/fuzzers"
 JSON_C_LIBS=$(pkg-config --libs json-c)
 GEOS_LIBS=$(geos-config --clibs)
-PROJ_XML2_LIBS=$(pkg-config --libs proj libxml-2.0)
+PROJ_LIBS=$(pkg-config --libs proj)
+if command -v xml2-config >/dev/null 2>&1; then
+    XML2_LIBS=$(xml2-config --libs)
+else
+    XML2_LIBS=$(pkg-config --libs libxml-2.0)
+fi
 GDAL_CFLAGS=$(gdal-config --cflags)
 GDAL_LIBS=$(gdal-config --libs)
-POSTGIS_FUZZER_LIBS="$JSON_C_LIBS $GEOS_LIBS $PROJ_XML2_LIBS"
+POSTGIS_FUZZER_LIBS="$JSON_C_LIBS $GEOS_LIBS $PROJ_LIBS $XML2_LIBS"
 POSTGIS_PACKAGE_RUNTIME_LIBS="${POSTGIS_PACKAGE_RUNTIME_LIBS:-1}"
 target_local_cflags()
Summary of changes:
 fuzzers/Makefile                    | 4 +++-
 fuzzers/build_google_oss_fuzzers.sh | 9 +++++++--
 2 files changed, 10 insertions(+), 3 deletions(-)
hooks/post-receive
