[SCM] PostGIS branch master updated. 3.6.0rc2-654-g4c65e7d66
Sun Jun 21 13:32:48 PDT 2026
the project "PostGIS".
       via  4c65e7d664d7fb279c90f80674573b940a662dce (commit)
      from  633a4c5663021efbd2ad8fa11f6a0e93ccda226d (commit)
revisions in full, below.
commit 4c65e7d664d7fb279c90f80674573b940a662dce
Author: Darafei Praliaskouski <me at komzpa.net>
Date:   Sat Jun 20 22:16:20 2026 +0400
    Infer geometry_columns constraints for direct views
    Teach geometry_columns to inherit constraint-derived geometry metadata from direct view and materialized-view columns by reading top-level rewrite-rule origin metadata. Keep expression outputs generic unless they carry an explicit typmod cast.
    Parse only the top-level target list so nested subqueries cannot make an expression column inherit base-table constraints.
    Closes #1705
    Closes https://github.com/postgis/postgis/pull/1065
diff --git a/NEWS b/NEWS
index 117a044bc..b3d2d98a0 100644
--- a/NEWS
+++ b/NEWS
@@ -100,6 +100,8 @@ To take advantage of all postgis_sfcgal extension features SFCGAL 2.3+ is needed
           (Darafei Praliaskouski)
  - #3103, Add regression coverage for exact-schema find_srid and
           geometry_columns lookups (Darafei Praliaskouski)
+ - #1705, Infer constraint metadata for direct view and materialized view
+          geometry columns (Darafei Praliaskouski)
  - #6038, Avoid stale relation lookups in geometry_columns after topology
           objects are dropped (Darafei Praliaskouski)
  - #5655, [doc] Skip XML validation during `make check` when xsltproc is
diff --git a/doc/using_postgis_dataman.xml b/doc/using_postgis_dataman.xml
index b902f54af..d5b91fc75 100644
--- a/doc/using_postgis_dataman.xml
+++ b/doc/using_postgis_dataman.xml
@@ -1768,9 +1768,10 @@ SELECT populate_geometry_columns('myschema.my_special_pois'::regclass);
 -- set optional use_typmod argument to false
 SELECT populate_geometry_columns('myschema.my_special_pois'::regclass, false); </programlisting>
-<para>Although the old-constraint based method is still supported, a constraint-based geometry column used directly
-in a view, will not register correctly in geometry_columns, as will a typmod one.
-In this example we define a column using typmod and another using constraints.</para>
+<para>Although the old constraint-based method is still supported, direct
+pass-through view columns register correctly in <varname>geometry_columns</varname>
+for both typmod-based and constraint-based source columns. In this example we
+define a column using typmod and another using constraints.</para>
 <programlisting>CREATE TABLE pois_ny(gid SERIAL PRIMARY KEY, poi_name text, cat text, geom geometry(POINT,4326));
 SELECT AddGeometryColumn('pois_ny', 'geom_2160', 2160, 'POINT', 2, false);</programlisting>
 <para>If we run in psql</para>
@@ -1809,20 +1810,21 @@ SELECT *
 SELECT f_table_name, f_geometry_column, srid, type
 	FROM geometry_columns
 	WHERE f_table_name = 'vw_pois_ny_parks';</programlisting>
-<para>The typmod based geom view column registers correctly,
-but the constraint based one does not.</para>
+<para>Both the typmod based geom view column and the direct constraint based
+view column register correctly.</para>
 <screen>   f_table_name   | f_geometry_column | srid |   type
  vw_pois_ny_parks | geom              | 4326 | POINT
- vw_pois_ny_parks | geom_2160         |    0 | GEOMETRY</screen>
+ vw_pois_ny_parks | geom_2160         | 2160 | POINT</screen>
-<para>This may change in future versions of PostGIS, but for now
-to force the constraint-based view column to register correctly, you need to do this:</para>
+<para>If the view applies a spatial function to the geometry, such as
+<function>ST_Transform</function>, you still need to cast the transformed
+column explicitly so the view can expose the correct type and SRID:</para>
 <programlisting>DROP VIEW vw_pois_ny_parks;
 CREATE VIEW vw_pois_ny_parks AS
 SELECT gid, poi_name, cat,
   geom,
-  geom_2160::geometry(POINT,2160) As geom_2160
+  ST_Transform(geom, 2160)::geometry(POINT,2160) As geom_2160
   FROM pois_ny
   WHERE cat = 'park';
diff --git a/postgis/postgis.sql.in b/postgis/postgis.sql.in
index 027170b68..d4025cda8 100644
--- a/postgis/postgis.sql.in
+++ b/postgis/postgis.sql.in
@@ -6575,6 +6575,99 @@ LANGUAGE 'sql' STABLE STRICT PARALLEL SAFE _COST_MEDIUM;
 -- Changed: 2.4.0 List also Parent partitioned tables
 -- Changed: 2.5.2 replace use of pg_constraint.consrc with pg_get_constraintdef, consrc removed pg12
+-- Extract base-column origin metadata only from a view rule's top-level target list.
+-- pg_node_tree text also contains nested Query target lists for subqueries; treating
+-- those as outer view columns would make expression outputs inherit constraints.
+CREATE OR REPLACE FUNCTION _postgis_geometry_columns_view_column_origin(
+    view_rule pg_node_tree,
+    view_attnum smallint)
+RETURNS TABLE(base_relid oid, base_attnum smallint)
+AS $$
+DECLARE
+    rule_text text := view_rule::text;
+    rule_len integer := length(rule_text);
+    i integer := 1;
+    token text := ':targetList (';
+    token_len integer := length(':targetList (');
+    ch text;
+    prev_ch text;
+    in_quote boolean := false;
+    paren_depth integer := 0;
+    brace_depth integer := 0;
+    in_top_targetlist boolean := false;
+    entry_start integer := 0;
+    entry_text text;
+    match text[];
+BEGIN
+    WHILE i <= rule_len LOOP
+        IF NOT in_quote AND NOT in_top_targetlist
+            AND paren_depth = 1
+            AND brace_depth = 1
+            AND substr(rule_text, i, token_len) = token
+        THEN
+            in_top_targetlist := true;
+            paren_depth := paren_depth + 1;
+            i := i + token_len;
+            CONTINUE;
+        END IF;
+        ch := substr(rule_text, i, 1);
+        IF ch = '"' AND prev_ch IS DISTINCT FROM chr(92) THEN
+            in_quote := NOT in_quote;
+        ELSIF NOT in_quote THEN
+            IF in_top_targetlist
+                AND entry_start = 0
+                AND paren_depth = 2
+                AND substr(rule_text, i, 12) = '{TARGETENTRY'
+            THEN
+                entry_start := i;
+            END IF;
+            IF ch = '(' THEN
+            ELSIF ch = ')' THEN
+                paren_depth := paren_depth - 1;
+                IF in_top_targetlist AND paren_depth = 1 THEN
+                    RETURN;
+                END IF;
+            ELSIF ch = '{' THEN
+                brace_depth := brace_depth + 1;
+            ELSIF ch = '}' THEN
+                brace_depth := brace_depth - 1;
+                    AND entry_start > 0
+                THEN
+                    entry_text := substr(rule_text, entry_start, i - entry_start + 1);
+                    entry_start := 0;
+                    match := regexp_match(
+                        entry_text,
+                        $re$^\{TARGETENTRY :expr \{VAR [^}]*\} :resno ([0-9]+) :resname [^:]+ :ressortgroupref [0-9]+ :resorigtbl ([0-9]+) :resorigcol ([0-9]+) :resjunk false\}$re$
+                    IF match IS NOT NULL
+                        AND match[1]::smallint = view_attnum
+                        AND match[2] <> '0'
+                        AND match[3] <> '0'
+                    THEN
+                        base_relid := match[2]::oid;
+                        base_attnum := match[3]::smallint;
+                        RETURN NEXT;
+                        RETURN;
+                    END IF;
+                END IF;
+            END IF;
+        END IF;
+        prev_ch := ch;
+        i := i + 1;
+    END LOOP;
+END
+LANGUAGE 'plpgsql' STABLE STRICT PARALLEL SAFE;
 CREATE OR REPLACE VIEW geometry_columns AS
 WITH constraint_defs AS (
     -- Trim trailing NOT VALID so metadata inference works before constraint validation (#4828).
@@ -6595,6 +6688,17 @@ SELECT current_database()::character varying(256) AS f_table_catalog,
      JOIN pg_attribute a ON a.attrelid = c.oid AND NOT a.attisdropped
      JOIN pg_namespace n ON c.relnamespace = n.oid
      JOIN pg_type t ON a.atttypid = t.oid
+     -- Direct view columns have rewrite-rule target entries with origin metadata.
+     -- Use only top-level bare VAR target entries, so expressions keep needing explicit casts.
+     LEFT JOIN LATERAL (
+           SELECT origin.base_relid,
+                  origin.base_attnum
+             FROM pg_rewrite AS r
+             CROSS JOIN LATERAL _postgis_geometry_columns_view_column_origin(r.ev_action, a.attnum) AS origin
+            WHERE c.relkind = ANY (ARRAY['v'::"char", 'm'::"char"])
+              AND r.ev_class = c.oid
+              AND r.rulename = '_RETURN'
+     ) AS vco ON true
      LEFT JOIN (
            SELECT s.connamespace,
                   s.conrelid,
@@ -6602,7 +6706,7 @@ SELECT current_database()::character varying(256) AS f_table_catalog,
                   (regexp_match(s.consrc, $$geometrytype\(\w+\)\s*=\s*'(\w+)'$$, 'i'))[1]::text AS type
              FROM constraint_defs AS s
             WHERE s.consrc ~* $$geometrytype\(\w+\)\s*=\s*'\w+'$$::text
-     ) st ON st.connamespace = n.oid AND st.conrelid = c.oid AND (a.attnum = ANY (st.conkey))
+     ) st ON st.conrelid = COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) = ANY (st.conkey))
      LEFT JOIN (
                   s.conrelid,
@@ -6610,7 +6714,7 @@ SELECT current_database()::character varying(256) AS f_table_catalog,
                   (regexp_match(s.consrc, $$ndims\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer AS ndims
             WHERE s.consrc ~* $$ndims\(\w+\)\s*=\s*\d+$$::text
-     ) sn ON sn.connamespace = n.oid AND sn.conrelid = c.oid AND (a.attnum = ANY (sn.conkey))
+     ) sn ON sn.conrelid = COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) = ANY (sn.conkey))
      LEFT JOIN (
                   s.conrelid,
@@ -6618,7 +6722,7 @@ SELECT current_database()::character varying(256) AS f_table_catalog,
                   (regexp_match(s.consrc, $$srid\(\w+\)\s*=\s*(\d+)$$, 'i'))[1]::integer As srid
             WHERE s.consrc ~* $$srid\(\w+\)\s*=\s*\d+$$::text
-     ) sr ON sr.connamespace = n.oid AND sr.conrelid = c.oid AND (a.attnum = ANY (sr.conkey))
+     ) sr ON sr.conrelid = COALESCE(vco.base_relid, c.oid) AND (COALESCE(vco.base_attnum, a.attnum) = ANY (sr.conkey))
   WHERE (c.relkind = ANY (ARRAY['r'::"char", 'v'::"char", 'm'::"char", 'f'::"char", 'p'::"char"]))
   AND NOT c.relname = 'raster_columns'::name AND t.typname = 'geometry'::name
   AND NOT pg_is_other_temp_schema(c.relnamespace)
diff --git a/regress/core/tickets.sql b/regress/core/tickets.sql
index b31490528..c8a6e69cb 100644
--- a/regress/core/tickets.sql
+++ b/regress/core/tickets.sql
@@ -1654,6 +1654,49 @@ SELECT f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, t
  ORDER BY f_table_name, f_geometry_column;
 DROP TABLE IF EXISTS test5829, test5978;
+-- #1705, constraint-based geometry metadata for direct view columns
+CREATE TABLE test1705 (
+  gid integer,
+  geom geometry(Point, 4326),
+  geom_2160 geometry);
+ALTER TABLE test1705
+  ADD CONSTRAINT enforce_dims_geom_2160
+  CHECK (st_ndims(geom_2160) = 2);
+  ADD CONSTRAINT enforce_srid_geom_2160
+  CHECK (st_srid(geom_2160) = 2160);
+  ADD CONSTRAINT enforce_geotype_geom_2160
+  CHECK (geometrytype(geom_2160) = 'POINT'::text OR geom_2160 IS NULL);
+CREATE VIEW test1705_view AS
+  SELECT *
+    FROM test1705
+   WHERE gid > 0;
+CREATE VIEW test1705_alias_view AS
+  SELECT geom_2160 AS shape
+    FROM test1705;
+CREATE VIEW test1705_buffer_view AS
+  SELECT ST_Buffer(geom_2160, 1) AS geom_2160
+    FROM test1705;
+CREATE VIEW test1705_nested_buffer_view AS
+    FROM (SELECT geom_2160 FROM test1705) AS nested;
+CREATE VIEW test1705_scalar_buffer_view AS
+  SELECT ST_Buffer((SELECT geom_2160 FROM test1705 LIMIT 1), 1) AS geom_2160;
+CREATE VIEW test1705_mixed_view AS
+  SELECT ST_Buffer(geom_2160, 1) AS buffered,
+         geom_2160
+    FROM test1705;
+CREATE MATERIALIZED VIEW test1705_matview AS
+  SELECT geom_2160
+    FROM test1705;
+SELECT '#1705', f_table_schema, f_table_name, f_geometry_column, coord_dimension, srid, type
+ FROM geometry_columns WHERE f_table_name IN ('test1705', 'test1705_view', 'test1705_alias_view', 'test1705_buffer_view', 'test1705_nested_buffer_view', 'test1705_scalar_buffer_view', 'test1705_mixed_view', 'test1705_matview')
+ ORDER BY f_table_name, f_geometry_column;
+DROP MATERIALIZED VIEW test1705_matview;
+DROP VIEW test1705_alias_view, test1705_buffer_view, test1705_nested_buffer_view, test1705_scalar_buffer_view, test1705_mixed_view, test1705_view;
+DROP TABLE test1705;
 -- #3103, geometry_columns/find_srid exact-match behavior
 CREATE SCHEMA test3103a;
diff --git a/regress/core/tickets_expected b/regress/core/tickets_expected
index 9e968e2dd..93529c7b5 100644
--- a/regress/core/tickets_expected
+++ b/regress/core/tickets_expected
@@ -499,6 +499,17 @@ public.test5978.geometry SRID:4326 TYPE:POINT DIMS:2
 public|test5829|geom|2|4326|GEOMETRY
 public|test5978|geometry|2|4326|POINT
 public|test5978|shape|2|4326|POINT
+#1705|public|test1705|geom|2|4326|POINT
+#1705|public|test1705|geom_2160|2|2160|POINT
+#1705|public|test1705_alias_view|shape|2|2160|POINT
+#1705|public|test1705_buffer_view|geom_2160|2|0|GEOMETRY
+#1705|public|test1705_matview|geom_2160|2|2160|POINT
+#1705|public|test1705_mixed_view|buffered|2|0|GEOMETRY
+#1705|public|test1705_mixed_view|geom_2160|2|2160|POINT
+#1705|public|test1705_nested_buffer_view|geom_2160|2|0|GEOMETRY
+#1705|public|test1705_scalar_buffer_view|geom_2160|2|0|GEOMETRY
+#1705|public|test1705_view|geom|2|4326|POINT
+#1705|public|test1705_view|geom_2160|2|2160|POINT
 #3103.1|4326
 #3103.2|3857
 #3103.3|test3103b|3857
Summary of changes:
 NEWS                          |   2 +
 doc/using_postgis_dataman.xml |  20 ++++----
 postgis/postgis.sql.in        | 110 ++++++++++++++++++++++++++++++++++++++++--
 regress/core/tickets.sql      |  43 +++++++++++++++++
 regress/core/tickets_expected |  11 +++++
 5 files changed, 174 insertions(+), 12 deletions(-)
hooks/post-receive
